Previous in Blog: This Fueling Station Fills Vehicles With Clean Hydrogen From Dirty Water   Next in Blog: British Gas Installs Smart Meters
21 comments
'Wind Lens' Could Triple the Power Output of Turbines
Posted August 31, 2011 8:31 AM
From TreeHugger:
This just seems too easy: Japanese researchers say that they've discovered a simple way to make wind turbines up to three times as efficient. By placing a 'wind lens' around the turbine blades, they claim that wind power could become cheaper than nuclear.
Re: 'Wind Lens' Could Triple the Power Output of Turbines
08/31/2011 10:38 AM
Have they heard of Betz' Law?
08/31/2011 11:17 AM
You had to make me look it up didn't you?
Those pics in the article don't stand up to scrutiny.
I reckon all Betz are off <groan>
Good Answers: 7
08/31/2011 12:35 PM
Hello JohnDG,
if they manage to increase the power flow within that additional ring, it means they will have more kinetic energy per unit area and time. So they will get more mechanical power without "switching off" Betz' law.
This is not the first concentrating scheme proposed, and some look quite similar.
Regards
Snel
08/31/2011 5:10 PM
This is like the "mount a wind turbine on a trolley, connected via a drive train to the road wheels - once you get it moving, it'll go faster and faster and faster ..." argument discussion. It doesn't work.
The area of the turbine inlet appears (from the images) to be only about 10%-ish greater than the area swept by the blades. It cannot "suck air in", tho' it may increase the air flow (and hence power) a bit. I can see that a large funnel could do some good, but not these things. They may gain a little - but a 200% increase???
I stand to be corrected, but it seems to me like pie-in-the-sky. These claims need to be peer-reviewed, before any poor suckers get sucked in.
08/31/2011 6:55 PM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Reply Off Topic (Score 8)
08/31/2011 7:12 PM
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
Good Answers: 83
08/31/2011 9:46 PM
Good Answers: 204
08/31/2011 10:37 PM
09/01/2011 4:13 AM
Anonymous Poster #2
09/01/2011 4:01 AM
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
08/31/2011 10:37 PM
I have often wondered if some kind of earthen structure could help boost a turbines power by directing more air to the blades, and away from the area between turbines.
08/31/2011 10:46 PM
I can think of some creative sharia-style remedies...somewhat like a tortilla press.
08/31/2011 10:53 PM
Was the article ghost-written by joe.fordham?
Good Answers: 54
09/01/2011 3:03 AM
Additional income could be produced if they hang small carriages around the circumference and call it an "Eco ferris wheel".
Could triple power, could be cheaper, could ... etc.
09/01/2011 10:31 AM
As JohnDG pointed out, Betz's Law (yeah, I had to look it up, too) limits the efficiency of any wind turbine to just under 60%. It's a theoretical limit making extreme assumptions of massless props and so forth. The explanation I read appeared to assume a laminar air flow; I don't know if a turbulent flow, such as this 'lens' creates, would make any difference or not, though I didn't see anything in the math that would suggest any way to change the max value.
I suppose if a wind turbine was consistently operating at well below the Betz limit, say at 10%, over a wide range of wind speeds, then a 3x increase would be possible -- but would anyone actually design and build one that operates that poorly?
One other comment concerns the main drawing. To get maximum efficiency the propeller must face the wind, and the lens must remain in a fixed relationship to the prop. The large drawing shows fixed (floating) propellers on barges, with no obvious way for each propeller assembly to rotate into the wind. Makes me wonder who did the sketch and wonder if the Japanese researchers approved this sketch.
09/01/2011 11:40 AM
Turbulent flow makes a big difference - output drops off greatly.
I think these guys are just trying to get funding so they can have jobs.
Betzs law has proven out well over the many years since he wrote it. No one has been able to beat it yet.
Location: East of Seattle, Washington state Republic of the 50 states of America
09/01/2011 3:51 PM
Hmmmm, a ducted turbine and stator. More efficient? Very likely. As cost efficient? Not so likely.
09/02/2011 12:19 AM
Search 'ducted turbine' - more efficient is the one statement you won't find - along with 'operational'.
09/02/2011 2:12 AM
Sorry wrong syntax. shrouded propeller is what I should have said.
This is the application I learned about them.
While a 300% improvement would mean a 15 to 20% efficiency to start with, more realistic would be 20 to 50%. The issue is cost and complexity just went up 300% or more to get it.
If you spin the shroud mass becomes an issue, If the shroud is stationary then clearance and wind direction get complex. For a uniform wind in a non changing direction the shrouded propeller is hard to beat. Add variable dynamics and life gets interesting.
09/02/2011 1:07 AM
Suppose a turbine was 40% efficient. Then making it 3 times as efficient, it would be 120% efficient? I don't think so.
11/07/2012 6:40 AM
I can certainly see that such a lens could possibly improve the efficiency of a wind turbine. Not unlike the way winglets work on the wings of modern aircraft I feel.
I found the video on YouTube (it has been removed from the web link) and the first demonstration on the video, assuming that the air speed itself was not changed to falsify the results, was pretty impressive.
Where I am at a loss, is why is the lens fixed in position on the larger versions. If it was part of the turbine and turned with it, although bearings/impeller etc. would need to be beefed up of course, it should improve efficiency/stability due to not needing the fixed supporting arms.
Also, the extra weight should work as a flywheel, evening out the gusts etc. and the small effects of the spinning lens, "throwing" the air out at the back centrifugally, might actually further increase the efficiency a further small amount......
Furthermore, it should also help with the stability of some sort of "furling" system to allow the turbine to slow or furl the blades when storms or generator failures happen that could produce a dangerous situation if the turbine could not be stopped. Similar to that on modern propeller aircraft to turn the blades parallel to the direction of air movement when a motor is unusable, thereby reducing drag considerably....
I certainly feel that there is a lot of possible merit to the idea and I would like to see exactly what happens over the next year of so with this as it is improved and developed.
At the end of the day, the extra cost of the lens needs to be significantly MORE than offset by the efficiency increase, that has not fully been demonstrated as of now to my mind.....though I do feel that this extra efficiency is fully possible.
Andy Germany (1); Anonymous Poster (2); chrisg288 (1); ffej (1); JohnDG (4); ronwagn (1); russ123 (2); Snel (1); sue (1); Tornado (3); U V (2); Usbport (1); user-deleted-1105 (1)
