Previous in Blog: Funny Drag: Newsletter Challenge (05/04/10)   Next in Blog: Helium Balloon: Newsletter Challenge (07/06/10)
Page 4 of 5: « First < Prev 2 3 4 5 Next > Last »
Sailing: Newsletter Challenge (06/01/10)
Posted May 30, 2010 5:01 PM
User-tagged by 1 user
You are in a sailing race on a very wide river. On land there is no wind; it is a dead calm. The race is 10 Km downstream, and the river is running 5 Km/ hr. Your opponents decide that to make the best time, they will streamline their boats to the wind and float downstream as fast as they can. You decide on a tacking strategy, sailing back and forth across the river's width. Who wins the race? What is the winning time?
And the Answer is...
ou win the race, because you are sailing upwind. The winning time is: less than the time your opponents took.
When you all cast off you all feel a wind (a perceived wind) in your face as you float downstream. The wind is really the still air, relative to the shore, that you are moving past.
Relative to the river, in which you float, the wind is in your face, and all modern sailboats can sail into the wind--that is, tacking back and forth, up wind. Your path will be much longer than your opponents', but your downstream time will be faster.
Your opponents' maximum speed into the wind, and as measured by the land, will never be faster than the 5 KM/H current. Your speed will be faster by the speed you are able to sail upwind.
In reply to #257
Find in discussion
Re: Sailing: Newsletter Challenge (06/01/10)
06/25/2010 12:53 PM
I'm sure you understand the situation correctly. It is his first post that you may have missed.
His first post (#233), is completely wrong. His VMG through the water is correct, given a 4 km/h boat speed through the water: 2.8 km/h VMG with respect to the water. What he fails to do is add that figure to the water speed to get the speed relative to the ground. So his time of 3.57 hours for sailing is completely wrong. Given his figures, it should be 10/7.8 = 1.28 hrs.
His drifting option is almost correct. However, in practice a dinghy "streamlined" for drifting downstream against an apparent wind would have the pointy end facing downstream (upwind), and the flattish stern facing upstream (downwind). The sails would be lowered. The apparent wind would have little to act against, but the dinghy hull would be stuck in water (water having 800 times the density of air, and substantial viscosity). Under this condition, the skipper may have a hard time maintaining head-to-wind condition, but I'd guess the sternway would be closer to .2 or .3 km/h, relative to water speed. But otherwise he's just about right... the drifting time would be a somewhat more than 2 hours.
His third option, which he thinks is fastest, is actually slowest. Let's assume that he did not turn turtle and get his mast stuck in the mud at the bottom of the river. With the dinghy capsized and perpendicular to the apparent wind, it would get blown upriver with respect to the water. (If the bottom is facing downriver, the wind's force on the dinghy's bottom would cause the dinghy to turtle. This is why dinghy sailors who have failed to jump on the centerboard immediately upon capsize, must then try to float the mast tip (e.g. with a spare PFD) and must get the mast tip pointed into the wind, so that the windage on the hull helps (rather than hinders) righting the boat.*
With the 5 km/h apparent wind up the river, one could also sail up the river, but at a speed much less (through the water) than the speed of the current relative to the ground. (I used to have a spinnaker rated for a maximum apparent windspeed of 5 knots [9.3 km/h] which would fill adequately in this wind, of around 5km/h at the instant of spinnaker hoisting.) A capsized dinghy will be sailing up river, if turtling is prevented. With its hull acting as a spinnaker, it might make 1 km/h upriver relative to the water, for a ground speed of 4 km/h down river. That makes this alternative the slowest option, not the fastest. 10/4 = 2.5 hours. Realistically, however, it is very hard to keep a dinghy from turtling... so this option, combined with the skipper's apparent inability to sail, could result in hours in the water. (In practice, the skipper, boat and any crew would be aided by a motor boat, and the chagrined skipper would drive to the finish line [perhaps the first one to get there... but not by boat, so it wouldn't count] to hear his friends' chortles.)
*Watching new dinghy sailors can be good entertainment. Invariably, they forget that they had cleated the mainsheet before the capsize, making getting the boat upright a real challenge, with the sail full of water and fighting you all the way. Then just as it comes up, after lots of struggle, the boat gets blown right over again, because the sheet is still cleated, and there is nobody in the boat to stabilize it.
BTW,if you're going to capsize, you might as well do it with some drama. These guys are all competing in the Moth Worlds -- so they are not new to sailing. You can imagine how tricky these boats are to sail.
Another good sailing video -- this one with very high video production standards.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
In reply to #261
06/27/2010 4:56 PM
depending on the time of day, does the river at it's mass and speed, drag the air above it down stream with it, or because of temp. differential,and expanding air, can the air move upstream? Consider that in a wide river there is allot of "leverage" passing one point at 5 km/hr. "ON LAND there is no wind, it is dead calm"
In reply to #270
06/27/2010 6:41 PM
Craig! For crying out loud, it's a simple thought problem,,, don't complicate it. Do you know what a free body diagram is? If so you'd be the nerd that asked what the friction of the pulley is,,
I give up,,, no more
In reply to #270
06/28/2010 1:10 PM
Yes, of course. The effect is so small as to not be worthy of consideration for this problem.
No, not in any reasonable sense. A very large river will have slight sea breezes and land breezes roughly perpendicular to the river's flow.
Neither phenomena has any effect on the outcome of the problem. The sailors win.
In reply to #274
06/28/2010 1:41 PM
Right on!!!
As rediculous as some of the comments are, I am beginning to enjoy this blog again, just reading the appropriate sailing reponses to see how many ride-um out floaters are still not covinced. They must surely be hard-headed engineers, as I are one, myself.
Little about much, much about little
In reply to #275
06/28/2010 3:49 PM
"Hard-headed", well that's being polite I guess...
In reply to #274
06/28/2010 7:19 PM
"You are in a sailing race......." "YOUR opponents decide to float".... "YOU decide to tack".....
thank you for your answers. I also think the sailors win. (me,myself,&I).
#235
In reply to #233
Find in discussion
06/23/2010 1:06 PM
I think you missed my point. This problem is just not that complicated. IF there were wind involved, I'd go with the tacking solution. However - to cut, as it were, straight to the heart of the matter, chop off the masts. Orient one boat 0 degrees to the current (the ones who chose to occupy the middle of the road), and the other at 90 degrees (they who chose to tack). The one with the most hull cross-section is the one who also has the most force generated, and ends up traveling at close to the same speed as the water. The other boat, the zero degree people, will drift quite a bit slower at first, eventually reaching some fraction of the current speed.
In reply to #235
06/23/2010 1:19 PM
But there IS wind ... that is if you go with the common definition of wind as being air in motion. The thing is that if you choose to stick to the static "earth" referential you then have to speak in terms of relative wind as being air in relative motion to an object. There are plenty of posters that explain this better than me, just read a bit of the thread ...
hugomad
#239
In reply to #238
06/23/2010 1:46 PM
  • But there IS wind ... that is if you go with the common definition of wind as being air in motion. The thing is that if you choose to stick to the static "earth" referential you then have to speak in terms of relative wind as being air in relative motion to an object. There are plenty of posters that explain this better than me, just read a bit of the thread ...
...AAAAnnd, it's immaterial. The crew fiddling with ropes is gonna win by virtue of a slight distance gain plus the [greater] hydraulic advantage. This is a word problem, not a math problem. It might help to draw a picture and know what tacking means, but it mostly boils down to relative vector magnitude between the two contestants.
#278
In reply to #235
06/28/2010 5:46 PM
unbelievable????? get with the program !!!!!!!!!!!!!!!
In reply to #233
Find in discussion
06/24/2010 6:47 AM
Do please NOT forget that the tacking boat AND the one that just floats BOTH have a basic speed of 5 MPH from the river flow......so even if the sailing brought no speed gain, they would arrive together.......
But a good sailor would be able to increase his speed made good to actually win the race.
A really, really bad one maybe not.....
Where/what are these "Options" you mentioned and did not mark as options?
#276
In reply to #241
06/28/2010 2:10 PM
  • Do please NOT forget that the tacking boat AND the one that just floats BOTH have a basic speed of 5 MPH from the river flow......so even if the sailing brought no speed gain, they would arrive together.......
Umm, no. I wanted to minimize characteristics of sailing vessels in particular in this, but there is one thing that needs pointed out. Hulls are designed for and to drag numbers. It will take a measurable amount of time for the floaters to reach their final velocity, which will be close to, but not equal to, the river current. I do not know what that time will be, but I do know that it will be much longer than the other hull oriented 90 degrees to the flow. One of my base assumptions is that the sailors in said 90 degree craft also know enough to keep it from capsizing. I don't know how much steering control they have, but they can even probably zig zag across if they like. And throw raspberries at the other crew.
I can't believe this thread is generating this much static.
In reply to #233
Find in discussion
06/25/2010 1:22 AM
what sailor would capsize his boat?
In reply to #256
06/25/2010 12:57 PM
These ones.
#279
In reply to #256
06/28/2010 6:37 PM
  • what sailor would capsize his boat?
Judging by some of these entries, I'd say engineers who are not sailors. I am not a sailor. I do remember floating sideways in a canoe and saying - "watch out for that" right before I got dunked.
Sideways to a fluid flow with an unstable hydraulic foil and no sustaining counterforce (rudder control or wind) will eventually re-orient the craft to the most stable or lowest energy configuration. Some sail will help. A boat with a tapered or curved hull is a hydraulic foil. Of course so is a flat board. The flat is stable, the hull is only stable when it has proper forces applied at control points. It does have a neutral zone though.
This is the type of quiz question we had every day in dynamics, right before we got handed the day's 10 problems for homework.
In reply to #279
06/29/2010 3:19 AM
You are bogging yourself down in unimportant (to the original post anyway) details.....
Take a large step backwards and look at the big picture, I think you then have a good chance of seeing a proper solution......
Most of the guest posts (lets say all for safety!) are completely wrong.
This is a good tip.Study the posts that come from logged on members only. They are not all correct, but the percentage of correct to incorrect is very high!!
06/24/2010 11:10 AM
Never in the history of blog has such a simple concept been explained in so many ways and still not got through to so many.
Trust me people, the active sailing boat will win. By how much we can't say because we know so little about the boats, but unless it's being crewed by some of the confused land lubbers above the sailors should be in the bar first.
Growing old is inevitable, growing up is optional
Reply Good Answer (Score 6)
In reply to #244
06/24/2010 11:16 AM
In reply to #244
06/24/2010 12:49 PM
Like it. Also GA from me!!!
06/24/2010 3:31 PM
the floaters win it takes 2hrs tacking takes longer as the wind resistance of the sail will slow them down slightly. There will be not wind power advantage as there is no wind blowing.
seanhome
Reply Score 2 for Off Topic
In reply to #247
06/24/2010 5:16 PM
Again, I give up -- for good this time, perhaps.
In reply to #248
06/24/2010 5:45 PM
I know, its very sad, but please stay with us, PLEASE?
In reply to #247
06/24/2010 5:44 PM
Wrong, wrong, wrong and yes WRONG!!
You are no SAILor!!
But compliment, you did use your CR4 avatar....thanks!!
In reply to #247
06/25/2010 7:33 AM
Enough. Look up "lift" or sailing theory. If sailing slowed you down, the Europeans would never have reached the Americas. Now I give up.
In reply to #258
06/25/2010 7:51 AM
LOL!!
06/25/2010 1:56 PM
I/We tried but still ................................
I think I may go for a sail down river. The theoreticians won't be able to get me there.
A thought....maybe just maybe they are winding us up......I do hope so if only for the future of techy land.
#264
06/25/2010 3:39 PM
At what point across the river was the 5Km/hr measurement made.
This rate would not be equal throughout its entire width.
Friction, viscosity considerations at point where river meets land!
In reply to #264
06/25/2010 5:09 PM
You've GOT to be kidding me!!
Assume infinite width, since it was not specified, idiot.
Anything not specified should always be assumed to be either zero or infinity, depending upon how it effects the problem. Why try to confuse and complicate the basic issue?
#266
In reply to #264
06/25/2010 5:24 PM
You have a good understanding of the incredibly obvious.
In reply to #264
06/25/2010 8:12 PM
You're one of those guys that was always putting his hand up in exam hall and asking the invigilator to "clarify" the question aren't you??
#268
06/26/2010 10:59 AM
If this is a sailing race with all the rules of sailing in place, it would be canceled due to lack of sailors. If i am the only one sailing and 99 others drifting there is no race
#269
06/26/2010 12:47 PM
Apparently my first answer to this problem got lost in cyberspace as I do not see it anywhere.
After having read most of the arguments for and against "tacking," I stand by my first explanation that the "tacker" will win. No, there is no breeze to help the tacking, but that was never a consideration in the first place. Perhaps a better word to use would have been "steering."
The answer lies in the amount of boat surface that is presented to the current. Going head on offers the least surface for the current to push against, whereas by turning the boat slightly (tacking)(steering), more surface is presented to the current thereby gaining a slight advantage over the head on approach and resulting in a slightly better time than the alternative.
At least this has been my experience in the past when I was still able to get out of this stupid wheelchair and hospital bed to enjoy those things that I used to take for granted. Take my advice gentlemen and avoid old age. Wisdom gained doesn't count for much when you are unable to take full advantage of it!
Of course, old age beats no age!
Ken Leigh
Ken
In reply to #269
06/27/2010 7:59 PM
Again, you are relying on black magic rather the natural laws of physics.
From where is the lateral thrust for your rudder coming??? With zero water current relative to the rudder, you have absolutely no rudder control over the heading of the boat!!!
In order to achieve that relative motion, you MUST rely on the relative wind to create that motion relative to the water (Read my Comment #240, as well as many others too numerous to list right now). Now, you have control over your boat, and you win. However, in so doing, you have used the wind. Now, (in my opinion) that is sailing.
In reply to #272
06/28/2010 11:50 AM
RIGHT ON BROTHER!!!
06/28/2010 7:59 PM
Thank you guys,,,,,,,(Jorrie,MoronicBumble,Blink, Mareng, Switchman, Tippycanoe, Amichelen) among others..... reading back to aug. 06, we only have to win by an inch but we win this brain teaser.
#285
06/29/2010 10:09 AM
You will win because the current will carry you faster especially with your centerboard down but your keel and hull alone presents more surface area as you tack back and forth across the current than if you stay in line with the current and therefore will allow the current to carry you faster downcurrent. The closer to the center of the stream usually the faster the current will flow as well.The water causes more friction with the larger side presentation
In reply to #285
06/29/2010 10:14 AM
This is an infinitely wide river (not simple stream)! Therefore, there is no edge. Hence, no edge effects. Don't complicate the un-complicated. KISS -- Keep It Simple and Stupid.
#291
06/29/2010 2:15 PM
Why not put a windmill on the boat, capture the 5mph wind generated by the river current and power an electric motor?
Reply Off Topic (Score 4)
Good Answers: 114
#292
In reply to #291
06/29/2010 3:33 PM
Because it has nothing to do with the challenge.
06/29/2010 5:51 PM
I change my mind about sailing/tackin...stow sails, secure tiller centered, tie the bow line around my waist, dive in and breaststroke to victory!
Time 1 hour 20 minutes.
Good Answers: 114
#294
In reply to #293
06/29/2010 7:58 PM
Are you an Olympic champion? you will have swum for two hours @ 1.67km/h, towing a boat that now had more freeboard (wind resistance area) because you were overboard.
#295
06/30/2010 12:43 AM
The one who sails, tacks will win. On land there is no wind. When following a current at 5km/hr there is a relative wind. The sailer must sail into the wind. like one would do on a lake.
Consider if they were on a lake, the one who trimmed goes nowhere. The one who tacks makes progress. In this case the lake is moving.
Thanks,
#299
In reply to #295
06/30/2010 8:43 AM
I have read many (although by no means all) of the posts on this thread, and I'm afraid I come (at the moment) to the conclusion that it is not possible to use the apparent wind to increase the sailboat's speed relative to the bank. I think it was mentioned earlier, but an increase in speed means an increase in kinetic energy. This means that energy has been transferred to the boat from somewhere else. The only potential sources of energy in this case are the water and the air, however the air is not moving (regardless of which reference frame you use - if you change the frame then it is the frame that is moving, not the air) and therefore has no energy to impart. Therefore the air cannot possibly speed the boat up. Two illustrations that have at least convinced me: 1) The apparent headwind that the boat experiences is equal to its speed (NOT the speed of the water). This means that if the boat speeds up, the speed of the apparent wind also increases. This would presumably mean that the boat could speed up a bit more, further increasing the "windspeed"... to what limit? Surely an infinitely wide river would result in infinite speed? 2) If hypothetically the boat is able to move faster than the river by tacking, this means that the water is no longer powering the boat (it will be causing drag at this point). So where is the power to resist this drag coming from? The apparent wind? And what causes the apparent wind? The movement of the boat! So the movement of the boat is powered by... the movement of the boat. This is perpetual motion is it not? My apologies if this has been covered in any of the middle posts that I skipped!
In reply to #299
06/30/2010 9:41 AM
No apologies needed, we are quite used to such ideas as several other guests made the same stupid comments.....
Ask yourself the question:-
How does an aircraft carrier help its aircraft take off?
By steaming into any wind available at a preset speed to get an "apparent wind" flowing over the flight deck and the aircraft on the flight deck.
Does this work when there is no wind movement at all?
OF COURSE IT DOES!!!!
Apparent wind is what ALL aircraft fly with.......
Apparent wind is what all sailing boats use.......
Fast boats make the apparent wind, even on a broad reach, appear to move to be "more inline" with the course.
Apparent wind (on fast sailboats) can actually cause the sail (jib) to luff on its front edge....
Many forget that a sailboat actually uses the same/similar laws of aeronautics that keep planes in the air!!!!
Apparent wind is what you feel when in a car and you stick your hand out of the window! You will notice just how strong it can be!!!!
Make yourself clever, read the following website fully through, it will significantly improve your knowledge on this subject!! (You and all the other guests!!!)
http://en.wikipedia.org/wiki/Apparent_wind
I would just like to quote one BEAUTIFUL sentence from the website:-
Windsurfers and certain types of boats are able to sail faster than the true wind. These include fast multi-hulls and some planing mono-hulls. Ice-sailors and land-sailors also usually fall into this category, because of their relatively low amount of drag or friction.
This link provides even more general sailing information:-
http://en.wikipedia.org/wiki/Sailing#Reducing_sail
#307
In reply to #300
06/30/2010 12:28 PM
"Apparent wind is what ALL aircraft fly with......." Aircraft use apparent wind to direct the thrust produced by the engine, they do not use it to increase their speed relative to the ground - only the engine can do that .. take away the jet engine, the plane falls out of the sky. Take away the thrust from the river (by sailing faster the the water is flowing) and the same will happen.
In reply to #307
06/30/2010 4:09 PM
Reading about sailplanes might help you understand both flying and sailing. Also look into DDWFTTW. A low resistance sailing craft can sail directly downwind at greater than wind speed.
#316
In reply to #300
07/01/2010 12:37 AM
There is a tiny difference between this boat and a palne - the plane is driven by a propellant or jet-turbine (not tour biene) and is (nearly) independent from the environment.
Our Boat is drifting on the water and is undriven or driven by the wind that creates the boat itself by its movement on/in the water.
the blowing drive wind is a force for driving the boat - who much this force is depends on the sails and the trimming of the sails, the course of the boat and maybe many other things (is the sailor drunken?).
In reply to #316
07/01/2010 6:04 AM
What about sailplanes or gliders as they are called.....how can they fly all over, some have remained up to 12 or more hours in the air...
Please explain how this type of aircraft (Caproni Vizzola) manages to have several world records in distance and speed circuit flying??? It will be very interesting to hear you describe how it would not be possible!!!
Look here.
http://en.wikipedia.org/wiki/Caproni_Vizzola_Calif
By the way, it makes NO difference as to whether the wing is vertical (sail) or horizontal, laminar flow laws are the same for both!!! Any engineer will understand that without needing to be told!!!
In reply to #318
07/01/2010 10:52 AM
the reason sailplanes,sailboats,iceboats,etc. do so well, is a mater of competence, and design. The pilot/sailor (s), are so good about keeping their ship in perfect trim, 24/7. The new designs are pretty sophisticated .
In reply to #299
06/30/2010 9:45 AM
re read the comments by sailors to find out who would win. in this case as i have said before there is only 1 sailor in this race.
In reply to #299
06/30/2010 10:58 AM
1) The apparent headwind that the boat experiences is equal to its speed (NOT the speed of the water). This means that if the boat speeds up, the speed of the apparent wind also increases. This would presumably mean that the boat could speed up a bit more, further increasing the "windspeed"... to what limit? Surely an infinitely wide river would result in infinite speed.
You are almost correct. The apparent wind speed is the vector sum of the boat speed and the "true" windspeed. (In this case the "true" wind speed is actually the induced wind speed.) As the boat speed increases, the apparent wind moves closer to the bow (so that if the boat is sailing a course 45 degrees off the centerline of the river, the apparent wind is apt to be 30 degrees off the bow, in a typical slowish sailboat). (In very fast boats, the angle is much less.) Lift increases with the square of speed (supporting your perpetual motion theory) but hydrodynamic drag increases even more quickly, and the vector angle of the lift force gets less effective with smaller apparent wind angles. So an equilibrium is reached.
In many boats, "hull speed" has a crippling effect on speed, so the the equilibrium speed is reached at hull speed. But in fast wet water boats, boat speed can be twice (true) windspeed when sailing upwind. In fast hard water boats, it can be 8 times windspeed.
The best way to understand what goes on is to sketch up the vector diagrams, and plug in some realistic drag figures into a spreadsheet, and see if the boat can continue to accelerate at several trial speeds.
All sailboats generate their own wind, but it is common to hear that fast boats (windsurfers, ice boats, some racing classes) make their own wind -- because the effect is more obvious. Sailplanes also make their own wind -- with their best speed being 60 or 70 knots.
Using actual figures from a windsurfer, you can calculate the forward thrust vector from lift force at (for example) 5 knots boat speed and 10 knots wind speed. Assuming the true wind is from abeam, the lift vector direction will be favorable, and the boat will accelerate. When the boat gets to 20 knots, the vector direction is much less favorable, but the force is 4 times as great. Hydrodynamic drag (in the planing mode) will have increased by less that twice. Aerodynamic drag (much from the sailor herself, and quite a bit induced by the sail) will have increased at roughly the square of the apparent wind speed, and will be well-aligned to help prevent the boat from accelerating.
Whether a boat sails in seemingly still water and moving air, or seemingly still air and moving water makes no difference. All that is required is a difference in the vectors. (If the wind is blowing in the same direction and speed as the current, then sailing is not possible.) In both cases, the air gets stirred up by the sail, and the water gets stirred up by the centerboard.
Reply Good Answer (Score 4)
Good Answers: 114
#304
In reply to #302
06/30/2010 11:34 AM
Thank you! For me, that is the clearest explanation so far. GA.
I had some understanding but mainly hung my hat on the assurance, from others, that a sail boat make progress against the wind by tacking diagonally across it. Now for the pencil and paper and the calculator and some simplified efforts.
#306
In reply to #302
06/30/2010 12:22 PM
I'm not sure that's right - an equilibrium is reached for any given wind speed, but the wind speed will be continuously increasing, which means that the boat will continue to accelerate (although the rate of acceleration will decrease as speed gets higher due to the effect of drag that you mention). Unless you are saying that a point will be reached where the boat will not go any faster even if the wind speed increases?
In reply to #306
06/30/2010 1:15 PM
That's essentially what I am saying, if by wind speed, you mean apparent wind speed. The shape of the drag curve varies with the hull type. In a displacement hull, the drag goes up roughly with the cube of speed. In planing hulls, the drag increases similarly at low speeds, but then the curve flattens dramatically at high speeds, so that doubling speed results in less than double the drag.
In planing boats there is, therefore, a resistance "hump" in the drag curve. Sailors of boats that can plane (a small minority of sailboats in general) are very aware of this hump. Windsurfers, in marginal winds will "pump" the sail to get over this hump, and the the boat will suddenly accelerate, generating more lift as it goes. However, the drag on the sailor and anything above the water is increasing just as fast as lift, and the vector direction is becoming increasingly more effective is slowing the boat, while the lift vector direction is becoming increasingly less effective in accelerating the boat.
The top speed of a sailboat for a given true wind speed is that speed at which acceleration falls to 0.
#303
06/30/2010 11:06 AM
They win with 2 hours time. One has to stick with the centerline of the river where the speed of the stream is max. As there is no wind taking any action other than following the centerline will slow down the boat.
#308
In reply to #303
06/30/2010 12:58 PM
Total twaddle, but we expect that fron certain Guests......
There are here many well written and simpe to understand explanations as to why a boat sailing or reaching will increase its overal speed against a boat just drifting......
I am not going to waste my time further......
A horse must be lead to water, but it has to drink on its own.
Are you still thirsty?
07/01/2010 11:39 AM
They state that you have the option to sail, and most sailboats need at least 3mph (about 5K) relative hull speed in order to have stearage way, therefore; the tacking boat will travel at least 5K above the 5K current. Since they are tacking, this is not 100% towards the finish line. Assuming worst case (a gaff rig, not Marconi) we can assume they are tacking at 45 degrees to the straight line path, and not running down wind (since that would be jibing,) so relative progress is half of 5K= 2.5K+ the 5K current= 7.5K relative progress. This will put them across the line at 1 hour 20 minutes.
We will give the passive boat the benefit of the doubt and assume they are travelling backwards (to allow for maneuvering,) with a storm anchor deployed to create more drag (and also some crude maneuvering,) so they will be travelling the current speed minus drag, therefore will finish in more than two hours (assume 2hours 15 minutes)
The tacking boat wins in 1 hour 20 minutes, nearly an hour ahead of the passive, and now possibly quite inebreated competitors, giving them plenty of time to maneuver out of their way.
Good Answers: 114
#328
07/01/2010 7:33 PM
Great Flying Spaghetti Monsters people! once you start to catch up with the river, you can steer by using a small sail or piece of rigid board as a rudder in the air, before that, you could use an oar at the leading (downstream) edge of the boat, which ever it is at the time.
#339
07/02/2010 10:31 AM
I officially withdraw the idea of any hydraulic advantage, although I can still make a case for it. It had to be combined with tacking anyway.
My vote is for tacking, the selected multiplier is .37, and the finish time is approximately 1hr, 15min. I cannot calculate the tacking loss or efficiency - both are human factors. If that number approaches .5, then the time would be 1hr, 37min, which is putting it pretty darn close.
If you want to win, you have to work.
In reply to #339
07/02/2010 1:35 PM
I agree 100 percent. See my post #240, which may be a bit wordy.
However, I did assume a fairly efficient sailing rig. Your estimates probably are closer. Either way, we still have time to finish off a few beers before the floaters come in.
#360
07/13/2010 2:49 PM
Ok folks. We could get into discussions about center of lateral resistance and center of effort and lift til the cows come home but in the real world a boat will not sail or steer if the boat is drifting. This is called having "no way on". PLEASE go out in a boat and try this. I have been in these situations where the captain lost his cool and declared a steering casualty when in actuality, it was only due to loss of motion through the water. Once we got "under way" the boat steered perfectly well.
Good Answers: 114
#361
In reply to #360
07/13/2010 7:01 PM
In this case, you either move through the water or through the air or both. If you can't use one, you can use the other to steer.
#362
07/27/2010 11:31 AM
Still noodling over this one. Seems to me the tacking boat will be slower to reach the end because the energy creating the relative wind is actually coming from the river. Therefore the longer travel distance and the increase in drag from the sail will ultimately be a minus compared with the boat capturing the river's energy by drifting. We cannot get more energy out of a system than is there in the first place. All that tacking and sail in the wind has to be subtracted from the energy available to push the boat along. If there was real wind, there would be additional energy available and the sailing boat could win, but not under the conditions described.
In reply to #362
07/27/2010 12:01 PM
Wow! We still have non-believing non-convincible land lubbers amongst us!
Unbelievable!
In reply to #362
07/27/2010 12:36 PM
If you had read some of the excellent and correct answers before posting, you might not have posted.....
Imagine (as many have already said here) that you are on a lake with completely still water, but a 5 KMH wind in your face. That is exactly the same logical conditions.....and many weekend sailors on lakes around the world sail slowly but stately in such conditions.......
Think about it before answering!!
#367
In reply to #366
07/28/2010 12:54 PM
The still water lake with the 5KMH wind is NOT the same logical condition. That wind provides energy from a completely different source. The relative wind created on the river in still air comes from energy provided by the river. All of the energy in the race between the two boats is provided by the river. Please explain how sticking up a sail will produce anything besides additional drag in this situation. If the wind was created by some other source, energy could be extracted by tacking and thus added to the motive force provided by the river. Under the described conditions of the problem, there is no other energy source besides the river, therefore anything that increases drag will only slow the boat down. The streamlined boat wins, assuming identical hulls.
In reply to #367
07/28/2010 1:32 PM
How is the energy source relevant? Whether you hold a pinwheel up in a 5 kmh breeze or walk at 5 kmh in still air, your pinwheel will rotate at the same speed. It matters not a jot that the power source is the wind in one case and you in the other.
Now (as others have exhorted) apply that information to the dozens of excellent posts that explain the mechanics of sailing upwind (in this case, downstream).
#370
In reply to #368
07/28/2010 4:18 PM
The energy source is exactly what's relevant in this example. If you sat on a frictionless surface holding your pinwheel into the 5 kmh wind, would you move forward because the pinwheel is pulling you? The river is the only source of energy in the problem, the drifting boat is using almost all of it to go downstream. The boat with the sails is only creating drag, because there is no energy to be obtained from the relative wind. All the available energy is used creating the wind.
In reply to #370
07/28/2010 5:11 PM
Oh dear. Where to start?
First, I'm not sure where you're going with the frictionless surface analogy but, if you start stationary relative to the surface, then yes: the drag of the pinwheel will gradually accelerate you in the direction of the "wind"*, regardless of whether the air is moving or the frictionless surface is moving.
"The river is the only source of energy in the problem,"
Yes, if you insist on using the shore as your frame of reference, the river is the only power source, but it doesn't really matter.**
"the drifting boat is using almost all of it to go downstream."
No: it is hardly extracting any power from the water because it is moving with it and not slowing it down.
"The boat with the sails is only creating drag, because there is no energy to be obtained from the relative wind."
No: in this case, the sailing boat will be slowing down some of the water and will thus be able to extract useful power from it.
* I'm trying to avoid using the term "apparent wind;" some otherwise-correct posts have been using it to mean the wind relative to the moving water, whereas in conventional sailing terminology, it means the wind relative to the moving boat.
** An energy (or power) balance will indeed look different according to your frame of reference, but the differences will cancel to give the same net power available to the boat.
#374
In reply to #371
07/28/2010 6:04 PM
Thank you for your patience. Let's forget the pinwheel and frictionless surface stuff.
The river is indeed the only source of energy or power or motive force in this problem. And yes we must use the shore as a frame of reference because this is a race of 10 km as measured on the shore.
The drifting boat gets all of its motive force or forward motion from the river, at a rate very close to 5 kph, the rivers speed.
"The sailing boat is slowing down some of the water and will thus be able to extract useful power from it." I agree. It will be able to extract useful power from the tacking action in the water, but this will be less than the power used in drag by the sails. If this were not true, where does the additional energy come from?
In the real world, boats sail happily into the wind all over the world, but that is because they are able to extract real energy from the wind, which is actually a great mass of moving air and has a great deal of energy. In this problem, however, the air is stationary and has no available energy. Most replies seem to posit that the sailing boat is able to extract energy from this stationary air simply by moving through it. I think this motion through the air costs energy to the boat and will thus slow it down. The additional distance caused by diagonal travel only makes it worse.
What am I missing? Where does any additional energy come from?
In reply to #374
07/28/2010 6:20 PM
Entertain that the river is infinitely wide, so you cannot see the banks.
Now, you and your boat don't know what is causing the breeze in your face, but it is there. Now, you sail your boat into this wind and observe that your boat is, indeed, slicing through the water, indicating that you are moving relative to the water.
You don't even know the water is moving. Then, someone gives you a pair of glasses so you can see the banks out beyond infinity (really?).
Hey! Now you see that the water in the river is moving past the banks, but you are moving relative to the water in the same direction. Therefore, you are moving faster than the water in the river, relative to the banks.
Simple. Right?
#382
In reply to #376
07/29/2010 3:23 PM
Thank you for the entertaining word picture. It made it easy to get on board with this problem.
I think all you sailors are actually at a disadvantage here, being unable to separate what happens in the real world from the unreal constraints of this problem. All of you seem have assumed that the 5kph relative wind is a constant and always available. I think not. The relative wind speed is a function of the current pushing the boat MINUS the drag, some in the water, most of the drag from that wind. Any increase in drag immediately decreases the relative wind speed. Putting up the sails is rather a large increase in drag, slowing the boat noticeably. Tacking is a way to recover some of that loss, but it will never recover all of it because the increase in speed increases the drag. There is no energy available to add to the equation.
In the real world, there is almost never a situation where there is NO wind, and in any case, all such real winds are another source of energy, not a function of some wimpy current pushing the boat.
Under the constraints of the problem, I think the sails are a drag, and the streamlined boat crosses the finish line first.
In reply to #382
07/29/2010 4:02 PM
This is an idealized case (as physics problems always are) but it not so divorced from real-world sailing that it invalidates the responses of those of us in the reality based community.
There is nothing in your comments about drag that, if true, wouldn't apply to a boat in still water sailing into a headwind. Sailing does indeed create drag, but the point is that it is outweighed by lift, resulting in a net forward component for a boat sailing at 45 degrees to the wind. The net result is that the apparent wind speed increases.
I'm not sure why you're so convinced that a 5-kmh wind can provide the power to sail upwind, but a 5-kmh river current can't, but if you can't get past that, then you really do need to get over your hangup about the energy source and the frame of reference and accept that there is no difference between a 5-kmh wind over a lake and a 5-kmh current in still air.
Whatever you may believe, your fixation on the shore as the only valid frame of reference is quite arbitrary (though any other frame of reference does mean that the start and finish lines become moving targets). What if the whole setup was constructed in a vast spaceship traveling at 1000 km/sec? What reference frame do you use then? Why not Randall's example of a frame of reference that doesn't rotate about the Earth's axis? If you applied your logic and that frame of reference to wind turbines, our energy problems would be solved at a stroke by 1000-mph winds! Until, that is, you realized that the usable power does not depend on the velocity relative to some arbitrary frame of reference, it depends on the relative velocities of the components in your system.
#386
In reply to #384
07/29/2010 4:27 PM
The difference between the 5kph wind across the still lake and the 5kph river current is that the current MAKES the wind in that case. That relative wind is a result, derived by the current pushing the boat into still air. The relative wind diminishes as the drag of the sails dimishes the speed of the boat relative to the shore, the shore being the location of the start and finish lines. If paying attention to the constraints and conditions of the problem is a fixation, so be it.
In reply to #386
07/29/2010 5:41 PM
  1. See 385.
  2. You could easily reframe the problem to eliminate the shore and the start and finishing lines -- without changing the sailing mechanics at its core -- by stating that the river is flowing (say) northwards and simply asking which boat makes faster progress in a northward direction. If the river is wide enough that the sailors cannot see the shore, I challenge you to demonstrate how the velocity of the shore relative to the water will influence the boats.
  3. Again: see 385.
  4. You are using circular logic to state that the drag of the sail will slow the boat down therefore the apparent wind will be reduced; therefore the boat can't sail ...
    but it's all based on a false premise: the "lift" of the sail will move the boat forward in the water (well, with a forward component), increasing the apparent wind.
In reply to #384
07/30/2010 11:44 AM
GA from me for a really excellent post.
I still don't think that "HE" will either get it, understand it or even bother to read things that he disagrees with....eg. "He" is a hopeless case.....
As someone else pointed out before, I forget who, "you can lead a horse to water, but he must drink all on his own!"
This Guy is simply not thirsty....
Apologies to the person who first said that that here somewhere on the Blog, I just forgot who it was (senior moment!), but it was well put.
Joke.
Q. "Mrs Brown, where does your son get his thirst for knowledge?"
A. " The knowledge he gets from me, the thirst from his Father!"
In reply to #382
07/29/2010 4:18 PM
As long as the air is moving relative to the water: it does not make any difference which one it is that is still.
That is why several people have tried to get you to imagine situations in which you cannot tell whether it is a "river" in still air or a lake in a breeze.
Given that it's easy to construct these hypothetical scenarios in which it is impossible to distinguish between the two cases: it should be easy to extrapolate that the mechanics of sailing will be the same in both.
In reply to #374
07/28/2010 9:27 PM
Thanks for posting. While this point of view is indeed challenging, I personnaly believe it can be really interesting to question the easy or seemingly obvious answer. More often than not, we all gain a greater understanding and from time to time, we are all allowed to step back and realize that a misconception has been adopted. As much as I appreciate the multiple worthy developments provided by various members, we have also been witness to a few comments that demonstrated greater shooting abilities than actual reading skills.
In any case, I appreciated reading your posts, Thanks.
A pilot, glider pilot and sailor (yes, in heavy tidal region as well as on peacefull lakes :-)
In reply to #374
07/29/2010 2:26 AM
Its the energy from the apparent wind that will be used here by the sailing boat.
Apparent wind is for example the wind you feel when on a windless day, you get in your car and drive at 100MPH and then stick your hand out of the window. The "apparent" wind will buffet your hand, almost painfully, especially if you try holding the flat of your hand forwards. Now that is energy!!!
If you had a small windmill generator, it would tear round also generating some electricity - all on a "windless" day.......
If you got into a sailboat, on a lake with still water, but with a 5 KMH wind, that is EXACTLY the same conditions for the sailing (and the non sailing boat) as on the river.
No difference whatsoever.
Many weekend sailors sail across such still lakes, back and forth, with the power extracted from a 5KMH wind.
Depending upon the efficiency of the boat (but we can pick and chose any sailing boat we wish) you can sail at a minimum of 45° to the wind and make good in the direction of a point 20KM downstream (if I remember correctly)...
Remember also that the river can be infinitely wide and infinitely deep.....so even on one tack, you can sail from the start to the end....
Remember that some very modern/exotic boats, using the wind can actually sail and make good DIRECTLY INTO WIND!!
Remember, the sailing boat only has in fact to beat the non sailing boat, even 1" is a win! (This implies that every extra inch can be VERY important!!)
Here you can see a model proa, almost sailing directly into wind, note the direction of the waves :-
http://www.youtube.com/watch?v=Oq6ULIcNc9I
Here is another boat with a simple mechanical system, also sailing directly into wind:-
http://www.youtube.com/watch?v=Aw4F3Lk11As
In reply to #374
07/29/2010 3:34 AM
WHAT additional energy??? You are postulating there will be a need for additional energy ... In terms of energy here is a brief and simplified picture of what happens:
a) the boat with the sails down will match the current speed, so without a velocity gradient there is no viscous force acting on it's hull. No force means no work (no energy extracted from the current). This boat just extracts the initial energy from the current to get to 5kph and then just moves at constant speed as predicted by newton's laws of motion.
b) the tacking boat constantly extracts energy from the current, as the drag component of the forces acting on the sail must be balaced by a viscous force exerted by the water on the hull (perpendicular to the boat's motion). The lift component is responsible for moving the boat across the water.
it's very simple, actually, and you are partly right. Specifically you are right to say that on the frame of reference of your choosing the river is the only source of power, but you are wrong both in saying that the tacking boat doesn't extract any energy from the river and in saying that the drifting boat does. It's the other way around. The marvel of the laws of physics is that when correctly applied they hold true regardless of the referencial you use. If you come to two different solutions for the same problem just by chaging reference frames, you can rest assured that one or both of the solutions are wrong!
hugomad
#375
In reply to #371
07/28/2010 6:06 PM
A GA from me too...
But I don't think that he has the "where-with-all" to understand your, or any of the other good posts we have already had before Mr.Trunner chanced upon this blog......
Nor is he able to understand that he doesn't understand either! Sad!
He could read and learn, but has chosen not to (learn!). His choice, not ours.
"You can lead a horse to water, but he has to be able to drink all on his own!"
Some are not thirsty I guess pardner!!!
#373
In reply to #370
07/28/2010 6:00 PM
You would obviously like to try and prove the errors of thinking that Einstein made?
HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA
You really are amusing us today (again!)
I have not laughed so hard in several weeks (not since you last posted I think!!)
Good Answers: 114
#377
In reply to #370
07/28/2010 7:35 PM
Suppose that you wake up somewhere and you don't remember getting there. You find that it is a dark, cloudy moonless night, you feel that the object you are standing on is rocking slightly, you hear water gurgling, you feel a wind that you guess is 5MPH and you conclude that you are on a boat. You reach down and find that the water is not moving.
Are you:
  1. On a boat, anchored in still water, with a wind blowing?
  2. On a boat, floating free on moving water, through still or slow moving air?
  3. On a boat, floating free on moving water, with a following wind moving faster than the water?
In reply to #377
07/29/2010 4:26 AM
GA
Over to you English Rose.
#390
In reply to #370
07/29/2010 11:21 PM
a sail in the wind is like a planes wing moving thru the air or in moved air - both create a force perpendicular to the direction of the flow (or the sails position).
In reply to #367
07/28/2010 3:24 PM
Suppose the river (or lake) is running round part of the equator. Then it and the air are travelling at ~1000 mph relative to the centre of the earth. How can it make a difference whether you chose a frame of reference which is still relative to the banks i.e. doing the ~1000mph OR still relative to the river i.e. doing ~1003 or ~997 mph.
#372
In reply to #367
07/28/2010 5:57 PM
You have just proved to us all here that you are:-
a) not a great person in mathematics
b) not a great person in physics and
c) not an engineer either.
Your points are all totally invalid, but you cannot see or understand why.
Are you in book keeping or similar? It would fit well if you are!!!!
We gave you the opportunity to think things through.
Either you did not do that or you simply could/would not understand it. Pick one or the other!!!
Mr Trunner, try and improve in the future.....a well wisher!!
#383
07/29/2010 3:34 PM
The 5kph relative wind is not a constant. It is a function of the current pushing the boat minus the drag, mostly from that wind. Any increase in drag diminishes the relative wind speed. Putting up a sail is a significant increase in drag under these conditions, slowing the boat. Tacking is a way to recover some of this loss, but no set of the sails will overcome the losses incurred, because there is no energy available except the current in the river. The streamlined boat should win, because it has reduced its drag.
In reply to #383
07/29/2010 6:08 PM
Mr Trunner, draw yourself a vector diagram of the forces involved in sailing a boat. Now look closely at the diagram, it consists of forces generated by the interaction of wind and sail and keel and water. You cannot determine from the drawing if the wind forces are generated by the wind moving relative to the sail, or the sail moving relative to wind: I know that sounds stupid at first, but that is the key to this problem. The same applies to the keel/water part of the system, it's all relative and the boat sails to windward, whether that wind is generated by the current acting on the keel or the keel pushing through the water,, you simply cannot tell without an outside frame of reference,,, if you can't grasp this , welll...
In reply to #383
07/29/2010 6:16 PM
In reading all your comments and replies, I see that you are hung up on the energy here and the energy there. In reality there is no energy transfer from the river to anything, ignoring the friction at the interfaces between the river and earth and the air. The simple fact is that the river is simply flowing past the still air and the earth, which are both assumed to be stationary. Now, we all know that there energy here, but it is POTENTIAL energy, waiting to be used. The energy transfer occurs on the object (our sailboat) at the interface between the two fluids that are moving relative to each other. The relative motion of these two fluids imparts forces on the object caught in the middle. It makes no difference which fluid is moving how fast relative to what frame of reference other than relative to each. They both could be moving at 1000 MPH relative to the earth, the sun, or some galaxy somewhere. The only fact of importance to this problem, at this moment, is that one moves 5 KPH relative to the other. This relative movement between the two fluids imparts movement to the trapped object (our boat) relative to both of the two fluids. Now, the direction of movement of the object relative to some other frame of reference is a function of which media (frame) is moving relative to that frame of reference. In our case, it is the water in the river moving relative to the earth. Therefore, our advancement through the water in the river is additive to the movement of the water in the river relative to the earth in order to obtain our total movement relative to the earth.
If this does not clear things up for you, a have a detailed explanation of the basic principles of the actions and reactions on objects caught in the interface between to frames, where a sailboat being driven on water by the wind is merely a special case.
See you guys next week.
#391
In reply to #389
07/30/2010 9:50 AM
Thank you. I get it now.
The guy with the red face.
In reply to #391
07/30/2010 3:49 PM
Trunner, well done. I was at the point of suggesting that someone take you out in a boat and demonstrate the whole thing by placing you in the water, to act as the drifting boat, and then to sail away down stream.
In reply to #393
07/30/2010 5:22 PM
LOL
He saved himself in the nick of time!!!
#395
In reply to #393
07/30/2010 5:41 PM
Thank you for your graciousness. I was so far off on so much, I suspect I still don't have it all. I am (obviously) not a sailor. The last time I was on a sailboat, I spent the whole time puking, and it had a motor anyway. Thanks to all for attempting to educate me.
07/31/2010 12:08 PM
I had to add this in just for fun.
It is NOT the same problem as we have been discussing, but still a very interesting one, probably even more difficult to understand fully for most....
Here:-
http://www.youtube.com/watch?v=DPvGTjmn9y0
http://www.youtube.com/watch?v=xHsXcHoJu-A
Here is another fun one to watch:-
http://www.youtube.com/watch?v=k-trDF8Yldc&amp;feature=related
#397
08/03/2010 4:02 PM
Now turn upstream and run before the wind. As your speed cancels that of the water you are standing still w/r to shore, there is no wind. What happens then?
#398
In reply to #397
08/03/2010 4:34 PM
Dear guest, your thinking processes are flawed....nor do you understand any thing about sailing. Also that was not the question.
So switch the brain on Mr Simpson.....
In reply to #398
08/03/2010 4:55 PM
"So switch the brain on Mr Simpson.....", I think he broke of the pull chain, in the "off" position.
#400
In reply to #397
08/03/2010 6:07 PM
Your speed is only about 1/2 to 2/3 that of the effective wind, so you are still moving down stream, but at only about 1/3 to 1/2 of 5 Km/Hr, or about 2 Km/Hr. For this scenario, you are racing to see who gets to the finish line LAST.
Reply to Blog Entry Page 4 of 5: « First < Prev 2 3 4 5 Next > Last »
129CBRider (3); Amos (1); Andy Germany (51); Anonymous Hero (4); Anonymous Poster (76); ARMY-MARS-GUY (1); Aviator (6); baxterm (21); bdbwoods (1); BWW (6); ca1ic0cat (1); charsley99 (1); Codemaster (1); conchwood (1); Concrete Universe (1); damummert (14); davidforbes (4); dvmdsc (3); English Rose (2); ergoargo (1); ExPat (10); FJDomingues (28); GeoffJohns (2); grumpygreybeard (3); Happy Fish (1); HarryBurt (1); hugomad (14); JRW (1); jt (3); Kenneth Leigh (1); kevinm (3); Marjer2 (5); MoronicBumble (36); munch (23); ozzb (1); passingtongreen (14); phph001 (6); Randall (13); robert.c.allen (4); seagull (1); seanhome (1); SuperVinnie (1); tick-tock (1); TimKI (1); Tornado (2); traneengineer (1); Trevor Walden (1); trunner (9); Usbport (1); vagabond (2); wangito (2); WilhelmHKoen (7); Zadok (1); zorvis (2)
