Hello Gentlemen
The guy in the garage located the timing belt in accordance to the 3 timing marks. Then tightened the top cover down onto the camshaft, squashing the exaust valves on cylinder 6.
When the timing marks are lined up, pistons 1 and 6 are at top dead centre.
I replced the damaged valves and now neither him nor I are inclined to do it again.
I had the idea that all the pistons should be in the mid bore position when the camshaft is placed, such that the valves are not pressed onto the camshaft.
My question is Are the timing marks correct (ie piston at top dead centre) or has the crankshaft pulley been moved.
Is it normal to tighten the camshaft pulley down onto the valves and press them open. (In our case they were pressed onto the piston at TDC)
