Previous in Forum: Transformers   Next in Forum: Brushless Alternator
Synchronous Machine - 50Hz to 60Hz
10/16/2009 4:20 AM
Hello,
anything should i consider if i want to run syn machine 60 hz which used to run at 50 hz at power station.
Re: Syn . machine running at 50hz to 60 hz
10/16/2009 5:04 AM
Re: 50 Hz & 60 Hz from THREAD 50 Hz & 60 Hz
posted in Electrical Engineering
Pathfinder Tags: 50 Hz 60 Hz motors
03/08/2007 6:32 AM
by
ashelec
517
03/01/2007 10:52 PM
by Guest
517
50 Hz & 60 Hz posted in Electrical Engineering
02/14/2007 10:33 PM
by Guest
408
Re: POWER FACTOR. from THREAD POWER FACTOR.
05/19/2008 5:53 AM
by
chhotu1990
371
Re: machine to drive 50hz to 60 hz from THREAD machine to drive 50hz to 60 hz
09/27/2009 5:41 PM
by
lynlynch
284
Re: transmission lines from THREAD transmission lines
06/27/2007 3:52 PM
by
Haajee
256
Re: difference of 50 hz and 60 hz machines from THREAD difference of 50 hz and 60 hz machines
Pathfinder Tags: electric machines frequency
03/16/2008 9:49 PM
by
biswanath.das
187
03/15/2008 1:24 PM
by
marke
187
Re: 50 Hz and 60 Hz: Pros, Cons and National Standards
10/16/2009 6:49 AM
No,but you can run the machine by connecting a Ac drive. By connecting your 60 HZ M/C you can run but not at full speed. you will get only the M/c rated speed/60 X50.
Binod Kumar Panda
10/16/2009 10:26 AM
syn, machine means ?is it Generator u are referring or any motor?
Re: Synchronous Machine - 50Hz to 60Hz
10/21/2009 12:53 AM
Friend, syn machine has been designed in order to get maximum benifits at minimum maintenance.
But I do not recommend for this.
Do you remember this formula: N=120*f/P
Where N= speed in rpm
f= frequency
P= No. of poles
So for 4Poles at f=50Hz, N=1500rpm;
similarly for 4Poles at f=60Hz, N=1800rpm.
Hence, we need to run this machine at high speed, the probable problems occurs are:
1. Vibration
2. Failure of bearing
3. more forces over over hangs of rotor.
4. Probable chances of rubbing between rotor and stator.
I feel I have answered your question.
Suvek Kumar
Er. Suvek Kumar
Register to Reply 4 comments
lyn (1); nesubra (1); pandabinod (1); suvekkmr (1)
