Previous in Forum: Acoustic Engineering   Next in Forum: Ground Mount Solar Array
Building a New House and Very Nervous, Also Using a New Builder in Town
12/30/2013 10:14 PM
Hey guys I am a long time lurker but new poster here on this forum.
I just started my process of building a house and I am nervous and excited at this whole ordeal. I am using a new builder which is a friend of a friend. He is a realtor but just started his own construction company.
I was very nervous on the foundation part because I know this is the key part of the build so I wanted to know what you guys know about this. Anything that can help me would be great from PSI of the concrete to what questions I need to ask the engineer's and home builders.
Thanks in advance!
Re: Building a New House and Very Nervous, Also Using a New Builder in Town
12/30/2013 10:32 PM
Welcome.
If you've been lurking, you should know that the more information you supply, the better answers you will get.
So far you have only, nothing.
Location, house design, size, type of foundation proposed, basement, something to go on, please.
Pretend you're writing a proposal for the house to someone who doesn't know you, or where the house will be built.
12/30/2013 11:30 PM
Ah yes I knew I forgot most of the info, and I apologize.
This will be my first build/first home. The house size is going to be 2500 sqft, one story with a bonus upstairs. I do not have any foundation proposed, and no basement.
If any other info is needed I will supply, even house plans.
12/31/2013 12:15 AM
It's hard to speculate on the foundation without knowing where you are. SOIL type and ENVIRONMENT are very important. Does it freeze there? Is it desert? Does it rain?
We also don't play 20 questions very well.
Like I said tell us a story, do a narrative, give us some details that we can't know if you don't provide them.
Good luck. Maybe someone can help you.
Good Answers: 70
12/30/2013 10:56 PM
You say you was very nervous about the foundation? Is that because it's already poured? If your foundation is already poured, it maybe a little late to be worried about the psi of the concrete.
12/30/2013 11:31 PM
Hey DJ,
No I have just started the paperwork to get the house building going. I will be buying the lot this Wednesday.
Good Answers: 11
01/01/2014 11:15 AM
What does "I have just started the paperwork" mean? Typically, a builder has a contract which outlines what his payment schedule will be, includes plans, etc. They give it to you and want you to sign it. It is ALWAYS written in favor of the builder, and should NEVER be signed until you take it to an attorney who specializes in this area and will amend it for your protection. A contract is an agreement between TWO parties - always remember that. I will reiterate what I said earlier - if you haven't signed the contract, run now. If you already have, hire an architect or civil engineer to oversee. Don't try to come into a forum and randomly ask for advice. The architect or civil engineer will KNOW WHAT QUESTIONS NEED TO BE ASKED and what the correct answers to those questions are and can prevent costly mistakes or attempts to cheat you. It is always best to AVOID MISTAKES AND DISAGREEMENTS BEFORE THEY HAPPEN because even with a contract, you will spend years and thousands of dollars pursuing an incompetent or dishonest contractor in court with little recourse if he has no assets to garnish or simply chooses not to pay a judgement (selecting an insured contractor helps, but the insurance company is insuring the contractor, not you). BTW, a licensed, experienced architect is more than qualified to oversee a residential home building project - this isn't a skyscraper.
12/31/2013 12:19 AM
With luck, maybe Capt Moosie will awake from his dogmatic slumbers....
12/31/2013 9:43 AM
Moosie is a slacker he doesn't even wake up until you slap a slump test result report on his desk
12/31/2013 3:47 AM
Employ on recommendation (and ideally viewing of previous work) not friendship.
"He is a realtor but just started his own construction company".
If the above statement doesn't set warning bells ringing I suggest you need to see a squirrel who has just set up as a psychiatrist
12/31/2013 5:07 AM
That's what I was going to say. Things like this are what ends friendships.
Having a home built, is far too important to risk getting stuck with an albatross.
I'd hire someone with a solid reputation as a builder, along with his knowledge. There are too many things that must be known, for the homeowner to be able to go behind and check...which they shouldn't have to do.
Edit: Also, a "new" home builder won't have established any relationships with the other trades that will be working on the home, so everything from the bottom up will be a crapshoot. An established guy will have people that he already knows and trusts.
12/31/2013 9:45 AM
I tend to agree, if he's an actual friend have him join the project when its time to paint the interior and share some beer and pizza
01/01/2014 4:31 AM
That is just so base over apex ! I always recommend the 'four walls and a roof' start. Everything else sort of follows on. Worry about the foundations later . I'm much in favour of the 'try-fail-learn' iterative method, though it depend upon who's money I'm spending
01/01/2014 5:12 AM
The quicker alternative is to dig a hole and pour in wheelbarrow loads of money.
01/01/2014 5:34 AM
It's so true !
12/31/2013 9:35 AM
basically the strength of your concrete selection has everything to do with what you expect the concrete to deal with, it really doesn't make sense to go with 5000 PSI when 3500 is plenty, as noted your soil and drainage have to be accounted for before you make your initial pour, why don't we start there?please tell me you haven't poured any footings yet!
12/31/2013 10:04 AM
Sounds to me like you are nervous because you are getting a poor feeling of confidence in your prospective contractor.
Is this the only contractor you have approached; based on a recommendation of a friend, based on "who can do it for cheap" or "who needs to drum up business"? Are you doing a friend of a friend a favor or what reason do you have for not using experienced local contractors ?
If you are having doubts / anxiety then you should be prepared to learn very quickly to become a building inspector and approve any work done. If you cannot do that then you are at the mercy of people who say "trust me".
My best advice is to approach at least one other builder / contractor and compare your feelings between them. This realtor may actually be no more than a guy who hires other contractors, so there is another layer between you and the people who are supposed to know what to do and then do it right. What does the realtor - come builder know of the codes and practices in your area? Is he capable of inspection to standards or is he just saying "trust me".
I would be nervous too.
12/31/2013 12:42 PM
At least get several bids, with references.
The realtor might be the guy, but he's going to have to prove it.
12/31/2013 12:54 PM
You are aware of what a contractor is? Its just a con with a tractor doing work for you.
Do what I am doing with my new house. Find all the relevant code info you can and do some reading.
If everything appears to meets or exceed the coded definitions that odds are you will be fine.
As far as ensuring your concrete quality thats easy. Just make sure you tell the mix plant you are getting it from what you need it for and make sure you get the batch paperwork from each truck driver before he unloads it. If the paperwork does not match your specs send him home!
12/31/2013 1:11 PM
Good idea, but isn't that what we have overpaid inspectors for?
Just kidding.
12/31/2013 3:12 PM
Heavens. Most contractors are too important to be bothered with such trivial footwork as checking codes or meeting specs.
They don't need no stinking code book. They are licenced.
Good Answers: 140
12/31/2013 1:49 PM
Make sure to... GET IT IN WRITING.
Your's would not be the first friendship to go down the crapper because of unkept promises. If your friend balks at putting any aspect of this project on signed paper... you need a new contractor or friend.
Good Answers: 70
12/31/2013 1:51 PM
You may want to go to the building department and meet the field inspectors, they may be your best asset to cover your a$$, or your worst enemy if your realtor/contractor doesn't know his codes.
12/31/2013 1:53 PM
Well I'll tell you how I would do it.....First, visit as many new home construction sites in your area that are in the same price and size and type category as the house you intend to build......compare the quality of the builds, talk to the workers....check with the buyers after they move in the new houses, and ask their opinion of the quality and service they received....settle on one builder and check out older houses they have built and talk with the owners about any issues they encountered and how they were dealt with....contact the builder and start negotiations, get a price.....wait for a slow period when the builder is needing work....renegotiate deal, get best price and proceed.....
In your research you are likely to gather a lot of interesting info that will assist you with typical problems that may occur, and how others have dealt with them....I would never go with a novice, this could end in disaster, with the builder going out of business and you left holding the bag......Never do business with friends unless you are willing to forgive them anything, and I mean anything.....
12/31/2013 2:27 PM
Damn! I just lost another response due to this shitty system.
Good Answers: 151
12/31/2013 2:46 PM
Same happened to me in another post. The Select, copy, start a new reply and paste method worked for me.
12/31/2013 3:11 PM
If you remember to do that. But, why do we have to?
Good Answers: 70
12/31/2013 5:12 PM
Where's Edward Snowden when you need him? I bet the CIA and NSA is censoring your posts
12/31/2013 5:20 PM
This is a system defect. Didn't used to have this problem.
12/31/2013 6:28 PM
Could be worse. All of my posts are being screened at another web site and I didn't even provoke anyone to get it that way.
Well I did after the fact but I did not fire the first shot for once.
12/31/2013 6:01 PM
welcome to the "waste my time club"
Good Answers: 141
12/31/2013 9:28 PM
Lyn,
It happens to me all the time because I am a slow redactor. Most of the time I get the message -could not process.......-
I go back in the browser, copy and paste the text, go further back and throw it in again.
And I am OK.
Plenty of room here
Good Answers: 70
12/31/2013 10:00 PM
Don't feel alone, it's been happening to me too! And I also use the copy & paste along with the back button. It seems like it's something that started recently or has gotten worst recently. NAS maybe??
Good Answers: 141
12/31/2013 10:37 PM
We are becoming too slow, blind and deaf to not see the world turning .......? It is build into our system to remain with our wife. (sorry I have no mirrors)
Plenty of room here
12/31/2013 10:08 PM
Thanks, I'll try that. What's to lose?
Usually my economy with words allows me to post under the insane time limit.
Happy New Year.
Good Answers: 11
12/31/2013 10:43 PM
This reminds me of the old t.v. commercial: "Today, we do winnndows". On what planet does being a realtor qualify one to become a general contractor??? My advice to you is to run like the wind if you can get out of this. Your home is your largest investment and you have entrusted your life's savings (or future indebtedness) to someone who's educational background is a month long realtor's training class (or business/finance degree)? If it's too late and you've already signed up, then hire an architect or civil engineer to review the realtor-now-contractor's project management schedule and specs and stick to him like flies on fly paper throughout the building process. You obviously don't know what to ask, so you need someone to look out for your best interests who actually does. I know you didn't budget for this, but one major mistake and you'll wish you'd done it! Best of luck to you.
Good Answers: 39
12/31/2013 10:52 PM
You have barely started the process of overseeing your home construction. If you want good advice, give good information. If you want hostility from the forum and from your "builder friend of a friend", keep playing games and withholding information. You haven't a clue so far, nor do we. Good recipe for disaster. Building a home is a technical problem, not a game of high school favors.
Align culture with nature...
01/01/2014 2:02 AM
Well Said.
DHAYANANDHAN.S
01/01/2014 7:44 AM
I dont see a problem.......yet
12/31/2013 11:18 PM
Will it be a slab foundation? Or pier and beam? Slabs are pretty simple. But make sure that all the plumbing is in place before the slab is poured, and the sewer lines have the right slope (down from house to street). I mention this because our builder, a big one, had to jackhammer the slab and redo the sewer lines. Slabs are usually "prestressed" or "poststressed", where they thread steel cables horizontally from side to side to strengthen the slab.
Make sure that the city inspectors do their job and try to be there when they come; don't trust the builder to fix problems.
Take lotsa notes and pictures, you may need them later in court Hope not.
01/01/2014 9:36 AM
BS! your comment that slabs are "usually" prestressed is complete bunk
Good Answers: 179
01/01/2014 9:48 AM
Agree 150%...BUNK!!!!!
01/01/2014 10:28 AM
Christ...... You must have time, what don't you just do it yourself...... Your doing it anyways.
It may not be right, but it'll save you in attorney fees.
Good Answers: 16
12/31/2013 11:24 PM
For your fiends first construction project you are going to finance the high price of his education. At a minimum I would insist on him obtaining the assistance of an area builder-consulting network.
Here in south Texas there are two good companies. Check to see if there are similar companies in your area:
http://builtgreencustomhomes.com/
http://www.ownerbuildernetwork.com/
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
12/31/2013 11:57 PM
First,make certain the contractor has insurance.Not just liability and workman's comp for his employees, but performance bond insurance.This way ,he has to pay if he screws up the job.
Make sure he is a licensed general contractor for the type and scope of job he is doing, and make sure all craftsmen he hires are also licensed, bonded, and insured, to do their jobs, such as electrical, plumbing, heat and air, etc.
Make sure any changes to the original drawings are accompanied by a change order,and signed by you and the inspector,if it is a structural change.
Exterminators in my state are required to put a decal inside of the electrical panel containing the company name,license number, and date of treatment.I have seen people charged for pre treatment and it was never done.The electrical contractor is also required to put in a similar decal with their info on it.
Get a commitment for the job to be completed in XXX number of fair-weather days,and attach a significant penalty for every day it is not completed on time.Without this "time to completion" clause, the job can drag on forever.If he will not sign the contract,he is not a real professional,find someone that will.Shop around.There are plenty of good professional contractors available with the housing market in a slump.
Make sure he pulls a permit from the local authority.It should be posted in plain site at the job site.
Make sure the land will perk if you will have a septic tank installed.
If material is delivered to your site,(especially bricks, blocks, etc.) do not allow it to be removed.Some contractors will knowingly order extra for a job and divert the surplus to a pet home project (beach house, etc.). Threaten to report the material as stolen if he removes it.
Do not pay the final 1/3 of his payment until ALL of the items on your checklist are finished.Promises do not mean anything unless in writing and signed with a witness.Same for the other contracts I spoke of.
You must separate friendship and business .You can be friendly,but you must be all business and dilligent when it comes to the work performance.
I know this will take a lot of extra time and trouble, but you will move in with a smile on your face and sleep well at night with a job well done.It is well worth the extra effort.You will have to look at mistakes for the rest of your life,unless you build again.Good luck
01/01/2014 1:55 AM
Discuss your requirements with a green home designer & ask for drawing,specifications & cost estimate. If you are rich enough contact 3 different parties & select the best.
pnaban
01/01/2014 2:00 AM
" He is a realtor that just started his own construction company". Considering this is a major investment for you, I would advise you not to let your project be his learning curve. Get answers to your questions from him. If he stumbles, there is your sign to move along. Don't waste your time here getting insulted and questions answered that will have no accountability with your deliverables. Screw "friendships". Residential construction is the lowest margin of profit to subcontractors. Greedy builders will drop someone they have used regularly over a 50 buck price cut. Been there , done that. QA/QC will be your burden. Is your realtor/builder a self perform contractor or is he just a broker? You need an experienced builder with references and a track record. Your friend will get over it as he looks for his next project. Down the road, when/if you build again perhaps he will have gained the reputation as the best in town. Realtor to contractor....that's like car salesman to mechanic.....good luck and Happy New Year.
01/01/2014 4:00 AM
I'm an architect in South Africa and agree with 90% of the posts. However one point I must stress is that strength of concrete foundations and slab have very little significance if soil conditions are not precisely known. Depth of founding is critical. Is there no such animal as a structural engineer around? I wouldn't dream of starting even the simplest house without paying an engineer to do a basic soils analysis. He will also give all relevant conc. specs.
A realtor/new builder?........... No thanks!!!
01/01/2014 10:38 AM
Quite the hypocrite aren't you?
First, you say, " Don't waste your time here getting insulted and questions answered that will have no accountability with your deliverables".
Then you turn right around and offer your own somewhat arrogant advice!
Why should he waste his time here listening to you?
Just sayin'.
Good Answers: 117
#99
01/04/2014 8:38 PM
He was not arrogant. Realistic maybe...
01/01/2014 5:57 AM
Who will be doing the drawings?
Employ an architect who should produce the drawings and all relevant specifications for foundations, drainage and so on. The responsibility then depends on the architect's specification.
Tony Aston
01/01/2014 6:05 AM
Drawings? You mean it has to have drawings
Reminds me of ages ago where my Brother worked the were building a huge road interchange. He said to one of the workmen how it was amazing how it was all coordinated and the construction all came together.
The Irish labourer replied.
"Ah sure, they work it all out on paper first!"
Good Answers: 179
01/01/2014 8:57 AM
I looks like I came to the ball game late w/o a glove. Can I play? Pretty much everyone has thrown their weight into answering the posed question, so I can't add much more to the discussion.
A realtor turned contractor? Look out for a very rough ride if he and his crew have little experience.
Make sure he has construction insurance and liability insurance + performance bond, etc. this was already mentioned above.
No mention what type of foundation wall. Is it reinforced concrete or Concrete Masonry Units (CMU) aka concrete block? It certainly makes a huge difference on lateral wall resistance to the backfilled soil and groundwater.
If it is a concrete wall, make sure it gets reinforcement steel to resist shrinkage cracking as well as lateral soil and groundwater loading. Having an unreinforced wall is inviting disaster immediately, or even in the long term. Foundations settle. Foundation concrete walls can crack. Cracks facilitate groundwater penetration into the basement, and even washout.
Do not use a concrete mix less than a 3,000 psi concrete mix, air-entrained, a maximum Water-to-Cement of 0.44, and a maximum concrete slump of 3-inches. Personally, I actually prefer a 4,000 psi minimum compressive strength. Make sure the contractor obtains the BATCH TICKETS for each truck load of ready mix concrete delivered to the job site. All the weights of the concrete mix will be depicted on those tickets....they are generated by the concrete supplier at the time the truck drum was filled.
WHEN IN DOUBT, HIRE A STRUCTURAL ENGINEER experienced in structural engineering. Do not go on the word of the contractor or another contractor or an Architect, since this is a strictly a structural engineering/construction issue. Remember, it's you money, and lots of it. A huge investment by you that needs to be durable, perform, and have longevity. Hiring a Professional Engineer for a few thousand dollars is CHEAP insurance compared to the entire investment cost of your house. It will give you a piece of mind and reassurance that the work was done in a satisfactory manner.
01/01/2014 9:36 AM
When you start building a house, you must start with a proven engineered plans from certified architect, he should know everything about it.
guds777
01/01/2014 9:52 AM
guds777
01/01/2014 11:42 AM
I cannot understand what do you mean by "proven engineered plans from certified architect"? The decision to employ a structural engineer rests with the client. If a client decides to avoid this step, in my country an architect cannot be held responsible for this short-sighted response by a cash-strapped or stupid client, provided they have been so advised.
In reply to #60
01/01/2014 1:01 PM
Here in Iceland we follow a strict building codes, and nothing is built without a engineered proven drawings. There's a reason why when we get earthquakes and eruptions our houses stands still, but in US everything falls down like cheap cardboard houses.
guds777
In reply to #66
01/01/2014 1:08 PM
stupid statements that are purely anti-American might get laughs in Iceland but collectively we resent your shit
In reply to #67
01/01/2014 1:18 PM
Did i hit a nerve.
guds777
In reply to #67
01/01/2014 2:26 PM
No no... I'm laughing too...
Just tell him his banks collapsed...OMG... nope all our banks collapsed.
You Yanks are a bit touchy about stuff.... I mean it's not even your country
Hey.. let's all be pals and just vent our wrath on the bankers...
C'mon happy new year and all that.
(Just pullin' your chain Fredski... feel free to take the micky out of us stiff old Brits...
Stiff... at my age? I should be so lucky... oh someone please make me stop, I've been at the 2013 cider)
In reply to #73
01/01/2014 2:29 PM
Where's the off button?........
In reply to #73
01/01/2014 2:53 PM
If you're like me, you get stiff in the wrong places.
Now, take another nip o cider, let the soft, fuzziness soak in and take a nap.
There's football on the TV today over here. BORING!!!!!!!!!!!!!!!!!!
In reply to #66
01/01/2014 1:17 PM
Say what you want, when disaster strikes Iceland,.... We'll be there to assist to get you through it............. As usual.
In reply to #68
01/01/2014 1:44 PM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
guds777
In reply to #70
01/01/2014 1:53 PM
My, my! Such arrogance! First pnaban and now you.
Your radical, fanatical rants will make you no friends here.
Suggest you go find another forum to insult. I doubt you'll ever get another civil response here.
In reply to #70
01/01/2014 2:02 PM
Never got the message about the terrorist............... As far as the drones,....... Yes, keep that in mind..........
As far as not helping, I'm for all that....... Problem is, when you need it and we're not there as expected...... We'll catch hell for that too...... So yes whether you like it or not, we'll be there for you.
That post about housing not standing up to an earthquakes......... Takes a lot away from you're credibility as well as intelligence.
PS
That thing about your country being put in a terrorist list........ Must have really hit a nerve on you.... Which explains your responses.........Ah, mate............
In reply to #70
01/01/2014 2:42 PM
I would really like to help you.
How would you like to be a hero in two countries?
You can be,very easily.
By simply moving to Newfoundland, you will increase the national average IQ of both Iceland and Newfoundland.
I am sure you can find enough contributions to send you half way there.You may have to swim the rest of the way.
In reply to #66
01/01/2014 2:28 PM
"There" in Iceland, I can appreciate your confidence in your country's adherence to codes and standards. In our country we do the same thing. However, not every area is subject to equivalent seismic activities. We have different zones as I assume Iceland does from your rambling above. This information correlates to design detail which would impact design in different areas. So Iceland has never had a building fail during extreme seismic activities, quakes, tornado's etc. ? I'll challenge that one. What I can't appreciate is your inability to properly communicate in a forum such as this one and your obvious absence of professionalism. "There" in Iceland this may be considered acceptable and normal. Here in the USA, we view someone like you as empty....the street term would be idiotic. When you come in here show the same respect you wish to receive or go to CL forums where there are tons of empties....another free piece of advise - please use the King's language properly.
Good Answers: 179
01/01/2014 9:50 AM
Ummm Architects don't do engineering plans! Engineers do!
Also, in the USA Archies aren't "certified", they're Licensed and Registered.....
Just saying.....
01/01/2014 9:55 AM
do you have a list of specifications that the house has to meet?
Some of the items to discuss ahead of time would be:
Change orders - cost of adding/subtracting additional items such as tile instead of carpeting, two car garage instead of a carport. 2 zone heating/cooling instead of one zone.
Contract should also include time to complete, and payment information. As one poster mentioned, keep track of extra material that is charged to your project. (and building a house is a project). A lot plan showing all easements and encumbrances on the land is a must for the build and for future reference in case you want to add an outbuilding or have a neighbor who encroaches on your property. (I have to remind the nice lady who abuts my lot that she is planting on my side of the line, otherwise it'll become part of her estate when she leaves).
I would also ask how this real estate broker became a general contractor, hope it wasn't a home study course grad.
01/01/2014 10:26 AM
Since when are you tied to one contractor?
Start getting estimates from two other general contractors......... That what you at least have have is a reference point. But that's doesn't mean your not going to have headaches.
01/01/2014 10:57 AM
He's probably 'become' a builder to help or shore up his poor realtor sales.... :/
01/01/2014 11:23 AM
Since we have no useful information from the OP, it's hard to draw any conclusions at all.
But, since the housing/economic crash, the majority of home builders, developers and the skilled/semi-skilled labor that was used to build residential housing has nearly vanished.
Nobody has been building new houses for years. The labor force has either gotten too old to return, returned to Mexico, sought other types of work to survive or is no longer available for many other reasons.
Same with generals and even materials suppliers. They've disappeared. Or, moved to sourcing their materials from China, or other substandard suppliers.
About the only ones left are the realtors who stayed afloat by dealing in other people's misery and listing the houses and commercial buildings left vacant by the swindlers who started this all. (leave politics aside please)
So, As I said in an earlier "disappeared" post, I'd find an established home builder that was offering a quality product, today, and leave both my, and the realtor turned builder's, learning curves out of my new house.
In reply to #59
01/01/2014 11:43 AM
A little off topic
What I can't understand, in my area, Green Bay, Wi, during the recession, or housing bust, what ever it's called, there were a lot of homes for sale, a little stagnant sales, I'm sure some on contingent on buy a new home contingent on the sale of their home. but building was still going on.
Both private homes, duplexes and apartments. Yet existing apartments were empty. I could not figure that out.
But now, there are a lot of new homes being built and filled
01/01/2014 12:03 PM
Getting mighty particular in your old age, aren't you?
01/01/2014 12:37 PM
Particular??............ Just a second......
(Opens front door, and yells).....
"YOU KIDS, GET OFF MY FRONT LAWM!"
OK, Where was I now? Oh yeah, particular....... No not really....... Peculiar.... Well.....
Good Answers: 16
01/01/2014 12:04 PM
People move to where the jobs are. Many people have no choice but to relocate when there is no local employment. This was my exact scenario in the 90's moving from small-town Wisconsin to Houston.
In reply to #63
01/01/2014 12:32 PM
As far as employment, I have felt that Wisconsin was always average...... That's is until your unemployed..........
01/01/2014 11:16 AM
allow me to congratulate you on your first thread here . good view numbers so far. you can also see why most people that have had a custom home built usually don't ever do it again! so spend a fair amount of time interviewing and checking references before you commit........best of luck and check back with us as your different phases unfold and we'll bury you with ideas and questions that just might help
01/01/2014 3:01 PM
This thread is about Novicebuilder's questions about building a house. Stay on topic.
Also, stop derailing every thread into this NSA tracking garbage.
01/01/2014 3:14 PM
What happened here?
Geez, I take less than 24 hours off, and everything goes to the dogs.
You guys settle down and get your little digs in, over in OT land.
Don't make me repeat myself! Behave.
In reply to #79
01/01/2014 3:30 PM
Man. Even the sense of humor is gone?
01/01/2014 5:36 PM
As with my house project I am far less concerned about what a guys pervious profesion was than what his present quality work says for itself.
I could probably find you guys a hundred people with zero contractors licences that could build you a fine high quality home just as easily as I could find you a hundred licensed goons that are nothing more than hack builders and crooks that have been building stuff for years.
Just because the guys previous job title was real estate sales doesn't mean he never learned to how to run a tape measure or swing a hammer.
In fact I would suspect that as a real estate sales person he is very aware of just how bad some contractors work can be and felt that if those idiots can make money building crap he probably can make more building anything even just slightly better than what he was expected to have to sell in the past.
My point is how many of you had the skills to be an engineer in your present field long before you had the piece of legal paper or title that said you were one?
How many more of you can name people who you work with who have their engineering papers and title that honestly don't belong where they are doing what they do?
So what? The guy was in real estate sales. To me that says the guy was around enough houses to have had to know the good and bad behind house construction to some degree to be able to sell a house without it coming back to haunt him later.
In reply to #81
01/01/2014 8:49 PM
As for me and my house....I do care what the previous profession was. Selling houses IS NOT the same as building houses. Selling yesterday , building today......not! You want the auto parts stock person filling in for a certified mechanic? I mean he has been exposed to automotive repair, he can twist a wrench and he knows what a screw driver looks like and you don't care what their previous profession was. Turn him loose on your prized classic automobile. Anybody can swing a hammer and stretch a tape...that is not even remotely qualifying any person as a craftsman. It takes years to learn and master a trade. He should hire the talent, surround himself with employees who have years in the biz both in the office and the field. He would do himself good that way and LISTEN and learn the details of contracting and construction. You gotta start somewhere but I still would be hesitant to give my project to the guy who just started.That is different than being "exposed" to it because you sell houses. 85% of an agent's time is showing finished houses.........not field trips to observe construction progress or quality. They just want you to hurry the hell up so they can get it sold.
In reply to #82
01/03/2014 5:32 PM
I'm not sure how much experience you have had working around certified mechanics but I have had enough to know that when they are certified it for one type of work usually on one single model of vehicle. Thats all.
Now on the other had the guys I deal with that run the parts desk tend to be part time wrench turners and many of them are darn good at it. Most likely better than most certified mechanics I know. One of my friends is a auto mechanic that has been working behind his local autoparts store service counter for years.
Unlike a certified service tech that guy knows the aftermarket and factory parts cross references by heart! Say the starter goes out on my Dads Lincoln. To a certified mechanic that has only one starter that fits and it costs $400! To my auto parts desk buddy that $400 starter cross references to at least a dozen other starters that are not only direct fits but some are superior in quality and performance while still being half the price!
Relating to a house salesperson building houses well one of my grandparents worked as a realtor for as long as I can ever remember. One thing a good realtor knows is how to determine whether a house is built well or not.
Simple hands on experience of having seen many houses ranging from partially constructed to fully finished would give anyone willing to pay attention would give a persons a very good idea of whats quality construction and what's not. From there it's just a matter of following building codes and having people who know how to construct something that meets or exceeds them. After that things still have to pass a master building inspectors approval.
So would i trust a guy who was a former realtor to build a house? Well if all of my experiences with hims give me strong reason to believe he understands what is quality and what is not and he has a work crew of people who have a similar mindset I would give them a shot! After all they still have to pass a final inspection by a certified inspector.
In reply to #93
01/03/2014 6:13 PM
No matter how you minimize it or try to justify it, experience over exposure will trump every time. My son is a seasoned, certified mechanic. BTW- mechanics are constantly brushing up on current technology and what is even down the road before product hits the market. When the parts guy has a question...he goes to the garage. The guy deserves a chance don't get me wrong. He can build your next house.You can be the guinea pig and after 2 years see if you'd be honest and let him build your next one. You may win that debate with others - not here. We are not talking about a deck- we are talking about a breathing, living structure with systems. Just because an inspector approves something only mean it meets the minimal code requirement. Inspectors carry no skin in the game and are untouchable in the event a claim arises. It is obvious we are not eye to eye on this one and quite frankly, this whole subject thread is old and beaten to hell. Enjoy your weekend.
Good Answers: 11
#95
In reply to #94
01/03/2014 6:36 PM
I'm with Steve on this one 100%. I wouldn't want most builders to build my house, let alone a realtor switching gears to start a building business, lol. Many states don't even require a license to be a builder and there is less consumer protection for purchasing houses than toasters. I would strongly recommend anyone contemplating building a house to use an architect! It's simply too big a gamble to trust that much money to an uneducated and/or inexperienced person. I wonder if you'd feel the same way about a realtor in pearls and heels turned general contractor, TCM ;)? Something tells me ....uuhhhemmm... NOT. Being a guy who hangs around houses or sells them doesn't qualify him to build them any more than being a band aid salesman qualifies one to be a physician.
In reply to #95
01/04/2014 12:05 PM
That's exactly why I said that you have to have a feel for the person. I live and work around people of multiple skill sets so to me just because a persons last job was XYZ that doesn't imply anything to me that they may not have a solid skill set relating to something else entirely.
My last job was putting fuel into railroad locomotives. Does that mean that now I can only do that for a living and any and all other skill sets I have and use are no longer valid and should never be used again?
Good Answers: 11
#97
In reply to #96
01/04/2014 12:31 PM
It's a very competitive world out there, TCM. Personally, I would hire the most qualified person for any job. Someone who claims to have a skill set but no educational background, is untested, unproven and inexperienced would not be on my list of candidates for any job, especially when the skill set and knowledge base is so critical and the financial commitment is so large. If I were that realtor, I would go back to school and then take a job in the construction industry and gain some experience and a reputation before declaring myself a general contractor. If "having a feel" were all that's required, there would be no con men in prison, lol.
Good Answers: 117
#100
In reply to #97
01/04/2014 9:04 PM
So how do you get the knowledge and experience?
My uncle came back from the war (wwII) and built a foundation in Thunder Bay Ontario. He sold that and built a foundation with a frame on it. He sold that, then he built a foundation with walls and a roof.
Then he proceeded to build homes.
His method worked because it pretty well had to. He had his demob money, and a wife and two daughters. He never DID get his contractor's licence until the mid seventies. At that point, he got the licence because he had to employ people because of his age. He never stopped complaining about the people he was employing...but I know of one frame which was ripped down because the i d ten t who was working for him failed to attach it to the foundation.
So you don't have to be a great contractor...but honesty goes a LONG way. My uncle used up ten to fifteen years proving he did good work. I would not personally hire a person who had never built a house to build MY house, unless I was a contractor myself who was able to observe things like concrete slump results, the use of oriented strandboard instead of more expensive plywood, proper drainage around the foundation and hurricane clips on the rafters.
So, in my rambling way, I got around to the topic.
Good Answers: 122
#83
01/02/2014 8:10 AM
Research the building code for your area before you attempt or sign off on anything pertaining to foundation specifications suggested by any contractor and follow them as a minimum standard.
Remember that it is not possible to keep concrete cement from cracking and the object is to control the cracks so that the structure does not suffer damage.
Nothing can replace steel (rebar, wire re-mesh, and stressed cable) in stabilizing concrete and keeping all of the surfaces in alignment.
Relief cuts and/or expansion joints placed at the correct interval spacing are critical and required.
Thickness, slump, and strength of the concrete is dependent on soil type, moisture content of soil, type of structure, height of structure, and method of application.
You should be able to get everything you need from your local courthouse and/or building inspector.
I would be very wary using a realtor-turned-new contractor unless that person could prove extensive prior experience as a builder.
The cheap cost will soon be forgotten when the home starts exhibiting structural issues and the cost of re-doing will be at least 300% more than the savings.
Good luck but I would suggest using a reputable contractor especially since you do not seem to know much about home construction. (yet)
In reply to #83
01/02/2014 9:31 AM
It is true that concrete cracking cannot be totally eliminated, certain additives can help, such a fiberglass and other additives.The cause for cracking in most cases is uneven distribution of moisture within the concrete.A little known additive is Sugar Cane Bagasse. It has been found to reduce cracking when added in the proper ratio by controlling the moisture gradient, and it also increases the strength when used as a replacement for cement in the mixture(up to 20%).
http://eece.wustl.edu/ContentFiles/International/2012/RadkeSugarcaneBagasseAshWasteBrazil2012.pdf
This may or may not be available everywhere as an additive,but eventually will be.
Another method of preventing cracking in exposed concrete is a surface coating of Sodium Acetate,which is as effective as epoxy for sealing concrete against moisture.
It is also benign to the environment.
It expands when dry, allowing trapped moisture to escape,and shrinks when wet to prevent moisture from penetrating.
There are many more additives that I have not mentioned that date back to Roman days,whose concrete has endured for thousands of years with no rebar at all, due to the high content of volcanic ash (Pozzolzanic) in their mixture.
01/02/2014 9:07 AM
Qualifications for becoming a contractor vary widely from state to state.In North Carolina, for instance, any project with a total cost below $30,00 dollars requires no exam for qualifications.Anything above that amount is divided by valuse of project and size of building.Each step requires a minimum of XXX years of experience before even becoming eligible to sit before the Board and take the exam.
An inspector (A code enforcement inspector, not a "home inspector")(A "home inspector" is an entirely different category) also has a vigorous training requirement, and all trades have required a certain number CEU's for renewal of their license. Some small city inspectors do the whole job, from electrical,plumbing,and structural.They have a very broad training base and must stay current on the latest methods and technologies. He is usually,a REALLY GOOD "Jack of all trades".You can usually rely on his advice more so than a contractor, for he has no vested interest in the contractor's profit margin, and is primarily concerned with sound engineering practices and procedures.
Be Diligent!
Inquire about the proposed contractor's experience,training and the licensing requirements for your state.This can usually be found with a Google search for "board of examiners of general contractors " for your state, or similar terms, and will usually list by name,city,county and license number of the licensed contractors in your state .
Do your homework before you do your "HOME" work,or you will have many restless agonizing nights of regret afterwards.
An old timer told me once: "The bitter taste of poor quality lingers long after the sweet taste of a low price."
Good luck!
#86
01/02/2014 10:18 AM
try www.greenbuildings.com
pnaban
Good Answers: 70
#87
01/02/2014 4:23 PM
It seems the Novicebuilder has left the building, probably didn't like the common sense advice about using his Realtor/ newbie contractor. As they say, "you can only them to water but you sure can't make them drink". Hopefully it all works out for them.
Best of luck and Have a Happy New Year
01/02/2014 5:29 PM
If the guy had a great reputation as a realtor, there's always a possibility that he has done his homework, put together a competent crew, and will build you one of the best houses in town.
My sister called me earlier, and she just paid the husband of one of her friend's, (he owns a repair shop), $800. He had the car for just over an hour, told her he was giving her a great deal, and it sounds to me like he just topped off the power steering fluid.
Why didn't I fix the car? Well, she didn't ask, she never runs out of projects that need doing, and if I charged her $20, she would have thought it was too much.
Anything beyond a small, simple job...I won't touch it for friends and family. It's not worth the hassle.
In reply to #88
01/02/2014 5:53 PM
Your price was too cheap to be perceived as a good deal.
case in point:
I bought an air boat at a yard sale.Very cheap.$50dollars.Engine would not start.
I fixed it by simply changing the gas and installing new plugs.
I put up a sign FOR SALE $300.Several people inquired, and asked what was wrong with it.I told them nothing.I would start it up and let it run,and they were still convinced there had to be something wrong to be selling it that cheap.
I raised the price to $600 and it sold to the very first customer the next day.
Go figure.
In reply to #89
01/02/2014 6:26 PM
Yeah. I usually end up beating myself when working for friends or family. All of them expect a deal...which I give them, and it isn't really worth the time and hassle. None of them are capable of doing anything that I would trade for, so I just keep it to small stuff, and have them pay me in beer.
In reply to #90
01/02/2014 6:35 PM
thats why you tell them to get 3 bids in writing first and tell them after you see the bids that since you're such great pals you'll do the same job for a bit less........they'll quit asking when they see they have to actually do a little leg work
In reply to #91
01/02/2014 6:55 PM
I've already quit doing it. It's the same every time...
While you're here, could you look at this?
I think I might have a roof leak, do you mind having a look?
Before I know it, I'm cutting into time that I could be somewhere else, actually making money.
01/04/2014 1:17 PM
If you would like to get an idea about how "Friends of friends" build houses,check out the TV show "Holmes on homes".
One horror story after another.The "home inspector" has no skin in the games, as has been stated, and no legal liabilities,however, in some states the Code Enforcement Inspector does have legal obligations, and can be sued if structure fails due to a code violation,and can face criminal penalties if loss of life occurs.
You should find out from your city or county inspector's office exactly what his responsibilities and obligations are.
A code inspector works for the city or county.A "home inspector " is usually playing golf (or ball) with the realtor and is subject to "grade on the curve" to get the house sold.Not saying they are all corrupt, but from what I have seen,some are.The realtor will send business to those home inspectors that he "likes" best.
You have a reason to be nervous.Your gut is telling you something.Listen to it and to most of the sage advice you have gained here.
I am a retired unlimited electrical contractor with over 40 years experience, and I have seen a lot,but I am amazed at the new and novel ways a new home buyer can be hung out to dry.
I know how anxious you must be to to get into your new home,and your better half is probably putting a little extra pressure on getting started,but do not throw caution to the wind.
Be very careful.A mistake is a learning experience, but one that takes 30 years to pay for is a catastrophy.
RSVP and let us know how things are going.
Al-mentor (1); Anonymous Poster (1); CaptMoosie (3); daveh (2); Delmar (2); dhayanandhan (1); dj95401 (5); dvmdsc (2); Fredski (9); gringogreg (1); guds777 (5); HiTekRedNek (6); kramarat (8); Kris (2); LongintheTooth (1); lyn (11); North of 60 (1); Novicebuilder (2); old salt (1); ormondotvos (1); phoenix911 (9); pnaban (2); SHOCKHISCAN (1); SolarEagle (1); specifier (4); SSCpal (1); Steve Batey (4); tcmtech (6); Tony Aston (1); user-deleted-1105 (4); yamdankee (1); Yusef1 (2)
