Sports, Fitness, and Nutrition Blog
The Sports, Fitness, and Nutrition Blog is the place for conversation and discussion about topics related to sports and sports fitness, general fitness, bodybuilding, nutrition, weight loss, and human health. Here, you'll find everything from nutritional information and advice about healthy eating to training and exercise tips for improving your overall well-being.
Previous in Blog: Do the Risks Outweigh the Benefits of Medical Tourism?   Next in Blog: Should You Be Running Barefoot?
Introduction to Yoga – Arm Balances (Part 2)
Posted August 24, 2010 12:00 AM by Jaxy
Make sure to check out the part one of this two-part entry on arm balances to learn some preparatory poses. This blog will go through some poses that will have your body reaping the benefits.
The Key to Practice
After you have built enough strength to support a healthy-looking four-limbed staff pose, you probably have enough arm strength to move forward. When most people approach arm balances, they find that determination will cause the body to fill with anxiety and tension. Jason Crandell, a yoga instructor in San Francisco, emphasizes that relaxation may be key in achieving arm balances. Create an attitude toward arm balances that is playful, curious, and nonstriving. The key to achieving these poses is to find the balance between effort and relaxation.
Precautions
Do not practice arm balances if you have any hand, wrist, elbow, or shoulder injuries. If you experience pain while in a pose, there is a good chance that you are either not ready to practice the poses and need to do more preparatory work, or that you are in the pose wrong.
Start the Arm Balancing
Dolphin Plank Pose
This pose strengthens the arms, legs, and core muscles; assists in preventing osteoporosis; stretches the shoulders, hamstrings, calves, and arches; and calms the brain. If there is any neck tension, rest your forehead on a block between your forearms.
Eight-Angle Pose
Eight-angle pose strengthens the wrists and arms while toning the abdominal muscles. If balance is difficult, rest your bottom hip and outer leg on a bolster.
Firefly Pose
This pose stretches the inner groin and back torso, tones the belly, strengthens the arms and wrists, and improves sense of balance. This pose can be modified to assist beginners. Start by sitting on the floor with legs spread to a 90 degree angle. Elevate each heel on a block and press your palms into the floor between your legs.
Scale Pose
Most of the time, people attempting this pose have a hard time lifting the legs when the hands are on the floor. Try using a block under each hand to elongate your arms. This pose strengthens the wrists, arms, and abdomen.
Resources:
YogaJournal – The Secret to Better Arm Balances?
Re: Introduction to Yoga – Arm Balances (Part 2)
08/24/2010 11:13 PM
Thanks Jaxy
In India traditionally it is called Mayurasan. (Mayur... Peacock. Asana... Posture)
