As part of a medical device I need to be able to clean the inside diameter of a stainless steel tube it is 1.3mm diameter and 250mm long open at both ends. To date I have tried single and multiple cycle ultrasonic cleaning in an alkaline detergent at 60 degrees C. To date the best result has still left 0.03mg/hole of oil this has been identified as the oil used by the manufactures of the tubing during their drawing process.
Other detergents are being tried but I believe the problem will still be there due to the small diameter of the hole not allowing the free flow of fluid. This can not be a new problem but I am struggling to find a practical solution that could be used in a production environment. Has anybody any suggestions or an explanation of the theory behind the problem.
Coming from an engineering back ground I have no concept of how much 0.03mg of oil actually is and how this relates to the real world can someone give me an analogy?
Many thanks
