Previous in Blog: Lost Binoculars: Newsletter Challenge (01/29/08)   Next in Blog: Dumbbells: Newsletter Challenge (02/12/08)
Cleaning The Pool: Newsletter Challenge (02/05/08)
Posted February 03, 2008 5:01 PM
The question as it appears in the 02/05 edition of Specs & Techs from GlobalSpec:
Tomas purchased a new swimming pool for his family. Unfortunately, after their first dip in the pool, they discovered their daughter, Juanita, was allergic to chlorine additions. Tomas tried using bromine and several other chemicals, but little Juanita also developed a rash from exposure to these harsh chemicals. She was unaffected by very low levels of the chemicals, but these would only clarify and adjust pH while leaving the algae and parasites alive. How can Tomas kill the algae and parasites and keep the pool clean without giving Juanita a rash?
(Update: Feb 12, 8:54 AM EST) And the Answer is...
Tomas should purchase a chemical free UV sterilization system for the pool. The UV water sterilization system should allow them to kill the algae and parasites and keep their pool clean with only residual levels of chlorination and pH control chemicals. Tomas will not get a rash because high levels of harsh chemicals are not required. Another benefit is Tomas will never have to add chemicals to the pool again.
Industrially, UV Light Systems are useful for sterilization, curing, analysis, identification and sunlight simulation. One manufacturer even provides a consumer product for pools, the Sentry Aqua Guard Pool System.
Re: Cleaning The Pool: Newsletter Challenge (02/05/08)
02/03/2008 6:33 PM
This is not a challenge. There are many schools of thought on the subject and each has their plusses and minuses.
The most popular choice is salt (salt chlorine generator). This provides chlorine from the salt at a low level that is less irritating to the skin and eyes (your body's fluids are saline anyway). The following link gives some of the features of the system and how it works.
Salt Pools
There are other systems, including one that uses copper. Some uses ionizers, oxidizers, and UV has been a method used in the past, too.
All of those systems work, but struggle to do the job as well as chlorine. I looked into the copper systems by Ecosmart, but found many owners had issues, particularly in warmer climates.
So far the salt systems have the majority of sales in Florida and it is something I am considering as a cost saving measure. Using chlorine is tricky because the concentration levels tend to bounce around due to usage, rain, and sun. For my pool the conversion is about $1,000 to $1,500, so it will take 3 or 4 years to pay itself back, but less work to maintain.
02/05/2008 9:07 AM
One that you missed, and I don't know if it would be applicable here: Sodium sulfite added to the pool water will generate sulfur dioxide that will kill alga, bacteria, etc. Then run the pool filter overnight and let the SO2 escape from the water, and the pool should be fine. One would likely have to adjust the pH after decontamination also.
02/05/2008 2:42 PM
SOLAR IONIZATION copper solution
Floatron is the original portable and floating water purifier combining solar electric power generation with ionization, resulting in the only solar ionizer manufactured today.
I have this system for years with no trouble.
#113
02/07/2008 11:01 AM
WHat about stabilized Bromine, as a preventive measure by starting with a clean pool, a very low concentration will prevent biofilm to get a grip.
Good Answers: 97
02/04/2008 6:47 AM
I would doze it with ozone and hope Juanita's skin can handle it.
02/05/2008 3:08 PM
Same problem with my ex wife who now has custody of the hot tub.
She couldnt handle the chems.
The spa store suggested the ozonator, a box with a germicidal UV tube
through which air / generated ozone passed on its way to the water
by way of a venturi. Never used chemz from that day on.
I Highly recommend it!
alzie
#104
02/07/2008 9:21 AM
There are many Germicidal UV systems out there that would work in this application.
The byproduct ozone that may be generated by the high intensity UV is readily removed.
This process is often used to provide ultrapure water for phamaceutical companies and laboratories.
Tony L
#105
In reply to #104
02/07/2008 9:36 AM
"This process is often used to provide ultrapure water for pharmaceutical companies and laboratories."
UV does not purify significantly - and if the water was truly pure it would be irrelevant.
What it does do is ensure that reasonably pure water is ultra-sterile.
So far as pools are concerned, it sterilises the water leaving the purification plant, but has little impact on bugs that live on the pool liner (or in the grouting). Most pools also require a "wandering" mechanical scrubber to keep the levels on the walls under some sort of control. Maybe the scrubber could be combined with a UV source?
#106
In reply to #105
02/07/2008 10:19 AM
Putting a mobile device into the pool that is powered by electricity is a little scary.
#108
In reply to #106
02/07/2008 10:30 AM
You would have to use intrinsically safe techniques - isolation, LV plus??
#109
In reply to #108
02/07/2008 10:43 AM
I agree. However, how do you make it idiot-proof so that you can't accidentally have UV exposure? I am thinking that our eyes are vulnerable to any UV leakage.
#111
In reply to #109
02/07/2008 10:58 AM
Difficult one that.
I can't think of a method other than disabling it when the pool cover is not fully across.
Perhaps someone can build on combining a pressure sensor with an acoustic system that checks both the presence of water and of a hard solid at the correct distance?
#116
In reply to #106
02/09/2008 10:34 PM
Um in Australia we have had scubbers like this for past 30 odd years, creepy crawly, barracuda are a few name brands...
#117
In reply to #116
02/11/2008 5:01 AM
Curious. Nearly everywhere else the pump is stationary and the scrubber itself is water-driven.
02/04/2008 7:47 AM
Commercial water treatment systems are starting to use ultraviolet light to kill all the organizisms in water. Get a 500 watt UV purifier and put into the flow stream of the filter. The UV unit is basically a light in a tube. The pump may need to be upped in capacity, but the UV light can also ack as a heater too.
This would certainly leave the water a bit better tasting than salt, for those times you forget to close you mouth.
02/04/2008 8:23 AM
You only need 2500 - 3000 parts per million salt concentration so you can barely taste that at all. It is nothing like the ocean.
UV gets expensive with electricity and the lamps loose efficiency. Additionally, you still need to add something to sanitize the pool because only a portion of the total water is actually sanitized. It takes a long time to circulate the whole pool's water. Finally, UV will not stop the algae from growing on the pool walls. So, you are resigned to add chlorine or some other algaecide to keep that in check.
The above problems are also the problems with the EcoSmart system.
Even standard chlorine is not that bad if, and that is a big if, you keep your eyes on the chlorine and pH levels like a hawk. You don't need excessive levels to keep your pool sanitized and crystal clear, but the problem is keeping the levels constant in a dynamically shifting environment. So we tend to overdose it, then the levels drop, overdose it again, and it is a vicious cycle.
The other half of the pool equation is pH levels. EcoSmart is really fussy about pH. Salt systems are more resilient to pH fluctuations. I don' know about UV, but we already know that you still need to add chlorine or bromine/copper to keep the algae in check, so what does that give you as an advantage when you develop rashes to bromine and chlorine? Copper also stains the pool if you add too much.
02/04/2008 1:00 PM
Can algae etc. can be kept down with periodic overnight Cl2 dosing + neutralisation cycles to leave a minimum safe level of salts during the day, or is this a ridiculously expensive solution?
02/04/2008 1:48 PM
My understanding is that salt water pools require virtually no additional algae control.
My neighbor has the salt system and claims very little maintenance, or at least lower maintenance compared to standard chlorine treatments.
My family and I really don't have reactions to chlorine, but I want lower maintenance costs and effort to keep it clean. If I lower my chlorine level too (i.e., salt, etc.), then that is a bonus.
02/05/2008 9:36 AM
Wouldn't that depend on the local climate? In damp subtropical regions I understand that pure-NaCl would either require higher levels of salt than most people like, or some type of supplement.
02/04/2008 4:09 PM
Yes that is true with UV but also with salt systems, the salt does not kill all algae and definitely does nothing to control bacterias. The chlorine can do both but the salts will have to supplemented with other methods to get rid of the bacteria or you can get very sick from your pool.
So salt is definitely not the panacea that is first proposed.
02/04/2008 5:06 PM
Are you sure? My understanding is the salt is used as the chlorine generator. Water (with a very mild concentration of salt) is passed over a set of specially coated plates, which generates an electric current that breaks down the salt and water into their basic elements to form hypochlorous acid, which is the active sanitizer in all forms of chlorine.
So the pool does have chlorine, but it is derived by the salt. The big advantage is that the level of chlorine is very low, but the concentration levels are very steady and more resilient to pH shifts in the pool.
The concentration of salt used is very, very low. You can barely taste it.
Like I said, this is not the only way to treat your pool without adding traditional chlorine, but it is one of the more common ways to do it and supposedly at a lower maintenance cost.
Good Answers: 58
02/05/2008 1:43 AM
Agree. This system was used extensively in the magnificent climate of Zimbabwe and worked well (actually nothing works there anymore), but has found little favour in the more tropical like climates of the East Coast of South Africa.
02/05/2008 7:48 AM
This tends to negative the original reason for the blog. The child is sensitive to trace amounts of chlorine, which is what the chlorine additives do. It is chlorine in an ionic state which the additives generate chemically that the salt will generate electronically. So for the sake of this blog, you can use the salt, but you can not ionize the chlorine out of it as suggested.
If the child is that sensitive to chlorine that she can not swim in a pool, the child would also have problems with normal tap water, as it is treated with chlorine. They would have to neutralize or filter the chlorine out of the drinking water to keep the child safe.
02/05/2008 8:16 AM
Reread the challenge puzzle. It stated that "She was unaffected by very low levels of the chemicals".
So, salt ionization seems to fit the requirement (as do a few other systems).
02/05/2008 2:32 PM
I agree. UV is the safest non allergenic method for purifying large quantities of water. These systems are widely used used in bottling plants where the flow rates are in thousands of gallons per hour.
intellectuals solve problems, geniuses prevent them ~ Einstein
02/05/2008 2:46 PM
Well, you still need to add an algaecide because UV will not stop algae from growing on the pool walls.
The pool walls do not pass through the UV chamber, so they are never sanitized.
This is the same problem with EcoSmart, ozone, and other systems that rely on passing pool water through any chamber for sterilization.
02/05/2008 4:06 PM
Very true, however the question was about reducing or eliminating the lady's reaction to chemicals and I would hazard a guess that most algaecides would also provoke her sensitivity. As one contributor suggested algae can be manually removed by suctioning the surfaces with a pool vacuum.
Prior to the acceptance of algaecides as partial remediation for pool maintenance pools were periodically drained and washed with a mild solution of Muriatic acid. This was also done to prevent an accumulation of polio viruses which at that time, were thought to be more prevalent in swimming pools.
UV sterilization, and as other contributors have suggested, Ozone infusion are the least chemically polluting methods of diminishing or eliminating any dermal aggravants from the pool water. Adding chemicals, no matter how benign, may cause other adverse reactions in dermally sensitive persons.
In reply to #65
02/05/2008 8:49 PM
Great point, but rereading the challenge puzzle it states, "She was unaffected by very low levels of the chemicals, but these would only clarify and adjust pH while leaving the algae and parasites alive. How can Tomas kill the algae and parasites and keep the pool clean without giving Juanita a rash?"
That is why the salt water system comes to mind. The residual Hypochlorous acid is very low and deals with both sanitation and algae in one shot.
Not a perfect solution, but there isn't a perfect solution out there, except a good Boddingtons ale, which I would not waste by filling a pool with it. So if you pardon me, I will have one as an evening drink. ;-)
02/04/2008 11:19 AM
Yes use Poolsan...
02/04/2008 12:26 PM
Dell, have you used Poolsan and what has been your experiences?
TNX
02/04/2008 12:40 PM
Not used it myself, but we are developing dosing systems with the manufacturer (for various pool sizes (spas, domestic pools, public pools)...all the data looks V good... it still needs ph correction and regenerator to get the redox level right... so you are looking at 3 chemicals... the Poolsan itself uses Cu++ and other ions to do it's funky thing. They have several test sites which we are dosing into with good results....none of that nasty chlorine() stink .
02/04/2008 12:50 PM
Interesting. Have any tests been done in Florida-like environments. It gets hot and humid here and we use the pool 9 to 10 months a year (solar heated). Also, we get lots of rain at time, which not only brings in contamination, but plays havoc with the pH.
Have any cost estimates been done? I think our pool is almost 80,000 liters, in-ground, and has a vinyl liner.
The EcoSmart system uses Cu rods for the redox process, but reading through the various forums, systems like this have not fared well down here. However, it is hard to really get a true unbiased report and the conditions (environmental, etc.) of use vary widely.
02/04/2008 1:08 PM
Bottom line is you need complex auto dosing which monitors ph and redox, or a system which allows you to enter a ph, O2 and Cu++ reading into the dosing system which will then dose appropriately.
This may be just once a day, or every couple of hours in a commercial pool. The big problem is reacting to changing conditions/bather load/rain etc (This is with respect to regenerator mostly)
The fully automated systems are V expensive...the prob with poolsan is it is difficult to get a reliable cheap Cu++ ion sensor.... but for a smaller pool (e.g. yours) manual read/auto dose it is fine (or manual read semi-auto dose)
The amounts of poolsan dosed are V small. The main dosing problem is the regenerator which can require pretty big doses say 100L a day depending on usage, so it is being dosed virtually constantly ( say every 10 mins), a 'shock dose is provided to boost the regenerator dose for those occasions when 30 kids suddenly turn up and pee in the pool .
Bear in mind I'm no chemical guy..I'm just trying to develop systems with these guys (who don't really understand what I can make the software do...) We are also talking to dosing system installers and users to try and produce a simple reliable user friendly system.
It is probably best to consider ph as one system and the poolsan/regen as a second system (or maybe 3 separate systems.... heck I dunno I'm just a cat...[until I go into work then I have to pretend to be a people ])
02/04/2008 2:16 PM
I would assume that 100 L per day is for a commercial pool?
02/04/2008 2:28 PM
Correct....
02/05/2008 7:52 AM
This sounds like an excellent answer to the pool problem. This probibly hwat the blog had in mind for an answer.
02/05/2008 8:31 AM
Maybe, but I can't find any distributors in the USA. Also, I don't know if it will pass local code here. It may be too new.
Good Answers: 94
02/05/2008 12:09 PM
"we use the pool 9 to 10 months a year"
You're just showing off now, in the UK we're lucky if we get 9-10 days a year to use an outdoor pool.
02/05/2008 12:51 PM
Well, you will have to just take a trip over the pond and look us up. ;-)
My brother and his family dropped in from the frozen north (Buffalo, New York) in January. When they got here the pool was a cold 73° (23°C), but they jumped right in much to our surprise. They said that their pool only gets to 75°F in the middle of summer, so they thought it was a real treat.
P.S. Bring some good brew. ;-)
Good Answers: 94
#81
02/06/2008 4:27 AM
"P.S. Bring some good brew"
Therein lies the problem, I buy the lovely real ale (which we have in abundance locally) take it home then think 'I may as well have just one, it can't hurt'. Several beers later I find that I am strangely unable to travel.......
Location: Somewhere in the hills of Pennsylvania, I think.
02/04/2008 10:49 PM
Hendrik has the answer. Put an ozone generator on it.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
02/05/2008 1:38 AM
I recalled reading an article about naturally balanced swimming pools. Here's what I found when looking that up:
Natural Swimming Pools
Do you like swimming in your backyard but hate the green hair syndrome? The natural swimming pool is a hot new trend in backyard recreation. It takes the popularity of water gardens to new heights with chemical-free swimming. That's right, the natural balance of a lake and the convenience of a backyard pool. No maintenance, no testing, no chemicals and less electricity use are the benefits of this environmentally friendly backyard-swimming oasis.
Natural swimming pools are fairly common in Europe but just starting to take off in the United States as people are becoming more interested in a lifestyle of simplicity and natural beauty. These pools are fairly complicated to build and run 10-20% more than a traditional in ground custom pool. You can keep the size down and the landscaping around the pool at a minimum to cut down some of the cost. The goal is to achieve a balanced eco-system just like in a lake where rocks filter particulates, plants beat out algae and a natural bacteria additive keeps the water clear and safe. You can even add fish (in fact, it's recommended!) to complete the cycle.
Natural Swimming Pool Tips
Go to a professional to get a good pool design with "bog filters", lots of plants and some streams to aerate the water
Find a contractor who has not only water garden experience but specific natural swimming pool experience
Don't swim in smelly or cloudy water - hire an expert to help get your pool back in natural balance
Check with local authorities for code requirements
Other Information and Resources
www.lostedenponds.com Local contractor installing ponds
Headberg Landscape Supplies / 651-423-5048
ask for Kevin Berry - Water Gardening Sales Manager
www.motherearthnews.com Do it yourself natural swimming pools
tom
02/05/2008 4:22 AM
I think he needs to install big heating elements and boil the pool every week.
If the water is heated up to 100°C for one hour, all bacteria will be killed.
Of course, he will lose some of the water by evaporation, but that is a small price to pay for a clean pool.
As regards the algae, he can get rid of those with the suction cleaner.
02/05/2008 10:17 AM
"I think he needs to install big heating elements and boil the pool every week.
Of course, he will lose some of the water by evaporation, but that is a small price to pay for a clean pool."
This is really the weirdest solution I could find on the blog. Let's make a small calculation:
Let us assume that we have a nice swimming pool with dimension 7m X 3.5m X 1.5m = 36,75m³ of water.
Heating up all this amount of water from swimmingtemperature of 28°C to 100°C every week will require
36750 kg water X 72° X 4,196 kJ/kgK = 11 102,616 MJ of energy every week. This is an equivalent of the energy required for heating at least 10 houses for a whole year.
Knowing actual prices for energy sources as oil, gas or electrical energy, I certainly would not talk about 'a small price'.
second consideration to be maid is that once the water has a temperature of 100°C, you can no longer use your pool and you have to cool down again the water.
I follow more the opinion about ozone or the salt solution. They are both reliable and affordable solutions to reduce chlorineconentrations in the water
02/05/2008 10:35 AM
I can't imagine the cost of heating 20,0000 gallons of water every night and then cooling it to a comfortable 85°F (30°C) for normal swimming during the day.
Also, there goes those late night private dips we like to enjoy!
I have solar heating and in the winter it runs full tilt just to get the water to 75°F - 80°F on sunny days in January. I just checked the temperature yesterday evening and it peaked at 83°F. Ready to start swimming again!
02/05/2008 11:00 AM
Guys, GUYS! (Guest and AH) Come on! I think "tradestar" meant the suggestion as a joke, and you guys took the bait! He is probably laughing at you right now!
Hmmm.....I wonder what the effect of running an uninsulated high voltage cable through the water would be. Might it kill the bacteria and algae or at least provide an inhospitable environment to prevent their growth?
Hmmmmmm......
You could install motion sensors around the pool that cut off the current when humans or pets were around. However, with an appropriate sensitivity, insects would not trigger the cut-off and you could have a great bug-zapper as a bonus!
02/05/2008 11:03 AM
"Guys, GUYS! (Guest and AH) Come on! I think "tradestar" meant the suggestion as a joke, and you guys took the bait! He is probably laughing at you right now!"
Well, at least I am providing some good amusement, so I am happy to bring some, even at my own expense. ;-))))
02/05/2008 4:48 AM
Go with Hendrik on ozone sterilized pool, or go with Tom.. on the natural one. The first one is the KISS solution, particularly with an aereator added to flush out remaining ozone, the second one is the real McCoy, but tricky, if some pathogen gets past your attention. It is your skin...
Good Answers: 97
02/05/2008 5:43 AM
To get back to ozone. It is a great bacteria killer, and fortunately decays quickly.
It however a pollutant at large concentrations.
The following link is one to be found on the net:=
http://www.p2000.umich.edu/recreational/r3.htm
Ozone can be produced by ultraviolet or corona discharge and more.
I think it can be used but the production of bromate should be monitored.
02/05/2008 7:57 AM
Looks like all solutions have drawbacks!
02/05/2008 9:41 AM
Ozone purification
02/05/2008 10:23 AM
What a wonderful group of informed responses. Check out www.halopure.com I just completed a test using a combination of their products to clean an industrial water mix. The effluent was Vibratory deburring discharge with high concentrations of ceramic and steel. After just 10 passes through a pressure filter, I could drink the water. They are very close to receiving US EPA approval on the product group I tested. It is already being used in India. They have a patented process where they capture chlorine in small polystyrene beads. The chlorine reacts to organics on contact, never releasing into the fluid stream. I combined that product with their Chitosan flocculant to achieve my results. I have never seen this level of efficacy on this particular discharge. We will be implementing the process soon on site. I suspect cleaning a pool would be relatively easy.
Inga Binga Bunga Banga Boonga Binga Buuuunnnnga
02/05/2008 10:30 AM
Install an AZONE generator.
02/05/2008 11:16 AM
http://www.parpool-spa.com/Page/PoolCare/Nature2_Natural_Pool_Purifiers.html
http://www.parpool-spa.com/Page/PoolCare/BioGuard_Optimizer_Plus.html
Check these two sites out. My wife is sensitive to chlorine and won't even go into a hotel pool where chlorine levels are actually unheathly in my opinion. We have about five years experience with Optimizer Plus and two years with the Nature 2 purifier at our home in Northern IL (we can have very hot periods, too.) Since we need a new liner, we have experienced the pool both with and without optimial level of Optimizer Plus (OP). We added OP once five years ago. With the recommended quanity (for our 20,000 gallon pool) the pool water is very stable, doesn't seem to bounce around Ph wise, and the water feels great, stays clean, looks good, etc. Last summer, we used more water due to our liner needing replacement, and as a result OP levels dropped to around 25% of recommended amount. We had lots of problems keeping the pool from turning green, etc., but we resisted adding more OP since we plan to replace the liner this spring. We can't wait to add OP, it works so well. As for the Nature 2 sanitizer, we experience less chlorine and sanitizer needed to maintain a balanced pool. We really like both products (my wife especially appreciated OP). You might want to try these two products.
02/05/2008 11:26 AM
Nice find. How often are you replacing the cartridge with Nature 2? I am trying to get a handle on operational costs. You still need a very low level of chlorine or equivalent it seems (which I am okay with).
Do you have a cost estimate for Optimizer Plus? I know they make claims on the website, but it is better to hear it from actual users.
If you were to rate each product, which do you find best and why?
02/05/2008 11:30 AM
Tomas could stock the pond with algae eating snails, or even shrimps. The numbers can be controlled with a regular pool-side BBQ. Whatever he does, Juanita will change sex if the last question is anything to go by.
02/05/2008 12:34 PM
Use OZONE to purify the pool water. Economical ozone generators combined with ultra-violet light purifiers work well for private pools which have limited pathogenic agent contamination potential.
'Public' pools which may have large numbers and high peak load contamination risk need a residual sanitizer (chlorine or bromine) in the water to insure sanitary status is maintained.
Keith E Bowers, PMP
02/05/2008 12:55 PM
Draw a slipstream (does he use a recirc pump ?), add the appropriate concentration of chemicals to do he job and return the slipstream to the pool. Dilution should ensure the daughter does not develop an allergic reaction.
Bhima
02/05/2008 12:55 PM
Just drain the pool and walk away. Pools are a pain to mess with.
#118
02/12/2008 10:37 AM
At last! The only sensible solution!
Reduce your 'eco footprint' and gain plenty of extra time to actually live your life. you would even have time to go down to the swimming pool and enjoy company while you swim in a biiiig pool.
United States - US - Statue of Liberty - Who is John Galt?
02/05/2008 12:57 PM
Little Juanita should smear with mineral oil before swimming, as a moisture barrier! *NOT* OK Sorry!
Why couldn't this thread come out last week? I really really need a lowest TCO solution as I'm shopping for 45X pools...
Anyone have a reliable & cost effective solution *before* I commit to 45 new pool filters & supporting systems?
Posting is fine or if you prefer confidentiality -- inventhelp [at] stxvi [dot] com
Thanks!
I'd've written a shorter post, but I didn't have the time.
02/05/2008 1:04 PM
An excellent new method of providing sanitation and keeping all other life forms from growing is to use nano-particle silver in the water. Very low concentrations are effective. Nano-particle silver is so effective that many hospitals are now using it in wall paint, equipment coatings, sterile drapes, dressings, etc.
Keith E Bowers, PMP
02/06/2008 1:33 AM
During WWII, England and the US provided troops in certain locals where obtaining good water could be problematic, small hand pumped filters with diatomaceous earth cartridges embedded with particulate silver, that were so effective that with one pass even raw sewage water could be rendered safe, and clear for drinking. These types of filters are still available for drinking water, and larger scale filtration.
In reply to #78
02/06/2008 8:00 AM
Actually these filters are still widely available. They are sold at any sporting goods store, for avid hikers who go deep out into the natural spaces where no processed water sources are available.
02/05/2008 1:14 PM
go to the following 'url' are read about silver ion disinfection power and utilization. No more chlorine needed its obsolete and ineffective by comparison
http://www.silverinstitute.org/news/4d1997.htm
Keith E Bowers, PMP
Location: East of Seattle, Washington state Republic of the 50 states of America
02/05/2008 1:22 PM
You beat me to it. score 1 from me.
Brad
02/05/2008 1:23 PM
There are many many ways to do this
Ozone would certinly work but is expensive as you need pure oxygen and lots of electricity to produce it.
UV light with peroxide as an oxidizer is very efective and not as expensive.but would the peroxide bother her?
there is also a way to mix chlorine with ammonia to come up with chloramines that may not bother her skin since the chlorine are bound to the ammonia and last longer than free chlorine and is more stable
02/05/2008 1:58 PM
Mix chlorine and ammonia??? You're dangerous!
02/05/2008 2:38 PM
Agreed! Here is why:
http://www.bbc.co.uk/dna/h2g2/classic/A795611
02/05/2008 3:53 PM
mixing chlorine and ammonia happens every day at most larg water systems
NH2Cl is commonly used in low concentrations as a disinfectant in municipal water systems as an alternative to chlorination. This application is increasing. Chlorine (sometimes referred to as Free Chlorine) is being displaced by chloramine, which is much more stable and does not dissipate from the water before it reaches consumers.
In reply to #63
02/05/2008 3:59 PM
So-called chlorine intolerance or allergy is quite commonly an allergy to Chloramines rather than the Chlorine itself. Here is an extract from the Wikipedia reference you cited; it's from the section headed "Situations where NH2Cl should be removed"
"Chloramines, compared to free chlorine, are both less effective as a sanitizer and more irritating to the eyes of swimmers. When swimmers complain of eye irritation from "too much chlorine" in a pool, the problem is typically a high level of chloramines, caused by too little chlorine in relation to the amount of organic matter."
In reply to #63
02/05/2008 4:50 PM
The difference, my dear Guest, is that in the one case you have a controlled chemical process being carried out very carefully by trained, experienced, technical personnel in a closed system where the results are carefully checked and rechecked before the product is released to the public through a distribution system that keeps it free from contamination.
In the other case you have an untrained, non-technical homeowner, often distracted, rarely reading instructions or heeding warnings, typically dumping chemicals first and checking later to see if results are anything close to what he was trying to attain. Not a good way to mix chemicals which have potentially dangerous or hazardous products, especially when protective gear and safety equipment is not available.
#121
02/12/2008 1:10 PM
IN ELEMENTARY SCHOOL WE WERE INSTRUCTED NEVER TO MIX CHLORINE AND AMMONIA. DOESN'T THE MIX EQUAL MUSTARD GAS?
In reply to #121
02/12/2008 1:54 PM
When you mix amonia and bleach together the product is chlorine gas. Bleach is usually the most conveinient source of chlorine available for residential use.
Many have tried to mix the two substances together to hopefully enhance their cleaning abilities. However this is usually a once in a lifetime experiment because the chlorine gas released results in spasmodic contractions of the diaphragm which inturrupts breathing and copius tear production in the eyes.
Continuing the exposure can lead to death. Surviving chlorine gas exposure still leaves a most undesireable effect which is only detectable several years later. The vascular system, scarred by the highly active chlorine molecules, accumulates plaques of chloesterol and calcium in those scars.
Ultimately enough plaque is accumulated to affect arterial elasticity resulting in "hardening the arteries" leading to hypertension (high blood pressure) and vascular disease.
02/05/2008 1:53 PM
UV light
02/05/2008 2:15 PM
For algae and parasites, a UV sterilization system should work.
02/05/2008 2:21 PM
not an engineer or anything , but isnt there a way to take the pool water and outside the pool run it through a cultured natural marine biological environment, simple fishtank with lots of snails and things that keep water bacteria out, then put it back through a natural medium on its return path back to the pool.
obviously there is a large body of water but arent there natural biological things that just keep on eating the smaller things than themselves that could be used.
I know it works in a fishtank, perhaps also create a sacraficial anode type environment so to speak within the pool to make it more worthwhile the stuff that you kill with chlorine to live in a quarantined area so to speak, and then draw from there the waqter that gets to the outside living bacteria controlling environment.
A put and take system could be used whereby the water is drawn out low, heated via solar technology as it rises through the environment and then at its warmest, tapped off and gravity fed back through a cooling environment somewhat like a still at which point it could enter the pool.
You all might think I have too much time to think and my lack of knowledge reflects but some of the brightest ideas in the world happened from people extracting parts of far fetched ideas and combining them.
any comments, just email deadroo243@yahoo.com.
02/05/2008 2:49 PM
Ozone is radical oxygen that just loves to "combust" organics. Ceramic plates made of anatase (TiO2) are photoconductive and serve as electrodes in some ozone generators, avoiding metals reactions with the water and current. Anatase is also known to enhance cleanup of biological molecules in air or water in the presence of UV light at a rate that is 10,000x times greater than UV alone. UV light on anatase dissociates water to H and OH radicals that reduce organics to carbon and water.
So we have two possible ways to clean a pool withut chlorine 1) generation of ozone using commercially available ceramic plate generators and 2) the use of anatase coated solar or LED illuminated plates (which also could be used to generate ozone if current were applied).
02/05/2008 3:00 PM
By putting a small electric current through two copper electrodes thus putting copper ions in the water which the bugs don't like. small breif but to the point.
Regards Brendan
02/06/2008 8:08 AM
Have you noticed the price of copper recently!!
02/05/2008 3:20 PM
Just change the water every day,
DO what they do around here, damn up a river, it turns into a pool with an overflow over the dam.
Water stays clean, people like water, viola,
Either that or go to a beach, I prefer Florida Keys
02/05/2008 3:21 PM
Ozone injection.
02/05/2008 3:47 PM
Tomas needs to install a ozone generator and blow ozone through a diffuser into the pool water, a simple and cost effective solution adding great health benefits.
02/05/2008 4:12 PM
High,
RE: CLEANING THE POOL
I understand that many modern pools use Ozone as a disinfectant.
Our local pool does and seems to be clear of infections.
I have not gotten involved in the details of the process - after all I just swim there!
I believe that Chlorine is used downstream to clear the outflow?
Sleepy
02/05/2008 5:18 PM
The obvious answer is to use an ultra violet irradiation cell after the filter, which destroys some of the unwanted matter. However, less well known and much more effective is to pass the return water through an ultrasonic cell which destroys the bacteria and algae much more thoroughly.
Good Answers: 97
02/05/2008 5:25 PM
When I was a boy we used to leave a inflated car inner tube in the small farm reservoir( (also used for swimming). It did control the algae to some extend. The tube also provided a relaxing seat.
Where I stay we have saturated dolomite water. The Ph is over 12 and the calcium carbonate is about 300 ppm. Pools turn from clear to an ugly green in minutes at the hint of an electric storm. Most of the proposed methods won't really work properly here. The girl won't last here, thats for sure.
Over here it would be best to immunize her against the allergens.
02/05/2008 6:37 PM
I would put a pump in the water and shoot the water into the air thus oxiginating the water and cleaning it of any impurities
Bill
02/05/2008 6:56 PM
My first response, so please be gentle.
Everyone seems focussed on killing the bugs (My vote is for UV light treatment). What about the filtering to remove the organic residue (from the algae and such) to stop that becoming nutrient for later life cycles?
In Australia we use "creepy crawley" devices that run from the filter suction and scrub the pool walls while no-one is around. The water is filtered through sand, activated charcoal or diatomacious filter materials.
Seems to work here
In reply to #71
02/05/2008 8:33 PM
Welcome to CR4!
Not a bad plan. The UV and ozone techniques are valid ways to oxidize the pool water (albeit a bit expensive on electricity). The wall scrubbers probably do a good job at keeping the algae at bay on the walls and floor, which is a weak spot for the UV and ozone generators.
I don't know what would be involved with filtration at that level.
In reply to #71
02/06/2008 2:30 AM
You are safess with us preciousss, come in and take a seat resssst your weary footsiesss (to be read in Gollum voice).
Welcome aboard It's always nice to have another victim member
Del (the ship's cat)
In reply to #71
02/06/2008 3:19 PM
I also join Anonymous Hero in welcoming you. Your vote for UV light treatment echos that of many contributors. The idea of filtration removing organic residue which may become nutrient for later life cycles and your suggestion of using a 'creepy crawler' to scrub the pool walls are excellent. Thank you for joining CR 4.
02/05/2008 9:03 PM
If you want to stick to chemical treatment of the water, you could dose the pool at night (after sundown) with liquid chlorine bleach. By noon of the following day, the sun would have dissipated most of it. This should be OK for the little girl to swim in. If you start with good water and follow a good water maintenance plan, you should be able to have good, clean and sanitary water using less chlorine than found in a municipal water supply (and we drink that!) I do think that it is necessary to shock the pool water once a week (with a larger dose of chlorine) to eliminate any "bugs" that may be building a resistance to the low chlorine concentration.
02/05/2008 9:49 PM
ozone, uv, sand filter
02/05/2008 10:08 PM
Although previously mentioned, silver and possibly copper ions are particularly good at keeping bugs down in water, whilst only being present in parts per million concentration.
The following link is to a suppplier of such a pool system:
https://www.aquamatics.com.au/
There are water filters using silver for making drinking water from tap water, showing how harmless silver is when in minute concentration.
However the above answer seemed obvious, and not a challenge, and so I will put on my thinking cap to come up with an answer or 2 from outside the square.
One is don't let Juanita swim!!!!!
The other is use the minimum of chlorine to effectively dose the pool and filter the water with activated carbon.
02/06/2008 12:04 AM
No one has mentioned hydrogen peroxide(H2O2). We used hydrogen peroxide on our farm in our water system. It was injected into the water with a metering pump. It was simple, cheap, and effective. The anaerobic bacteria are the harmful ones and these would be targeted by the hydrogen peroxide. An occasional shock treatment could be used in combination with the hydrogen peroxide to provide a complete solution in case the water got out of balance. The pool could be avoided by Juanita for a few days while the chlorine cleared. Hydrogen peroxide is produced by our own cells to fight harmful pathogens. Highly concentrated hydrogen peroxide can cause severe burns and should be handled carefully.
#107
In reply to #77
02/07/2008 10:24 AM
You may be interested in this link: H2O2
Not the panacea that I was hoping it would be in hot environments where I live. That and it is not approved as a stand alone treatment because compared to chlorine (or ozone, chlorine dioxide, or uv-light), H2O2 is a rather poor disinfectant. So you need to use it as a supliment.
On the plus side, H2O2 does break down chlorine, so shock treatments would be rapidly dissipated.
#110
In reply to #107
02/07/2008 10:47 AM
"H2O2 does break down chlorine". Does that help?
[Presumably the end by-product is a pair of Chlorine ions? Wouldn't this stay in the water and be a more reactive form of chlorine?]
02/06/2008 2:54 AM
The option for using Ultra Violet light is a known solution for algae in ponds, I have been successfully using a UV filter for many years in my Koi carp pond. This is also thought to kill some bacteria and parasites although I don't think you could rely on it to kill all the bacteria and parasites so perhaps some additional measures would be needed. The Koi are still susceptible to bacteria and parasites probably because the UV filter is inline with the pump and only ensures that the returned water is treated, if there are any dead spots where there is poor water circulation then this water would not get treated to the same level and thus allow parasites and bacteria to survive. The difference is quite amazing, the pond can go from only being able to see 5 or 6 inches down to crystal clear (see the bottom 5 feet down) in about 3-5 days. These are cheap to run as they only use a few watts of electricity. They can affect the PH as the algae dies and this may need to be checked.
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
02/06/2008 7:40 AM
Easy.
Convert the pool to salt water.
"Nothing, is as it seems." Dr Wally.
Good Answers: 266
#85
02/06/2008 8:12 AM
UV light sanitizer in the intake to the filter. May have to increase pump and filter to better handle the turn over of the water. Or separate the sanitizer. Aerating the water will help also.
3Doug (1); ad4yt (1); agricola (1); agua_doc (1); alzie (1); Anonymous Hero (20); Anonymous Poster (44); askjoet (1); Cardio07 (1); cuznmonkey (2); FKIA (5); funtlrn (1); Goanna (1); Hendrik (3); InventiveFarmer (1); johnfotl (1); Just an Engineer (1); Keith E Bowers (3); Kris (2); leveles (1); Nigh (2); ozzb (1); RickLee (8); Sleepy (1); STL Engineer (4); Student (1); Stueywright (1); taejonkwando (4); The Prof (1); tick-tock (1); tomfranpat (1); tradestar (1); U V (1); user-deleted-1105 (6)
