Previous in Blog: Stealth Boat Glides Over Gas Layer   Next in Blog: This Fueling Station Fills Vehicles With Clean Hydrogen From Dirty Water
35 comments
Chinese Want to Capture an Asteroid Into Earth's Orbit
Posted August 31, 2011 8:23 AM
From DVICE:
While most astronomers seem to be understandably worried about the best way to steer asteroids away from Earth, Chinese scientists are instead trying to figure out how they can capture nearby asteroids into Earth orbit. And then mine them.
Good Answers: 179
Re: Chinese Want to Capture an Asteroid Into Earth's Orbit
08/31/2011 9:59 AM
Ohhhh joy of joys.....
It only takes one time for the Chinese to screw-up the astro mathematics, and instead of parking this huge chunk of real estate into orbit it hit Earth instead!
I'm not keen on the Chinese singularly making such a decision that could effect the rest of the Earth's inhabitants! Just one screw-up would kill the rest of us...VERY BAD JUJU IMO!!!!!!!!!!
08/31/2011 11:40 AM
I'm with you on that....regardless of it being the Chinese, Russian, Americans, or even Jamaicans.
J B
Good Answers: 101
08/31/2011 1:53 PM
As long as they can mine some Unobtanium and sell it on the black market so I can get my hands on some I'm ok with it...
08/31/2011 2:14 PM
Best idea ever! Just imagine - a space program with balls.
09/01/2011 12:04 AM
can see some blokes out there working out how to attach a motor and bring one in for a landing instead of orbital parking. Or even if they can just get it inside the atmosphere and using those 'new' dirigbles(? spelling) being developed, lower it gently to the surface. (sic)
'Nunc est bibendum'
09/01/2011 1:24 AM
To the moon, Alice...
Which one, fatso?
09/01/2011 1:53 PM
Good one, but lost on too many, I fear.
09/01/2011 9:06 PM
I doubt it was lost on many.....there are a lot of us older folks out here.
J B
09/01/2011 4:50 AM
Doesn't China have enough mineral reserves, then?
Good Answers: 109
09/01/2011 6:02 AM
Cut it to chunks of 1 Kg each, divert it down with 7Km/s velocity into one of the deserts and observe the fine impacts with kinetic energy equals 0.5Kg x 49x106 Joules each.
25 Megajoules is just below the energy of the US-Navy's latest railgun test.
The sand and dust of the desert will dissipate this energy.
But at reasonable rates of 1 shot per second you will get down only 86 tons per day and these difficult to recover?
So the atmosphere has to do a lot of the braking: smaller chunks a necessity.
Big showers of 1 cm diameter, 8g each, still near sonic velocity?
RHABE
09/01/2011 9:44 AM
I can see the military applications of this. "Better watch it or we will drop an asteroid on you." Can anybody say the new Nuke?!
"We cannot sow thistles and reap clover. Nature simply does not run things that way. She goes by cause and effect." Napoleon Hill
09/01/2011 2:06 PM
More evidence of the Western mentality infecting the (previously) Asian perspective -- long-term vision. Seems sort of Rube Goldberg to me. Think: The chances of any one rock being unique in composition, in a field full of rocks, scattered about, is slight. I doubt if any one, on average, would prove to be that enlightening. Better to work on the travel technology of getting to these rocks, to enable going around the whole field and taking a look at more than one.
09/01/2011 2:16 PM
Asteroids are likely to be full of water. Water = fuel and life in space.
09/01/2011 2:20 PM
We have water here.
and Water ≠ fuel and life in space. Water = Water and the possibility of life in space.
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
09/01/2011 2:29 PM
Yesssss - we have water here. Bringing home an asteroid to get more water on the earth is stupid.
That's not why you capture asteroids.
Water = two parts hydrogen + one part oxygen = rocket fuel.
Good Answers: 101
09/01/2011 2:58 PM
Energy Crisis solved!
The world is covered in Rocket Fuel!
09/01/2011 3:33 PM
Well, yes. If you had an inexhaustible source of power, say the sun, we could convert all the worlds oceans into hydrogen and oxygen, then burn it.
If you can do that in space, then you no longer need to lift millions of tons of fuel, oxygen and water out of the earth's gravity well in order to explore the solar system.
09/01/2011 9:08 PM
Or how about:
Alien water = water + microbe or virus that wipes out life (as we know it) on Earth.
J B
Location: East of Seattle, Washington state Republic of the 50 states of America
09/01/2011 3:27 PM
Park it in lunar L4 (Lagrangian point) and start the first space ship yard. Put some space shuttle solid rocket boosters on it so if things start going wrong.
Good Answers: 109
09/01/2011 3:46 PM
Spectroscopic surveys indicate that the surfaces of many asteroids simply is silicatic rock.
But a considerable fraction is iron or iron-nickel alloy.
Some are said to contain vast amounts of precious metals.
Water and ice below dust - yes, in the comets without doubt. But to get there for astronauts will be impossible if not somebody will invent a Schwarzschild-Generator: a small black hole with mass fed into and 30% of the mass coming out as radiation. Light-years away but sometimes good SF.
RHABE
09/01/2011 3:58 PM
Last estimation I read was 20 metric tons of the gold and platinum group per 1/4 mile dia metallic asteroid.
At 500 lbs per cubic foot the iron/nickel steel is where the money is.
$10,000 USD per Lb. to orbit, if you charge 5,000 USD and give away the machining then no one could under cut you until they started their own operation.
09/01/2011 4:34 PM
Will the Chinese confuse metric and imperial dimensions? Just a thought.
09/01/2011 7:36 PM
That wasn't a thought, it was a worry. They won't be confused if they look through Hubble's glasses.
Canada - Member - New Member
Good Answers: 39
09/01/2011 5:44 PM
Interesting, and you guys call yourself engineers? Someone proposses the greatest and most difficult engineering project in history and all the "western" engineers sneer at it. No wonder all the work is going elsewhere.
I do notice however that the article quotes no sources and gives no planned timeline for the project. The Chinese leaders and thinkers however tend to plan further ahead than us westerners who only seem to plan for the next election. This could be something on their to-do list for the next century.
All that is required for evil to succeed is for good men to do nothing.
09/01/2011 8:19 PM
I think its more a case of cynicism. Its also a good method of asking what if questions-brainstorming so as to speak.......or we just jealeous we didn't float the idea ourselves
'Nunc est bibendum'
09/01/2011 9:12 PM
Actually, engineers tend to be good at applying science and math to find pratical solutions to problems. They are not necessarily visionary. And a big factor imbedded in the word practical is cost.
Currently, there are more practical ways to solve problems than risking the lives of the entire planet.
J B
Hobbies - Musician - New Member Hobbies - Car Customizing - New Member Popular Science - Cosmology - New Member Popular Science - Weaponology - New Member
09/01/2011 10:55 PM
So IF it so happens that they do happen to get it into Earth's orbit then what? How exactly to they intend "bring it down"? I got a dollar says it hits my house.
When god gives you lemons, find a new god.
Engineering Fields - Mechanical Engineering - New Member India - Member - New Member
Good Answers: 67
09/05/2011 4:58 AM
Instead of mining it on space, if scientists concentrate on developing ways and means to capture gravitational energy of the object while falling on earth and wireless transmission of huge energy so produced will be beneficial to all. (1) Tapping the gravitational energy will slow down speed of fall, so it will not damage earth surface and its inhabitants. (2) After it reaches earth, it can be mined as we like with extremely low cost compared to at space.
Good Answers: 109
09/05/2011 11:09 AM
How to get the heat and convert to electricity?
Space Shuttle with propellers that drive turbines (one for any 10 tons)?
Very slow entrance profile seems to be the one and only working solution and at near 30km above ground a small parachute.
Attach a guiding unit or totally passive?
There was once (2300 years ago) some meteorite like this one that broke up into maybe 80 pieces high in the atmosphere and devastated a 50 x 100 km area near lake Chiemsee in southern Germany. Search for "Chiemgau Impact" if you are interested.
The Greek mythology says to this event that Phaeton - one of the many sons of Zeus - did steal and try the sun-chariot of Helios, but he deviated from the road and broke the car and the sun-like remnants hit the earth somewhere in the far northwest.
So better think about a smooth method to brake the parts to near sonic velocity by atmospheric drag. This seems to be possible if going up again if the actual drag is too high for integrity.
The same questions have been discussed some time ago here!
RHABE
Good Answers: 117
09/05/2011 3:44 PM
Further reading on this great link you provided suggests some very disparate dating.
The only connection between a greek myth and a meteorite is the very questionable dating. It would take a lot more than this to break down my sceptical barriers.
However, the myth might be useful to get tourists to come visit. Worked at Tours.
09/06/2011 12:43 AM
All fine and dandy but how are you going to store the energy long enough to be usable? You might start with lightning, as far as I know we haven't mastered the storage of that yet.
Another issue would be heat dissipation. Even at 99.9% efficient the heat from 1/1000 of that energy would cause some serious issues. Don't get me wrong I like the idea but the Moon might be a better place for it or not.
Brad
09/12/2011 9:10 PM
You can't capture that energy, you have to apply energy to bring it down. It's far to dangerous of an idea to even try.
09/13/2011 10:48 AM
Hoping his research would lead him to the same conclusion.
Good Answers: 74
09/12/2011 10:38 PM
It would be cheaper for them to just go and invade Australia. They would have all the "whadevva" they needed, including rear earths.
Australia would not fall on every ones heads either and the profits would be as high as the market is going to pay.
Our accent might get lost, and that would be a shame but who's gonna be counting in 50 years time.
Who comes up with such incredible crap?
Chinese will get board too, Ky.
The Twain Has Met
09/14/2011 10:38 PM
The Chinese are silently invading us now anyway. Its actually a question who is going to get there first - Chinese, Muslims or Japanese as they are all madly buying up huge amounts of Australia. And the other problem is some of the Muslims are pushing for Sharee Law; which if some idiots in Australia allows will leave the door open for other people to push for the right of their laws.
I agree with you; only it'll be more than the aussie acent out the window.
No I'm not racist - I just like Australia to remain AUSTRALIAN (or rather the concept of what it is to be Australian). so we need to get out here and breed faster- about thirty kids per couple might help and teach them the ANZAC way..and if we can't breed fast enough we need to intergrate immigrants into being Australians likes us, not like where they came from .....soapbox delivery over.
'Nunc est bibendum'
Reply to Blog Entry 35 comments
Anonymous Poster (2); Apothicus (1); bhankiii (4); CaptMoosie (1); crashcol (3); JBTardis (4); ky (1); pritam (1); PWSlack (1); RHABE (3); RVZ717 (2); StandardsGuy (2); thall (1); Tornado (1); U V (4); uniltirantokx (1); Worrier (1); WWkayaker (1); Yusef1 (1)
