Previous in Forum: Difference Between Perpetual Motion Machines, Over Unity Devices and Free Energy   Next in Forum: Washington Post Got Got
A Sustainable Renewable Energy Solution
10/05/2013 1:32 AM
Outlined here is a sustainable renewable energy solution that can provide 10KW electricity continuously 24/7. Or 240 KWh. It uses no fuel except natural forces and is absolutely pollution free. The wind and solar energy are forms of renewable energy that provide free energy, in the sense that once set up, apart from maintenance the energy they yield is free. Any list of renewable energy sources that you might commonly come across contains the following:-
1) Solar, including PV and thermal and CSP and CPV.
2) Wind
3) Tidal
4) Wave
5) Biomass
6) Bio-fuels ( including algae)
7) Geothermal
8) Hydroelectric
9) Osmotic
10) Ocean thermal
The amazing thing about this list is that it does not include either atmospheric pressure or gravity as a source of energy. Having said that look at this video:
http://www.youtube.com/watch?v=YaB8UrNXSho
The way in which the elevator cage with passenger is lifted using just a partial vacuum and atmospheric pressure is quite astounding, don't you agree! No power is needed when descending, just the force of gravity. If this had been described in words one in ten would have said it is impossible, but since it isn't ……!
So although these sources of energy, gravity and atmospheric pressure, have never yet been successfully tapped they are as perennial and ever present as the wind or solar. Can we utilize them to produce power ?
Have a look at this drawing:
As can be seen the counterweights are connected to an open ended shuttle by cable, so that when the counterweights are released there is practically no resistance to their descent except for the friction at the generator spool and the friction where the open ended shuttle is touching the tube. Suppose the height at which the counterweight is situated is 10m and that the generators which they are turning by means of the cable (just as in a car alternator) are capable of generating 5 KW. http://www.aurasystems.com/pages/prod_exploded.html
Lastly the vacuum device seen (attached by ducting to the tubes containing the shuttles) at the bottom right of the picture can consist of a multi turbine system with a backing pump if needed, needs 3 KW of power to operate. Then the sequence is as follows the counterweight weighing 150 Kg is released, generating 14.7 KJ of energy and taking about 1.4 seconds. This means that 7.25 KW approx. are available to turn the generator which needs only 5KW ! The generator which is generating 5 KW of electricity supplies the vacuum motor which needs only 3KW of power. All this time the counterweight has been descending and the open ended shuttle has been rising. When the shuttle is almost at the top of its tube it is sealed by means of an actuator or similar device converting the open ended shuttle into a closed air-tight piston.
Atmospheric pressure is now introduced above the piston with the result that there exists a partial vacuum below the piston and atmospheric pressure above. If a vacuum of 1 torr is achieved. The piston (30 cms dia) would have 706.5 Kgf acting on it while it needs to lift only 150 Kg ( i.e., the weight of the counterweight) . As the shuttle travels downwards under the force of atmospheric pressure the counterweight travels upwards till it reaches its original position. The piston is once more unsealed turning it into an open ended shuttle and the whole cycle keeps repeating. Looking at the diagram above, one of the tubes and counterweights is used exclusively to create a vacuum in the system while the other tubes and counterweights, use this vacuum in a parasitical manner to produce usable electricity by spinning their generators, the generators are geared to produce electricity both while the counterweights are descending and ascending. Thus it is possible conservatively to generate 10 KW of clean, sustainable, renewable energy.
What I really want to know is , is our technology up to it ? I think it is, things like valves, vacuum pumps ( turbines, blowers etc,.) friction reducing materials, pulleys etc., have changed beyond comprehension, in fact it should be possible to monitor the whole process, through strategic placing of pressure sensors. If that is indeed the case and it can be done, the system has a small footprint, needs little maintenance and what maintenance there is will be basic. Put one in every house (or garden) it would generate enough electricity, to cook, bathe, wash clothes, run all of the household appliances, heat the house AND still have enough left over to (a) either charge your cars lithium ion battery OR make and compress enough hydrogen through electrolysis to use in a hydrogen fuel cell.
Find in discussion
Re: A Sustainable Renewable Energy Solution
10/09/2013 4:58 AM
This is still ALOOB.
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
10/07/2013 3:08 AM
Great fun here again!
N:
glad 2 C your effort
now a simple model of your sources of energy: gravity and atmospheric pressure
I imagine L and "my friends" have already tried this at home.
N:
your terminology for the model I would like to see in action as your description, I believe I am missing something about...
an induced (field of magnetism) Gravity energy source:
would be a powered electric coil at a set potential/voltage and current working for
holding a magnetic spring enough as "atmospheric pressure" of say ~ 50% compacted in to the electric coil platform under the spring...
Now we have (magnet on spring of an acceptable compression) Atmospheric-Energy Source spring-pressureD [not just pressure, but gravitationally pressureD] on/in Gravitational Energy Source:::
This material model is the atmospheric source of energy held and pressurized by the source of energy of affixed field-strength in a the other (gravity) here- electro-magnetic field induced as the attractive and nice looking Spring's desire.
OPPOSITES DO ATTRACT !
our hetero gravitational model with an atmosphere in place!
Now N:
Please show how the mechanics work at any induced Gravitational Pull on the Atmosphere pressurized by that gravity as modeled above.
Select any size and spring-coefficient with sufficient fixed induced attraction (power ignored) as it is as a GRAVITY ENERGY SOURCE that holds ATMOSPHERE ENERGY SOURCE [spring to electro-induction plate or core under the spring...
---- that thar'z m' Q: N !
Atmosphere GETS or IS a compacted-PRESSURED (past tense) source of "Energy" in your terms, pressurized from where? Your mechanics should move well within this model, then , sitting on L's floor.
That "Atmosphere Energy Source":
Is it more "energized" away from the Earth in the mountains, or near the sea level closer to Gravity Energy Source central ?
I believe you exist, and can even change with speed an existence in a reference, but I do not believe time is an existing thing to be warped nor broken nor has barriers either.
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
In reply to #63
10/07/2013 3:22 AM
That same elctro-magnetic field on the electric core -plate in the lab would also be such to act on your devices made of then magnetic material but accounting for in some way their relationship to true gravity, so take it into an orbit of weightlessness or counter-spring an equal amount under your devices to off-set gravitational real forces.
some place in the partially compressed spring would be an acceptable cross member of which models the Atmosoheric-Pressure Energy Source 'pushing' to that you have referred as it would be under the influence of the Gravity Energy Source- the electric coil base for the model set up.
Certain parts would be non magnetic, like a frictionles counter balance to the real weight of moving parts, etc.
In reply to #64
10/07/2013 7:50 AM
What do you smoke up there in Ohio?
10/07/2013 4:34 AM
Notary, you mention,
"So although these sources of energy, gravity and atmospheric pressure, have never yet been successfully tapped they are as perennial and ever present as the wind or solar. Can we utilize them to produce power ?"
I like this one for it's potential,
http://www.nauticaltorquetechnology.com/
Also, for pneumatics, this is a good read, and will give you pointers on how to refine and revise your argument
http://en.wikipedia.org/wiki/Compressed_air_storage
In direct competition with aura systems motor/generator, I prefer this technology,
http://www.boulderwindpower.com/the-bwp-generator/efficiency/
Which I came across while reading these,
http://www.popsci.com/gadgets/article/2013-06/gardening-circuit
http://coreoutdoorpower.com/technology/
https://www.facebook.com/CoreOutdoorPower?filter=2
Moreover, you mention how beneficial your system might be based on measurements in KW and KJ interchangeably.
One flaw in this calculation is KJ converts to KW hours not KW. Therefore, the 14.7KJ of energy is converted to 0.0040833333333333 kilowatt hour (kWh) or 14.7 KW seconds
http://extraconversion.com/energy/kilojoules/kilojoules-to-wattseconds.html
http://extraconversion.com/energy/kilojoules/kilojoules-to-kilowatt-hours.html
Furthermore, the 3KW pump you mention will run for only 4.9 seconds minus some losses. Also, your calculation of 150Kg dropped for 1.4 seconds does not complete the equation for conversion to KJ because the formula for Joules (1/1000 KJ) is (KG * M squared) / (seconds squared)
http://en.wikipedia.org/wiki/Joule
Also, the atmospheric pressure above and vacuum below creates resistance against the vacuum pump as those values accumulate and thereby require more power to operate the pump.
One last point to make, for now, is the counterweight gain requires load matching (can add complexity and cost to a design) and experiences reduced energy capture by leaks/thermal losses in a pneumatically driven counterweight.
I'd analyze your statement some more but it is getting late and I need to sleep. Good luck in revising your statements. I'm sure you will find some benefits to energy capture, just not in the argument you made.
In reply to #65
10/07/2013 7:20 AM
Gary, how you came to that conclusion is really difficult to understand ! KJ is just energy in thousands of Joules right, take that energy per second and you have Kilowatts not Kilo watt hours. Does that make you feel better ?
In reply to #71
10/07/2013 7:53 AM
14.7kWs will run 3kW for 14.7/3s. However, there will be some losses, so the above statement is correct in principle.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
#87
In reply to #71
10/07/2013 11:40 AM
Quit talking and just build it. That's the only way you're going to convince anyone, especially here.
Build it, then have it independently tested by more than one source.
However, remember, extraordinary claims require extraordinary proof!
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
In reply to #87
10/07/2013 12:06 PM
Logic does not work on this poster.
#95
In reply to #71
10/07/2013 5:08 PM
Yes, I agree that a KJ is just 1000 Joules.
But, before we go any further, did you state that the counterweight (150KG) drops 10M in 1.4 seconds?
#97
In reply to #71
10/07/2013 8:30 PM
That's where your calculation is going wrong!
Given, One Joule = One Watt X One Second
So, lets apply 14,700 Joules (14.7KJ) which took 1.4 seconds to create from 150KG released but more on that later to turn a 5KW generator. At maximum load, the 5KW generator will convert 5,000 Joules (5KJ) into less than 5,000Watt (due to losses) for only one second or 5KWs. And, 14.7 KJ of Total Kinetic Energy is used up in 2.94 seconds to produce an output of less than 14.7 KW seconds not 7.25KW!
Since KWs is the output variable equal to KJ, both KW or s will act as input variables into the equation. Your given 14.7KJ will consume no more than 2.03 seconds of run time at 7,25KW every second. As a result, you will run out of available free energy in that short span of time!
Therefore 7.25KW every second would not make me happy and it shouldn't make you happy either because you want your calculations to be spot on and verified, right?
Lest you be offended.....
Now on the flip side, 1 Joule = 1 KG X 1 M squared / 1 second squared
Therefore, 150 KG x 10 Meters squared (100) / 1.4 Seconds squared (1.96) = 7,653 Joules or a little over 7.6 KJ
But this value is approx. half of the 14.7KJ if you count for friction and other losses. So perhaps you are counting energy on the way down and up by mistake. But the problem here is there is no contribution from the counterweight on the lift up. Any contribution would come from the energy doing the lifting of the counterweight, not the weight itself.
Good Answers: 117
10/07/2013 9:44 AM
one and all.... while I have read almost every comment... and get the impression that not everyone agrees with the sustainable renewable energy.. so I'd like to offer my contribution to this discussion... however for the life of me I cannot figure out how to put a link in here (using a Mac) please copy and paste the following link into your browser...
http://www.youtube.com/watch?v=yY29De0yxIg
In reply to #78
10/07/2013 9:50 AM
Good Answers: 117
In reply to #79
10/07/2013 10:00 AM
LOL.. yep I know what it should look like.. but I'm damned if I can get it!! Windows.. no sweat!
In reply to #78
10/07/2013 10:03 AM
OOPS.
Got too busy trying to see if CCW was something worthwhile, or just a scam.
PWSlack already posted a link.
ELETTRONICA SANTERNO S.P.A seems to be the parent company.
Don't know how this relates to notary's fantasy.
Good Answers: 117
#82
In reply to #81
10/07/2013 10:53 AM
No Santerno are not the parent company, they sell the inverters only.
I thought renewable energy was the theme.. what CCW do is classed as renewable!
In reply to #82
10/07/2013 11:13 AM
CCW Energy Systems - Complete profile - Canadian Company ...
Scroll down to "Company Description"↓
"CCW Energy Systems are the Oil& Gas design group of Santerno Inc."
This all sounds fine, but bears no resemblance to any of notary's fantasies.
In reply to #78
10/07/2013 12:06 PM
Brich. It sounds like you are using Safari as your browser. For whatever reason, Safari does not support the CR4 toolbar, or perhaps CR4 does not support Safari. In any case, Firefox does. I've used Firefox for at least six years, always on Macs. There have been two or three occasions where I had to use Safari, but I don't remember why or when. Periodically I check back to see if either Safari or CR4 have changed, but so far no luck (I just checked).
If you must use Safari, then you must use the directions given at the bottom of the edit window:
In other words, on a separate line you would type:
link url="http://www.youtube.com/watch?v=yY29De0yxIg" /link
Dick
Good Answers: 117
#100
In reply to #90
10/08/2013 12:49 AM
many thanks for that.. yes using Safari.. I do see the instructions as you mentioned, however, when I try following said instructions... and I click 'preview comment' the line with the link disappears!!!
firefox for Mac methinks!!
In reply to #100
10/08/2013 1:10 AM
You're welcome...
That "click 'preview comment'" problem may be related to CR4's current timing problem for preview. Currently, if you take more than a couple minutes to compose a reply, when you click 'Preview Comment', then 'Submit' , CR4 says something like 'unable to process form'. To get around that problem I've gotten accustomed to doing a 'Select All' and 'Copy' (Command-A, Command-C), then going back to the original thread and pressing 'Reply' a second time, then pasting the contents of the clipboard (Command-V) and pressing 'Preview Comment', then 'Submit'. This bypasses the timeout.
Perhaps a similar procedure might work for the link problem, but I've been happy with Firefox - I think that is the easier solution.
10/08/2013 12:56 AM
"Then the sequence is as follows the counterweight weighing 150 Kg is released, generating 14.7 KJ of energy and taking about 1.4 seconds."
Until now, I hadn't bothered to check on your original numbers, other than the 14.7 kJ of energy stored in the 150 kg weight lifted 10 m (which is indeed correct).
Now about that 1.4 seconds: the distance traveled by a freely falling body is given by x=1/2 at2. 1/2*9.8*1.42=9.6m. So a freely falling body wouldn't quite make the 10 m fall in 1.4 sec. Your weight is NOT falling freely. Did you notice that Aura (your link) recommends six to twelve belts to convey power from the prime mover to the generator? Your 150 kg weight is significantly held back by the generator, and will fall MUCH more slowly than a freely falling body.
After all, if your weight fell freely, ALL of its original potential energy would be converted to kinetic energy, and NONE of that potential energy would be converted to electric energy. If you wish to convert the potential energy to electric energy, than you want the weight to reach bottom with very little kinetic energy, in other words slowly.
Thus a more reasonable time to reach bottom would be something like 10 seconds, providing an average power of around 1.4 kW into the generator, so the generator might convert that into 500-700W of power for the ten second interval.
...or that the generator does not generate full power until it has at least 2400 RPM?
If you haven't gotten the message by now, I'm totally wasting my time.
Your system won't lift the weight more than a few cm after the first fall!
#105
In reply to #101
10/08/2013 4:04 AM
I am sure that there is something wrong with the logic, I just can't put my finger on it, but believe me it is there, some oversight or mistake in your calculations.
#106
In reply to #101
10/08/2013 9:48 AM
I am a bit disappointed in dkwarner, at least in this post. What about regenerative braking in cars when almost all of the braking power is converted into electricity, you can even come up with rough answers as to the amount of electrical energy that will be generated. What about regenerative elevators which is even closer to Home Grid, than regenerative braking is, b'cos the same kind of cable pulley sheave system is being used. Regenerative elevators feed electric energy back into the building grid. Nuff said…….
p.s. ideally the load should be equal to mg of the counterweight, when this happens the counterweight will descend at constant velocity !
In reply to #106
10/08/2013 10:10 AM
You've got a lot or ARROGANT, UNMITIGATED gall to say that you, a complete and total fool, are disappointed in anyone.
I've stayed out of this mostly because I think you are an uneducated buffoon, who does not listen to reason.
But, it is very arrogant for you, a newcomer, to pass judgement on long standing, respected members who have humored you this far.
You've been here for 4 days now, and have not made a single worthwhile statement, and certainly no contribution to anything except your astronomical ego.
The other members here are too polite to say what they really think about you. I am not bound by such manners.
In reply to #106
10/08/2013 11:59 AM
What is it that disappointed you? That I keep telling the truth and facing reality?
"What about regenerative braking in cars when almost all of the braking power is converted into electricity"
If you consider 80-90% to be 'almost all', then the above statement can be considered correct. I would consider 98-99% to be 'almost all', and that does not happen.
These car systems store the energy in batteries, so now you need to find a DC driven vacuum pump, or add an inverter to the system for even more losses.
" ideally the load should be equal to mg of the counterweight, when this happens the counterweight will descend at constant velocity"
NO! The load should be equal to the mg of the counterweight minus friction and other loss forces, after the system has reached equilibrium speed. If the initial load is equal to mg, then it won't move!
#112
In reply to #110
10/08/2013 1:45 PM
SUMMATION !
We have all had a great time kicking this idea all over the block ! Finally it was dkwarner who cracked it by pointing out that a 150 Kg weight can never ever under any circumstances, produce more power than mg regardless of whatever height it may be at. It can and will produce something close to mg. HOWEVER, the 'Home Grid' design is so robust, so unusual and so daring that it managed to survive, although in a truncated form, putting out a respectable 3 KW (small adjustments in weight can be made) instead of the lofty 10 KW that it aimed for. In order to do this confidently it might be necessary, as a safeguard, to have two units producing power for the vacuum device. The situation is now as follows, volume to be evacuated is three quarters of the volume to be evacuated in a vacuum elevator of similar size. Vacuum motor draws 3 KW and it might be necessary to use both flywheels and ultra capacitors in order to maintain the vacuum during the piston descent (i.e., counterweight ascent). The end result is that it is now possible to state with a fair amount of confidence, that we have something that we didn't have before, a low maintenance, simple to maintain, self cooling system that turns out a respectable 3 KW , 24/7 . It will work, regardless of weather or climatic conditions or whether it is day or night, anywhere in the world except if you happen to live in the Rockies or the Himalayas in which case you might have to make do with 1 Kw or 2 KW instead of the standard 3 KW.
Good Answers: 104
#113
In reply to #112
10/08/2013 3:15 PM
Having grown up with 2 older sisters, I can assure you that, as much as you might want it to be so, getting the last word in doesn't necessarily make you right. No matter how loud you SHOUT it. And yes, I've been on both ends of that .
In reply to #112
10/08/2013 3:18 PM
I wasn't going to say any more, but I gotta!
"a 150 Kg weight can never ever under any circumstances, produce more power than mg"
mg is a force, not a power! Until you understand the differences between force, mass, energy, and power, there is no way you will be able to understand why your system won't work.
The "Home Grid" design may have survived in your mind, but nowhere else!
One more time, as several others have said: Build it! When it works, as verified by at least two trustworthy independent testing agencies, I'll contribute to the statue!
#115
In reply to #114
10/08/2013 3:24 PM
I would like to point out that the term mg is just a cipher after all, it has no meaning at until translated through distance and time. When that happens, the original calculations made by notary hold good, and his original figures are correct after all. His 'Home Grid' system will theoretically produce 10 KW after all. Remember the KE he has calculated is 14.7 J, this is used to turn a 5KW generator, it looks doable.
In reply to #115
10/08/2013 6:03 PM
This is what is called "peer review": when the proposer of a silly idea gets someone equally as silly to review and approve it. This technique is popular in pseudoscience, theology, and other such phony disciplines.
In reply to #115
10/08/2013 6:16 PM
Don't talk daft, mate! You'll be branded as an idiot almost before you've joined CR4!
In reply to #119
10/08/2013 6:19 PM
It's too late.
Only two posts, and it's already certified/confirmed.
10/08/2013 3:01 AM
Ok lets play it your way.
I recently invented a beer driven lift for a bar in Arisona which worked on the principle that you described somewhere above. We are talking about an open system!
The bar is open lets say 24 hours (as it does not really matter).
Access to the bar is given with a beer driven lift.
How does it work?
Well, the toilets for said bar are downstairs and yes you guess it. The lift is a dual cab balanced system. People from the bar that have been drinking heavily need to get downstairs lifting the people up that come back from toilet or just want to get in for one or two. You get it?
It was quite amazing to think this out but to even build it used up all the mental strength we could muster! Now the vacuum that is created is on top of the beer hose. Of course we have to get the beer up to the upper level! For this we actually applied for a patent as it is a very sophisticated device that takes part of motion from the beer driven lift to create a vacuum due to friction but I don't want to bother you with details.
I was once asked if I need compressed air, but I think most of the time the air rushes through without compression!
Yes thats how my lift works! It reminded me of your machinery.
Oh and don't bother with the KW and KWh and stuff. Beer is only good with over 5%!
Good Answers: 119
#109
10/08/2013 10:30 AM
What you are failing to understand is that gravity and air pressure/vacuum do NOT SUPPLY ANY ENERGY unless you first INPUT the same (OR MORE) energy than you want to get back. For the sake of this discussion you need to consider gravity, air pressure/vacuum, mechanical springs, inductors, capacitors, etc. as ENERGY STORAGE devices.
Gravity... You must do WORK (supply energy to) an object to move against gravity. When you raise the height of an object on Earth, you INPUT energy which becomes potential energy. When you allow the object to return to its original position, you can "theoretically" get back all the energy you put in. Since we cannot build "perfect" (no loss) systems, you will only get back a portion of the energy you input. NEVER more energy than you started with!
Air pressure/vacuum... You must do WORK to compress or evacuate air against the ambient pressure. When you allow the pressure/vacuum to return to its original state, you can "theoretically" get back all the energy you put in. HOWEVER, pneumatic systems are typically lossy since the heat generated during compression is usually lost. In small scale applications (like this discussion) pneumatic system are quite useful but very lossy. You will be lucky to get back 50% of the energy you originally input.
An ideal elevator system will have the car(s) counterbalanced with large weights. The only work done is to move passengers up with LOSSES from windage, bearing friction, and the motor/drive system. While regenerative electronic motor/drive systems can capture some of the braking energy, friction brakes may also be necessary for "normal" operation. This further increases energy loss in the system. The potential energy of people going down can be recovered by the regen system, but all those pesky losses present on the trip up are still there on the trip down... MORE energy lost.
Please try to review and understand the basic physics involved. One possible starting point could be:
http://en.wikipedia.org/wiki/Classical_mechanics
After reading through this thread it becomes obvious you are NOT interested in learning and expanding your knowledge base.
I can think of 3 possible scenarios why you continue to post here.
1) You ARE a scam artist looking for suckers and/or some validation of your scam idea to bilk investors.
(Suggest you try to post on a known over-unity site where your ideas may be accepted.)
2) You are completely convinced (obdurate AND delusional) that your idea actually works despite evidence that it violates all known physical rules and NO ONE ELSE can understand your unique vision.
(A medical or mental health professional may be able to help here.)
3) You really DO know this idea is junk science and you just like to POKE bee-hives.
(You are really GOOD at poking bee-hives!!)
#126
In reply to #109
10/11/2013 9:22 PM
Have a look at what you are first ! Remember that when you point a finger at someone 3 fingers are pointing back at you ! What is it with this fracking! What are you doing to a beautiful land ? Is that greed or what is it, you are poisoning the whole land. Do you know that fracking has only just started and already 0.1 per cent of all the fresh water in the country is being used for fracking ? 0.1 per cent of all fresh water ! Yes, the shale people say there is no danger but would any of them drink a glass of water used in fracking ? That water, a lot of it will stay down there for thousands of years, even if you get it back where do you put it ? So please put on your thinking cap, and don't sound so smug and self satisfied, is all I ask.
In reply to #126
10/11/2013 9:35 PM
Don't sugar coat it. What are you really trying to say?
Is it, that after three posts, you have become an expert on the forum and how it works?
None of your babbling is on the subject at hand, but just childish drivel which leads one to believe that you are the other fool here, whatever their name was, on a different computer.
Cheers, there's a good boy. Go and play.
#128
In reply to #127
10/11/2013 10:16 PM
I am not sure it is all that off topic, the question seems to be one of greed, am I right ? I was reading the other day that parts of Texas are already running out of water, I forget which newspaper, most of the water was being used for fracking ! Running out of fresh water is the least of the concerns, when it comes to fracking, yet you don't want to have arguments like this where you have proved nothing, and where deep down you know it just might work.
In reply to #128
10/11/2013 10:40 PM
So, it's true. You are he.
You are also still............................................................hopelessly disconnected.
I will now leave you to your delusions. May you/he come to your senses, or not.
In reply to #128
10/13/2013 12:45 AM
This reply, especially just after #126, offers fairly compelling evidence that 'Notary' and 'Harami' are two screen names used/owned by just one person.
Perhaps someone could check to see if the originating IP addresses are the same?
Good Answers: 119
#130
In reply to #126
10/12/2013 10:36 AM
Did you post to the wrong thread?
http://cr4.globalspec.com/thread/86669
What does fracking, a real world issue about accessing NON-RENEWABLE energy sources with REAL pros and cons, have to do with the imaginary (not real) source of renewable energy proposed in this thread?
#144
In reply to #109
10/30/2013 3:53 PM
what he say i say again, as I say it was abovesay:
the air PRESSURE is the gravitational force on it and all stabilized in its envelope, never is an "ENERGY SOURCE"
please remove that from thoughts and then find the UNDER UNITY that regardless of any human or Lyn people-personal logic, is just sensible under-unified energy stabilization/consumption-product or summation= negative ends
Good Answers: 42
#131
10/12/2013 1:21 PM
Notary,
Your energy source concept of gravity energy is very correct. Gravity is available 24 hrs, 365 days given at any part of the planet- let it be land or oceans or islands / mountains or the polar regions.
The down ward journey of falling weight or fluid is already being exploited as Hydro power needless to say.
Rather all such extraction devices can be best called as converters and strangely the term generator is used.
You are partially correct about the energy resource, but the means chosen needs reconsideration and refinement. Good effort.
Nature is so graceful and naked. Human possession is ridiculous.
In reply to #131
10/12/2013 1:47 PM
The problem with gravity "power" is that what goes down to create the power, must first go up.
This requires energy in some form.
Hydro power only works because water was lifted first, in the form of water vapor, to the height from which it falls. This requires energy.
Our schizophrenic, "friends" cannot grasp this.
Good Answers: 183
#133
In reply to #132
10/12/2013 1:50 PM
Why do you continue ? It is hopeless he is a BELIEVER and nothing will make him change his mind (if he has one).
In reply to #133
10/12/2013 1:55 PM
I am through communication with notary/harami and any other of their personalities that may materialize.
You are right, I think it's time to pull the plug.
Adieu.
<unsucscribe>
11/11/2013 12:25 AM
In reply to #146
11/11/2013 4:21 PM
129CBRider (1); Anonymous Poster (1); bigg (3); bravo88 (1); brich (5); Bricktop (1); ci139 (2); dkwarner (17); Fredski (2); garyrich2000 (3); harami (3); IdeaSmith (1); JNB (1); JohnDG (6); JP76 (10); lyn (20); masu (4); mjb1962853 (5); nick name (4); notary (19); Passerby (1); PWSlack (10); RAMConsult (2); Rixter (1); Rockyscience (1); ronclarke (1); s.udhayamarthandan (1); Sleepy (1); Tornado (2); truth is not a compromise (11); Usbport (1); Yusef1 (6)
