Previous in Forum: Selenium Rectifiers   Next in Forum: Power Protection Engineering Courses
17 comments
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Voltage Measurement
07/02/2012 1:57 AM
VFD- Variable Frequency Drive
V- Voltmeter
M- Motor (Brushless DC)
Voltmeter measuring voltage = voltage supplied to the motor - Voltage coming back from the motor (back emf) - Voltage drop in the motor.
Is this correct?
you need to go, to get something
Good Answers: 34
Re: Voltage measurement
07/02/2012 2:38 AM
No.
07/02/2012 4:56 AM
Then what will be the reading of voltmeter?
07/02/2012 9:48 AM
The voltage applied to the motor.
07/02/2012 2:53 AM
And what is a VFD doing on a DC motor?
07/02/2012 4:57 AM
Its not DC, its brushless DC, VFD is used for electronic commutation
07/02/2012 3:19 AM
No (plus #2↑).
07/02/2012 4:57 AM
Why??
07/02/2012 6:58 AM
If it were a PWM controller on a DC motor, then fine. If it were a VSD controller on an AC motor, then fine. One cannot mix-and-match; it's NBG.
Good Answers: 982
Re: Voltage Measurement
07/02/2012 11:29 AM
You need to review your electric motor fundamentals. All electromagnetic motors work by magnets attracting and repelling each other. In your review of motor fundamentals you will see that a variable frequency drive (VFD) generates an AC signal and not a DC signal.
07/03/2012 1:25 AM
Yeah you are right..
It should be an AC motor, then what is the voltmeter measurement??
Good Answers: 982
07/03/2012 9:27 AM
What do you want? If you want a numeric value, I'll give you 42. If you want an understanding of what the motor is doing by just measuring the voltage across the stator windings then you cannot have that. Why? Well that's because you do not provide enough information to discern at all what is happening. You really need to review your electric motor fundamentals.
Without a basic understanding of electricity, kinematics and how an AC induction motor works a correct answer will likely not be understood by anyone.
07/03/2012 10:53 AM
Well, i dont want 42 for now okay. I think u dont need numbers to answer this.
i think u didnt see the original post correctly. see my 1st post
and you are not able to catch the question.
Good Answers: 295
07/03/2012 11:11 AM
The reading of the voltmeter will be null.
In your schematic there is a motor, a VFD, and a meter.
Good Answers: 982
07/03/2012 11:18 AM
You are absolutely correct, I am not able to catch your question from the way you've written it. This is why I asked you, what do you want? Your original question of this thread has a glaring mismatch of hardware choices. Your original question is wrong. Please rephrase your question.
07/04/2012 12:28 AM
V- Voltmeter
M- AC motor
VFD - Variable Frequency Drive
In operating condition, will voltmeter read the value only applied to the motor from drive or what?
07/04/2012 12:33 AM
Yes, it will read the voltage applied to the motor.
Good Answers: 982
07/04/2012 8:30 AM
Yes, I'll buy that.
Register to Reply 17 comments
Doorman (1); Joshi (1); PWSlack (3); redfred (4); sharath4 (6); Tornado (2)
