Second only to flash floods in the annual number of deaths due to weather, lightning is one the most underrated deadly risks. Because it only claims one or two victims at a time and tends not to cause massive destruction, people tend to believe that lightning is not as deadly as other storms, but Americans are twice as likely to die from lightning than from floods, hurricanes, or tornadoes. Lightning is increasingly becoming a force to be reckoned with.
Striking Facts
Lightning strikes can range in length from two-to-ten miles long. At four-to-five times the temperature of the sun's surface, lightning in a cloud-to-ground strike can range from 100 million-to-1 billion volts and can carry a current of 10,000 amps.
There are as many as 100 lightning strikes per second around the Earth. That leaves the odds of being struck in the United States in a year to 1 in 700,000. Even more striking is the odds of being struck sometime in a person's lifetime, which is 1 in 3,000. Twenty percent of people that are struck by lightning die, and seventy percent of survivors experience long-term effects.
Thunder Will NOT Save You
People can be hit by lightning while working under clear skies; "positive giants" are lightning strikes that hit the ground up to twenty miles away from the storm. Since thunder can only be heard about a maximum of twelve miles away and sometimes as short as two miles away from the storm, it isn't guaranteed that a person would have an auditory indicator that a storm is on its way - much less a bolt of lightning.
The rule that you can predict how far away a storm is by using the time period between when you see the lightning and when you hear the thunder is unreliable at best. This method should not be used as an approximation. If you can see the lightning, chances are you are in danger due to the vast traveling distance of lightning. You can also be within striking distance of lightning and never hear the thunder due to its relatively short traveling range.
Since most lightning strikes occur outside, it is in everyone's best interest to stay inside during an encroaching storm. Even if you are not directly hit by lightning, lightning can still have lethal consequences for those 60 feet-or-more from the contact point on the ground; this lethal radius increases to 600 feet in water. Don't underestimate the consequences of being caught outside in a storm with lightning, it may prove life-saving.
Resources:
http://www.stormwise.com/striking.htm
https://news.nationalgeographic.com/news/2004/06/0623_040623_lightningfacts.html
