Previous in Forum: Single Pump or 2 Pumps Running with VSD?   Next in Forum: "5IK40GN-A" Oriental Motor Induction Motor: Wiring Diagram
Stability Room Design
12/22/2013 3:10 AM
If any could help about the the arrangement of heater, humidifier and volume damper at the end of supply duct.
Is there any standard arrangement of these three equipment at the end of supply duct or no matter if they put randomly.
else, if any would gratefully send useful links about room design.
Re: Stability room design
12/22/2013 10:07 AM
12/22/2013 10:21 AM
Thank you very much
Re: Stability Room Design
12/22/2013 8:42 PM
putting the heater upstream of the humidifier isn't desirable
Good Answers: 203
12/22/2013 11:00 PM
Fredski-
Correct me if I'm not correct. Aren't humidifiers put downstream of the heaters (heater upstream of the humidifier)? The air goes through the heater and then the humidifier. The heater heating the air reduces the relative humidity and the humidifier raises it back up somewhat.
A simple example would be a residential forced air furnace. The return air is heated and then goes through/adjacent to the humidifier. From there it goes through the distribution air ducts to the room registers.
Perhaps a typo error? I have them too.
Good Luck, Old Salt
12/23/2013 8:01 AM
you most certainly have it correct
12/23/2013 3:35 AM
At the end of supply duct???. Please check it. Generally Air Handling unit is the device which is used to condition the air based on heat load calculations and Psychrometry analysis.
Register to Reply 6 comments
abueed (1); Fredski (2); lyn (1); mrswamy (1); old salt (1)
