Previous in Blog: Cleaning The Pool: Newsletter Challenge (02/05/08)   Next in Blog: Night Fishing: Newsletter Challenge (02/19/08)
Page 2 of 3: « First < Prev 1 2 3 Next > Last »
Dumbbells: Newsletter Challenge (02/12/08)
Posted February 10, 2008 5:01 PM
User-tagged by 1 user
The question as it appears in the 02/12 edition of Specs & Techs from GlobalSpec:
You have a dumbbell (similar to the ones used in weight training) consisting of a rod of a certain length (l) and two masses (m) at each end. The dumbbell is standing vertically in a corner formed by two frictionless planes (a wall and the floor). When you move the bottom end slightly away from the wall, the dumbbell begins to slide. Determine the speed of the bottom end at the exact moment when the top end loses contact with the vertical plane.
(Update: Feb 19, 8:31 AM EST) And the Answer is...
You have a dumbbell (similar to the ones used in weight training) that consists of a rod of length l and two masses (m) at each end. The dumbbell is standing vertically in a corner formed by to frictionless planes (a wall and the floor). You move the bottom end slightly away from the wall, the dumbbell begins to slide. Determine the speed of the bottom end at exactly the moment when the top end loses contact with the vertical plane.
(Feb 20: 11:05 AM) D'oh, sorry about that: Here's the Correct Answer:
At the moment when the top mass loses contact with the wall the normal force is zero (hence its horizontal acceleration is also zero). A free-body diagram of the system is shown below.
Let be the vertical velocity of the top mass, and let the horizontal velocity of the bottom mass. Knowing that we can write
(1)
We can express gravity as a function of the vx , as follows
By substituting the value of vy from Eq. (1), we have
(2)
From the above equation we can determine the horizontal speed, which is given by
(3)
But this equation is still a function of y, a variable. Let's see if we can find a function that relates y to known quantities.
Like all isolated systems this system has to conserve energy. Let's assume the frame of reference to be the horizontal axis (the floor). The total energy before the bottom mass starts to slide is simply given by the potential energy of the top mass, or
(4)
The total energy at the moment the top mass looses contact with the wall is the sum of the potential energy of the top mass and the kinetic energies of both masses. In equation form we have,
(5)
The law of conservation of mechanical energy states that , or in equation form
By substituting Eq. (1) into the above equation we get,
(6)
Solving this equation for y, we get
(7)
Now, substitute Eq. (3) into Eq.(7) and solve for y, or
and
Finally,
(8)
By substituting Eq.(8) into Eq.(3) we finally get the speed of the bottom mass at the moment the top mass looses contact with the vertical wall, or
And
(9)
Note 1: It is interesting to see that Eq.(8) gives the height at which the top mass of the dumbbell looses contact with the vertical wall. One might think that this will happen only when y=0. Remember that the rod is not a flexible device.
Note 2: According to Eq. (9) the speed of the bottom mass is only dependent on the length of the rod (r) that keeps the two masses at the same distance from each other. For a given dumbbell this is a constant, so the horizontal speed is a constant. This is expected because our two planes – the wall and the floor (as is clearly stated in the question) – are frictionless.
#103
In reply to #98
Find in discussion
Re: Dumbbells: Newsletter Challenge (02/12/08)
02/18/2008 7:05 AM
The lower end remains in contact with the floor, the only change is that the upper end reverses its vertical component - with a velocity that depends on the coefficient of restitution. What is clear is that it never again reaches the vertical - because the energy available to be converted back to PE does not include the horizontal component of the KE.
Fyz
In reply to #103
02/18/2008 10:36 AM
Thanks Fyz. If we remain in this theoretical world (and consider the end masses as points), is it possible to quantify the position to which the mass (at the wall end) bounces ? I'm tring to envisage the situation with constraints like that previous challenge question, with perfect elasticty of the balls. While the KE is recovered by way of PE gain, the whole assembly will have rotational + translational components of movement (?)
#108
In reply to #104
02/18/2008 11:59 AM
The maximum vertical height at least is quite straightforward - the horizontal velocity of the centre of gravity is (1/3.gn.l)½.2/3. Both vertical KE and inertial KE are zero when the rod reaches a maximum height, so the loss in peak potential energy is just what is stored in lateral kinetic energy, or m.x'2/2 = 2/27.m.gn.l. That will reduce the maximum height following elastic bounces to (1-2/27)0.5.l
In reply to #108
02/19/2008 2:38 AM
Thanks for the clarification Fyz.
#116
In reply to #114
02/19/2008 4:43 AM
Regarding your tag line - is there really any need to encourage men to think about nuts?
In reply to #116
02/19/2008 7:19 AM
Haven't a clue what you mean.
In reply to #98
Find in discussion
02/20/2008 7:10 PM
Kris -- this time I don't think I am guilty of introducing perfectly elastic bouncing balls, but the question you raised (104) and the reply by Fyz (108) have added to the spice and the substance. How I'd love to watch that dumb bunny hopping along to infinity, nose never leaving the floor, but rear end bobbing up and down.
The original bouncing balls issue pre-dated my blundering into CR4 (belatedly in that interminable boxes and coins affair). But I was fascinated by it, and was quite disappointed by the official answer, so I tried reading up more on the subject. Admittedly I could not 'solve' the problem and perhaps it should be redefined with additional conditions. But I was convinced that the much-quoted analogies with bouncing tennis balls or basket balls were way off track. The elastic behaviour of a stretched membrane enclosing a gas under pressure involves many parameters which do not pertain to solid spheres at all. Despite wading through the Hertz equations for impact between spheres, contact stresses and deflections, velocity of sound waves, etc. I did not arrive at any profound conclusion worth sharing in CR4.
For the present problem however, I think the methods using velocity poles or instantaneous centres of rotation (as taught in Theory of Machines) may provide more insights or elegant alternative approaches. But I just don't have the motivation to read up that subject from scratch again after forty years!
TeeSquare
In reply to #157
02/21/2008 1:42 AM
Hi TeeSquare,
I still wake up in a cold-sweat over that elastic balls question ! Luckily Fyz has nailed this question, and part answered my slightly insane diversion to elasticity. 'Ideal' theoretical constraints are always good for fermenting discussion.
Seeing problems tackled by alternate routes is always an eye-opener. A good example was (again !) Fyz's dissection of Pyramids. I could have looked for a month of Sundays and not discovered that elegant solution.
Good Answers: 247
#161
In reply to #159
02/21/2008 9:10 AM
I still wake up in a cold-sweat over that elastic balls question!
Do I get extra points for maintaining a sense of propriety and decorum if I refrain from further comment on this? I'm sure you planted this as a test.
In reply to #161
02/21/2008 2:46 PM
Why Ken, you shock me by seeing some other meaning. It wasn't a test tease either.
Good Answers: 247
#167
In reply to #166
02/21/2008 4:36 PM
Im not sure if I'm laughing or groaning... but certainly appreciative in either case.
In reply to #166
02/22/2008 10:36 AM
Wot's that? It wasn't a test tickle, did I hear you say? Well now, that's certainly a horse of a different color...
In reply to #161
02/22/2008 10:34 AM
Not from this sodding lot you won't! If it was placed as a test, and you failed to rise to the bait, you probably failed the test. However, that does presuppose the author was smarter than the audience...
In reply to #173
02/22/2008 12:36 PM
It be symbiosis.
In reply to #177
02/22/2008 12:48 PM
Parasitism, be more like it...
In reply to #178
02/22/2008 12:58 PM
Admit it, you hound-types enjoy scratching the ticks in your groin.
In reply to #179
02/25/2008 9:27 AM
My ticks are all in my...
#185
In reply to #184
02/25/2008 9:30 AM
No need to throw a wobbly - I'm sure Kris didn't mean it personally.
In reply to #185
02/25/2008 11:14 AM
I'm fairly sure he did, y'know - that skwirrel's got fleas...
In reply to #186
02/25/2008 1:19 PM
Squirrels groom each other, when not taunting cats (or worm infested Coyote's).
#189
In reply to #186
02/25/2008 2:01 PM
That pesky clock is still at it. And to judge from the way the wildlife is twitching in time with it, some of those fleas have arrived in my garden.
In reply to #189
02/26/2008 2:24 AM
Blame the Hegehogs (noisy critters), they don't risk snowy slopes !
#163
In reply to #157
02/21/2008 10:32 AM
Once the dumbbells have parted company from the wall, you can easily rewrite the equations I wrote for the situation contacting the wall.
The sole change you need is to swap one of the original constraints for a new one:
instead of requiring that
. the top mass stays in contact with the wall,
. you require that the centre of gravity moves at a constant velocity.
All you need do then is force the sum of (the potential of the top mass, the kinetic energy of the centre of gravity, and the kinetic energy of rotation) to remain constant. The relationship between theta and heights remains as before, so you can use the differential equation to extend the model until the bounce time. Then simply reverse the velocity when it bounces and go on until the next one. Tedious, but straightforward.
#171
In reply to #98
Find in discussion
02/22/2008 6:08 AM
What happens after the initially higher ball hits the ground ? I am way too scared to tackle that !
I don't think this is too scary. We can study the movement of the CG, as if it was a bouncing ball, i.e. synthesize a vertical free fall motion along with a horizontal steady one. The issue is only to calculate the initial conditions, which are the vertical and horizontal component of the velocity at the moment the upper ball hits the ground, and the displacement along x-axis that this happens. Then, it's easy: the dumbbell's CG just moves at a constant speed towards x-axis while the upper ball bounces up and down, never reaching a vertical position over the lower one, though! (Some dynamic energy has been converted to kinetic)
These initial conditions can be calculated by noticing that at the moment the upper ball loses contact with the wall, the dumbbell doesn't experience any horizontal force, therefore it's CG's velocity has a constant horizontal component from then on. This velocity is simply half the one given as answer to this challenge (i.e. the velocity of the lower ball). Similarly we get the vertical component, by halving the velocity of the upper ball at that moment of detachment. All these are easily obtained. Then, by using energy preservation we can go on and do some school math to see where the dumbbell hits the ground and at which velocity.
tkot
#172
In reply to #171
02/22/2008 6:30 AM
You will find that this was already covered, but marked as "off topic" because it was not part of the original problem. On that basis both your contribution and this comment are also off-topic.
#101
In reply to #97
Find in discussion
02/18/2008 6:54 AM
No problem about missing #73 - there are so many posts it's hard to read everything.
A relatively easy way to demonstrate that the force on the floor is always positive is to consider the case of dumbbells falling with the base fixed, where the vertical force is:
m.gn-m.l2.(θ')2.cos(θ) = m.gn{1-2.cos(θ).[1-cos(θ)]}
This has a minimum value of 0.5.m.gn which is reached at 60O to the vertical)
Clearly, as the horizontal component of the kinetic energy fails to reduce once the dumbbells have left wall, the rotational KE (and hence θ') is lower for the sliding ladders, so the vertical force for the sliding ladders will remain significantly above 0.5
All you need to do now is balance the energy equations while retaining constant horizontal component of KE for the CofG after the ladders have parted from the wall.
02/16/2008 10:47 PM
In my humble attempt I have tackled the problem by considering M1 as a mass rotating about M2, and the forces that come into play are centripetal and centrifugal, and the arrows emanating from M1 being there representation.
FIG 1, shows the centripetal force at maximum and the centrifugal force at minimum. As gravity 'g' acts, the masses move to the position as shown in FIG 2, where the masses are at 45° to each other, in this position it can be seen that 'g' is balanced between the centripetal and reactive force with the wall, and the centripetal force is g/2.
and the force acting horizontal at M2 is g/2 x 0.0707. As the centripetal force at this point is greater than the centrifugal force the energy in M2 will cause M1 to shortly there after to come away from the wall, as M1 accelerates under the force of gravity, so does the centrifugal force increase to the point as shown in FIG 3, where they are balanced?
Pass this point the centrifugal forces increase beyond the the centripetal force and de-accelerates M1, where upon at the point shown in FIG 4, centrifugal force is at maximum and centripetal at zero. It is assumed that the centrifugal force in FIG 4, cancels out the centripetal force shown in FIG 2, leaving the acting force of g/2.
Therefore my answer is M2 rate of ecceleration at the point when M1 is level with M2 is: velocity = g/2 x 0.707 x t², where 't' is the time taken for M1 to fall.
Regards JD.
#102
In reply to #92
02/18/2008 6:59 AM
I think you may be assuming constant angular velocity around the point at which the dumbbells part company with the wall. However, the angular velocity is increasing all the time (under gravity), so the zero-horizontal-force point is delayed. What surprised me was that it came so close after the 45-degree angle (slightly less than 3.2O later).
Fyz
In reply to #102
02/19/2008 6:35 AM
Yes I agree there are a few assumption, and also I seem to have misread the question, not for the first time, I had at first thought that M2 would be doing more work than M1 if it moved away from the wall, but that is erroneous thinking also.
Regards JD.
02/17/2008 10:44 PM
This challenge has a few holes in it. 1. If the planes are indeed frictionless, that would mean that if the mass of the entire dumbell is greater than my mass, as I try to move it, the dumbell's inertia would exceed mine, and I would pull myself to the dumbell. 2. If I understand the intent of the question, when the top end looses contact with the vertical plane, the horizontal speed should be 0, but because the horizontal plane is frictionless, and nothing opposes the horizontal speed generated by the effect of the top mass falling from heighth L.....the horizontal speed of the bottom mass would be only what is generated by the vertical speed of the falling top mass. So by that convoluted reasoning, I would say that the horizontal speed would be the same as that generated by any mass being dropped from a heighth (l).
Mens Sana In Corpore Sano
#99
In reply to #95
02/18/2008 5:17 AM
Nothing says you have to be on the smooth surface, but if you were, you'd pull yourself towards the dumbbell, but it too would move. (You might also fend off against the wall)
What is the vertical component of the motion when "the horizontal speed would be the same as that generated by any mass being dropped from a height (l)", and where does the additional kinetic energy for that come from?
In reply to #99
02/18/2008 11:40 AM
My point about the floor being frictionless, is that if it truly so... that would mean that once the upper weight reaches the floor, the bottom weight has achieved a certain lateral (horizontal) speed. If the floor is truly frictionless, then the lower weight would not deccelerate from top speed.
If you imagine a very large scale dumbell...at one second, the top weight is moving at 10m/sec (yeah I know 9.8-bear with me). at 2 sec, speed is 20;3 sec, 30 etc etc. If you do a distance covered (area under the velocity graph) the distance covered in the 1st sec is 5m, 2nd is 20m, 3rd is 45m, 4th is 80m, and 5th is 125m. Because the length of the dumbell remains the same, use trig to find the distance the bottom weight moves laterally each second. sec 0 to 1 the lateral distance moved is 35m; sec 1 to 2 - 32.8m; sec 2 to 3 - 28.2m; sec 3 to 4 - 20.6m; sec 4 to 5 - 8.4m. Without do any lengthy calculus...if the floor is truly frictionless, the speed when the dumbell loses contact with the wall, the speed would be the same as the max lateral speed which is around 35m/sec in my example. If there is some minimal realistic friction that will stop the bottom weight from shooting across the floor... do the calculation as the distance of the top weight to the floor approaches 0, and the speed will be 0. In other words, at the instantaneous moment when the top weight reaches the floor, the bottom weight has stopped moving away from the wall.
#109
In reply to #107
02/18/2008 12:16 PM
Once the dumbbells leave the wall, tension in the rod will cause horizontal deceleration of the bottom mass and acceleration of the top mass. However, the horizontal velocity component of the centre of gravity will be constant.
I failed to understand sufficient of what you meant in the second paragraph to give a relevant answer - but in any case I think it is unhelpful to introduce friction to this specific problem until the lossless case is sorted.
I believe (not completely certain) that it will be possible for there to be sufficient floor friction both for the rod to leave the wall and for the bottom to stop before the top hits the floor - but I suspect the range is quite narrow (it's a significantly more involved problem than this one). (Would you have identical coefficients of friction for both the floor and the wall? - and no, I'm not volunteering to do this).
By the way, when the top weight reaches the floor, the rod is horizontal, so the horizontal component velocities of the top and bottom masses are identical
#115
In reply to #109
02/19/2008 4:41 AM
"I believe (not completely certain) that it will be possible for there to be sufficient floor friction both for the rod to leave the wall and for the bottom to stop before the top hits the floor - but I suspect the range is quite narrow" What a load of rubbish! If there is floor friction the movement won't start unless the rod is at a suitably large angle to the vertical - in which case rod will fall to completion regardless of how high the (finite) coefficient of friction might be. So there's a wide range over which it stops - but not with the "small angle" specified.
Good Answers: 247
#110
In reply to #107
02/18/2008 12:24 PM
I use 10 much of the time, too. (In fact I would favor a movement to change the official value! That may involve changing where we think the planets are, or revising the value of a kilogram... but that's the price of progress.)
In fact, the top mass cannot accelerate at this rate. It is prevented from doing so by the lower mass, which would have to accelerate at a very high rate in the first few milliseconds, because the mechanical advantage of the upper mass over the lower is so disadvantageous. From the starting position, just pull the lower weight back toward the wall a tiny amount, and no acceleration at all would occur (assuming nobody sneezes, absolute zero, etc, etc.) By your figures, the lower mass moves 35 m in the first second, implying an average acceleration of 7g, which would require a very high force. However at this instant, the mechanical advantage is such that the force must instead be very low.
If the top weight could move along the wall, vertically all the way to the bottom, then the lower weight would have to decelerate so that it is stopped when the upper weight reaches the floor. However there is no way to transmit the required force to decelerate the lower mass: the upper mass would have to locked onto rails.
In reply to #110
02/18/2008 3:17 PM
ok but the challenge implies frictionless surfaces. Without any friction against the lateral movement of the lower weight, wouldn't the top weight be in free fall?
In reply to #111
02/18/2008 4:12 PM
The lower weight is resting on the horizontal surface with a force greater than its weight due the bar linking the two weights.
Good Answers: 247
#113
In reply to #111
02/18/2008 4:39 PM
No.
The lower mass can slide without friction, but it still has inertia. It will accelerate according to A=F/M. The force starts out extremely low, because the mechanical advantage is so poor. For example, if the bar is one degree from vertical, a 1kg upper weight will have a downward force (i.e., weight) of 9.81 newtons. The horizontal component of that force is only 1.7% of 9.81 newtons. Therefore, the lower weight will accelerate very slowly at first. Because the lower weight refuses to get the heck out of the way, the upper weight cannot free fall.
In reply to #113
02/19/2008 9:22 PM
ok but..the weights are in contact with frictionless surfaces. Imagine the dumbell standing perpendicular to the floor without the wall. If you let it go, the top weight should describe an 90degree arc at a predictable rate-shouldn't it? I dont know the expression for figgering the time it would take to fall, but the length of the dumbell divided by that time should be the speed of the bottom weight when the dumbell is horizontal if the floor is frictionless and doesn't oppose the acceleration of the bottom weight.
#148
In reply to #138
02/20/2008 7:30 AM
No, no, and no. If you let the dumbbell fall without the wall, the C of G will not move horizontally, so the path of the top will be nothing like circular. As the top dumbbell hits the floor, the CofG is still not moving at all horizontally, and the stiff rod joining the "top" and "bottom" masses means they can't move laterally compared to the CofG - so neither of them is moving horizontally either - which means that the bottom mass is stationary at that time. If the dumbbells are erect initially, the only thing that will start them moving is random thermal motion, so we don't know when or in which direction they will start to fall.
Your contribution also reads as if you are not distinguishing between instantaneous and average velocities.
Given that the rod is vertical initially, it will only start as a result of random thermal motion, so both the time before it gets started and the direction of falling are completely unpredictable. However, once the motion is started, the relationship between the angle of the rod and the velocity and positions is of course predictable (if you neglect the very small thermal component).
Good Answers: 247
#106
In reply to #95
02/18/2008 11:37 AM
In fact both you and the weight would move, but by different amounts. But it is reasonable to assume that you are not in the friction free zone. That zone could consist of just a wall and a floor each perhaps a square meter, and you simply reach in to position things.
... the horizontal speed of the top mass, that is. When the top mass leaves the wall, its horizontal speed would be zero at that instant, but the bottom mass will have already accelerated to its maximum horizontal speed.
However, at the moment addressed in the question, the weight has not fallen through a height of l. It has only fallen 1/3 of the way to the floor at the time when it (the top weight) is pulled away from the wall.
Initially, the force applied to the lower mass is infinitesimally small. Therefore, the initial horizontal acceleration of the lower mass is very slight. Not only its speed but also its acceleration are non-linear with time.
#120
02/19/2008 9:17 AM
I think someone got up too early in the morning to post that answer. ;-)
Good Answers: 74
#121
In reply to #120
02/19/2008 11:16 AM
I put a dumbbell in the hall
And watched as it started to fall
It sped through the door
On a frictionless floor
Driven on by a frictionless wall.
Bruce
Good Answers: 247
#122
In reply to #121
02/19/2008 12:07 PM
Keep this up and we'll make you the poet laureate!
In reply to #121
02/19/2008 12:09 PM
Didn't see THAT one coming!
02/19/2008 12:19 PM
"....that consists of a rod of length l.... "
Does the change of wording mean we have to start again ? If so, I'd like to plagiarize Fyz and claim kudos for answering the revised question.
#132
In reply to #124
02/19/2008 4:27 PM
Not to forget the lack of "when" and of italicisation.
P.S. Here's some qdos
In reply to #132
02/20/2008 1:36 AM
I was leaving the new sentence construct ("You move the bottom end slightly away from the wall, the dumbbell begins to slide") for ER to savage. It reads like a line from the Michael Jackson song Thriller.
The qdos will be iterated ad infinitum with my qbasic.
#125
02/19/2008 12:36 PM
Good answer.
#126
In reply to #125
02/19/2008 12:40 PM
Shame we can't rate it as such.
In reply to #126
02/19/2008 1:26 PM
#128
02/19/2008 2:06 PM
So what's the answer? It says the answer is posted but it's obviously not. All I see is the same question posted twice.
#129
02/19/2008 2:15 PM
How about an answer instead of a restatement of the problem?
Good Answers: 247
#130
02/19/2008 2:19 PM
The profundity of the official answer is most impressive. On the obvious (and perhaps superficial) level, it is saying "The answer is the question."
But then there are the subtle differences: "two" in the question becomes "to" in the answer-question. A rod "of a certain length (l)" becomes the more succinct "of length l". I think what the answer/question is trying to say (and, personally, I think it says it eloquently) is that despite subtle changes in questions (that occur from culture to culture) certain meanings are nevertheless universal, and that perhaps certain questions are universal, as well.
It is both interesting and revealing that the comma splice in the question (You move the bottom end slightly away from the wall, the dumbbell begins to slide.") remains in the answer-question. I think the author is intending to say, by eschewing common syntax conventions, that form is not the determinant of meaning. "Would a sentence without proper punctuation still smell as sweet?"
Frankly, I am a little embarrassed at having taken the question so literally -- and I suspect that Fyz, who used many words to clearly explain his answer, is now thinking: "If only I had said, 'The answer is the question.'"
Clearly, these questions are here to foster human communication. Are the "answers" important? Are the "answers" really "answers"? Is it really more important that I am right and all the rest of you are wrong to lesser or greater degree? I think not. Or maybe so. But the point is that we should at least pretend that's its all about the free flow of human interaction and discussion.
It is what it is.
In reply to #130
02/19/2008 3:21 PM
"It is what it is."
And apparently what it is, is Zen physics.
What is the sound of one dumbell sliding?
In reply to #131
02/20/2008 1:53 AM
It's like, surreal....
#133
In reply to #130
02/19/2008 4:32 PM
I am indeed severely embarrassed by my pointless wordiness.
Yahweh?
In reply to #133
02/19/2008 4:42 PM
Pointless?!? Hardly so, sir! Actually it was highly entertaining.
Good Answers: 247
#135
In reply to #133
02/19/2008 4:54 PM
Yahweh?
Ja.
Good Answers: 74
#136
02/19/2008 5:08 PM
...a rod of length l and two masses (m) at each end.
as opposed to one mass (m) at each end? i.e. total mass = 4m?
Bruce
In reply to #136
02/19/2008 5:18 PM
To quote Blink (Post #130):
"It is what it is."
#139
02/19/2008 11:32 PM
Where is the answer?
Good Answers: 74
#141
In reply to #139
02/20/2008 12:21 AM
The answer, apparently, is in the question. Or is it the other way around? I can never remember! Perhaps the question is in the answer. I thought that Fyz did an excellent job in establishing a theoretical basis for a proper answer. The answer we received, no matter how eloquent, was not a proper answer. Come on, CR4, give us a proper answer to the question. Either that, or let Fyz take over. I think I'll have another drink.
On a completely different note, here is a picture of my back yard in January.
We have two mountain ash trees and a birch tree in our back yard. Every year, about this time we are visited by hordes of Bohemian Waxwings who feast on the orange berries of the mountain ash trees. In a single day, the berries are totally wiped out. Amazing!
The little structure on the right is a bird feeder which I fill with sunflower seeds. Chickadees love sunflower seeds. Just to the left of that is a bird bath, currently covered with snow. If you look very carefully at the photo, you will see the waxwings, although I must admit my photography skills are less than perfect.
And therein lies your answer. But I have forgotten...what was the question again?
Bruce
#144
02/20/2008 2:01 AM
mgl=2mv2/2
v=sqrt(gl)
Good Answers: 74
#145
02/20/2008 2:03 AM
A dumbbell was placed in the attic
For years its stood perfectly static
But just one small shove
From a power up above
Has made it become kinematic.
Bruce
Reply Good Answer (Score 4)
#149
In reply to #145
02/20/2008 7:32 AM
I'm certain that EL would have approved too
Fyz
Good Answers: 247
#150
In reply to #145
02/20/2008 10:25 AM
Upon reading this, I feel compelled to second the motion of whomever it was who proposed that you be named the CR4 poet laureate!
Good Answers: 74
#151
In reply to #150
02/20/2008 10:46 AM
You do me an honor, sir. But wait...you can't second your own motion under Bob's Rules of Order.
Bruce
Good Answers: 247
#152
In reply to #151
02/20/2008 12:35 PM
I think you will find a footnote in Bob's Rules. I don't have a copy in front of me, but I seem to remember something like this:
1 Of course, in cases of premature senility, in which the second motioner can not be certain of the identity of the first motioner, then, that old fool can second any motion he darn well pleases.
Also from Bob's Rules, I seem to remember something about an overlap having to be established outside the two boatlength distance from the mark... unless there is an obstruction such as a falling dumbbell.
In reply to #151
02/20/2008 1:13 PM
Very well, then, tell Bob that I will second that motion.
We have a motion and a second on the floor. All in favor, show of hands, please!
#162
In reply to #154
02/21/2008 10:14 AM
V V
Fyz
In reply to #145
02/20/2008 12:59 PM
"I think I'll have another drink."
Of what?!?
Something tells me the waxwings aren't the only Bohemians munching on the orange berries...
Still a 'GA' though!
#146
02/20/2008 3:03 AM
The answer appears to be remarkably similar to the question!
#147
02/20/2008 3:04 AM
At the moment in question bottom end will stop, so speed is equal to zero.
Good Answers: 247
#155
02/20/2008 1:25 PM
Oh dear (New) official answer, how do I love thee?
Let me count the ways.
I love the disappearance of l, and the appearance of r.
I love the novelty of measuring from the floor to the center of the upper weight, rather than the tediously conventional center-to-center distance.
I love all the numbers and stuff.
I love how long it took me to figure out this: "We can express gravity as a function of the Vx" (Do we mean the gravity of the situation?) (I fear I used to think of gravity as being something of a constant, around where I live – something that would not necessarily vary with the velocity of a dumbbell.)
I love how the calculations end with the square of the velocity, rather than the velocity.
I love how it shows that there is more than one way to skin a cat – the answer, although a bit squared, it still pretty good.
I'm not sure it's as good as the first official answer, though.
In reply to #155
02/20/2008 2:14 PM
"...there is more than one way to skin a cat..."
Better duck out, Del, not enough we have skwirrel hunters, now there's cat skinners about.
02/21/2008 1:02 AM
This analysis is very nearly completely correct. However, the implicit assumption of y=(r^2-x^2)^1/2. in equation (1) is that the bells on the dumbbells are point like masses. This is not what the problem states nor is it what the free body diagram shows. This means that the continuous integral of the sine and cosine functions of the angles expressing the relation radius of the contact points for the planes must be computed. This is necessary to correct for the continuously varying amount of angular offset between the point of contact for the falling mass and true center of mass for that portion of the rigid body.
The last time I attempted to solve that particular type of problem was several decades ago and it took me several days of hard work to find a first solution. In checking my work I stumbled across a vastly more elegant solution based on a ratio equivalence in pythagorean theory. I believe that this solution became the basis for the algorithm that machine tools currently use to compute tool radius offsets on the fly.
However, there is no set of equations of which I am aware that can be used to compute this integral without using the radius of the bells which is not given in this problem. So, I contend that the complete and accurate solution of the theoretical problem is non-determinant.
I am rather unwilling to devote the couple of days it would take to develop the software to solve this problem so at this point i can not prove my claim that there is an actual difference in the result when you assume a non-zero radius for the bells however, I did a highly similar computation involving the cantilevered slide in a crankshaft, piston rod, piston, cylinder wall assembly and in that case the degree of misalignment between the piston rod pivot point and the piston skirt which slides against the cylinder wall was a small but note worthy factor. If you have ever wondered why there is typically wear and scoring of the piston skirt in this area, the offset load between the piston and piston rod when the charge is exploding is the answer.
In that instance it was necessary to include fudge factors to allow for the action of friction in the mechanism in order to achieve a useful model of the real world.
In this problem the upper bell will separate from the frictionless wall somewhere when V(horizontal, lower bell) > V(vertical, upper bell. This condition will be met very nearly around the 45 degree angle point. If allowances are made for the intrusion of real world into the problem then the action of friction would delay the moment of separation to a later time and a lower angle.
Sincerely,
Mr. Gee
PS In engineering the "correct" answer is the one that most closely approximates a real result! If there are some enterprising students out there who would like to determine what the true correct answer is then affixing two wheels to each end of a ladder will approximate the frictionless condition of the problem and filming a falling rod, bar, or ladder while falling past a tape measure should give a useful approximation of the "correct" answer.
Increasing the drag in the wheel bearings would assist in modeling friction and measuring and or mathematically estimating the degree of inclination before the device free falls would make for a rather nice experimental test of the validity of whatever mathematical model or models you choose to evaluate.
The greatest difference between a working engineer and an individual who professes to teach engineering is that the professor believes that the correct answer is the one the text book endorses and the working engineer knows from sometimes bitter experience that the correct answer is the one that best matches reality.
Furthermore, If you wish to engineer really good systems then consider dynamic systems that make predictions, measure results, and correct the model better match the results.
Men have been hurling projectiles at each other for several centuries. Your course work did, or does include formulas for ballistic projectiles and these formulas marked a milestone in man's progress in the art and science of killing each and so they are much celebrated in our educational literature. But, in the real world a brave individual known as a a forward spotter is often forced to sneak behind enemy lines so that he can observe the actual point of impact of the artillery round. The aiming is adjusted based on his observations and then verified, (miscommunication is a common problem) and only then does the battery fire for effect. As the barrels heat the steel in them is weakened and subsequent rounds fall short of first rounds so an experienced gunner will automatically raise his sights and continuously adjust for Kentucky windage. Inexperienced gunners will often tragically not adjust and lay down a devastating barrage of "friendly fire" on their own troops.
As you may have guessed by now, I have a genuine distaste for challenges of the type expressed in this problem. If you make unrealistic assumptions about the behavior of the real world like frictionless planes and such a then maintain that these fantasies are "correct" you perpetuate the myth that mathematical correct answers are also valid answers. Which is simply not true often enough to warrant the sort of faith we tend to put in these types of results.
Mathematics are the servants of man, but they are the slaves of reality. They do not determine reality, at best, they imperfectly reflect it.
In reply to #158
02/21/2008 5:14 AM
Fyz's solution and the official answer only ignore the MIs (Moment of Inertia) of the end masses.
#165
In reply to #160
02/21/2008 10:44 AM
As you imply, the equations are correct provided that the "length" of the dumbbell is the distance between the centres of the spheres.
NB that my extended answer (posting #73) provides an easy basis for the use of more generalised moments of inertia**, should the information to calculate their values become available.
**That would include incorporating the mass and MofI of the connecting rod as well as the MofI of the spheres
Fyz
Good Answers: 247
#164
In reply to #158
02/21/2008 10:40 AM
Although I understand and respect your point of view, I certainly don't agree. I think this is among the best challenge questions we've had. Some pretty smart people have come up with potential solutions that are entirely unsupportable by generally accepted physics and math principals. I take that as evidence that a correct solution requires some clear thinking -- and that is, largely, the point of these exercises. Certainly, no one thinks that a frictionless world is "real," but many would agree that there is a mathematically "correct" answer to this problem. It is not a myth that mathematically correct answers are also valid answers.
Simplifying assumptions are part and parcel of both physics and engineering. In engineering, CFD and FEA are both used for prediction of continuous phenomena, but the techniques are discontinuous. They are simply approximations, and it's only fairly recently that these approximations have become close enough to the real world that some products can go directly from drawing board to manufacturing.
As a student, I used to tease my physics teacher when presented with textbook problems: "Did you want us to ignore Brownian movement in the gases surrounding the experiment area? How about local variation in gravitational field? Are the materials involved magnetic, and if so should we worry about possible eddy currents established as these things move, and if these eddy currents develop, should we feed the resulting temperature rise back into our Brownian movement calculations? ... etc., etc." Fortunately, my physics teacher had a good sense of humor.
Of course one is expected to ignore many real world effects, and most of the time, the nature of the question tells you which ones to ignore. If the question is ambiguous, (as all are to a degree) then you simply state the assumptions upon which your answer depends. The intent of the question is to get at the essential physics involved, and to come up with the math that can make a reasonable prediction of behaviour. It turns out, that in this case, if you use a ladder with wheels on both ends (as you suggest) Fyz's solution, and the few other correct solutions, accurately model real world behaviour. Several other solutions proposed do not, because they are not fully "thought out".
When I read through Fyz's solution (and the related solution from Harvard) I said "pretty cool," because they are masterfully presented: clear, concise, elegant, and appropriately complete. And when I started to think of Fyz's solution as being off by a factor of two... and then he patiently explained the cause of my (fortunately temporary) delusion... again, I said "pretty cool."
We might take into account 10 or so real-world phenomena to get a pretty accurate result for this thought experiment. Doing so, however, obscures, rather than elucidates the real issues.
Perhaps. Although one does not need to go more than a couple pages into a physics text before math comes in: it's not unreasonable to say that you can't understand reality without understanding math. Even simple concepts are very nearly impossible to appreciate without math. As soon as we make the "conceptual" comment that air resistance varies with the square of speed, we are already talking in mathematical terms.
Our ability to fly to the moon suggests that, although the math may imperfectly reflect reality, it is plenty close enough.
In reply to #164
02/22/2008 10:51 AM
"...Fortunately, my physics teacher had a good sense of humor...."
Good thing, too, else you'd have been calculating that Brownian movement add-in to this very day!
#168
02/21/2008 7:20 PM
The idea of letting the dumbbell fall without the wall is a delightful variation (cuznmonkey - post 138), to which one would have expected a more comprehensive response from Fyz (post 148). To me it looks like the centre of mass will keep bouncing forever to a height of l/2, but after each bounce the dumbbell might just do a flipover or fall in a random new orientation!
Now imagine the dumbbell replaced by a coin* falling sideways to a frictionless floor, with perfectly elastic impact assured. It should keep flip-flopping heads and tails alternately (or more likely randomly) ad infinitum. Or is there something I'm missing?
*[with a worn-out well-rounded edge, so its upright equilibrium is unstable, but otherwise geometrically perfect and symmetrical]
However, ba-ael has inspired a different line of thought:
By a wall in a frictionless shed
Was poised a dumb belle on her head;
Mid-way through a fall
As her heels left the wall
The CR4 jokers saw red.
alternatively, if I may plagiarise a phrase from Bruce
But her heels left the wall
Mid-way through a fall,
And out through the doorway she sped.
So how about some more variations on the theme from the other jokers out there as this thread is anyway going from bad to verse.
I agree 200% with Blink (post 164).
In reply to #168
02/22/2008 2:13 AM
When the coin has fully 'landed' it will flatten, and have neither heads or tails.
#170
In reply to #168
02/22/2008 5:48 AM
As it was off-topic, I didn't take it too far. Once displaced from the vertical, the algebra is so similar to the original that anyone who followed #73 would have no difficulty describing the motion. However, it looks to be worth going into a little more detail now - given your interest
Generally, I agree with your first paragraph.
. Assuming the start direction is triggered by thermal noise [rather than being due to the dumbbell not being precisely vertical (or stationary) in the first instance (Heisenberg in the limit?)], continuing thermal effects imply that the dumbbells fall in different directions each time they pass (approximately) vertical. The time to leave vertical in each case is indeterminate, but the probability of it staying apparently vertical (on any occasion) for more than a few seconds becomes ridiculously small (see this for a rough calculation - albeit based on a somewhat smaller object).
. If the fall was caused by the initial position not being vertical (and/or velocity being non-zero), the rotational angle along which the dumbbells fall will move the same amount each time they pass near the vertical.
Regarding the coin, if the initial velocity is zero and it starts at a slight angle to the vertical, it will not flip, but fall back on the original side each time.
. If the original impetus is thermal, the coin can behave differently on each occasion, and the probability on any occasion whether it will flip or fall back is roughly equal, though there will be a (very small) correlation between successive events.
. If the fall is purely due to Heisenberg uncertainty (how do we cool the rod this far?), the coin will do the same (pass across the vertical or fall back) each time. The probability of crossing the vertical will depend on how tightly you constrain the initial position relative to the velocity; the probability that it will pass through vertical is always less than 50%, but the more tightly you constrain the position the closer to 50% it will become.
Oh, and I like the limericks; and please register - you'll be a welcome addition
In reply to #168
02/22/2008 10:47 AM
Not ba/el, but not bad, either!
Thanks for the effort, and for the challenge...
To agree with Blink is no joke,
That dude is one savvy bloke.
But then so is Fyz,
Says: "it is what it is",
To which I reply OkeyDoke!
Reply Off Topic (Score 4)
Good Answers: 247
#187
In reply to #175
02/25/2008 11:36 AM
To agree with your poem's impolite;
I'm really more dim than bright,
But then there's my ego,
The size of Montego,
Which says you're most certainly right.
In reply to #187
02/25/2008 3:09 PM
02/22/2008 7:02 PM
I have an objection to the experimental model suggested by Mr Gee (post158) using a ladder fitted with wheels. The rotational kinetic energy of the rolling wheels introduces extraneous terms which significantly alter the nature of the problem. One could perhaps get around it by having a heavy ladder compared to wheels of negligible mass (or moment of inertia), but aren't we then drifting back into the realm of idealistic assumptions in the same category as frictionless surfaces?
Does the 'good answer' categorisation in CR4 require further subdivisions to accommodate the off-topic posts which are sometimes more enlightening than the 'true' answers to stupid questions. I am in favour of more 'challenges' in which the answer remains a matter of dispute!
=TeeSquare=
#181
In reply to #180
02/23/2008 1:28 PM
Agreed on all fronts - even (sometimes) multi-answer challenges. (Posing usefully "open" questions is a rare skill).
In reply to #181
02/24/2008 6:57 PM
Hi Fyz, thanks for your concurring remarks.
Allow me to add some qualitative observations which I feel are relevant to the topic as it has evolved so far. They were triggered by your reference to the Harvard solution in post 170, which I managed to skim through. But I don't expect you or anyone else to undertake any further analysis, as everyone would be in a state of fatigue from the dumbbell exercises by now.
I am limited to a very rough qualitative appreciation of quantum phenomena, as they are somewhat beyond my mechanical imagination. I got the drift of the argument minus the maths, but it set me thinking about the falling pencil and how it would hit the floor -- whether the kink at the cone/cyl interface would cause the tip to bounce, and what sort of motion would ensue subsequently (in the scenario of frictionless floor/wall and elastic impact).
Since impact is an additional complication (introduced by Kris and myself mainly) I feel we can avoid it altogether by assuming the 'body' to have a smooth convex shape all over (like an ellipsoid or prolate spheroid). After sliding some way down the frictionless wall it should just move off with a motion akin to a travelling rocking chair. Given the mass and MI, the mechanics ought to follow your equations in post 73. I'm not going to try working out the point of departure for an elliptic profile though.
If it was a free fall without the wall, then the top and bottom ends should keep exchanging positions, with each new fall being in a random horizontal orientation. The maths may be simpler if we consider an elliptical cylinder and treat it as a two-dimensional problem.
I just added these thoughts as a matter of interest. I'll remain satisfied with the qualitative picture, and hope there is no gross conceptual error in my thinking. Regards =TeeSquare=
#183
In reply to #182
02/25/2008 6:36 AM
Looks good to me - except that a generalised convex shape would be extraordinarily hard to analyse . There may be a few that I could handle analytically (at an appropriate fee!), but most would have me resorting to numerical tools.
#192
02/26/2008 4:55 AM
Your sollution is presented well; however I have a problem with your equation
y = (r² - x²)^0.5
When x = 0 then y = r - ok!
When r = 0 then y = (-x²)^0.5 - Not ok?
Please enlighten me?
#193
In reply to #192
02/26/2008 5:36 AM
As the equations are only valid while the dumbbells are touching the wall, x2 must always be less than r2.
Does that solve your problem?
#194
In reply to #193
02/26/2008 6:36 AM
I see! You are not treating r as a variable but as a constant.
In these cirumstances then surely x is a function of y and the equation amended accordingly?
Wouldn't simplify matters ?
#195
In reply to #194
02/26/2008 7:27 AM
r is specified in the drawn restatement of the problem as the length of the dumbell (it was l in the original question). Personally, I would choose to express everything in terms of the angle θ between the rod and the vertical, as this is easier to generalise. Given that the required answer is the horizontal velocity, I agree that x would be a more natural choice for the parametric variable than y - but it makes little difference to the manipulations in practice
02/28/2008 4:17 PM
Sorry guys and gals, but I can't hold on any longer. The answers given are almost ALL incorrect. (Including the official answer.)
Conservation of energy. YES
Trajectory of the centre of mass. YES
Energy equations used in derivation of "point of separation from wall". ALL WRONG
There are THREE energy systems in play while the dumbell is ROTATING from one stable condition (vertical) to another stable condition (Sliding across floor with constant velocity.). The third is the rotational dynamics of the dumbell accelerating from a vertical rest with rotating velocity = zero, through a maximum and reducing back to zero when the dumbell is horizontal. The energy stored in the rotational momentum means that the "theory" calculation used by everyone for the dynamic movement of the dumbel are thus incorrect as they only consider conservation of energy in two of the three systems.
The answer to the problem is very simple when we use the two stable conditions and some logic. The transition (unstable) condition does not matter.
My answer with some elaboration.
Start condition. Two masses (each m) joined by a rigid rod. I'll call total length "L", (centre of mass at L/2.) with end masses each diameter "d". (With no rotational velocity/energy.)
End condition. Two masses (each m) joined by a rigid rod moving with constant velocity "v" across the frictionless floor. (Centre of mass now at d/2 from the floor, meaning both dumbell ends in contact with the floor.) (With no rotational velocity/energy.)
Logic to use: Once the dumbell loses contact with the vertical wall there can be no further change in horizontal velocity. (Since from that point on there is no "opposing force" available to change the horizontal velocity, so the end velocity is equal to the velocity when the dumbell leaves the wall.)
Now we use our conservation of energy formulae.
Delta Potential Energy (PE) = (L/2 - d/2) * g * (m + m)
[Centre of total mass falls from L/2 to d/2.]
Delta Kinetic energy (KE) = 1/2 * (m+m) * (v * v)
[Total dumbell is moving with constant velocity.]
Delta rotating energy = Zero - Zero
Thus 1/2*(m+m)*(v*v)=(L/2-d/2)*g*(m+m)
Eliminating (m+m) and multiplying by two.
v*v=(L/2-d/2)*g*2
v*v=(L-d)*g
v=sqrt[(L-d)*g]
Think about all the other answers that say the dumbell leaves the wall before reaching horizontal situation. They all account the total PE as having been converted, but in fact unless the dumbell is completely horizontal, then the final PE condition has not been reached.
If the dumbell left the wall as described in many of the solutions, then they are implying the dumbell would move across the frictionless floor with constant velocity with what was the top end never falling any further.
If you really want to "crunch the math" then add in the necessary rotational inertia and such in the energy equations, do the integrations and get a headache.
#197
In reply to #196
02/28/2008 4:57 PM
Let me apologise in advance, as your courage in going against the crowd does not deserve a condescending response, and I fear that what follows may appear that way.
Conservation of energy applies continuously through time. So the amount of potential energy that has been removed from the top mass at any particular time must be present in some other form at that time. If you bear that in mind when you look at the equations in the "good answer" solutions, you will see that they do in fact conform to this requirement. [That is to say they do not convert "all" the available potential energy - just the amount that has been sacrificed at any particular time]
Now, the following may be a misinterpretation, but the only way I can see that you have reached the conclusion that the final position has to be horizontal is if you believe that the balls on the ends can only have constant horizontal individual velocities. That would be the same as saying that a rigid body moving freely through space cannot rotate. Please see what happens when you throw your ruler (gently now). What happens is that the centre of gravity must have constant horizontal velocity once the dumbbells have parted company with the wall; the ends can accelerate relative to the centre of gravity (equal and opposite if the dumbbells are symmetrical), because the connecting rod provides force along its length. It is this rotation of course that allows the top end to continue falling.
You also express discomfort with rotation not being considered as an additional degree of freedom; while we consider the total mass of the dumbbells to be located in just point masses at the ends, all the kinetic energy is indeed accounted for in the linear motion of the masses - provided you consider them separately. That is no longer practical if the rod has mass or the masses are distributed, in which case you need to consider the body in terms of a mass at its centre of gravity and its moment of inertia. This more general case was analysed in post #75; it was still a restricted case because the dumbbells were assumed to be centro-symmetric. (BTW, this formulation has the advantage of starting with just three degrees of freedom in the plane of movement, whereas the two-body solution starts with four, which then reduced to the equivalent by constraining the separation of the masses)
I think that covers all the issues you raise. If not, please clarify what is omitted.
Fyz
#200
In reply to #197
02/29/2008 11:30 AM
I hate to cause consternation between us engineers; I enjoy intelectual exercise along with the best of them, however not all the potential energy will be converted directly into horizontal kinetic energy. The velocty of the top dumbell will be at its maximum when it hits the ground. Its action would be normally through its own center of gravity, especially if its mass is signifcantly larger that the rod.
In reality the top dumbell would normally bounce when it strikes the ground. Presumably, when specifying the initial assumptions, you could have added "dumbells having no elastic properties"? But would this have any effect on the horizontal velocity because both plains are frictionless? If there is no friction between the dumbell and the surfaces, will it matter if the dumbells are in the air or not?
If the top dumbell does bounce it will cause a partial negative rotational effect; retarding the motion of the lower dumbell. The motion will therefore be of a non linear nature.
Life and engineering are not always as straightforward as they first appear.
Good Answers: 247
#201
In reply to #200
02/29/2008 11:43 AM
I fear that you might have read the question incorrectly.
The upper end of the dumbbell looses contact with the wall long before it gets anywhere near the floor. Therefore, there is no bounce to worry about. Any bouncing would occur at a point in time after the instant referred to in the question. The nature of that motion could be a subject for another question, but it is not part of this one.
#202
In reply to #200
02/29/2008 12:17 PM
You write: "not all the potential energy will be converted directly into horizontal kinetic energy". I agree, and the proportions of the total kinetic energy that appear in the horizontal and vertical directions respectively (at any time before the top dumbbell loses contact with the wall) can readily be seen to be sin2(θ) and cos2(θ) (using the notation of post #63). In fact the horizontal component of the kinetic energy reaches its maximum just as the top of the dumbbells loses contact with the wall - and the horizontal component of KE stays constant so long as the dumbbells continue moving unrestrained across the frictionless floor, whereas the vertical component continues to increase until the upper mass hits the floor. We know nothing about the vertical component following impact, because we aren't told the coefficient of restitution.
BTW TeeSquare's (post #157) image of the "dumb bunny hopping along to infinity, nose never leaving the floor, but rear end bobbing up and down" is exactly right for lossless movement on an infinite plane (with minor modifications if you want a round Earth)
Reply to Blog Entry Page 2 of 3: « First < Prev 1 2 3 Next > Last »
3Doug (1); AccuDave (2); agua_doc (1); amichelen (1); Anonymous Hero (8); Anonymous Poster (37); ba/ael (5); Blink (29); Cardio07 (2); cuznmonkey (5); DCaD (1); double_j_b (1); EnviroMan (19); inquisitivefred (3); jdretired (3); jim35848 (2); Just an Engineer (2); Kris (16); Mr Gee (1); nicolaievlad (1); Physicist? (43); PWSlack (1); Randall (4); RickLee (2); TeeSquare (5); tkot (2); user-deleted-1105 (5)
