Previous in Blog: Expansive Expansion: Newsletter Challenge (December 2013)   Next in Blog: Icy Explanation: Newsletter Challenge (February 2014)
41 comments
Brass Plate Heating: Newsletter Challenge (January 2014)
Posted January 01, 2014 12:00 AM
A brass plate with a hole in the middle is heated from room temperature to 60°C.
Does the hole get bigger, smaller, or remain the same size?
And the answer is:
The hole will become bigger. In linear thermal expansion the distance between two points on the brass plate increases proportional to the increase in temperature. The distance between two corners, for instance, will increase, as well as the diameter of the circle. The expansion inward into the hole will make the diameter smaller, contradicting the principle of linear thermal expansion. Some readers may say that there will be an expansion of the distance in the figure. This is correct, but the expansion does not take place by pushing point d toward the center of the hole, but because there is an expansion of the distance
Re: Brass Plate Heating: Newsletter Challenge (January 2014)
01/01/2014 1:10 AM
It will get larger, think of the metal around the centre, as the same as a ring with square edges, and the ring expands, same as heating an object for a shrink fit?
Regards JD.
01/07/2014 10:35 AM
I remember many years ago when we still did general science at school we had this neat little experiment to illustrate the expansion of metals. it was a brass ring attached to a small stand and in it sat a brass ball which would not pass through the ring until the ring was heated. simple but effective way to demonstrate the principle. I agree with your comments.
Regards
Andy
01/07/2014 11:33 AM
"when we still did general science at school" Unbelievable. Where are you?
Floss or die!
01/01/2014 2:09 AM
The thread could just as well be closed at this point, but it may be amusing to see if anyone disagrees with given answer.
Good Answers: 114
01/02/2014 11:16 AM
Surprisingly, some do.
I think that at least one is thinking of the differentials caused by the heat spreading outward from the hole, and stopping before the temperature of the whole plate reaches the new temperature.
Australia - Member - New Member Engineering Fields - Mechanical Engineering - New Member
01/01/2014 10:49 PM
Just as well the metal was specified because some metals can shrink when heated.
Dont get on to the roundabout if you dont know how to get off
01/01/2014 11:21 PM
With the old school experiment, the hole became larger because as the metal expanded evenly, the center was under compression and could not move in. As the outer rim moved out it pulled the center out in tension. A plate of this shape would also expand the hole but it would distort the opening from a true circle because of differing amounts of material in the sides and corners.
Good Answers: 203
01/01/2014 11:47 PM
Hole gets bigger. Old freshman physics lab question about "the coefficient of thermal expansion"
Good Luck, Old Salt
01/02/2014 12:24 AM
Gets bigger. All dimensions of the plate get larger on heating - including circumference of the hole and hence its diameter.
Ashok Pillai
01/21/2014 11:26 PM
Ash55 has hit the nail on the head, very logical answer explaining the relativeness of the hole's circumference to its diameter.
GA to Ash55
01/02/2014 12:25 AM
Talk to any machinist or mechanic, it gets bigger. It's how we often fit bearings. Heat the bearing, cool the shaft,, press together, when the reach the same temperature good luck getting them apart.
Martin
01/02/2014 4:31 AM
My best thoughts would be to maybe expect the metal to go say from possibly being flat after the hole was bored at say temperature "A" (stress relieving), to faintly "Fuji Volcano" shaped, the hole getting slightly bigger of course at the same time, at a higher temperature of "B".
Therefore if the temperature of the metal was to have been significantly different to room temperature when the hole was bored, all bets are off as to what happens......higher temperatures possibly resulting in a bigger hole maybe.....
Any further ideas?
01/02/2014 5:51 AM
A hole reacts as if it were the parent material. Thus it expands.
I remember this one from my school days.
(KrisDel corporation has a special range of press fit high stability holes for critical applictions)
01/02/2014 8:37 PM
Do you have half holes, or just whole holes...?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
01/02/2014 9:10 PM
For sale:
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
01/03/2014 2:44 AM
Oh, yeah KrisDel has half holes too. Kris developed 'em specially for when he has half a nut left over to bury.
Reply Off Topic (Score 6)
01/02/2014 7:06 AM
What is the room temperature
Torque is not cheap
01/02/2014 8:58 PM
No matter what the temperature is in a room, that's room temperature.
Reply Off Topic (Score 4)
01/21/2014 5:06 PM
Let's see....a room in Hell is what temperature? Might it be more than 60c?
01/21/2014 11:47 PM
Let us know when you get there!!!
United Kingdom - Member - Not quite retired Member
Location: Up an araucaria araucana tree, South London, United Kingdom
Good Answers: 7
01/02/2014 9:10 AM
All linear dimensions vary as the coefficient of expansion. For brass that's 18.7 x 10-6 per 0C. 18.7 x 60 x 10-6 = 0.001122. So the hole is larger, 1.001122 of its original size.
I keep losing the superscripts but you know what I mean!
01/07/2014 9:30 AM
That's one cold room. I ain't sleeping with you!
Floss or die!
01/02/2014 9:31 AM
http://www.youtube.com/watch?feature=player_embedded&v=V0ETKRz2UCA
Bigger
Peter Jensen
01/02/2014 1:52 PM
This doesn't sound the same as a ring with square edges. I'm not going to argue, but my first thoughts were that it depends on the size of the hole; a large hole would get bigger, but a small hole would get smaller. Has anybody actually tried this, or do you blindly accept your physics text book?
Good Answers: 7
01/02/2014 2:00 PM
It's logic - linear dimensions behave similarly.
01/02/2014 7:16 PM
Logic doesn't always work in physics, especially quantum physics. The anchients thought it was logical that a heavy thing would fall faster than a light thing. They were wrong. A hole containing air doesn't have the same coefficient of expansion as brass.
01/07/2014 11:31 AM
However, air is a fluid, & takes the shape of its container.
Floss or die!
Good Answers: 114
01/02/2014 3:40 PM
Consider the plate with a grid marked on it, Say 5"x5" with 1" grid spacing. Say the plate is uniformly heated and expands 10%. The plate becomes 5.5" square and the grids all become 1.1" square. Consider 1" diameter circles drawn in each grid square, touching the grid lines before heating the plate. Would they still be touching the grid lines after the plate has expanded?
01/02/2014 5:35 PM
If you imagine you could instantaneously remove the disc of metal from the hole while it was hot or cold you can hopefully visualize that it would just lift smoothly out as the disc and parent metal will be at the same state of expansion. The hole left as the disc is removed isn't going to suddenly get bigger or smaller else the disc (still carefully maintained at the same temperature wouldn't fit back in)
The size is irrelevant... the metal doesn't know if a hole is 'big' or 'small' it has no concept of measurement units or number... or can a brass plate tell that 20 mm is in fact smaller that 1 inch?
01/02/2014 7:25 PM
That makes sense.
01/03/2014 12:59 PM
If the outer edges of the plate were mechanically constrained in a clamping system that had low thermal conductivity and low thermal expansion, such as a high tech ceramic, then the plate would be forced to expand inward, and the hole would shrink. It's likely the plate would warp, too. This of course is not the scenario posed in the question, but it is a method that would force to hole to contract somewhat.
01/03/2014 1:45 PM
If you take a bunch of balloons, and place them in the shape of this holey plate, and inflate each balloon more, what happens...?
01/03/2014 5:10 PM
They bobble around, spring away from eachother and end up under the sofa.
Wassat prove?
Good Answers: 114
01/03/2014 7:00 PM
I thought your reply would say, "Target practise."
01/03/2014 7:04 PM
Nothing.....I just like balloons....
Good Answers: 69
01/06/2014 4:33 PM
Well, in this case the picture pixels coarsen.
01/06/2014 5:36 PM
I thought I saw something like this one night on the Playboy channel. But it was late and there was alcohol involved . . .
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
01/07/2014 1:45 PM
All three. If it's a large hole it will get bigger. If it's a small hole it will get smaller. Somewhere in the mid size it will stay the same.
01/08/2014 12:41 AM
it depends on the material of the plate!
most metals (not all) get bigger with increasing temperature.
if the plates outer diameter increases, the inner diameter will increase too.
the inner diameter will do the same like the outer diameter.
01/08/2014 12:57 AM
The material was specified as brass. Oddball metals are irrelevant.
01/08/2014 1:00 AM
i don't know all the material constants and i answered before i read any comment.
Reply to Blog Entry 41 comments
Andy Germany (2); ANDYSAN (1); Ash55 (1); baxterm (1); Bricktop (1); garth (1); Geoffrey36 (2); geraldpaxton (1); jdretired (1); merc600sec (1); Mike W (1); No_eing (1); old salt (1); passingtongreen (3); Pj3ns3n (1); rickwil (1); SolarEagle (3); StandardsGuy (3); Stuart21 (3); Tornado (2); Turnmike (1); Usbport (1); user-deleted-1105 (4); walt (1); WilhelmHKoen (2); Yahlasit (1)
