Previous in Blog: Funny Drag: Newsletter Challenge (05/04/10)   Next in Blog: Helium Balloon: Newsletter Challenge (07/06/10)
Page 3 of 5: « First < Prev 1 2 3 4 5 Next > Last »
Sailing: Newsletter Challenge (06/01/10)
Posted May 30, 2010 5:01 PM
User-tagged by 1 user
You are in a sailing race on a very wide river. On land there is no wind; it is a dead calm. The race is 10 Km downstream, and the river is running 5 Km/ hr. Your opponents decide that to make the best time, they will streamline their boats to the wind and float downstream as fast as they can. You decide on a tacking strategy, sailing back and forth across the river's width. Who wins the race? What is the winning time?
And the Answer is...
ou win the race, because you are sailing upwind. The winning time is: less than the time your opponents took.
When you all cast off you all feel a wind (a perceived wind) in your face as you float downstream. The wind is really the still air, relative to the shore, that you are moving past.
Relative to the river, in which you float, the wind is in your face, and all modern sailboats can sail into the wind--that is, tacking back and forth, up wind. Your path will be much longer than your opponents', but your downstream time will be faster.
Your opponents' maximum speed into the wind, and as measured by the land, will never be faster than the 5 KM/H current. Your speed will be faster by the speed you are able to sail upwind.
In reply to #125
Find in discussion
Re: Sailing: Newsletter Challenge (06/01/10)
06/08/2010 3:05 PM
Your interpretation may be correct, but I think by "a tacking strategy, sailing back and forth across the river's width" the writer meant sailing back and forth at the angle that would best cause you to win the race (about 45 degrees to the banks and the induced wind). It is, after all, a sailing race, in which the sailors are expected to sail the course that will cause them to win. Sailing a "proper course" (a term used in the rule book) would mean that you would arrive at the finish line in significantly less than 2 hours.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
In reply to #127
06/08/2010 5:38 PM
I have to agree with you fully.
GA
What many have forgotten is that the boat that tacks, but just for example at this moment does not gain any speed over a boat just going down river, WILL ARRIVE AT EXACTLY THE SAME TIME AS THE RIVER MOVES BOTH BOATS AT THE SAME SPEED!!!! (All other points being equal!)
Stupid statements that losing momentum at the point of going about is simply not understanding the situation. The boat STILL moves downstream at the speed of the river, even while going about!!!
Assuming that you have a large well cut Genny and your boat can sail at 45° to the wind, then it is HIGHLY likely that you will make up and actually add a tiny bit of speed to the boat that is tacking, therefore the tacking boat will win....it does not have to be much, even 1 cm in front is a win situation.
#130
06/09/2010 12:00 AM
For the opponent it would be better to have less free board and you would want maximum hull drag and minimum air drag to maximise the speed down the river. The air drag will slow you down you would end up say 4.9 or 4.8 km/hr.
The tacking manouvoure is better as the sail will act like an aero foil and drives the boat forward while the current is still pushing at less than 4.8 km/hr but you would be gaining by 2 - 3 km/hr by the action of the apperent wind giving you a total VMG of 0.7 (cos 45 Deg) of the 2- 3 km/hr gained ( so 1.4 to 2.1 km/hr ) in total of 6.9 km/hr
So the opponent will finish at 2.08 hours while you will finish at 1.44 hours
#131
06/09/2010 12:04 AM
#132
06/09/2010 1:04 AM
1.) 5km/h is nearly 3 miles/hour!
2.) the induced windspeed of 3 knots creates a sailing speed of 3 knots rectangular to the rivers flow direction, a total sail speed of ~4.2 knots (45° cruising, square root of 18)
3.) the distance for the diagonal speed line is more than 40% (factor square root of 2) higher than the shortest line for the drifting sailor.
4.) result: the higher speed for the longer distance results in the same race time for the sailor as for the slower drifter
#133
In reply to #132
06/09/2010 1:05 AM
fixed and closed
#134
In reply to #133
06/09/2010 2:20 AM
LOL!!!
A person with a strong sense of humour and a manager's intellect!!!
In reply to #132
06/09/2010 3:35 AM
I think you are forgetting that regardless of the wind all boats move downstream at the same speed. So I think that instead of considering on one case JUST the flow of the stream and on the other case JUST the induced wind, on the second case the induced wind should add to the stream effect, thus giving the tacking boat an advantage.
hugomad
In reply to #135
06/09/2010 11:36 AM
Hum... I believe the achievement is not to "gain" on the wind (there is really no wind) but not to be slowed down downriver by that immobile mass of air while tacking madly across the river. While it might not have been entirely his intention, Randall illustrated very clearly the movement of two boats starting in precisely the same position in his diagram in post #21.
Again, failing to see a geometric illustration of a tacking boat advantage, I am forced to maintain that the passive sailboat wins for the keel of the tacking sailboat cannot be perfectly efficient (that is, discounting the gains that could be attributed to that madly tacking boating while "rolling from one tack to the next ;-)
I still believe adding the river flow to an imaginary wind, as you (and many others) are suggesting, amounts to counting the river flow twice.
Now, to really mess things up, I confess to having come up with the "ice boat on a drifting ice slab" analogy in a previous discussion on the very same subject. If someone is willing to rationalize this - you are very welcomed...
In reply to #138
06/10/2010 1:57 AM
Again, failing to see a geometric illustration of a tacking boat advantage...
If you have failed to see, you have failed to look. There have been many links provided that illustrate the physics of sailing. I gather that you have done some flying. Although sailing is considerably more complicated than flying, you are probably a bit ahead of a complete neophyte.
You perhaps understand that taking off into a 15 knot headwind requires less speed over the ground at liftoff than is required when taking off into still winds. You probably can sense that a sailplane doing 70 knots in "calm" air has a 70 knot "apparent" wind over its wings... even though you seem to think such wind is "imaginary." One would hope that you understand that when that sailplane is flying, the only thing the wings care about is "apparent" wind: at 70 knots airspeed, the wings see 70 knots regardless of whether ground speed is 100 knots or 40 knots. You may know that the Wright brothers (with their wind tunnel experiments) showed that a stationary wing in a wind tunnel accurately models a moving wing in "still" air.
The link above provides the answer to the following question, which I repeat from a previous post:
  • A river runs straight from West to East at 10 knots. A 10 mile race is held: the boats sail downstream, from West to East. The first heat is held in the morning, when there is no wind. The second heat is held in the afternoon, when there is a 10 knot wind from the West. In which heat are the faster times recorded?
Obviously (to any thinking sailor) the fastest times are recorded in the morning when the wind (in your view) is "imaginary". If you read through the linked page looking at the various diagrams, and then sketch up a few vector diagrams of your own, I think you will come to understand something about how sailboats work. The answer to the puzzle is given near the bottom of the page.
Until you make that effort, you will probably have to count yourself among the folks who think that sailing directly into the wind at twice wind speed in not possible -- even though it has been both demonstrated and explained.
If none of this makes sense to you , then I can only recommend that you learn to sail in a lake, and then sail in strong currents.
In reply to #141
06/10/2010 9:18 AM
I had to give you a GA.
Not just because of your (fully correct) sailing knowledge, but also because you held back like a true Gentleman (or Lady?)....well done.
I am not well renowned (as you now are by the way) for such good manners in such cases of blissful ignorance!!!
Also your English is really excellent too (assuming it is not your first language!), better than many here with it as a first language!!
As you requested and very LOUDLY:- "PHUKET!!" (Was that "LOUD" enough?)
Sounds not so good in English though!!!
(I hope everyone understands why I said it so LOUDLY!!)
Also I hope to see you more often on CR4 as well......you are most welcome.
In reply to #138
06/10/2010 4:13 AM
"I still believe adding the river flow to an imaginary wind, as you (and many others) are suggesting, amounts to counting the river flow twice."
If I may, I'll try to counter this statement:
. set a reference frame solidary with the body of water
. on the initial moment you have, on this reference frame:
. Vboat relative to the air = 5 km/h
. Vboat relative to the water = 0
(this is obviously a simplification, but the drag effect of the air at this speed can be safely neglected, on bare poles etc.)
These conditions are mechanically equivalent in all aspects to a boat sitting still in a body of still water (suchs as a lake) with a 5km/h breeze coming from the finish line.
Now, as MoronicBumble (#53) has explained perfectly, there is a way to start sailing upwind under these conditions.
So you end up, on your mobile reference frame, with Vboat relative to the air > 5 km/h and Vboat relative to the water > 0.
Now, if you revert back to "earth" coordinates, if you are to determine Vboat you have to sum the velocity of the boat relative to the moving reference frame with the velocity of the reference frame itself (the velocity of the flow).
I think you will agree that this doesn't amount to accounting for the flow twice.
(Thanks to Randall for his help on how to insert pictures - a picture is worth a thousand words :) )
hugomad
In reply to #143
06/10/2010 9:35 AM
Really well put (even I understood it fully, well done, So surely some of the "non" sailing types will also? or am I hoping too much for that?).
I would just like to add for anyone who understood what you just wrote, please remember that on lakes around the world, many boats sail on completely still water, but with a 5MPH breeze (Zephyr?) and get about, even directly into wind (tacking and reaching).
That is the same as wind still and a 5 MPH current of the river water......
Under such conditions on the lake, some special boats will achieve as much as 10 MPH or more, but of course the are on still water and are sailing longer distances (tacking/reaching), BUT THEY ARE STILL MAKING HEADWAY DIRECTLY INTO WIND!!!! (Also called "Course Made Good", which is also the "ACTUAL" speed "DOWN" the river, parallel to the banks, which may only be say 2 or 3MPH!!!! )
But then add this headway speed made to the speed of the river in the case in question AND THAT WILL BE THE SPEED THAT THE BOAT WILL ACHIEVE DIRECTLY DOWN THE RIVER. Maybe in total 8MPH or so..... (depending upon boat type/quality of skipper etc..!).
I wonder if the sceptics now understand full?
(But I somehow doubt it, they are too well entrenched!!) Let us wait and see!!
#136
06/09/2010 4:49 AM
If it was me. I would throw in a drouge anchor, lean back and open a frosty
#137
06/09/2010 11:06 AM
The time is 2 hours (5km/hr for a 10km race). There is no wind on land so there should be no wind on the river. The boat sails were taken down to reduce the wind resistance produced from the 5km/hr movement with the river current. Without wind tacking would not be possible.
In reply to #137
06/09/2010 11:38 AM
More than enough has been written on this thread to support the tacking strategy, including the statement from experienced sailors that "boats make their own wind". You should at least read the previous posts and try a decent explanation of why you shouldn's count apparent wind instead of just adding to the general background noise ... that's my personal view, of course.
hugomad
Reply Off Topic (Score 4)
In reply to #139
06/09/2010 5:18 PM
You are right, anyone who has sailed will understand the problem (and tacking in such a situation and its effects) much better and easier.....
In reply to #140
06/10/2010 2:12 AM
I have to disagree: I have never sailed; several posters who claim they do still don't "get it". Everyone, whether they are a sailor themselves or not, knows that it is possible to make headway against the prevailing wind by tacking. What the people who still don't "get it" are struggling with is the change of frame of reference. This is despite the fact that Tornado explained it perfectly in posts #2 and #4; someone even voted against post #30 from Usbport, which explained it perfectly in a very intuitive and non mathematical way.
In reply to #142
06/10/2010 7:36 AM
No, those of us who have sailed, especially those who have sailed home on an incoming tide and against the wind do understand it. Yes, it is possible to make headway against a prevailing wind by tacking, otherwise sailors could never complete a triangle course, or any round trip in a prevailing wind for that matter. One needs to remember that in addition to the prevailing wind, you also have a 5 knot current (that is creating that wind). The question comes down to this: Will the tacking boat be able to use the apparent wind to make good over and above the current. I agree with those who say that it can, but only in an ideal theoretical world. My earlier post was based on real world conditions. Of course, in this exercise, I should have realized that only a theoretical ideal can be considered, so, I will change my earlier answer and agree with those who say that the tacking boat wins.
In reply to #144
06/10/2010 7:46 AM
"Will the tacking boat be able to use the apparent wind to make good over and above the current"
BMW, you are not trying to "make good over the current", it's already carrying you in the direction you want to go, you are using the apparent wind to add to it, thereby making significantly greater progress towards the finish line than the fellow that just lets the boat be carried by the current.
In reply to #145
06/10/2010 7:58 AM
Right, that is what "over and above means", adding to it.
In reply to #146
06/10/2010 8:23 AM
Exactly. You're making baxterm and Randall's points for them. Assuming the boat is capable of making any progress upwind in still water in a 5-km/h headwind, it will add that progress to the 5 km/h current and therefore win the race against the boat that is travelling marginally slower than the current.
I have only sailed a handful of times, so can't speak from great experience, but are you seriously suggesting that the effects of slip angles under sail and drift during tacking are such that a typical real-life boat and crew cannot make any upwind progress in a 5-km/h wind?
In reply to #147
06/10/2010 9:10 AM
You are probably correct that any craft should be able to make some progress versus drifting in the current. In a real world scenario, how much truly depends on the boat as well as the skipper and crew. I have sailed all my life, including a regatta winning career in FJ's and dinghies as a youth. I have also sailed catboats, catamarans and windsurfers. Some can make a 45 degree angle of attack, some definitely cannot. When I say that the tacking boat has to make good over and above the current, I am saying that the lift and speed generated with a 5 knot breeze will need to more than compensate for the effects of increased drag and the change in the angle of attack of the apparent wind (the faster you go, the more the apparent wind forces you to bear off as it changes direction relative to the boat). There are times when sailing a windsurfer in light air, 10-12 knots for example, that you are doing well to hold position on a plane; it is usually possible to pinch upwind at a very slow pace and sailing as a displacement hull (non-planing) in these conditions. In reality, we generally "pump" to get back to the beach when confronted with less wind and are happy to have made it back to the cooler.
Nonetheless, my initial error in this was to think too much like a sailor and not stay in the theoretical realm; as I said earlier, I have changed my answer.
In reply to #145
06/10/2010 9:37 AM
(His name is BWW I believe!)
He agrees with us now as well, so do forgive him please!!
In reply to #144
06/10/2010 11:29 AM
In most cases (in sailing, flying, mechanics, engineering, etc.) theory and practice coincide -- it is simply a matter of correctly applying the correct theories and avoiding gross oversimplifications. Good velocity prediction programs for sailboats can predict real-world performance on any point of sail with very good precision -- far better precision than would be required to correctly answer this question (which boils down to whether a generalized, typical sailboat can sail to weather or not).
In your other recent post you use the example of a windsurfer as being a craft particularly poor in upwind performance in light winds. The performance of a middle-of-the-road, floaty but centerboardless windsurfer in light winds is as theory would predict -- the fin is a small fraction of the size required for such conditions. With a 10 square meter rig, you would need a fin larger than the centerboard on a Laser, which carries only 6 square meters of sail. Given that this challenge question is about a race, it is reasonable to assume that competitors would come equipped with something close to the right equipment for the conditions, such as a Mistral One Design rather than a sinker. In the 2.7 knots of available apparent wind, any well-sailed MOD can make reasonably good progress to windward... exactly as theory would predict.
What about any other modern sailboat? The ability to sail to windward is a given... and any ability to sail to windward means that the sailed boat wins over the drifting boat. River and tidal sailors encounter the real-world condition of wind induced by the boat's movement in a current every day.
In reply to #155
06/23/2010 1:15 AM
Why is everyone leaving out the fact that the hypotenuse is always shorter than the sum of the other two sides of the triangle and that the efficiency of the sailing/tacking boat must be sufficient to overcome the additional distance it must travel?
In reply to #216
06/23/2010 3:21 AM
Why is everyone leaving out the fact that ...
When sailing to windward (which in this case is sailing down river) a sailboat tacks because it cannot sail directly into the wind. It's path through the water is therefore about 1.4 times as long as the path of a motor boat going directly into the wind. The efficiency of sailing has little to do with the current question, however, because any sailboat can make some progress to windward. So even if the boat tacked through 120 degrees instead of the normal 90 degrees, it would still be making better progress to windward than a drifting boat, which is making no progress through the water.
Relative to the ground: the VMG of the drifting boats will be close to but less than 5km/h. The VMG of the sailing boats will be the VMG caused by drifting, plus the VMG increment caused by sailing. In a 5 km/h breeze, an average boat can sail at 3 km/h through the water, at 45 degrees to the stream centerline. The resulting VMG is roughly 70 percent of this, or 2 km/h. Thus the total VMG across the ground is about 7 km/h for the sailors, 5km/h for the drifters.
In reply to #221
06/24/2010 7:27 PM
is the air mass above the river moving with the river? Consider adiabatic process. Does it not change day to night on a river, especially a river with head waters at high altitude?
In reply to #251
06/24/2010 7:48 PM
Of for the love of ***** ,,, this is a simple thought problem. Like so many posed in physics the idea is to just deal with the simple stuff, stop thinking complex. It's simple, assume that the water is moving, forget the friction at the water/air interface, forget adiabatic processes,, keep it simple assume ideal. The river is infinitely wide, it is moving at 5k, the air is still. So you in your boat can't tell whether the water is moving or the air is moving. Given that, you do the logical thing and sail. Good God almighty this is so simple!!
In reply to #253
06/25/2010 1:16 AM
you are right about doing the logical thing, that's why I win the race, although all my competitors want to win too. This is a simple sailing race and the rules of the race tell all us racers how to race. One of the things you will be penalized for is jumping the start gun, so every racer will do their best to time the start, and, be in the right place. Since every one else has chosen to float and leave me to sail, I figure that all I have to do is beat them to the start, thus I will win by that amount. Theory says that we all start at exactly the same time and place. (how could you get to the middle of the river when the current would take you as soon as you put in the water) . I would make sure that I was ahead of every one 5 minutes before the start. Maybe instead thinking race, the question should have read, "if you put 5 empty rafts of smaller size next to your bigger raft with 3 people and all their beer, into the river at the same time, which one would go 10 km the fastest.? Drifting and paddling on a river is more fun anyway and maybe that's why there have been so many comments about this idea. It has been a nice distraction, for those of us stuck here on land. Let's SELL UP AND SAIL AWAY, to a much simpler life.
In reply to #253
06/25/2010 9:11 AM
"The river is infinitely wide, it is moving at 5k, the air is still. So you in your boat can't tell whether the water is moving or the air is moving. Given that, you do the logical thing and sail. Good God almighty this is so simple!!"
The perfect answer!!! (Except for the units)
Now, on to thngs that matter.
Little about much, much about little
In reply to #216
06/23/2010 8:35 AM
Why bother????
If the boat just drifts with the current, it does 5MPH downstream.
A tacking boat STILL DRIFTS DOWNSTREAM AT 5MPH WHILE SAILING! So at that point both are still equal!!!
So its final speed will be 5MPH PLUS what it makes good tacking........that is the sum of both tacks going directly into wind.......
So a tacking boat, only actually has to make a tiny bit of extra speed in the direction of downriver to win....even quite unhandy boats with little ability to "point high" will still get there first!!!
Also, as I and several others have pointed out, if you take a lake with still water, with a 5MPH breeze over it, many boats will be able to "sail" around the lake quite easily........as some boats can actually sail to windward (sum of both tacks in the direction of directly into wind) at a speed approaching twice the wind speed.......the better the boat design, the faster it can "make up" under such circumstances.....
No tricks needed. Nor Pythagoras either!!!
In reply to #142
06/10/2010 9:20 AM
Your loss, not mine!!!
In reply to #150
06/10/2010 9:31 AM
True, I'm sure.
06/10/2010 11:24 AM
sail down wind at night and you would win by a mile, although everybody would do it.
katabatic drain
Good Answers: 114
#157
06/10/2010 10:34 PM
I don't care what the losses are, the tacking boat only needs to get one good run in and then turn straight, enough to get a measurable distance ahead, then it can drop the sail and coast, just like the other boat.
#159
06/12/2010 7:06 AM
111 Draw a vertical line A-B with the length D, and name the point A as GOAL, and
the point B as Starting Point.
222 Draw a horizontal line A-C, and then draw a line from B to C to complete a triangle.
333 Draw a line from the top of the triangle A to the line B-C vertically so that
the line B-C is divided in half into the line L1 and L2 with an equal length.
444 Let's call the line B-C as line: L=L1+L2.
555 The height of the triangle drawn in 222 is the same length as L1 or L2, let's name it L3; therefore L=L1+L3
666 The angle between A-B and B-C is θ. Then D, the distance between the GOAL and the the Starting Point B is expressed as D=Lcosθ
777 L=VT, where V is the speed of the boat, and T is the time needed for sailing from the point B to C.
888 From the above, T=D/Vcosθ
999 As the river current flows constantly from B to A, a boat floating in the river travels down the river at the same speed of the river current, which is V. Neglect the resistance of water, and air caused by the moving boat. In this case the free floating boat flows down on the river stream in the same speed regardless of the direction of the bow, as the boat floating with no hoisted sail(s) moves with the mass of river water flowing constantly at V (Km/hr).
101 When the sails are hoisted, the boat receives a head wind with the velocity of V, caused by its movement toward downstream. As the boat cannot sail directly into the wind, the skipper will sail down the river with close hauled angle of say, 30~40 degrees and he will tack at the mid point of L after travelling L1 and follow the course L3 in close hauled toward the GOAL point A.
102 Suppose the opponents boat and our boat have the same performance as expressed in a standard polar curve of a modern sail boat, our boat will travel at about half the speed of the wind or as any other modern sailing ship in close hauled. This means our boat travels at 0.5V + V = 1.5V. (The current flow speed V + the speed of the boat which is about half the wind or air speed in close hauled.)
103 From the given question, cases such as in irons (into the wind), beam reach at 90 degrees, broad reach ~135 degrees and running -180 degrees are not applicable, as there is no natural wind. Therefore, only the close hauled case is considered.
104 Travel time comparison: (Travel distance divided by the boat speed )
Opponents Boat: D/V=10(Km)/5 (Km/hr)= 2 hours
Our Boat: (A) Close Hauled at 30 degrees : 11.547(Km)*/7.5(Km/hr)=1.54hours
(B) Close Hauled at 40 degrees: 13.055(Km)*/7.5(Km/hr)=1.74hours
where (*) travelling distance L at each angle.
105: Speed of our boat running in close hauled:
    1.5x5 (Km/hr) = 7.5 Km/hr
106: Answer: We will win!!!
107 If the our boat travels at the close hauled angle of about 48 degrees our travel
time will be the same as that of opponents boat.
In reply to #159
06/12/2010 12:38 PM
you are right, we win because the captain did his math and positioned his boat properly for this race. He put in and sculled to the center, or was towed, (before 5 minutes any thing goes) so he crossed the start line just after the gun, going at max speed. the other boats start drifting downstream as soon as they put in and they are also at the mercy of the current, so how does one time the start? in the real world the one who does best at this gains a big advantage. ( in theory, all boats start equal and drifting parallel so any tack would make you bump into another boat, and is this really a sailing race? we would be the only boat in it )
#164
In reply to #160
06/13/2010 1:06 AM
You are right, indeed. Reality is harder.
Thanks.
#161
In reply to #159
06/12/2010 3:33 PM
You are not thinking "out of the box"....
Read some of the other good posts here that will demonstrate in a far easier manner, that the tacking boat will always win.......no matter HOW bad its tacking angle is as long as its 89° or better........
At 90° it will take the same amount of time as the boat just riding the current!!
Its a really simple problem........you are thinking at too high a level........its simply not working for you!! Sorry!
Assume that the tacking does not bring any positive (or negative) effect on boat speed for a second. Then both boats will arrive together. That is tacking with a 90° angle........anything better than that (easily achieved) will mean that the tacking boat (which has a consistent 5 MPH, as has the non tacking boat) will add to that 5 MPH a small measure of extra speed.....OK?
So the tacking boat will win.
Take a high perforance hull, that tacks at near to 40°, it will streak away......
#163
In reply to #161
06/12/2010 10:02 PM
Was just curious to know the approximate winning time.
Thanks, buddy.
"Sometimes you get the bear. Sometimes the bear gets you!''
06/14/2010 9:50 AM
If I am in this sailing race , I am the only boat that is sailing, thus the race is canceled due to lack of competitors. In this theoretical race , how could every one start equal? There can not be any racing among drifters, who dangle their toes and have brewskis.
#166
06/15/2010 1:29 PM
You can look at this as a relitivity problem. Change your point of view and say you are in open water with a wind of 5 km/hr and you can see that the best your opponents can do is stay in the same place and not drift back. Finding the time is just an estimation at best. You have to make a lot of assumptions about conditions.
#167
06/15/2010 2:07 PM
The boat tacking back and forth. Less water will slip past the hull and keel crossing the current than one inline with it.
#168
06/15/2010 2:21 PM
The current is moving the boat and the apparent wind is creating resistance to the motion. The winner (in a little more than 2 hours) will use his sail to keep his hull 90 deg. to the current to get maximun exposure and little resistance to the air.
#169
06/15/2010 3:51 PM
Assuming the boat can sail upwind at the wind speed (5 kph), and can sail at an angle of 45° to the wind, the boat speed downriver through the water will be 3.54 kph. Over the ground, the speed will be 8.54 kph, and so the boat will reach the finish line 10 km downstream in 1 hour, 10 minutes, 17.7 seconds. The boat that drifts downwind at the speed of the current will reach the finish line in 2 hours. The tacking boat will win handily.
06/15/2010 4:09 PM
I win in the time of one hour.
The river current carries me at 5 Km/Hr.
I tack at approximately 45 degrees.
Assuming zero wind and water resistance,
the still air advances my boat at an additional 5 Km/Hr.
ASSUMING that I can either complete the course on a single tack,
or change tack instantaneously, the total speed = 10 KM/Hr.
Therefore, I travel the 10 Km course in one (1) Hr.
The other boat takes two (2) Hr, assuming zero wind resistance.
#171
06/15/2010 4:26 PM
You win! Your boat is positioned perpendicular to the direction of water flow all the time which results in overall largest momentum. Never mind the tacking - there is no wind. The winning time is somewhat larger than 2 hours.
#172
06/15/2010 9:03 PM
Actually, using the 5Km/hr current it is possible to create an apparent wind, airflow over the sails, this would allow the boat to tack downstream at 6-7-8km/hr Therefore the tack boat (if tacked efficiently) would be quicker
The drifting boat takes 2hours the tacking boat would take less than 2hours - if it was a catamaran or trimaran it would be even quicker
#177
06/16/2010 4:27 AM
No wind on the land usually means no wind on rivers. So tacking and using the wind is a no-go anyway.
Boats going downstream direct at 5km means two hours for 10 kms.
Tacking with no (stated) wind loses - distance is longer anyway.
The direct approach wins and takes 2 hours.(Though they could have rowed or paddled and travelled faster)
In reply to #177
06/16/2010 5:36 AM
Just read the thread ...
hugomad
#182
In reply to #177
06/16/2010 8:18 AM
Total rubbish.
In reply to #177
06/16/2010 4:24 PM
"Though they could have rowed or paddled and travelled faster"
If you hold to that, how can you not understand the wind issue?
#179
06/16/2010 7:24 AM
it's a tie
2hr.
#183
In reply to #179
06/16/2010 8:18 AM
Rubbish.
#180
06/16/2010 7:32 AM
Let's make it simple. Consider the water as stationary, and the air, land, and finish line as in motion relative to the water and boats. Since the drifting boat remains at the starting point in the water, the finish line will reach that boat in 2 hours. The tacking boat will make some progress away from the starting point in the water, in the direction of the finish line, so the finish line will reach it in less than 2 hours.
Bends in the river make no difference because, in this case, the relative wind is always blowing upstream.
As far as cheating in a drifting (light-air) race by blowing on the sails is concerned, that doesn't work (trust me); just face the stern, pucker up your lips and blow.
06/16/2010 7:46 AM
Assuming the river is deep enough, I would suggest that you put up all sails, capsize your boat i.e. turn turtle. climb on top of the hull and drift downstream with the current.
Upside down vessel will be very stable and totally maxing out the engagement with the water flow, upside-down hull will offer least drag resistence to the relative air flow.
You should get there sooner than other rafts, but maybe slightly wet. Time to finish - less than 2 hours.
#184
06/16/2010 8:42 AM
There are a couple of other points that are being neglected.
1) The time it takes to decelerate and accelerate at the end of each tack. How wide is the very wide river. I consider a minimum of 5 Km to be very wide.
2) The resistance that is being applied to the hull from the 5 Km/hr river current pushing against the 5 Km/hr wind of the tacking boat.
In reply to #184
06/16/2010 10:19 AM
Your point 1) is totally irrelevant provided the tacking boat tacks "better" than 90° (which is a broad reach and not a tack anyway...!!).
The current does not slow down (like the other boat being just carried by the current) just because the boat is tacking!
The boat, even if it went into "Irons" would still be moving downriver at 5MPH.....as is a stationary (I mean not sailing or tacking, just letting the current carry it) boat....The slowest speed relative to the land will always be 5MPH.....never a "minus" speed!!
Most sailing boats can tack at around 50° or better, some (Rotor Sails) can even get to within 20 - 30° of the wind.......(for a normal mono hull sailor thats almost as good as "tacking directly into wind" for him......incredible....)
You can read more on tacking here:-
http://en.wikipedia.org/wiki/Tacking_%28sailing%29
If you think for a moment of a river that is completely still (I know, thats a long lake not a river!!), eg. no current and a steady 5MPH wind is blowing along it, you will find literally thousands of different types ofsailing boat that can "tack" or "beat" to windward in such a breeze.....moving (at an angle to it) in the direction that the wind is coming from. Its a normal sailing procedure.......Thats how boats get from "A" to "B" when the wind is against them.....for many thousands of years!
If you then work out that "speed made good" directly to windward on a still river, and add it to the one moving at 5MPH only, you will have the speed of the tacking boat on the river....
It would not surprise me if certain types of boat are able to make at least another 5MPH made good (travelling on a 45° tack at say10MPH or so "MORE" than the river current!) on top of the river current, though most will make probably between 6 to 8 MPH in total (River current + speed made good along the river)....
As far as I am aware, the original poster ignored wind resistance, hull resistance etc etc.....so it is really only a theoretical question......though in practise it will be quite easy for a tacking boat to still make far, far better time down river than one just floating, in such conditions as set.....
I mentioned before (in an earlier post) that for similar reasons, certain fast mono and multi - Hull boats, even "Tack" (Jibing!) downwind and still make a far better pace downwind than boats who just run before it.....it also makes for a steadier boat, whereas a mono hull running before the wind will tend to "wallow" to port and starboard, a motion that I personally detest of all the sailing and boating "motions!"
Yes I have puked my guts up a few times over the last over half a century or so....one forgets just how bad it feels when one steps on the boat at the start of the voyage.
If its any consolation, there are many others here that simply have even less of a clue about sailing than you do.....
PS. If I have used any sailing terminology that is not understood by anyone, either look it up on the web or ask me, I will explain further!!
#187
06/16/2010 2:10 PM
I live on a sailboat on a very wide river. (St. Johns) This condition exists all the time. I just start the engine and get on with life.
06/16/2010 3:36 PM
I can honestly say after a couple of years on CR4, that I have never seen a Blog that provoked so many idiotic posts from guests!!! But as guests of course we cannot see who they really were.
So guessing a bit, they knew they were not up to the question in some way.....
It really has driven the worms from the woodwork.......
In reply to #188
06/16/2010 4:11 PM
Indeed, the mind reels. Imagine these near cretins, with their evident inability to either read, or comprehend simple physical concepts, being let loose in the engineering word!
Cheers
Martin
In reply to #189
06/16/2010 4:50 PM
LOL!
In reply to #188
06/16/2010 4:21 PM
Andy,
Based on a response I got last year, it appears that most "guests" are active members of this forum but, when out of town or some such and on a different computer, they cannot log on with their normal forum ID.
I really cannot vouch for this, as I never have any trouble logging on with my active CR4 ID, no matter where in the world I am or whose computer I am using.
In reply to #190
06/16/2010 4:52 PM
I agree in all respects except one, they are actually posting Anonymously.....because they have decided to.
No more, no less!!
#222
In reply to #188
06/23/2010 3:49 AM
Gosh Andy, you are sooooo clever....
In reply to #222
06/23/2010 8:45 AM
Why thankyou, but actually its not true, I do understand simple math and physics (because that is all thats needed to understand this problem). Thats all.....
You certainly do not need to be very "clued up"!
I stiil say that it still astonishes me that so many DO NOT UNDERSTAND THIS SIMPLE PROBLEM/CONCEPT....as even I understood it!!! WOW!
#194
06/17/2010 7:53 PM
I'd put my crew members in the water telling them, kick baby! kick!
Reply Score 2 for Off Topic
#195
06/21/2010 9:47 AM
It seems to me that tacking is the correct way to approach this problem.
Without going into the math and all, when your boat presents a wider (longer) surface for the current to act upon, it is going to increase your speed slightly, thereby putting you ahead of your opponent at the finish line.
Ken Leigh
#196
06/21/2010 2:37 PM
One thing I find most interesting is not everyone reads the full question. Many have wind as part of the logic when in the question it states there is no wind. Also it says the race is down stream, several posts indicated going up stream. Just food for thought.
In reply to #196
06/21/2010 2:58 PM
One thing I find most interesting is not everyone reads the full answers before critiquing them. Many have wind as part of the logic because there is wind, relative to the water. Also it says the race is down stream, several posts indicated going upwind (i.e., downstream). Just food for thought.
#199
In reply to #197
06/21/2010 6:03 PM
yes going down steam creating a 5 klm head wind on your sail, I don't mean to be a smart ass but as you say some people don't or can't grasp the whole picture pls think ?
#198
In reply to #196
06/21/2010 6:00 PM
Stop taking the pills and concentrate on the problem fully, that may help you further.......but I doubt it somehow....
#200
In reply to #196
06/21/2010 6:45 PM
Well, at least your sentence structure is pretty good.
#201
06/22/2010 11:34 AM
Perhaps a point of clarification that may help those that insist that the apparent wind cannot move you down wind any faster than the current:
The sail of a modern sailboat doesn't merely redirect the force of the air into a benificial direction. It is also an airfoil, much like an airplane wing, that creates its own lift force. I.e. air moves faster over the fore face than it does over the aft face, creating a pressure differential which develops lift.
Therefore, by trimming your sails properly, you can get a large percentage of the availabe energy turned into the desired direction of travel, even when sailing into the wind (of course not directly upwind because your sail luffs and you lose the airfoil shape.)
In this way, the apparent wind is useful for sailing, even if there is "no actual wind."
In reply to #201
06/24/2010 7:35 PM
consider the adiabatic process, and the time of day.
#202
06/22/2010 1:02 PM
Ok not an engineer or physicist, but a sailor. By drifting, the boat will eventually reach 5km/hr. At this speed the boat has no way on (speed relative to the current)and thus cannot steer (ie. tack). Prior to reaching that speed, the boat speed will not exceed the speed of the river either. The winenr will be the most aerodynamically streamlined boat in a little over 2 hrs. The displacement of the boat will be a factor as well (length of time to accelerate to current speed)
In reply to #202
06/22/2010 1:26 PM
Oops.
Now we are getting WAY out there in magic land. Neither the displacement nor the orientation have anything to do with it! Except as regard the orientation of the vessel and its sails in the effective wind.
Plus, if there is any wind; real, apparent, or otherwise, there will be relative movement between the vessel and the water, which will allow the rudder to perform its intended duty. Therefore, the boat that is sailing (rather than just floundering) absolutely will cross the finish line first.
Think of it another way -- consider the boat trying to sail UPRIVER. Here the sail definitely affects the response of the vessel because it reacts to the apparent wind, providing resistance to the downstream motion of the vessel. Therefore, why should the sail not affect the response of the vessel sailing down river?
#208
In reply to #202
06/22/2010 6:16 PM
Complete and utter twaddle.....
#217
In reply to #202
06/23/2010 1:30 AM
Evidentally you have not sailed in a current or in a river. There are also pilots who have no clear concept of how a plane flies, so you needn't feel bad.
United States - US - Statue of Liberty - Who is John Galt?
06/22/2010 1:25 PM
Over 200 posts, I'm amazed how many folks voted for the drifters even though they acknowledged that there are "effects" of moving through still air.
I think the puzzle would be more interesting if there was another race for powerboats going upstream at the same time, *and* if the question was how far the hawk would travel if it was chasing pigeons from sailboat to powerboat back and forth until the race ended... Then we'd have the infinite series dilemna to confound and create even more humorous responses :^)
I'd've written a shorter post, but I didn't have the time.
#205
06/22/2010 2:44 PM
I assume that since there is no wind on land there would be no wind on the river. Your speed whether tacking or going straight down river would 5 km/hr, the same as the current. Therefore a tie, with a total time of 2 hours.
In reply to #205
06/22/2010 2:48 PM
I give up.
In reply to #206
06/22/2010 3:08 PM
Wow, I don't blame you FJD. For all of you doubters of apparent wind: Picture this: it is a still day (no wind); you get on your bicycle and pedal in a straight line at 5 km/hour; do you feel the wind on your face?; what is the velocity of this apparent wind?; 5 km/hour.
#209
In reply to #205
06/22/2010 6:18 PM
Clueless twaddle.
#210
In reply to #205
06/22/2010 6:48 PM
you create the wind by drifting down stream ! do most of you just like to type on the pc or are you realy as ?? as you sound (without problem solveing skills )??? I thought this was a place for engineer's . Oh well ! I find it hard to remain in these discusions as so many ( with a few exceptions ) do not seam to let logic enter their minds ,maybe these are very young people ?
In reply to #210
06/22/2010 7:19 PM
Marjer,, it is hard to believe that these people have never had the wits to notice that when walking in still air there is an "apparent" wind on ones face,, and then extrapolate that one simple, stunningly obvious fact to this problem...
In reply to #212
06/23/2010 7:36 AM
You are dead right, even "simple" facts are not understood by them.....
In reply to #210
06/23/2010 7:35 AM
I agree with you entirely!
You wrote:-
"maybe these are very young people ?"....or very stupid......or Wankers or all three!!!
You do not have to understand simple physics, but if you can't, then they should not post here to my mind...." but it makes the rest of us look REALLY clever", so maybe we need them as a sort of "contrast"?
Most of the true idiots post only as guest anyway, then that indicates to me that they really know that they are not good at simple math and/or physics!!!! and they are CERTAINLY not Engineers of ANY discipline!!!!
I just wonder how they get their "kicks" other than posting here and being told that they are below par!!!! What a life!!
In reply to #205
06/23/2010 2:48 AM
When you stick your hand out of a car window the wind you feel is called "apparent wind". An airplane flies only on an apparent wind, not on "true wind" which is wind measured relative to the ground. The most basic and critical gauge in an airplane is the airspeed indicator, which measures only the apparent wind aligned with the airplane's fuselage.
If the true wind is from the north and an airplane is flying to the west, there is no wind blowing against the side of the airplane... (in other words, a tell tale mounted in front of the windshield would stream straight back.) The entire mass of air in which the airplane is flying (for miles around the airplane) is moving. (The airplane's wings could care less about this true wind movement.) When a plane flying in a true wind of 50 knots from the north is flying south, its ground speed is 50 knots higher than its airspeed. When it is flying to the north, its ground speed is 50 knots less than its airspeed. The lift and drag on the wings and fuselage is exactly the same in both cases. The plane only "feels" and operates on apparent wind.
The sail of a sailboat works as an airfoil when the boat goes upwind at an angle of about 45 degrees with the wind. The "lift" (which is now directed horizontally (because the "wing" has been stood on end) pulls the boat in a direction that is partly forward and partly to the side. The side force is countered by the keel (which also works like and airplane wing) but the forward force causes the boat to move forward.
So your assumption is correct that the wind over the river is stationary relative to the land. But is is not stationary relative to the water and relative to a boat drifting in that water. The drifting of the boat causes the boat to feel an apparent wind that makes it appear (to the boat's sails and anyone on the boat) that the wind is blowing up the river (just as the wind against your hand in the car appears to be coming from a point in front of the car.) Just as you can tow a glider with a car to launch it, (giving its wings the apparent wind they need to fly) the river pushes the boat, giving its sails the apparent wind they need to "fly".
#215
06/22/2010 11:58 PM
The fastest cataraman I've ever sailed alone was a NACRA 18, a single class boat that reliably could sail to windward at 27 knots in a 15 knot wind, or 1.8 times faster than the wind.
Assuming optimum tack is at 45 degrees, the distance it would have to travel relative to the drifting boat would be 1.43 times farther than the boat drifting, regardless of how many times it tacked.
This would give it an advantage of .37 mph down river over the drifting boat.
#223
06/23/2010 4:09 AM
I win the race. My opponents are just floating down the river, so their max speed will be 5 km/h. In the other hand I have an apparent wind of 5 km/h to start with. If I use it to maximize my sail power, I will make a little more speed than my opponents.
But this is with "all equal" conditions. In a real situation we have to consider in which part of the river they are floating, weather it is in the middle or closer to shore, type of boats we are using and so on.
As for the winning time... just under 2 hours.
#232
06/23/2010 10:49 AM
I'm not actually a sail type person, but fluid dynamics wins. The first boat sitting in the middle with the pointy end downstream is going to be dead last. Turn it 90 degrees and see what happens.
#233
06/23/2010 12:45 PM
Considering a middle of the range dinghy
Tacking Option - Max boat speed say 4km/hr at 45 deg to apparent wind: velocity made good = 2.8 km/hr: so for total of 10 km = 3.57 hrs
Drifting Option - Minimise your windage, point down current, say 4 km/hr achieved, given air resistance on rig and minimal hull hydro resitance: so for total of 10 km = 2.5 hrs
Now this is a race, so my 3rd option is to tighten & cleat the sheets, capsize the dinghy, and point it across the river. We now have min air resistance, max hydro resistance (via the sails acting as sea anchors), so we will achieve a speed of say 4.8 km/hr: so for a total of 10 km = 2.08 hrs
So the answer is Option #3 !!!!
In reply to #233
06/23/2010 12:52 PM
You are making a mistake when changing reference frames: see post #143 for explanation.
hugomad
#236
In reply to #234
06/23/2010 1:11 PM
No, I'm not buddy...
If the boat is static relative to the water - then there is a 5Km/hr relative breeze upstream ( and the opposite, if the boat is static relative to the air, then there is a pure 5 km/hr current downstream) .
The boat will find an equilibrium vector where the aero force(aka drag) = the hydro force (aka drag). Due to density difference between air and water, that equilibrium vector will be such that the boat's frame of reference will be nearer to static relative to the water endof that spectrum, than to the static relative to the 5 km/hr wind end.
What's more if you are a sailor, you will know this is true.
I stand by my argument...
Geoff
In reply to #236
06/23/2010 1:17 PM
OK, that's true on the "water" frame of reference ... but the race is 10 km as measured between two points on the river bank (they usually are ...) so the speed you calculated relative to a body of moving water will have to be converted to "river bank speed" by adding the velocity of the flow to whatever speed you determine relative to the moving water ... basic frame of reference change maths! I stand by my argument ... :)
hugomad
In reply to #236
06/24/2010 6:49 AM
You are fully correct. GA.
In reply to #242
06/25/2010 12:46 AM
He is correct in everything except the part where he says he stands by his argument (which was presented in post 233). His argument there is not correct, putting the drifters ahead of the sailors.
Some of these people have the bow wave forming at the stern of the boat.
In reply to #254
06/25/2010 4:56 AM
I thought I understood it correctly, now you make me unsure, but thanks anyway....
Reply to Blog Entry Page 3 of 5: « First < Prev 1 2 3 4 5 Next > Last »
129CBRider (3); Amos (1); Andy Germany (51); Anonymous Hero (4); Anonymous Poster (76); ARMY-MARS-GUY (1); Aviator (6); baxterm (21); bdbwoods (1); BWW (6); ca1ic0cat (1); charsley99 (1); Codemaster (1); conchwood (1); Concrete Universe (1); damummert (14); davidforbes (4); dvmdsc (3); English Rose (2); ergoargo (1); ExPat (10); FJDomingues (28); GeoffJohns (2); grumpygreybeard (3); Happy Fish (1); HarryBurt (1); hugomad (14); JRW (1); jt (3); Kenneth Leigh (1); kevinm (3); Marjer2 (5); MoronicBumble (36); munch (23); ozzb (1); passingtongreen (14); phph001 (6); Randall (13); robert.c.allen (4); seagull (1); seanhome (1); SuperVinnie (1); tick-tock (1); TimKI (1); Tornado (2); traneengineer (1); Trevor Walden (1); trunner (9); Usbport (1); vagabond (2); wangito (2); WilhelmHKoen (7); Zadok (1); zorvis (2)
