Previous in Forum: Moisture Content in Compressed Air   Next in Forum: Maximum Pressure for Testing
8 comments
Chang In Shaft Power When Speed Is Reduced
03/05/2014 7:27 AM
Consider a 50 kW motor operating a variable torque load. What would be the change in shaft power when the speed is reduced by 180 rpm?
a. 10.0 kW
b. 13.5 kW
c. 20.0 kW
d. 36.5 kW
e. None of these answers
Re: Chang In Shaft Power When Speed Is Reduced
03/05/2014 8:13 AM
Arrrrrrrrrrrrrroooooooooooooooooooogah! Homework alert!
One wonders what the change would be if the shaft was only doing 180rpm in the first place...
03/05/2014 9:05 AM
No hints. That wouldn't be fair to the other cheaters students.
03/05/2014 1:40 PM
or 90rpm . . .
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
03/05/2014 2:13 PM
Ohh! That one has to be 'e'!
03/05/2014 8:22 AM
we dont do your homework here
03/05/2014 11:54 PM
We also don't tell your instructor how to form proper questions.
03/05/2014 11:03 AM
Insufficient information; it depends on what the original rpm was.
08/28/2015 1:39 PM
This question is from the pdf version of the PEM (Professional Energy Manager) exam available through Schneider Electric's Energy University.
The pdf version is missing a key piece of information that the motor was originally running @ 1800 RPM. This number will show up when you take the actual exam online.
Anyway, the right answer is b. 13.5 kW.
(@1620 RPM, the demand will be 36.5 kW, so the change is 50 - 36.5 = 13.5 kW)
Good luck if you're taking the exam!
-WolfDrago-
Register to Reply 8 comments
Fredski (1); Mike W (1); PWSlack (1); Tornado (2); truth is not a compromise (1); Usbport (1); WolfDrago (1)
