Previous in Forum: Sprinkler In Operation Rooms In Hospitals?   Next in Forum: Publishing Studies Denying Climate Change
24 comments
Scientific Notation
01/14/2014 9:56 AM
So far I haven't found anything on the evolution of scientific notation from what I used in college (1.2 x 109) to what is used today (I think 1.2E9). What are the steps the notation has taken along the way? Google didn't help--explained it, but didn't give the evolution. Can someone guide me either with the steps or a source? Thanks.
Lehman57
Re: Scientific Notation
01/14/2014 10:00 AM
01/14/2014 10:05 AM
If I had to give an answer, I have to say the evolution took place due to digital representation (hand held calculators)
SE's link is good reading.....
01/14/2014 10:27 AM
An intermediate step might have been 1.2 x 10^9. This might have been for use in simpler text programs that don't support superscripts and subscripts.
01/14/2014 10:29 AM
that's how you would right it in an equation.......... this is shaking my cobweb collections loose............... spent quite a bit of time collecting those cobwebs.......
Good Answers: 88
01/14/2014 12:54 PM
I believe it has something to do with the design of the infamous 8087 math coprocessor used on some (not all) first gen 8086 PC's. An advanced version of that chip is integrated in all later main processors. S.M.
Good Answers: 444
01/14/2014 1:35 PM
Very little to do with the chip/hardware, everything to do with the programming language/compiler/interpreter. There was no way to show superscripts on a punch card keyboard so Fortran introduced the ** to indicate base 10 exponentiation, then other languages opted for Λ; over time most languages recognized both, then E became the standard to distinguish from base e
http://en.wikipedia.org/wiki/Scientific_notation
Good Answers: 104
01/14/2014 1:42 PM
If I recall from Fortran IV (it was a while ago), that would have been expressed as 0.12E09.
Good Answers: 97
01/14/2014 2:04 PM
The E notation was used in 7 segment displays of calculators and having limited digits.
Good Answers: 151
01/14/2014 2:18 PM
I believe this went back to early computer languages (FORTRAN) to distinguish numerical constants (6.03E23) from arithmetic operations(6.03*10**23)
01/14/2014 8:54 PM
When all else fails, I go back to basics.
Good Answers: 25
01/14/2014 11:37 PM
Where do you put the batteries?
01/14/2014 11:53 PM
Far as I know, they're hybrid. The display is solar powered and the slide is manual.
Good Answers: 25
01/15/2014 12:14 AM
Well-played! (I still use my Post Versa-Log II®.)
01/15/2014 9:09 AM
Dear Mr.EdWatts,
Refering to Posting No.10, by Mr.lyn, it is a SLIDE RULE. There is no Battery for this Slide Rule. There were many brands of Slide Rules and what you see in the picture is one type of slide rule.
About 50 years back, NO CALCULATORS and the Calculators came very popular and was in the reach of common man after 1975, with limited functions. After 1980, the Calculators have been developed in a very large way.
DHAYANANDHAN.S
Good Answers: 25
01/15/2014 9:57 AM
Uhh...
...Never mind.
Good Answers: 11
01/15/2014 12:21 PM
Thank you, Sheldon! LMAO
01/15/2014 10:24 AM
1.2E9 is called engineering notation. I think the HP35 handheld calculator was the first to use it.
01/15/2014 2:49 PM
SE: Nice site, but it is too early to have the "recent" changes I'm looking for. Recent being within the last 50 or so years.
Tornado: That's likely one of the steps, or maybe a double ** for exponentiation.
RAMConsult: But did we also have the notation 1.2 x 10E9? Might have been an intermediate step, but also seems superfluous.
Ed Watts: I still have my Post slide rule too, but no longer use it.
Lehman57
01/16/2014 5:21 AM
I think you are confusing Scientific Notation with Engineering Notation.
Engineering notation will always be expressed as a number between 1 and 1000, or -1 to -1000 with a power that is a number that is a multiple of 3. (milli,mega,giga,etc.)
Scientific Notation can be a power of any integer between 1 and ten and a power of any integer.The "E" is there to avoid confusion between the two.
01/16/2014 6:21 AM
Then is S used for scientific notation, e.g. 1.2S8?
01/16/2014 7:12 AM
Not necessary. If no "E" it is usually scientific notation.
Sometimes,when the structure of the number makes the system self evident, the E will be omitted.When the exponent is negative,for instance,you know the system is Engineering units.Or if the exponent is a multiple of 3,and the whole number is greater than 10, it is Engineering units.
If the whole number is 10 or less,and the exponent is not a multiple of 3,it is Scientific notation.
01/16/2014 7:17 AM
Oh, goodie, a decision thicket....
And if the number is less than 10, and the exponent is a multiple of three, one flips a coin to decide whether it is scientific or engineering notation.
01/16/2014 7:31 AM
Same value either way.In that case it doesn't matter.
Good Answers: 12
01/16/2014 3:12 PM
I started using 1.2E9 notation on my own in the late 1960s because it was alot faster to write than 1.2 x 10^9 . I don't know if I picked it up from Fortran or if it simply came to mind, but it was long before calculators.
Bill
Register to Reply 24 comments
bigg (1); dhayanandhan (1); Ed Watts (3); gringogreg (1); Hendrik (1); HiTekRedNek (3); Lehman57 (1); lyn (2); phoenix911 (2); RAMConsult (1); Sciesis2 (1); SimpleMind (1); SolarEagle (1); specifier (1); StandardsGuy (1); Tornado (3)
