Previous in Forum: Grounding   Next in Forum: Maximum Demand Calculation in Energy Meter
12 comments
Heavy Load on Low Power Supply
06/24/2010 4:48 AM
hi friends,
i have only the source with 5kw loading capacity on ac. but load is 10kw, is it possible to operate my load with this source. is any type of circuit or device designed to work on this condition. help me..................
Re: havy load on low power supply.
06/24/2010 4:52 AM
At least two 5kW sources are needed, operating duty/duty, or a single one rated for a 10kW load. Either that or at least 50% of the load needs to be shed.
Doing nothing will cause the 5kW equipment's overcurrent protection device to operate.
06/24/2010 5:23 AM
There is no such a equipment yet. You have to increase your source capacity or reduce your load.
Re: Heavy Load on Low Power Supply
06/24/2010 9:10 AM
I have a solution to your problem.
LynDoor® Inc. Overunity power generators are free and produce 100KwH of excess power so you can sell the un-needed power to cover the cost of shipping.
Just send your address, along with $100,000.00US for postage and we'll have one at your door yesterday. No need to hook it up, either. All you do is put it in the same room with the load.
Happy times ahead.
India - Member - New Member
Good Answers: 164
06/24/2010 9:15 AM
Are you sure this isn't Vader ? If yes, this makes three so far.
06/24/2010 9:23 AM
I believe you are right. Sounds like one of his victims. I was just trying to make a fast buck while the OP's brain was still muddled.
Some more:
Making & Breaking Current
How Much Weight A Chain Block Can Lift
Short Circuit in Sea Water?
F
HHO geneators??
MFI vs Shear Viscosity
About Electrical Panels
06/24/2010 12:24 PM
I like your solution.
Ah, the LynDoor® Mark1. We need to make up some ad slicks and print some brochures! These things are really taking off!
Let those over-unity scoffers snort their disbelief. From the veranda of my Swiss villa I will drink a toast to them all (after we work out those few pesky details).
Good Answers: 54
06/25/2010 12:28 AM
Sometimes it's possible to break a large load up into smaller components and then run just one piece at a time. This can often work with electric heaters or pumps
It's also possible to reduce the motor startup load using star-delta or soft starters.
Sometimes different gearing/motor sizes can help loading ie a rarely used big motor could be replaced with a continually running small motor.
Sometimes you can use different power sources ie swap electric heaters for gas fired heating.
It depends completely on the type of equipment and how much time/effort you have
It's probably cheapest to get a bigger power source
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
06/25/2010 3:41 AM
I can only get one pint in my one pint beer glass: please help me to get two pints in it.
06/25/2010 7:50 AM
Good morning Randall.
Just use a one pint glass with a 100% safety margin!
06/25/2010 8:43 AM
...And when you find the way to do it, I want to become your partner.
pleeeease don't forget me.
Wangito.
Never trade luck for skill.
04/18/2013 3:10 AM
ok
06/26/2010 8:24 AM
It is same as some one get salary for month and asked to work for two months.
Register to Reply 12 comments
Anonymous Poster (1); Doorman (2); ffej (1); kvsridhar (1); lyn (2); PWSlack (1); Randall (1); rizwanad (1); shahnawaz ansari (1); wangito (1)
