Previous in Forum: Blue Screen   Next in Forum: I Need To Convert Some Documents To .pdf Files.
28 comments
XP Pro Suddenly SLOW!
12/15/2013 9:09 AM
OK, my wifes computer a Dell that is 10 years old or so. Has just turned into a turtle, no take that back a snail. A turtle is too fast.
Once it is booted up, to do anything is an ordeal. Takes forever.
like to start any program. the sometimes typical path is like this.
Click on Start, window pops up OK about 5 seconds
Mouseover the thing that brings up the list of programs, and start waiting, about 2 or 3 minutes later the list appears.
Mouseover the desired one hopefully it is already visible and do not need to scroll to get to it. Mouse over it and wait again for 2 or 3 minutes for it to get highlighted then do the clicky to activate it. If you have to scroll, forget it, it's not gonna happen.
Now wait,,,
and wait,,
and wait,,,
finally somewhere between 5 and ten minutes it starts, Not running yet mind you but looks like your clicking actually did something because the programs loading start screen finally appeared.
and finally maybe ten minutes later it's able to run. But of course running is actually not practical. Like she uses thunderbird for e mail. and it say takes this long to just to get it to go.
Havent even tried to download mail from the server with it.
Just deleting one single message takes about 2 minutes.
A small green window appeared in the tray at the bottom, ya know where the sound control speaker is, and a mouseover of it says processor is running at 100%
I went to look in task manager to see what is running, yeah right
Got it started, and the window finally appeared about 5 minutes later, BUT..... it never got populated, it remained for 30 minutes an empty window.
So suggestions anyone what I should look for?
Joe
Good Answers: 21
Re: XP Pro Suddenly SLOW!
12/15/2013 9:15 AM
How much ram do you have?, upgrade ram or buy new computer! As cheap computers have become, that would be better course to take.
12/15/2013 9:28 AM
It is maxed out on Ram, (Do not remember how much off hand tho. but do remember it is maxed out) In addition, why would it be slow after ten years of flawless service suddenly? Ya know?
Joe
Good Answers: 141
12/15/2013 12:41 PM
Under "properties" you can see what your computer works with. I have a old dell computer too and with XP I could only have 1 Gb ram. XP is running towards it end and has plenty of updates, that make your system slow down.
That same dell now can run with 4 Gb once you install e.g windows 7 32 bits version.
($46 to $72 christmas gift to your wife?)
Windows 7 probably will see only 3.5, but it works. If you want more (up to 16 Gb) you can install windows 7 64 bit version.
Right now, I would run Emsisoft for malware, and CCleaner, bot have free versions.
You will see considerable changes.
Also, switch only the programs on that you use. Skype and others deplete your needed ram.
Plenty of room here
12/15/2013 9:29 AM
I had a ram chip go bad a couple of years ago, and all kinds of bad things started happening...including extremely slow running.
There was no way for me to figure it out at home. I had to take it to the Geek Squad. My computer was showing that ram was good.
If your wife just uses this as a basic computer, I got to poking around on the internet and found a Sears site that sells refurbs cheap...Kmart too.
http://www.kmart.com/computers-desktops-all-desktops/b-1231504201?keywordSearch=false&keyword=refurbished
12/15/2013 9:50 AM
@10 years I'd say you got your nickles worth time to shop sales run C cleaner 1st
12/15/2013 9:57 AM
It sounds like you have application program running in the background.....This could be a virus or maintenance procedure or possibly a software conflict.....So first I would run a virus scan, then check for maintenance programs that may be running, then run a complete maintenance with registry update...This should resolve the issue if it is software related.....
12/15/2013 10:01 AM
Don't know if this will help or not. Like a racer told me once, I just drive 'em, I don't work on "em.
Glacial PC
Good advice here, but I never got mine to speed up.
Good luck!
Additional Info:
12/15/2013 10:37 AM
Additional Info:
When I start it up in "Safe Mode" operations are quick.
Joe
Re: Additional Info:
12/15/2013 10:47 AM
fast when in safe mode suggests a corrupt driver or DLL.
Some times the best solution is to reinstall XP. Do not make a full complete reinstall then XP will reload all drivers and DLLs from disc. Be prepared to go through 150 updates and you should be faster and close to where you were last week.
The reload as opposed to the reinstall should leave all your data intact but remember the old saw BACKUP.
You MAY have to reinstall devices not in the XP driver list; stuff that came out fairly recently. ALSO reinstall a fresh version of your antivirus.
12/15/2013 11:07 AM
I had the same problem with my 10 year old Dell about a year ago. I found that my 70 gig hard drive was down to 2 gig of free space. And there were other issues. So my advice is:
Move as many personal files as you can to thumb drives. This would include pictures, videos, music, etc. Once you move them to thumb drives, be sure to delete them from the hard drive to free up space. And make sure to empty the Recycle Bin, once you've deleted them.
Check to see how much free space is on your hard disk. After 10 years it may be loaded with junk internet 'temporary' files that hog the space and slow down disk access. I found 45 gig of junk internet files; it took me 2 days to delete them and 3 more days to de-frag the hard drive and get everything running smoothly again.
Run Microsoft Security Essentials (free down load) which is a good anti-virus / anti-malware program.
Run Advanced System Care to find any malware that Microsoft Security Essentials missed and to clean up the PC's registry, to optimize your internet access, to clean up and de-frag your hard drive, etc. There is a free and a Pro version of Advanced System Care; the pro version cost $20/year (I think) and is worth the money, imho.
Run http://www.speedtest.net/ to make sure your internet connection is fast enough to meet your requirements.
12/15/2013 11:16 AM
This computer has a facility to delete unwanted files. One simply clicks on "properties", then a right-click brings it up.
Just dumped 243MB of, well, crilge, basically.
Norton (usual disclaimer) also has a facility to do this under "tune-up". It found 1.2GB. All gone!
Good Answers: 119
12/15/2013 12:20 PM
Just repaired a friends e-machine with exactly the same issues. AMD, 1GB, XP-sp3, ~8 years old, and Windoze started to C R A W L!
Used a Linux Live OS CD to boot and diagnose. All seemed good until I requested a hard drive S.M.A.R.T. report. Hard drive had dozens of bad sectors. Some of those were causing Windoze to go slow or crash. New hard drive, OS reload, ALL GOOD!
Fixed It!
12/15/2013 12:30 PM
I have no Idea why, but I fixed it.
This is what happened. The computer has been slower than mine. that I am using right now. They are twins exactly same bought at the same time.
But her's was slightly slower than mine. So she did some scans,
AVG
spybot, avg tune up etc. and all found nothing,
so I have also all those and one more. called Malware-bytes.
been using it for geez ten years? anyway a LONG time and it always finds stuff the others mentioned do not find. So I suggested to her to try it. hey it's free,
she did, and thats when it went deadlike. it found like 380 things,, wow.
anyway I uninstalled it just now and she is back to working,, soo odd that that happened.
Joe
Re: Fixed It!
12/15/2013 4:04 PM
It probably was a software conflict between spybot and malware-bytes or any other two anti-virus programs, they keep trying to disable each other and it takes up nearly all the resources....thus slowing everything else to a crawl....
Re: Fixed It!
12/16/2013 8:42 AM
This happens with my mothers laptop with XP-Pro regularly. I usually fix it by running a malware-bytes full system scan. Then I search through the installed software and browser add-ons and processes for anything that looks suspicious. I do research on my computer to see if they are legit and get rid of any that are not. Some require a bit of effort but the Malware-bytes website is pretty helpful.
Usually she has some malicious SW that loaded itself (she says) that is running some process continually. I do not let her keep multiple anti-virus running concurrently, but the McAfee she gets for free from the ISP is not adequate.
Good Answers: 918
12/15/2013 10:47 PM
Conspiracy Theory:
The last Microsoft XP update makes it run slower, and then slower, and slower...
Good Answers: 15
12/16/2013 10:42 AM
That's a well-documented feature of XP. Or any other Microsoft OS.
Ignorance is no sin. Willful ignorance is unforgiveable.
12/16/2013 1:02 PM
How do we recognize the last update? How do we remove it?
Lehman57
Good Answers: 918
12/16/2013 4:33 PM
That's the rub. They did not come in order.
12/17/2013 11:49 AM
It was the first installation of XP that made the computer slow...
...just sayin'
common knowledge...less common than common sense
12/16/2013 2:11 AM
to faster the Windows XP Pro, please follow the steps below;
  1. Try the Disc Cleanup and check the necessary check boxes.
  2. Open the tab"more options" and go to system restore cleanup, this should faster your system than before.
  3. You should download a program called CCleaner its free and clean your registry, this will faster your system too.
http://www.piriform.com/ccleaner/update?v=4.07.4369&l=1033&o=5.1W3
12/16/2013 7:07 AM
Lots of good advice here, but resist renewing XP as there may be problems in obtaining all the needed updates from Micro-Soft. Though I believe that there are other places where they can be obtained.
What I would do is the following:-
1) Defrag the disk (I use the free version of "Wise 365" and defrag and optimize, it will take a long time)
2) Let Wise 365 run its memory utility optimisation all the time.
3) Download MEMTEST86 for either a bootable CD or USB Stick (if your PC can boot from a stick! Some cannot!). Run MEMTEST86 and see if a) Your memory is as large as it should be and b) Any errors?
4) Let Windows CheckDisk have a good look at the disk and correct any errors
5) Is the disk full, clone it to a newer bigger one, that will be faster anyway than the old one. Is the old one NTFS? If yes = Good. A new disk should have an NTFS format at all costs...
Not necessarily in that order.
In fact I would probably take the disk out of the PC, connect it to a "good" PC via a USB interface and do the Defrag from the better PC...let MEMTEST boot and run while no hard disk is installed....in parallel.
Do not do a reinstall of XP if at all possible.....better to buy a new PC, then save all your data to it, before losing it all with an install.....Then re-install the XP.
All software I mentioned except XP is free to download and use.
12/16/2013 8:56 AM
Check windows task manager, in processes/svchost.exe.
If it is reading 100% cpu there are some pointers to correct this problem.
http://www.wikihow.com/Solve-the-Svchost.Exe-100%25-CPU-Utilization-Problem
http://www.technibble.com/how-to-fix-svchost-using-100-cpu-memory-leak/
difficulty is getting there with everything running so slow.
12/16/2013 9:55 AM
I give mine, also XP, a cleanup once a month--call it an enema. This includes: remove old files (I use 1 year for letters and such), virus updates & scans, defrag, disc cleanup, CCleaner, Malwarebytes, etc. Remove temp files and cookies. I have a list (recipe) if you want it. My hard drive is around 50% full; try to have as much RAM as your computer will handle (I think it's 3 GB for XP.)
For virus scanners, AVG has a free one (and paid too if you want it.) Don't have 2 virus scanners active at the same time, but Malwarebytes does seem to get along with another one. Avoid McAfee and Norton as I have not heard good about them. I have also heard that Microsoft Security Essentials is not so good anymore.
Do you have a computer support group near you? If so, I suggest you join. You can check for a local group on the national group I think--APCUG. One guy in my local group suggests that you turn off all the things in the startup menu (what shows in the tray) EXCEPT the virus scanner. (Start > run > msconfig > startup tab.)
I turn my computer totally off every night, but you might want to leave it running for the first defrag after you remove a bunch of stuff.
You can't hurry its startup. I get things turned on and started, then it seems best to go away for at least 10 minutes before trying to do anything.
Lehman57
12/16/2013 10:44 AM
Cnet and get the periform tools . install turn off your page-file sys and run Reg cleanser you will probably have lots and lots of sys restore points to delete The clue is in the time to delete a file it has to sort that back to when it was created.
Then do a de-frag a long one not a short one. turn your Page-file sys back on
you should notice the improvement
s
Torque is not cheap
Good Answers: 25
12/16/2013 1:28 PM
There is a very craftily hidden virus which even the normal anti-malware can miss.
(avg and many others failed to notice it, on my pc.)
It affects a file which propagates slowly little viruses throughout your system, making
it go progressively slower until it's too late, the pc is in a mess. (been there done this)
It is so insidious that malware (http://www.malwarebytes.org/) have brought out a
beta file called mbar. I have tried this, and think it works ok, but being beta it can
mess up your monitor driver, so your view is affected. (another pain, but correctable.)
I believe, but I'm not certain of this, the virus is in an "update your drivers" download.
What I do know is whoever writes these bugs should be hung by their "lower parts" for
about 12 months (or maybe a lot longer than it takes us to remove them?) for the hassle?
jt.
Hope this helps.
It is said..."There's nothing wrong with them that reincarnation won't cure."
Jack E. Leonard
Good Answers: 15
12/17/2013 10:07 AM
Good Answers: 918
12/17/2013 10:44 AM
BandAid, upon BandAid, upon BandAid...
Register to Reply 28 comments
Andy Germany (1); Anonymous Hero (3); dvmdsc (1); fixitorelse (1); Fredski (1); garth (1); JRiversW (1); jt (1); kramarat (1); Lehman57 (2); LongintheTooth (1); lyn (1); Lynn.Wallace (2); merc600sec (1); mjb1962853 (1); Mr Hyd (1); NSS (3); PWSlack (1); SolarEagle (2); The.Tinkerer (1); Usbport (1)
