Previous in Blog: Dropping the Ball: Newsletter Challenge (May 2013)   Next in Blog: Tube Race: Newsletter Challenge (July 2013)
70 comments
Time Traveler: Challenge Question (June 2013)
Posted June 01, 2013 12:00 AM
Pathfinder Tags: challenge question time travel
A scientist builds a time machine and successfully travels to the past and returns. Her husband later gets into the time machine and changes the destination time. The time machine disappears and reappears a few minutes later (programmed to return automatically after a few hours). It is very cold and the husband is dead. Why?
And the answer is:
The time machine has just spent the last few hours sitting in empty space. The husband had changed the destination time coordinates, but neglected to change the space coordinates as well. The Earth is in orbit around the sun, the sun is orbiting the galactic core, etc. His wife, the scientist, had accounted for all these motions and set the spacetime destination coordinates appropriately on her successful time travel trip. He did not and ended up in empty space for a few hours.
Re: Time Traveler: Challenge Question (June 2013)
06/01/2013 12:33 AM
There's no such thing as a time machine....? It was a freezer with a bunch of dials and switches added, and it was a plot to murder her husband all along, because he was so gullible....
Reply Good Answer (Score 4)
06/01/2013 1:00 AM
If only Anonymous Poster #1 would fall for that....
06/01/2013 6:34 AM
He did. He came back here brain dead.
06/02/2013 12:45 PM
As far as you know, it hasn't been discovered yet. Here are a couple examples to ponder: The earth was found not flat due to discovery; The earth was found not to be the center of planets due to discovery.
The only way to know is to apply what you learn!
06/01/2013 2:57 AM
He returned to the ice age, and she had not put any heating system in the time machine?
Regards JD.
PS hope I did not to much information?
06/01/2013 6:33 AM
Heat Death. He went to Milliways, the Restaurant at the End of the Universe, but arrived late.
Entropy wins again.
He had reservations, but went anyway.
06/04/2013 9:13 AM
You are referring to an entropy catastrophe. If this is true, since S= H/T, then when the system is adiabatic, for S to decrease, T must increase. The occupant is pyrolyzed. During the return trip S increases, T must decrease. The occupant is frozen solid (dead either way), but why not dead for the scientist as well as the husband?
The husband set the return time asymmetrically from the destination time (distance). Assuming there is a heat transfer and storage device onboard (big assumption), he runs out of heat by traveling just a bit too far forward in time, and runs out of heat to exchange to keep the temperature constant while entropy increases. He freezes solid.
06/04/2013 10:58 AM
Yes, I think you are correct. it is the delta of the return time.
06/01/2013 7:23 AM
He returned to a time when the earth was not here yet, popped out in cold, cold space, where no one can hear you scream....
Engineering Fields - Electrical Engineering - Analog and Digital Circuit Design Engineering Fields - Electromechanical Engineering - Transformers, Motors & Drives, EM Launchers Engineering Fields - Engineering Physics - Applied Electrical, Optical, and Mechanical
Good Answers: 119
06/01/2013 11:53 AM
http://en.wikipedia.org/wiki/Earth%27s_orbit
"The orbital speed of the Earth around the Sun averages about 30 km/s (108,000 km/h), which is fast enough to cover the planet's diameter (about 12,700 km) in seven minutes"
Theoretically, even a short hop into the past or future could be lethal without a full space suit.
06/01/2013 12:28 PM
Yes, there are so many endless possibilities that are not pinned down with this challenge as to render it nearly impossible to "solve".
However, if the challenge is written with foresight and skill, such unknowns, possibilities, and improbabilities may be nothing more than a diversion.
Assuming that is the case, then is there something with the clues that could be immutable enough as to derive an answer? Remember, one trip into the past was successful
That was my approach, although I kind of did it tung-in-cheek, but if you went far enough into the future to a point where entropy is at its maximum, then all things would also be at absolute zero; no light, no energy, maximum disorder.
The other possibility suggested by another poster was that his time-space coordinates landed him into the vacuum of space.
Or, maybe this is just an extension of the riddle of how do you put a time traveler in a refrigerator? The obvious answer is you must first take the giraffe out. :)
06/02/2013 1:01 AM
Interesting point. I wonder, if you 'dialed it in' to go forward or back exactly one year, how many inches (or more distance) you would be away from your origin.
06/04/2013 5:59 PM
Inches won't be a very convenient unit to measure the distance away from your origin in a year.
The Milky Way is thought to be traveling through space at around 300 km/s.
06/01/2013 9:05 AM
That's the trouble with voice activation - "Take me to the day I understand women"......oops.....'when hell freezes over' ain't a good destination.
Reply Good Answer (Score 7)
5
06/01/2013 12:58 PM
Let's take a look at the elements of the puzzle:
A scientist builds a time machine and successfully travels to the past and returns. Thus. time travel to the future and past are both possible with this machine.
Her husband later gets into the time machine and changes the destination time. Okay... so he's a fellow who has the urge to fiddle with stuff. He knows the first setting works but can't leave it alone. How much later... Years? Decades? Hours? Which, the future or past, did the husband select for his trip?
The time machine disappears and reappears a few minutes later (programmed to return automatically after a few hours). Confusing... time dilation? Computer malfunction? Did he fiddle around with the clock as well?
It is very cold and the husband is dead. Just what is very cold? The earth? The machine? Just how cold is very cold? 12 kelvins?
Why? Why what? Why did he change the settings? Why is it very cold? Why is he dead?
All right, here we go:
He travels back in time to the beginning of the modern industrial age. He believes that man is the primary source of global warming, and warns the people of earth. Armed with this trustworthy information, steps are taken to ensure there are no human caused contributions to this so called global warming. Upon his return, he discovers the ice age that man had held in check had been able to proceed as originally scheduled. Thus, it is very cold.
Reply Good Answer (Score 5)
Good Answers: 114
06/01/2013 4:33 PM
There are several rules to time travel:
1. The device must stay in the same position relative to the center of the Earth or it would be space/time travel and one would not be able to return home.
2. The traveller must not be able to interact with the environment in which it arrives or he might kill his own grandfather before he had a chance of procreating, thus eliminating his father, himself and his children, born or unborn.
3. Travel to the future is not possible be cause it doesn't exist yet. If travel into the future were to take place, the future would be fixed and free will and all probabilities would be frozen.
I conclude that it was very cold before he started and that he went back a short time, set a short delay and return, and committed suicide. The alternative is that he delivered heat to a previous environment and changed it with all the consequences of breaking the laws of energy conservation.
06/01/2013 8:27 PM
Rule # 1 actually has a fault. The Earth rotates. So, the inertial reference point must reconcile that.
Rule # 2 may not be the only way it could work. Any change to the past timeline would potentially cause a paradox, but it may also be possible that a new timeline unfolds from that instant that our time traveler materializes. The original timeline remains intact and you also have a somewhat parallel time line based on whatever altered events have taken place. However, you need to be careful when you use the word timeline as that is only a perception and not necessarily a given reality.
Rule # 3 appears to be false. I provided a proof for this in an earlier post about time being an illusion. If you can follow my post you will see that past, present, and future all exist together simultaneously. It appears that consciousness acts like a projector, projecting each frame of a film in a preset order.
When the film or DVD is delivered to your house, all frames equally exist on the film or disk simultaneously. The projector or DVD player methodically presents each frame in succession to form a meaningful story.
The only question I can't answer is if free will is an illusion and only one possible future exists or if all possibilities exist (much like a probability wave for an electron). There are many, many good scholarly arguments both ways on this one.
06/01/2013 10:52 PM
The time machine was built in an old factory unit. To ensure that no timelines were altered, the scientist had gone back to the time the factory was empty, before she rented it. Her husband went back only three weeks earlier - and arrived inside Ben & Jerries warehouse coldstore. At least he died happy!
Madness is all in the mind
06/02/2013 1:11 AM
I have just discussed this matter with Michael J Fox, and he assures me that unless the time machine was in fact a DeLorean, then time travel would be impossible.
He also informed me that the airconditioners in those things were notorious for failing to turn off.
He said he froze his nuts every time he used the damned thing, and complained to the Doc about it.
The Doc simply replied "Great Scott" and used a steam train for his own travels. He said that he never had a problem with being cold by doing it this way.
06/02/2013 1:28 AM
The Short answer:
The Scientist travels in one year increments. Where-as, The Husband goes to a time where there is lots of Space, and isn't inside or near the Earth.
The Long answer:
The scientist correctly goes back in time in exactly one year increments. The husband does not, thus going to a time where he is actually in space since the Earth moves, and matter can not occupy the same space as other matter, such as the Earth. So he didn't go to a time where the existence of Earth would interfere. In other words into a near-by mountain. The time machine returns to a time, near enough to it's origin time so that it's location in space has not changed relative to Earth.
06/02/2013 8:10 AM
That looks like the answer that they are looking for, but it assumes that the sun is stationary. Talking about being in the same place in the future is meaningless if all linear motion is relative and there is no absolute frame of reference.
06/02/2013 8:49 AM
Bingo. There are no privileged reference points in space-time.
06/02/2013 11:44 AM
So are you saying that a time machine was build already but nobody can prove it because nobody resolved the issue with the referenve points?
Just to let you know, I have such a machine and my husband just turn out cold . . .
Good Answers: 114
06/02/2013 8:50 AM
If you go in that direction, you run into difficulty:
A point on the equator revolves at about 0.46 kilometers/second around the Earth's axis.
Earth is moving at about 30kps around the Sun.
The Sun is moving at about 200kps around the Milky Way.
The Earth actually travels a spiral around the curved path of the Sun.
The Milky Way is travelling with its companions in the local group of galaxies towards an attractor.
The Earth never returns to the same spot, and that is without considering that the Solar system is above the galactic plane and rising although the rate of climb is diminishing.
06/02/2013 12:41 PM
I agree, this is all true. The time machine would have to be capable of travel measured in the micro or milliseconds. Given that is a new technology, I'm guessing would need a clock similar to that used in computers running MHz or GHz. If it was that accurate it could come back within mm or Cm's of the place it 'left' from.
06/02/2013 9:19 AM
I think that the wife is British and the husband is (US) American.
So the wife has the date panel laid out in the British style with the change in years as the first set of numbers, then the months, and then the days.
The husband, being American, thinks the first set of numbers is for the month and day, and inadvertently changes the date setting by many years rather than by a few months and days. The time machine takes him so far back he emerges into an Ice Age glacier and instantly freezes to death.
Good Answers: 114
06/02/2013 9:43 AM
Clever. GA.
But there is the pre-programmed return after a few hours except the dude came back in minutes. That must be significant. The UK is five hours ahead of the East coast of the USA, I wonder if you can work that in.
06/02/2013 10:45 AM
The number of minutes or hours that pass in the past does not mean that more or less time must pass in the present. There is no requirement stating that the two times must be linked.
That is, if you go back to a point in the past, spend one hour, then return. Must you return to the point one hour after you left?
THis is like the difference in time between the twin paradox, which is also a time machine that only goes forward into the future. There is ship time and Earth time and they obviously do not agree.
Good Answers: 114
06/03/2013 10:01 AM
"The number of minutes or hours that pass in the past does not mean that more or less time must pass in the present. There is no requirement stating that the two times must be linked."
The OP made a great point of the difference in duration; why if not to imply that they were away for different times. I think it is a necessary boundary for a solution.
06/03/2013 12:10 PM
You may be right.
"The time machine disappears and reappears a few minutes later (programmed to return automatically after a few hours)."
However, the way it is written, the machine returns after a few hours of ship time, not the passage of departure local time. I don't know what the significance of "a few minutes later..." means to this puzzle, but there is a disparity of time between ship time and time passage at the point of departure.
You would think, if it is a time machine it can return to whatever time-space coordinates it is programmed to.
06/02/2013 11:39 AM
Simple:
She knew that he will travel to see another girl he loved a lot too. Her husband programmed the machine to go to that time she put a poison, but she repented, now she revenges. (sorry for the bad english).
Good Answers: 114
06/02/2013 12:09 PM
Interesting. Schrodinger's cat all over again.
06/02/2013 12:23 PM
The wife traveled as a spectator to not upset the time line. She was gone for 2 hours. The husband sets his destination time a few minutes earlier to warn himself against marriage. By contacting himself, he upsets the time lime. In the alternate time line, the husband dies.The time machine returned as programmed. It's cold because the time travel occurred during winter.
06/03/2013 5:13 AM
As doorman pointed out. A lot depends on the interpretation of that penultimate sentence.
It is very cold...
By "It": do they mean the time machine, or, the weather "now".
Assuming it's the time machine, and, knowing what the weather is like in some parts of the world: it could be as simple as going back to the middle of winter instead of the summer.
06/04/2013 5:57 AM
Aw, stop being so "grown-up".
06/04/2013 6:31 AM
How's this?
06/04/2013 7:50 AM
06/03/2013 6:17 AM
There's a learning opportunity here. Don't follow the KrisDel™ time machine design drawings to the letter; there might be something wrong with them....
06/03/2013 8:41 AM
Isn't mass in that whole theory of relativity thingy? You'd have to assume the woman scientist was smaller than her husband (it is a safe statistical leap). If the machine energy input was not adjusted to compensate for additional mass, the only readily convertible energy mass, heat, would be all sucked out. Surprised the machine even made it back...
06/03/2013 9:24 AM
In time travel, unless the time AND displacements are calculated very carefully, one will end up somewhere other than the targeted destination. Navigation becomes extremely critical.
If the destination time is changed without programming in an appropriate offset to the displacement vector, then the total motion of planet earth will move the target out of position (i.e. - the galaxy is moving, the solar system is moving, the earth is in orbit around the sun, and the earth is rotating (and precessing)).
The husband found himself in the past somewhere in space, and the vacuum there resulted in immediate outgassing to a cryogenic temperature. Horrible way to go, poor chap.
Good Answers: 88
06/03/2013 10:25 AM
Any chance the time machine manual was written in chinglish? S.M.
06/04/2013 10:21 AM
...or the PLC program, even?
06/03/2013 2:55 PM
Using what we are given (and not speculating out & beyond that). If the scientist set the destination time I believe she also set the return time, not waiting for the default return time. So I believe this has something to do with the fact that the husband changed the destination time but not changing the return time?
Did the time machine try but fail to return the husband (causing death) at the same time as it was returning the scientist/wife ? This has something to do with the auto return time. Did it reset after failing and then return him only a few minutes after he left if he left 2 hours after she returned? So what state of existence was he in in the two hours in between the time he had not left but had also not returned yet? Did he exist twice or not at all. Where was he - dead! Cold? ??
Ok, I officially confused myself here and now I see I cannot arrive at a plausible answer! Drat! Time is a strange enigma.
06/03/2013 5:13 PM
There's a lot of blame to go around for this tragic accident. The scientist (wife) either left the keys in or failed to install a lock-out system to prevent any unauthorized use. (a time machine in the wrong hands can be a very dangerous). And the husband for taking it on a joy ride without permission. Perhaps he did from a dare from his buddies or maybe he had too much too drink and his judgment was clouded. His death will surely be in legal dispute. Will his wife get social security survivor benefits if the government proves that his time of death was before he was born?
Or did something more sinister happen? Did his wife con him into taking a trip; never knowing that she preprogrammed the machine to send him back to the ice age to meet an untimely death (no pun intended)?
These time machines clearly need better government regulation. We don't know what the environmental impact is. There are health and safety issues that need to be addressed such as long and short term exposure to time travel. Is it energy star qualified? Is it ADA accessible? Does it meet all the OSHA standards? Will the IRS target this machine if conservatives groups want to go back and change the last election?
Instead of going on summer recess, maybe congress could address these very important issues.
06/03/2013 11:16 PM
I think we have been approaching this problem all wrong.
It is not about a set of time-space coordinates at all. All of the banter about the rules of time travel, which are wholly unexplained in the simple puzzle are nothing more than a diversion we have set upon in typical engineering fashion. Perhaps this is of clever design by the author.
However, the puzzle is not so much about time travel, but everything to do about the arrow of time and of all things; Thermodynamics.
If thermodynamics is the root answer we are looking for, it would be easy to claim that the first Law of Thermodynamics is the applicable law that unravels the puzzle. Actually, it is the Second Law that speaks to the heart of the riddle.
Thermodynamic Time Asymmetry. S = k log W
Thermodynamics and its laws establishes an arrow of time. That is, wine glasses may drop and scatter into a hundred pieces, but you never witness glass shards suddenly gathering together and assembling themselves into a perfect crystal glass filled with your favorite red wine.
To do so would violate the laws of thermodynamics as no system can move from a state of disorder to a more ordered state without applying energy back into the system.
When a system evolves from a low state of entropy to a higher entropy it follows the Second Law of Thermodynamics. The arrow of time pointing only to the future is thermodynamics at work - entropy increasing, not decreasing.
Again, in order for a system to evolve from a higher entropy to a lower entropy state requires the addition of energy into the system.
The second trip of the time machine did just that. The machine was the energy source used to pay the bill that the husband rang up on his entropy tab.
Right now it is very late for me and if I can muster it, I will try to elaborate on this further tomorrow, but the gist of the puzzle is really not about time or time travel, it is about thermodynamics and the asymmetry it represents that instantiates the arrow of time.
Good Answers: 114
06/04/2013 10:46 AM
Entropy shmentropy, there is a clear case of an impossible (by the physical laws) let alone illegal transfer of energy from one time to another, which violated the conservation of energy laws at both ends. It was taken from the now universe and released into the then universe.
Perish the thought! he might have witnessed the Big Bang!!.
06/04/2013 10:59 AM
I don't think it is possible to witness the Big Bang. Rather one would have to be a participant of the Big Bang.
06/04/2013 3:31 PM
You mean we've stumbled on the cause of it??
06/04/2013 7:08 PM
Could be a Nobel Prize with your name on it. :)
06/04/2013 5:17 PM
Because "You can't be in three places at twice."
06/05/2013 12:26 AM
The time of destination is changed - during this time the Earth has moved position (the Earth moves at 465m/s). The temperature of space in the vicinity of Earth is 123 degree C but in shadow it is -233C - as the machine is cold I can only assume the machine materialised in the moon's shadow or that it was orientated so that the base faced the sun and cast a shadow. The vacuum of space would of course kill the husband regardless.
Regards
Brady
06/05/2013 12:50 AM
the time machine is battery driven - what else?
the battery is empty and how he can return now?
06/05/2013 12:21 PM
He went back in time farther than his wife. Hence, his return time caused him to age past his normal life span. Consequently, he was dead and cold.
06/05/2013 3:19 PM
OK further to my post #29. And trying to take the simplest possible interpretation of the elements of the question.
It is now the middle of winter, but, the time machine is in a nice warm building, which, needless to say did not exist in the past. The scientist knew that she had to program a destination time n and a half years in the past to avoid freezing to death. The husband however just programmed a destination time of m years in the past, with the unfortunate consequences described.
The It in "It is very cold" can now refer to: the weather outside, or, the time machine after the trip.
06/06/2013 12:24 AM
where is my rubber?
(no, i'm not an archaeologist)
06/06/2013 3:05 AM
I share your angst
Good Answers: 114
06/06/2013 6:13 PM
I wonder if the NSA monitored their journeys
06/06/2013 8:36 PM
More likely, sponsored it.
06/11/2013 11:45 PM
wouldn't you try too?
In reply to #59
06/12/2013 6:48 AM
Not without my towel.
I think that was the fatal error.
06/13/2013 6:27 PM
The 'few minutes' is the time it takes to move one way in time hence this is the destination time - He went to the future to see if his wife would outlive him but unfortunately not and he has just died and in the morgue. It was programmed to automatically go back to the current time, whence he would still be alive but no happier in the knowledge she will outlive him.
06/18/2013 1:09 PM
His wife programmed the Time Machine to "Take Her Husband Out" if he set the destination, to a time when he was still dating his Hotty Hot Ex-Girlfriend. If he got caught, she knew her Lawyer Husband would play the "But honey, we weren't 'Officially Married' back then" card. Dirty Dog got caught!
06/18/2013 1:39 PM
The husband had paid to be cryogenically preserved, and then realised both that it wouldn't work and that his life had become miserable anyway. So he went and collected the body from a sufficient way in the future, went to a new time until shortly after the expected death of his wife, got out of the time machine, and let the cryogenically cooled body come back to greet her.
I'm probably wrong, but - assuming a time machine (not time-and-space):
The husband readjusting the time coordinates could be a red herring so far as mis-location is concerned, because the (later) start location is different - and thus (if no spatial change is allowed) just as certain to miss the earth.
If the wife is tio land safely on Earth, her task too is improbable: the tolerances are critical - even if she can find a time when a viable location is in the same place relative to universal average coordinates (currently unknown) and going at the same velocity as her original.
Then you need to arrive somewhere with air unless the machine is sealed; in which case you would materialise with your body filled with additional air corresponding to the normal atmosphere. Bends at minimum - possibly explosion...
06/18/2013 5:39 PM
He programms it so far in the future that the sun has fizzled out and the earth is dead. He doesn`t survive but the time machine takes his remains back to when he came from.
"There is no punishment where a pun is meant"
Anonymous Poster #2
06/20/2013 6:33 AM
The problem is that he returned a few minutes later. He sould have returned at the exact same time. For those few minutes he was neither here nor there, schrodinger's cat. When he returned, the box was opened.
06/25/2013 4:05 PM
so many non scientific engineering answers...
the fourth derivative circuits of electricity...
with right and left hand rule magnetic tachyon fields??
without appropriate shielding...time travel may cause nervous system disorders??
06/27/2013 11:02 AM
Well, this is a little late but I thought I might try to add on top of the (good) comments my own modifications for fun....
And the answer is:
Unfortunately, the husband didn't know that his wife would first identify a most likely safe time and place to land prior to embarking on her journey. As a result, this hapless time traveler lost his life as will be explained later.
Because she was cognizant of potential sensitivities arising and dependent on initial conditions (Butterfly Effect), the wife took great pains to avoid changing events on Earth. Upon successive mappings of stellar objects large and small, the wife of this dead husband had identified with greater confidence her next step.
Such time travel experimentation decisions included confirming placement of reconnaissance micro-satellites in congruence with theories of safe time travel. Additionally, her success came not only from her own thinking but in collaboration with fellow associates of diverse backgrounds and capabilities.
Subsequently, this humble choice of alliance included bringing into the fold a sous chef and fellow dishwasher from a local eatery with no educational background in science or engineering. Such a decision to include someone who is neither a young fresh mind or well seasoned academic didn't seem wise.
However, this recently widowed time traveler liked to sit in the back dining area adjacent to the employee break area and would hear debates from time to time on topics such as why a recently launched space telescope failed.
This restaurant duo had belatedly proved their mettle by arguing the importance of masking or compensating for thermodynamic effects more precisely as one goes further back in time to ensure consistency of enthalpy of the present.
With further experimentation, short hops in time proved to be mostly negligible with changes in events but in the case of the dead hubby was a different matter. The unfortunate time traveler managed to transport slightly outside earth's orbit.
The time machine had redundant safety measures such as predictive modeling of the location of earth at different periods in time, removal/time transport equivalent thermal mass to the future, and placement away from civilization.
However, the husband traveled to a time prior to when a combination of large and small comets hit earth between his fateful time jump and her successful transport. These unforeseen events had changed the shape, spin, mass and orbit in ever so subtle ways over that time period. As a result, the calculations were off.
An additional result of the tragic journey, was a meteorite colliding with his environmental controls just as he was materializing in that period which led to the depletion of his oxygen before he could react (no surveillance satellites available to ensure safe arrival).
Although the motor control and other essential circuits had heaters to maintain operation of their components, the rest of the ship froze due to residing on the night side of the earth within 1 hour of arrival.
Upon returning from orbit, some vacuum of space was included within his trip home (due to the void created by the damaged environmental components) which resulted in a pressure drop within the hangar and remaining humid air interacting with the cold ship led to a rapid cool down within the enclosed space.
But the story is not over, the collision from the projectile with the ship along some slight shading of some nearby meteorites had created a subtle yet significant alteration of these tiny heavenly objects to collide with other objects they would have entirely missed altogether. This chain of events resulted in a comet large enough to cause significant damage to earth's population to now be on a collision course with our home planet within 30 days.
06/27/2013 12:19 PM
Given that the wife survived, the machine must have been built to swap the cargo with coincident material at the target destination. If the husband landed in empty space, there must have been one hell of a bang when he left.
06/27/2013 4:29 PM
The husband obviously neglected to consult CR4 for the wealth knowledge to be garnered to ensure a successful venture into time travel.
Only one question remains - should he have posted in General, Instrumentation, New Technologies & Research, Software & Programming, or Transportation?
In reply to #69
06/27/2013 8:46 PM
Excellent question. Now, which section should we start that debate?
We are starting to sound like the crew of the B Arc.
Reply to Blog Entry 70 comments
aloyolla (1); Anonymous Hero (14); Anonymous Poster (2); bradystumpmobile (1); bwilko (1); Doorman (1); elocwerdna (1); garyrich2000 (1); GM1964 (2); harveyab (1); James Stewart (2); jdretired (1); JPool (1); JustCurious (2); Kris (2); LuciousB (1); mjb1962853 (1); mostadorthsander (1); Paddy O'Flanigan (1); passingtongreen (7); Physicist? (2); PS1987 (1); PWSlack (4); pygalgia (1); Randall (3); Rixter (1); rls1230 (3); SimpleMind (1); SolarEagle (1); Tornado (1); truth is not a compromise (1); tye45 (3); Usbport (1); WilhelmHKoen (3)
