Sports, Fitness, and Nutrition Blog
The Sports, Fitness, and Nutrition Blog is the place for conversation and discussion about topics related to sports and sports fitness, general fitness, bodybuilding, nutrition, weight loss, and human health. Here, you'll find everything from nutritional information and advice about healthy eating to training and exercise tips for improving your overall well-being.
Previous in Blog: Are Raw Food Diets Safe?   Next in Blog: Could Sunscreen be Elevating Your Risk of Skin Cancer?
5 comments
Introduction to Yoga – Twists
Posted June 15, 2010 12:00 AM by Jaxy
There are many benefits to adding twists as part of a well-rounded yoga practice including relief of back pain and pressure, improved digestion, stretching and strengthening of the spine, and many others depending on the pose. If you have problems with your lower back or sacroiliac joints, do not mix twists and forward bends, or only do so under the guidance of an experienced instructor who is aware of your aliments.
Precautions and Safety Tips
As with any sport, it is important to warm up before yoga. To warm up for twists, you need to elongate your spine. Practicing forward bends like padangusthasana (big toe pose), uttanasana (standing forward bend), prasarita padottanasa (wide-legged forward bend), and paschimottanasana (seated forward bend) will help to elongate your spine and help warm your body up for twists.
Even though twists compress your diaphragm, it is important to breathe steadily. Try inhaling as you lengthen the spine and exhaling as you twist. Do not try twisting while you inhale as you will not be able to do so efficiently. To promote balance, be sure to practice the twists on both sides. It is suggested that if one side is tighter than the other, doing a twist twice on that side may be beneficial.
Let's Get Our Pretzel On!
Bharadvajasana I – Bharadvaja's Twist
Bharadvaja's pose stretches the spine, shoulders, and hips; helps relieve stress, improves digestion, and relieves lower backache, neck pain, and sciatica. If holding your arms in the orientation that the person in the picture (part of the above link) is doing, you can drop your right hand to the floor.
Marichyasana III – Marichi's Pose
Marichi's pose stimulates the brain, relieves mild backache and hip pain, strengthens and stretches the spine, and stretches the shoulders. Just as in Bharadvaja's twist, if you are uncomfortable with the orientation of the arms, try resting your right hand on the floor behind you , and either wrap your left hand around the knee (so that you are "hugging" your knee) or extended on the outside of the knee.
Parivrtta Trikonasana – Revolved Triangle Pose
Revolved triangle pose improves balance, stretches the legs, hips, and spine; relieves mild back pain, and opens the chest to improve breathing. This is a pose where a block is useful if you cannot touch the ground with your hands. You can also rest your hand on your ankle or the inside of the foot. If you have a back or spine injury, do not perform this pose without an experienced teacher.
For more seated and twisting poses: Yoga Journal - Seated & Twist Poses
Resources:
Yoga Journal – Do the Twist
Yoga Flavored Life – Yoga with a Twist
Picture: http://lh5.ggpht.com/_ENau7CTodQE/S0wPcNDMgXI/AAAAAAAADbQ/xSbWD9h2mXY/YogaTwist%5B9%5D.jpg
Good Answers: 25
Re: Introduction to Yoga – Twists
06/16/2010 7:02 AM
Hi Jaxy,
I think now you have become Yoga "Guru".
06/16/2010 8:22 AM
Thank you.
Although I know a bit about yoga, I know that I still have a lot to learn about this practice. I want to get to where I can comfortably do inversions and not be afraid of falling. Oh if I could lose all of my inhibitions like when I was a child practicing handstands. If I practiced handstands now, I couldn't do so with near enough abandon.
Good Answers: 25
06/17/2010 7:19 AM
Hi Jaxy,
Handstand is called "Sinhasana". You can start by taking support from wall, your back towards wall. Initially you may need some one's help to raise your legs. Latter on if you can balance yourself then you will not need support of wall. Here in India there are many people who can do it but except me.
Regards,
Suresh Sharma.
06/17/2010 8:02 AM
Probably not.
Sinhasana is
What is Simhasana?
Simha means lion in Sanskrit since one assumes the pose of a seated lion in this asana, hence the name Simhasana is given to this pose. In this majestic sitting pose the entire body and facial expressions are modified to invoke the great regal force in the practitioner.
Handstand may be of two types:
1 on the palm stand: I am not sure, if this is treated as yoga posture or not. Or probably it is called Adho Mukha Vrksasana
or
2. by touching had upto forearms to ground and stand upside down
This is called Pincha Mayurasana.
Good Answers: 25
06/17/2010 8:20 AM
Hi Gsuhas & Jaxy,
Sorry it is called "Shirshasana". But you have to put your weight on your head not your hands. Most useful Asana if you can do it.It Improves blood circulation in your brain and brain is sharpened.
Regards,
Suresh Sharma.
gsuhas (1); Jaxy (1); suresh sharma (3)
