Previous in Forum: Minimum Thikness Requirement to Check UT Lamination of Tubular Pipe   Next in Forum: Hydraulic Elevator Problem
8 comments
Design Pipeline
12/12/2013 11:45 AM
I'm working on a project for a pipeline. This pipeline river crossings has between 800 and 500 meters.
Someone has information on how to determine the collapse pressure pipeline under vacuum?
I would appreciate all your comments
regards
Pathfinder Tags: pipeline
Re: design pipeline
12/12/2013 11:48 AM
My first thought is that the mechanical or piping engineer should be able to figure this out. That's part of the design exercise that should happen so that the plans can be reviewed and approved by the various authorities. There are codes and requirements that we don't know, since we don't even know where you are.
This is not something that can be done over the internet by an anonymous forum.
Hire a consultant.
Re: design pipeline
12/12/2013 12:19 PM
You've just given a blind man a loaded gun.
Now, let's spin him around a few times and let him go.
Re: design pipeline
12/12/2013 12:32 PM
Now you don't really think this kid is in charge of anything other than graduating this semester, do you?
Re: design pipeline
12/12/2013 12:53 PM
Let's hope not.
Re: design pipeline
12/12/2013 12:20 PM
a 20 foot diameter pipe? 5 feet, what? what is the pipe made of clay, abs, stainless? we can't read minds here
Re: Design Pipeline
12/12/2013 12:29 PM
Here ya go. Don't forget to attach this to your calculations.
Re: Design Pipeline
12/12/2013 1:19 PM
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
Re: Design Pipeline
12/13/2013 6:16 AM
"... information on how to determine the collapse pressure pipeline under vacuum? ..."
You probably have figured too:
There just is more than a distant answer-
although, say, you may calculate a particular value for material to pipe wall thickness to pipe size and add-up some of many differential factors of pressure-to-"vacuum" effects
As L states, there are probably local engineering considerations and those that can really help with required local building safety factors too, to other codes -, of which PERHAPS someone officially, ? an inspector will approve for you if you go through all their expected and wanted about needed completed engineered layouts and design to implementation
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
Register to Reply 8 comments
Fredski (1); JP76 (1); lyn (4); PWSlack (1); SolarEagle (1)
