Previous in Forum: Transformer Question   Next in Forum: Help Requested - 3 Phase Rotary Switch Wiring
10 comments
Ventilation Fan Inrush Current
12/12/2013 12:00 AM
Hi,
Can you help me for finding inrush current for a 40 W ventilation fan its operating voltage is 230 and current is 0.17 A.
Re: ventilation fan inrush current
12/12/2013 2:02 AM
Measure the terminal resistance and divide it into the supply voltage.
Good Answers: 53
12/12/2013 2:42 AM
That's True for DC Motors. In locked rotor condition Inductance don't go to zero for AC Operated motors so the inductive reactance. Its the impedance that will replace resistance
12/12/2013 1:11 PM
The original poster did not state whether it was direct or alternating current therefore #2↑ is correct.
12/12/2013 8:07 AM
Read the nameplate. LRA
Re: Ventilation Fan Inrush Current
12/12/2013 11:23 AM
I have to ask...this is such a tiny load, are you actually asking so you can put a current protecting relay on it , an alarm indicator?
12/12/2013 11:57 AM
These questions are all on the test he's taking.
12/12/2013 1:15 PM
It's a shame there isn't a Good Question button.
12/12/2013 11:13 PM
If manufacturer cannot give,connect a power analyser or analog clamp on meter,switch on the fan and check inrush,starting and running currents.
pnaban
Good Answers: 70
12/13/2013 1:39 AM
Where was CR4 and the internet when I was going to school?
Dang it! I could have had someone else do my research and home work too
Good Answers: 117
12/14/2013 10:31 AM
No I cannot help you.
You must help yourself.
I suggest a test proceedure... hook up a fan to a tester of some sort. A volt-ohm meter that will record the value of a spike, or an occiloscope...but the best would be a rotating drum indicator.
Register to Reply 10 comments
dj95401 (1); Fredski (1); lyn (2); pnaban (1); PWSlack (3); rakesh_semwal (1); Yusef1 (1)
