Previous in Forum: OMRON PLC   Next in Forum: VFD Output Signals
Single shot pulse circuit
10/10/2009 10:47 AM
Dear friends ,i am looking for circuit which can generate a single pulse(TTL) duration 100 to 500mS as soon as the circuit power is turn ON.Meaning when i turn ON the power there is a single pulse and off. ( High to Low )Here the triggering signal is the power supply.(24Vdc)I am planning to use this pulse to trigger a SCR.
Thank you.
Pathfinder Tags: Single shot pulse circuit
Re: Single shot pulse circuit
10/10/2009 11:38 PM
Any text describing NE555 timers will have several ways to achieve this goal. Total parts cost around a dollar or two.
I'm not at home this week, so I can't quickly give you the exact title and author, nor a specific circuit.
Good Answers: 119
10/11/2009 7:01 PM
This simple SCR gate drive circuit could be sufficient. Values are just initial suggestions.
10/12/2009 12:18 PM
That's simple enough, but you need a SPDT switch to discharge the capacitor when power is removed, and possibly a diode in parallel with the resistor to discharge quickly, if the off time can be very short.
Good Answers: 119
10/12/2009 12:38 PM
Yup! If wired as shown, cap needs discharge path. Assumed load on 24Vdc would be enough, otherwise additional R is needed. More likely PS is switched from line side. Cap discharge could then occur through PS, load, or additional R.
Hobbies - Musician - Tube Amps Only Please!
10/11/2009 7:28 PM
I just used a design in this link just what you are talking about. Run it at 5V and adjust the timing capacitor works good I tested it. Here is the link: http://www.kpsec.freeuk.com/555timer.htm
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
10/12/2009 12:21 PM
Good Link!
10/14/2009 11:15 AM
Guys , thanks alot for the information. Really appreciated your ideas.
Register to Reply 7 comments
dkwarner (3); kumarr68 (1); maveric_manic (1); mjb1962853 (2)
You might be interested in: Circuit Breakers, Circuit Tracers, Power Transformers
