Previous in Forum: Ceiling Fan with Built-in Heater   Next in Forum: $745,000,000 to Cut Up Carrier Enterprise
88 comments
How to Move Water?
06/28/2013 11:25 PM
want to move water uphill without a pump 4 ft from the source at 45 degree incline about 2 ft higher than the source using wicking. Any suggestions?
Re: how to move water?
06/28/2013 11:50 PM
Give up while you are still ahead.
06/28/2013 11:51 PM
Use wicking. Cover the wicking material with a moisture barrier.
And maybe prayer.
What have you come up with?
By the way, if I tell you how to do it, and it works, I am the inventor, not you.
06/29/2013 12:05 AM
There was a thread about this a couple of years ago...it was some kind of perculation method using air. I'll never be able to find it. The guy was bubbling water out of a little creek, and it was very cool.
Anybody remember that one?
This is similar:
http://www.youtube.com/watch?v=plSqyQGuwWc
06/29/2013 3:09 AM
http://www.youtube.com/watch?feature=endscreen&v=b2kv8BUVy6E&NR=1
This may be what you need. Commercially available.
06/29/2013 12:46 AM
Wicker basket.
06/29/2013 1:30 AM
No, wicking basket.
06/29/2013 7:19 AM
A three foot long wicker basket placed a half foot into a large bowl of water. I expect the water will slowly wick through the capillaries in the plant material the entire length of the basket. I expect no more than a few drops of water to be present at the far end but the OP said nothing about quantity or time.
Good Answers: 804
06/29/2013 2:07 AM
I fail to see how any of this relates to ELECTRICAL engineering...
Good Answers: 140
06/29/2013 9:33 PM
Probably why it was posted in "General".
06/29/2013 10:43 PM
Electrical activity of the BRAIN......
Very comprehensive circuit layout....
Don't get 'stuck' just by thinking of common "technical(!)" solutions, be open to the not so 'usual'.....
06/29/2013 2:47 AM
It depends how fussy you are on the definition of 'wicking'. Are trees allowed ? There are many fun ways to do what you seek.
#1........
06/29/2013 4:03 AM
06/29/2013 6:32 AM
I want to turn water into wine.........no luck with that so far either
Good Answers: 918
06/29/2013 7:12 AM
Pour the water on the roots of the grapes! Duh!
06/29/2013 11:47 AM
I knew the leaves took in CO2 on the underside of the leaf, I wasn't sure what they liked to drink
Good Answers: 918
06/29/2013 12:01 PM
Of course. I am a vegetarian and I like to drink, too. :)
06/29/2013 10:12 AM
My wife can turn a breath of air into wine a whine. Does that count for anything good?
Good Answers: 114
06/29/2013 8:16 AM
2' higher and 4' horizontal and 45o?
Wicking doesn't deliver any fluid if the discharge end is higher than the source.
06/29/2013 9:00 AM
Fluid would be nice but wasn't asked for.
I'm still surprised none of us pointed out until now the geometry error. At a 45° angle the elevation change equals the horizontal change. There are too many things unstated and wrong in this poser. Is the water in a liquid state? How much water is available? Must all of this water be moved uphill? Is the sun shining on this water? Why must the mode of transit be by surface tension wicking or was this also in error? Is the two foot rise just part of the journey?
Good Answers: 114
06/29/2013 11:53 AM
Darn it, I really thought water was a fluid, and I did question the geometry.
07/01/2013 3:59 AM
'....Wicking doesn't deliver any fluid if the discharge end is higher than the source.....'
I think we may have different definitions of 'higher than the source'.....or have I been looking at candles and oil lamps up-side-down my entire life?
I think it is fair to say that a wick won't typically discharge higher than its source, but wicking and capillary action can deliver fluid higher than the source.
06/29/2013 9:12 AM
07/01/2013 5:01 AM
Now thats wicked!
Good Answers: 97
06/29/2013 9:32 AM
A ram pump can do that for you.
06/30/2013 7:15 AM
designing and making one of those that was my senior project in college....
Good Answers: 918
06/29/2013 9:47 AM
Try a tree.
06/29/2013 11:39 AM
does the sun shine in your location?
06/29/2013 11:42 AM
Ask congress to pass a law stating that water must run uphill upon demand.
06/29/2013 1:44 PM
Actually it's the Department of Natural Resources and the Department of Energy you need to contact to get exemptions for this.
Re: How to Move Water?
06/29/2013 1:58 PM
Why bother with a wick. A geyser moves water without a wick or any help.
06/29/2013 2:03 PM
getting just the right underground formations at just the right depth are always a tad tricky for mere mortals to get right with any degree of consistancy
06/29/2013 3:25 PM
True, but it certainly is easier than getting this OP to fill in any useful details.
06/29/2013 4:42 PM
If you seal the top of the wick in a glass globe the water will condense and run down the sides, so you need a trough around the bottom of the globe beneath the top of the wick....
07/05/2013 10:32 PM
The fiberglass wick is coiled in the water.....
Good Answers: 48
06/29/2013 6:06 PM
Flowrate?
This will determine whether you go for Hendrik's Ram Pump, or Kramarat's Bucket.
(Kramarat's Bucket has a certain ring to it. I like that!)
06/29/2013 8:03 PM
Is that where Schrödinger's cat is?
Good Answers: 918
06/29/2013 10:04 PM
Despite the finite improbability he turned up at the vet.
06/29/2013 10:09 PM
Yes, but bucket or box?
Alive, or dead?
And, what was the color?
06/29/2013 10:41 PM
Archimedes' Screw?
06/29/2013 11:53 PM
No.
This screw:
Del,
I didn't do it. OK, I thought about it. Laughed even.
K R I S S
d i d
i t.
BUT (no play on words) I didn't yell, "keep turning, keep turning" when the stabilizer is about to go home.
Good Answers: 141
06/29/2013 10:51 PM
1. drop version: a black hose and lots of sun.
2. solar panel radiator with hot out up.
3. water catapult.
4. automatic pee man.
all registered.
Plenty of room here
06/29/2013 10:56 PM
There have been a number of flippant comments on a genuine question. Capillaries have the property of apparently working against gravity, by making the liquid inside the capilaries to raise. But I have not seen any drop of water falling off the tube at a higher level. Some time back, in India there was quite a commotion saying that a Ganesha Idol drank milk from a spoon. We all tried the trick, and found it working. Obviously, due to surface tension, some water/milk that wets a surface, tends to flow through, giving an impression that the milk/water in the spoon is getting emptied on its own accord. The problem addressed has really many possibilities, provided the principle is applied in a proper application. To begin with, one could try a bunch of capillary glass tubes dipped in water and then, may be some one would come out with an idea, as to how to bring the water out of the capillaries !
Good Answers: 141
06/29/2013 11:49 PM
How gets a 8 meter high papaya tree papayas of 8 kg and lots of water inside? Better, a coconut tree. The coconut has between 0.5 and 1.5 liter water in it. And those blue prunes as big as a goose egg?
Plenty of room here
06/30/2013 12:11 AM
Movement of water or sap within a tree against gravity is also a capillary property, since there is apparently no compressor working in the roots of tree ! One could cut off a Papaya and take water out of it and then wait for another papaya to form before harvesting the water sent up by nature. None of us know, but perhaps some one would come out witha device that works on capillary principle and brings water up against gravity.
06/30/2013 12:17 AM
06/30/2013 3:26 AM
Transpiration is exhibited by leaves of plants that are not Xerophytic. Palm trees have leaves that have almost xerophytic characters, but the roots do carry water to the crown of leaves, which are atelast 10 to15 metres above ground level. Hence one cannot ascribe raise of water from the roots to the leaves to trnspiration. We need to accept that capillary action has to do something. Anyway, the point is that there should be concerted efforts to use this property to raise water from ground level to above, Andreas one of our members would have a workable suggestion, hopefully.
Good Answers: 203
06/29/2013 11:19 PM
Possible but requires a lot of adjusting and perhaps a four leaf clover might improve its effectiveness:
Take an appropriately sized pipe, tube or hose and submerge the lower end below the water level. This will probably be small in diameter but not minuscule. Take an air compressor and bubble air through the pipe from the bottom up. Adjust the air flow until you have a sufficient amount of water segments travelling up with the air. Don't stand at the upper end of the pipe because some of those water segments are nasty and will slap you in the face. Better to use an elbow, tee, or modified vent fitting at the upper end to stop this assault on your body. It works unless you use a compressor that requires water cooling, then you need to get some water into the compressor. I have seen it done in a college physics lab. Efficiency near zero, amazement extremely high but don't try to impress the girls with this. They get quickly bored with these things!
Personally I recommend prayer. It too can be effective if you are not real naughty. Probably has a higher acceptance rate than the air driven reverse siphon unit also!
Good Luck, Old Salt
07/01/2013 4:16 AM
To raise water 2 feet, you require approx one lb/sq in minimum. A suggestion for an automatic pressure source is as follows:
Have a large sealed metal container in the sun. The sun's heat will increase the pressure internally. A rise of about 40C will give you about 1 lb/sq in. Connect this to the water source.
At night a one-way valve allows air to enter the container, if the internal pressure falls below atmospheric pressure. A one-way valve is also required to ensure the air line between vessel and water cannot reverse at night.
If you have two vessels, one in the sun, one in the shade (connected between the heated vessel and the water), with one-way valves between vessels, and between cool vessel and water, you could design a system to continue operation at night.
06/29/2013 11:36 PM
How about a flexible siphon like you use to siphon gas from one tank to another only create your own arm that would raise and lower with a pulsating action to create suction in this flex tube in a continuous manner. Or use a vac pump like a wet dry shop vac to lift from the lower level to the 2 ft higher level like a barometric leg does in food processing. I am saying that because if the pulsating effect could be created with the flexible hose/tubing you could create the vacuum suction effect if you could time it to a flapper on the end of the hose to create the thumb effect of gas siphoning efforts. I have done so with stationary plumbing with barometric leg systems to treat the apple slice and have seen how human beings siphon irrigate row crops with a solid siphon tube where you are going the opposite direction from a higher ditch to a lower. Maybe it will only work with a vacuum pump anyway but you would eliminate water flowing through the pump impeller if that is what you are attempting to do. Just some thoughts to consider how to flow this short distance.
06/30/2013 1:57 AM
Built a house 30 years ago that used a Trom Wall system , a French design. 50 gallon drums were painted black, stacked in vertical rows, behind a south facing glass wall, filled with water , and the heat gained would force the water up and thru under floor copper piping for heating purposes. If I remember, the lift gained was about 3 feet--The rest of the extension pressure under the floors was accomplished by 12v pumps, in line, solar powered with battery backups. The pumps were only needed to move the water to the farthest rooms in the upper levels. The lift was done strictly by hot water pressure forcing up. I did not do the install, only the building, from foundations through cabinets and final finish, but do remember very cold days, with a nice warm floor to walk and work on. Maybe there is further info on this type of system..
06/30/2013 3:42 AM
Solar evaporator. Immerse a glass-roofed container in the water. Evaporating water will condense on the inside of the top of the evaporator and then you can let the water trickle off to where you want it.
06/30/2013 4:37 AM
additional information : the amount of water is about a quart is located in a can and is used to water a plant gradually.
06/30/2013 6:17 AM
You make a glasshouse with a pitched roof, or you have a tall, very large glass container with water in the bottom and a sheet of glass covering the top, set at an angle. Water condensing on the plate/roof trickles down to one side and is collected in a gutter that runs to where you want it. I assume you want a quart of water per day. If so, you will require bright sunlight on the floor of the evaporator and the roof area will need to be at least 2 square metres if I remember correctly. The water to be used will be in a thin layer on the floor of the evaporator, which should be painted black. You could use an automatic feed arrangement from a bottle, similar to a bird water feeder, to maintain the water level.
I suspect you don't have the room for this idea.
I suggest you research evaporators. The one I remember was used in the Atacama Desert to supply fresh water for miners from sea water, I think in the late 19th century (Check Scientific American paragraph back 20 years or more).
06/30/2013 8:04 AM
You might be able to draw it up, but you can't do anything with it without supplying energy to get it out of the wick. If it just dripped out of the top, you could put a waterwheel underneath and have a perpetual motion machine, which is illegal in most universes.
Good Answers: 179
06/30/2013 8:11 AM
Employ either a ram pump or a dosing siphon......
Neither requires electricity.
06/30/2013 8:19 AM
you use the term "source", but don't expand on what that means. several here have suggested a ram pump which will work if you have some pressure to begin with, if its just a pond or other static body of water a ram wont work, . I'm thinking solar
Good Answers: 203
06/30/2013 10:06 AM
What transfer rate of the water (gallons/hr., gallons/minute, gallons/day, gallons/month) are you looking for from your system? Metric rate are also usable.
This additional information would probably be helpful to repliers so they can give you more usable answers.
Just a suggestion.
Good Luck, Old Salt
06/30/2013 4:56 PM
a quart every 6 hours
06/30/2013 10:10 AM
Just let the stupid plant die. It's better off dead anyway. Problem solved!
06/30/2013 10:30 AM
Why do you want to do this? What problem are you trying to solve with this solution?
06/30/2013 12:51 PM
Liquid Piston Sterling Engine Water Pump. No moving parts except one way valves and the water.
http://www.fieldlines.com/index.php?topic=136368.0
06/30/2013 1:19 PM
How about trying something like this:
06/30/2013 2:53 PM
You might consider a pipe with a compressed airflow into a bubble injector as a means to raise the water by bouyancy effects.
06/30/2013 4:04 PM
Don't use wicking, use a water wheel.
In reply to #59
07/01/2013 9:04 AM
Perfect, A Watermill would work without a pump Good Idea !
In reply to #59
07/01/2013 12:13 PM
If the lower water source is moving, then your idea makes perfect sense. If that water supply has no current, then the OP might have to try an archimedes screw (or a bucket wheel) that is powered by wind (if there is wind on his part of the country), I recommend a tilted single shaft system (if he opts for the screw lift) that does not depend on wind direction, and will spin even in low wind. If he opts for the bucket wheel lift, there might have to be a spindle and cog (90-degree gearbox) to couple a vertical axis wind turbine to the bucket wheel.
Solar option: use a fresnel lens to focus the sunlight on the pipe with water in it (there will have to be a water tight box allowing the sunlight to be focused on the pipe below the water level in source water), and as long as the pipe is connected to a foot valve, the boiling percolation effect with shoot water up and out to the destination.
Good Answers: 918
In reply to #79
07/01/2013 5:54 PM
Or a mule...
Incidentally, since this is considered prior art there is no patent required.
In reply to #80
07/01/2013 10:42 PM
Or a governor....
06/30/2013 5:23 PM
If your "wick" follows the necessary path to the soil of the plant, the soil becomes an extension of the wick and will consume the wicked moisture more or less as needed. It would be well to enclose the wick to prevent evaporation along the way.
06/30/2013 8:17 PM
BTW, a US quart is about one litre, 1000 ml.
one drop of water is 0.05ml, so 1000/0.05 = 20,000 drops per litre.
6 hrs is 3600 X 6 = 21,600 secs.
So the flow rate is about 1 drop per second.
06/30/2013 8:33 PM
Per capillary, one drop per second. Good. If we have 'n'capillaries in a bunch, then we have n drops per second, and as every one knows or was told, drops make an ocean. We have a potential system which can move water uphill, without any external source of energy. Good luck to all thinkers.
In reply to #64
06/30/2013 8:36 PM
evaporation rates require no hills up or down
In reply to #65
06/30/2013 9:37 PM
Yes. Evaporation has no downhills: only up hills, since water vapour is lighter than air. But we do require a condensing surface at a lower temperature than the ambient for condensing and collecting water. Evaporation takes place at all temperatures. All very good. But what we are talking about is to move water physically up to a few feet, using capillary force. Any info about this most welcome.
06/30/2013 8:19 PM
Buckets...
guds777
Good Answers: 59
06/30/2013 10:16 PM
I am still partial to artesian well.
You drill it once. Water comes up under its own pressure.
Throttle it to the watering rate desired.
If more, than one plant is there, distribute it into different hoses.
It works only in a valley, but glasshouses are usually built there.
06/30/2013 10:33 PM
Now that some of the critical details have finally been brought forth I believe that a covered wick might be able to provide a quart of water per hour to a plant 2 ft uphill of your water source but only temporarily. You see unlike the transpiration of a plant your wick and sleeve will not be alive. As such organic debris and eventually organic life will fairly quickly clog the capillary paths of the wick. A fiberglass wick will work nearly indefinitely in a kerosene lamp because kerosene will not support life. Water will obviously support life. Ironically if you bury the upper end of your wick close to your plant you might even get the root hairs of your plant to clog the wick.
I recommend you drop this idea of irrigation by capillary action and investigate the well researched and documented approach of drip irrigation. Drip irrigation can easily meet your goals. Without knowing the nature of your water source, I will not guess how to fill this irrigation system.
In reply to #68
07/01/2013 2:06 AM
If we could get the roots to enter the capillary and follow the water to its source, that would be more elegant yet.
Good Answers: 918
In reply to #68
07/01/2013 8:25 AM
If we were a plant we would simply grow where the water source is rather than depend on silly humans to figure out how to water us. :)
07/01/2013 3:36 AM
Just lower the plant at least 2ft?
In reply to #70
07/01/2013 5:07 AM
or make the roots longer!
07/01/2013 9:08 AM
Instead of "wicking" try using osmotic pressure. Make sure the starter solution in the membrane bag (with a tube extending upwards to the area where water is to be delivered) has a higher concentration of solutes than the source water. You may need to have an evaporator pan to produce the initially salty water. By the way, the OP mentions nothing about the desired quality of the water, so this will work, and it has something to do with how trees can lift water such tremendous distances.
Good Answers: 918
07/01/2013 9:25 AM
Why not move the plant?
02/10/2021 7:14 AM
Plants do it all the time.
In reply to #83
02/10/2021 5:37 PM
Didn't read my #7
02/10/2021 7:23 AM
#86
02/11/2021 10:39 PM
how about using a watermill to lift depending on the depth of the lower basin to allow for the removal on the upper basin that is higher . just a thought that came to mind. Waterwheel height would have to allow for discharge into this upper basin.
In reply to #86
02/11/2021 11:36 PM
Will it be possible to have ‘U’ shaped capillaries so that water rises in the capillaries due to capillary action and delivery due to our well known gravity ?
Anyway glad that this topic is resurrected after 7 long years .
Anonymous Poster #2
#88
02/12/2021 3:16 AM
Only the shadoof knows.
ξ
Register to Reply 88 comments
Anonymous Hero (7); Anonymous Poster (2); C-Mac (1); CaptMoosie (1); Dan A (1); Deefburger (1); Dr. Harry (1); dvmdsc (2); Fredski (6); Gadepalli Subrahmanyam (6); Gene Hayes (2); guds777 (1); Hendrik (1); Holzfeller (1); IdeaSmith (2); James Stewart (2); jmikehendricksmh (3); JRaef (1); Kilowatt0 (1); Kim2012 (1); kramarat (2); Kris (2); leveles (1); lyn (7); North of 60 (1); old salt (2); passingtongreen (2); Phaddy (4); PWSlack (2); redfred (6); reefdiver (1); Rixter (1); SolarEagle (3); StandardsGuy (1); tcmtech (2); Tom_Consulting (1); Tornado (1); truth is not a compromise (2); vapsterinventor (2); wmerryall (1); yesyen (1)
