One of the twin towers collapses |
9/11 third tower mystery 'solved'
By Mike Rudin
BBC, Conspiracy Files
The final mystery of 9/11 will soon be solved, according to US
experts investigating the collapse of the third tower at the World
Trade Center.
The 47-storey third tower, known as Tower Seven, collapsed seven hours after the twin towers.
Investigators are expected to say ordinary fires on several different floors caused the collapse.
Conspiracy theorists have argued that the third tower was brought down in a controlled demolition.
Unlike the twin towers, Tower Seven was not hit by a plane.
The National Institute of Standards and Technology, based near
Washington DC, is expected to conclude in its long-awaited report this
month that ordinary fires caused the building to collapse.
That would make it the first and only steel skyscraper in the world to collapse because of fire.
See World Trade Center 7's location and structure
The National Institute of Standards and Technology's lead investigator,
Dr Shyam Sunder, spoke to BBC Two's "The Conspiracy Files":
"Our working hypothesis now actually suggests that it was normal
building fires that were growing and spreading throughout the multiple
floors that may have caused the ultimate collapse of the buildings."
'Smoking gun'
However, a group of architects, engineers and scientists say the
official explanation that fires caused the collapse is impossible.
Architects and Engineers for 9/11 Truth argue there must have been a
The founder of the group, Richard Gage, says the collapse of the third
tower is an obvious example of a controlled demolition using
explosives.
"Building Seven is the smoking gun of 9/11… A sixth grader can look at
this building falling at virtually freefall speed, symmetrically and
smoothly, and see that it is not a natural process.
"Buildings that fall in natural processes fall to the path of least
resistance", says Gage, "they don't go straight down through
themselves."
Conspiracy theories
There are a number of facts that have encouraged conspiracy theories about Tower Seven.
- Although
its collapse potentially made architectural history, all of the
thousands of tonnes of steel from the skyscraper were taken away to be
melted down.
- The third tower was occupied by the Secret
Service, the CIA, the Department of Defence and the Office of Emergency
Management, which would co-ordinate any response to a disaster or a
terrorist attack.
- The destruction of the third tower was
never mentioned in the 9/11 Commission Report. The first official
inquiry into Tower Seven by the Federal Emergency Management Agency was
unable to be definitive about what caused its collapse.
- In
May 2002 FEMA concluded that the building collapsed because intense
fires had burned for hours, fed by thousands of gallons of diesel
stored in the building. But it said this had "only a low probability of
occurrence" and more work was needed.
But now nearly seven years after 9/11 the definitive official
explanation of what happened to Tower Seven is finally about to be
published in America.
The National Institute of Standards and Technology has spent more than
two years investigating Tower Seven but lead investigator Dr Shyam
Sunder rejects criticism that it has been slow.
The collapse of Tower 7
"We've been at this for a little over two years and doing a two or two
and a half year investigation is not at all unusual. That's the same
kind of time frame that takes place when we do aeroplane crash
investigations, it takes a few years."
With no steel from Tower 7 to study, investigators have instead made
four extremely complex computer models worked out to the finest detail.
They're confident their approach can now provide the answers. Dr Sunder
says the investigation is moving as fast as possible.
"It's a very complex problem. It requires a level of fidelity in the
modelling and rigour in the analysis that has never been done before."
Other skyscrapers haven't fully collapsed before because of fire. But NIST argues that what happened on 9/11 was unique.
Steel structure weakened
It says Tower Seven had an unusual design, built over an electricity
substation and a subway; there were many fires that burnt for hours;
and crucially, fire fighters could not fight the fires in Tower 7,
because they didn't have enough water and focused on saving lives.
Investigators have focused on the east side where the long floor spans were under most stress.
They think fires burnt long enough to weaken and break many of the connections that held the steel structure together.
Most susceptible were the thinner floor beams which required less
fireproofing, and the connections between the beams and the columns. As
they heated up the connections failed and the beams sagged and failed,
investigators say.
The collapse of the first of the Twin Towers does not seem to have
caused any serious damage to Tower Seven, but the second collapse of
the 1,368ft (417m) North Tower threw debris at Tower Seven, just 350ft
(106m) away.
Tower Seven came down at 5.21pm. Until now most of the photographs have
been of the three sides of the building that did not show much obvious
physical damage. Now new photos of the south side of the building,
which crucially faced the North Tower, show that whole side damaged and
engulfed in smoke.
There is every evidence to show that Building 7 was destroyed by "Controlled Demolition".
The evidence was removed from the site, without giving proper structural Engineers opportunity to take samples, same as the twin towers.
Kind Regards....
