Previous in Blog: AM vs. FM: Newsletter Challenge (09/18/07)   Next in Blog: The Film on the Windows: Newsletter Challenge (10/02/07)
Playing the Didgeridoo: Newsletter Challenge (09/25/07)
Posted September 23, 2007 5:01 PM
The question as it appears in the 09/25 edition of Specs & Techs from GlobalSpec:
While vacationing in Australia, John walks into a music store and sees an instrument that he wasn't familiar with, a didgeridoo. John decides to buy the instrument and the shop keeper gives him a free lesson. While they're playing with the didgeridoo a leaf blows onto the end of the instrument and somehow gets stuck there. When John plays louder the leaf starts going into the instrument; when he stops playing the leaf falls off. Since the wind instrument is played by blowing into it, why did the leaf stick to the end and get sucked in instead of being blown off?
(Update: Oct 2, 8:31 AM EST) And the Answer is...
When you play the didgeridoo although you are blowing into it, you are also creating a standing wave within the instrument. A standing wave has alternating areas of low and high pressure. A low pressure area near the opening of the didg caused the leaf to be pushed in by the higher pressure air outside.
In reply to #96
Find in discussion
Re: Playing the Didgeridoo: Newsletter Challenge (09/25/07)
10/03/2007 12:55 PM
No....a Sweet Shop.
#111
In reply to #108
10/03/2007 4:05 PM
That's fine for the sax. Members of the brass section however, more commonly (all meanings intended) reside in the small room
In reply to #111
10/03/2007 11:59 PM
A piano may need somewhere more commodious.
#115
In reply to #114
10/04/2007 4:30 AM
Presumably that's just the stool you are talking about
(Perhaps this is too scatological for this thread?)
In reply to #115
10/04/2007 4:47 AM
Well I meant this !
#117
In reply to #116
10/04/2007 6:23 AM
A real piano's much better, and only occupies about three times the area
http://www.fazioli.com/eng/modello_f308.php#f308
But you still need a commode or other stool to play it
#139
In reply to #96
Find in discussion
10/07/2007 3:49 AM
yup! looks like this topic has run out of puff
#91
10/02/2007 10:08 PM
perhaps john 's playing sucked. with practice, he may become good.
#92
10/03/2007 12:20 AM
The tube acts as a simpler oscillator, the breath only acts to "pump" the oscillation...adding enough energy to maintain the standing wave. Hence the volume of air passing into the tube from the player has very little to do with the nature of the wave or the sound which is a characteristic of the pipe.
My daughter made a set of "paddle pipes" hollow tubes struck on the end with flat rubber coated wooden paddles. The pipes were tuneable purely by altering the length of the resonator......striking the tube harder made the sound louder....but with no alteration in pitch, although some aquisition of higher order resonant frequencies.
For you to hear the sound, air must be displaced......but there was no air input or energy input following the initial strike with a paddle pipe hence the standing wave decayed and became silent.
As mentioned earlier there is a long wavelength and high air wave velocity although low frequency....hence quite large air mass movement at the end port of the tube.
If it is accepted that the volume of air displaced past the end port position is many magnitudes greater than that introduced by the player to maintain the oscillation...then an overall vacuum in the tube is created if the equalisation can't take place at the exit port. Subsequently anything blocking the tube will be exposed to increasingly greater external air pressure as the high pressure "peaks" leak past the seal created by the leaf....rather like a flutter valve in a pump.
This process will only continue until the internal and external pressures on average equalise...then the leaf remains stationary. Driving the oscillator harder....increasing the energy or magnitude of the standing wave will increase both peak pressure and trough vacuum pressure and the external pressure will drive the leaf further into the tube....stop driving the oscillator and the pressure will equalise from either end through the player's mouth, or through leakage past the leaf which doesan't make a perfect seal, and it will drop off the tube.
This response offered by bonesrus.....a non engineering but physical science background type person
Location: Pringle Bay about 80 km from Cape Town, South Africa
10/03/2007 5:49 AM
Hi my name is Bruce Copley and if you would like to see more about what is possible with the didgeridoo check out Bruce Copley didgeridoo on You Tube
yours in rhythmic breath
bruce copley
When you are through changing, you're through
10/03/2007 9:51 AM
One last (hopefully) point:
Some have claimed that the standing wave will hold the leaf on with no air flow, citing the example of a "flutter valve", which opens and closes. However, unlike the flutter valve, which must have some sort of hinge or pin holding one (or two) side or edge (or even center) point(s) to be fixed, the leaf has no such fixed attachment to the musical instrument, which must then negate this as an example.
OK, one more LAST point (I really mean it this time! ):
Maybe my understanding of the terms falls short here, but wouldn't the regions or peaks of high and low pressure in a standing wave be considered "anti-nodes" rather than nodes? I thought a node in a wave was the point that did NOT change, having a value of zero, as the wave travels and the areas between nodes flip from positive to negative peaks (anti-nodes). Wouldn't this be the same definition in a standing wave, i.e. the node being the point of equalization between the two anti-node extremes?
#100
In reply to #99
10/03/2007 10:47 AM
On the subject of nodes and antinodes, I'll follow your lead elsewhere and say "that depends". In this case on whether you are referring to levels of pressure variation or velocity variation. In general, the pressure node (just outside the open end of the didj) corresponds to a velocity antinode, and vice versa (actually effectively just outside the closure at the mouthpiece end). For them others: peaks of pressure variation are pressure antinodes, etc.
I'm being a little pedantic here referring to peaks/troughs of "pressure variation" rather than of "pressure", because loose terminology in this area seems to have caused so much confustication* in this thread
*A portmaneau word denoting (totally?) confused explanation.
Fyz
In reply to #100
10/03/2007 11:16 AM
Right, that is what I thought. Of course a "peak" of pressure variation (maximum of absolute value) can be either a "valley" of pressure (negative) or a "peak" of pressure (positive), and so are anti-nodes.
Many people posting here wrote of positive and negative pressure "nodes", which made no sense to me, since they were referring to areas of maximum magnitude, and so should have been more rightly called antinodes. I don't think anyone called them velocity "nodes", except yourself, which I understand, since they are 90 degrees out of phase. A good analogy is voltage and current in a purely resistive (no inductive or capacitive reactance) or a tuned (inductive and capacitance reactances being balanced) AC circuit.
Uh, oh.....my "ped-antics" are showing again!
#103
In reply to #102
10/03/2007 11:33 AM
For them others again - over time, the pressure at any position in the didj varies from a minimum to a maximum - but (at least with steady-state sound) the average pressure at any point cannot vary with position - except by a small amount associated with the variable flow velocity of the exhaled air.
Pedestrantic Fyz
United Kingdom - Member - New Member Hobbies - Musician - New Member Engineering Fields - Mechanical Engineering - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member Hobbies - Fishing - New Member
Location: South-east corner of Spain 50 48 49.24N 2 28 27.70W
In reply to #100
10/03/2007 2:14 PM
I understand your troblem!
“It's kind of fun to do the impossible.” Walt Disney
#101
10/03/2007 11:04 AM
Just to throw a different areo-dynamic principle into the mix.. The leaf was most likely curved. I suspect a COANDA effect on the leaf itself.
In reply to #101
10/03/2007 11:48 AM
Hmm, perhaps, being in Australia, it was the KOALA effect. That is, a KOALA bear was chasing a eucalyptus leaf and while swiping at it created air currents that pushed the leaf against the end of the didgeridoo! By playing harder, the musicion cause the KOALA to grow more excited and increase the intensity of his waving arms (legs?) and therefore the force of the air current against the leaf. The KOALA then relaxed when the playing stopped allowing the leaf to fall.
The next question is, what was a KOALA and a eucalyptus leaf doing in a music shop? Perhaps John and his new-found friend, the shopkeeper, were having their music lesson outside in the Outback, or perhaps at the Sydney Zoo (do they have Koalas in the petting zoo?).
ROFLMAO!
Good Answers: 15
#112
In reply to #104
10/03/2007 7:18 PM
Dunno what Koala's you have been looking at, but they don't chase or play with leaves like cats do, if one blows by, they wouldn't go chasing it.. then I go back to another of my comments, and add to it.
Would you go into a music store that has wind and rubbish blowing around inside?
roflamo? you gotta be joking :P
In reply to #112
10/04/2007 9:16 AM
Snaketails, I guess it must be your beady little eyes causing dyslexia, but I posted ROFLMAO, not "roflamo".
OK, so my little joke doesn't meet your reality standards, but it created a humorous picture in my mind and put a smile on my face, if not actual ROFLMAO. I am hoping it made others smile as well. Have you never heard of absurd humor? Of course a KOALA won't chase a leaf around. Anyone who ever saw an old Qantas TV commercial advert knows that! <grin>
And, BTW, the bit about wind and rubbish (leaves) blowing around (or not) inside a music store has already been DONE! How about coming up with something new and funny?
In reply to #118
10/04/2007 9:27 AM
I give you 11/10 STL. Some people just don't see the funny side when they've been hit by a drop-bear.
In reply to #120
10/04/2007 9:57 AM
Gosh, Kris, thanks for more kudos! Good on you for the drop-bear reference! I had never heard of that before, but looking it up I was quite amused. It reminded me of the "killer rabbit" scene in Monty Python and the Holy Grail. Next time you come to the USA we can go snipe hunting (You can be the bagger!) But watch out for the wild jackalopes! I will have to ask my Scottish cousins if they have seen any wild haggis lately.
BTW, there was an excellent episode of Cheers! on TV which featured neophyte Frasier Crane learning about Snipe Hunts. It had a superb surprise twist ending! Can't find it on You Tube, though.
In reply to #122
10/04/2007 10:05 AM
I still could not find a clip, but here is a good plot summary of the Cheers! episode featuring Snipe Hunting.
WARNING: spoilers here if you would rather see the surprise ending.
http://www.imdb.com/title/tt0539897/plotsummary
In reply to #123
10/04/2007 10:16 AM
There's more than one kind of snipe, you know.
Madness is all in the mind
In reply to #124
10/04/2007 10:53 AM
Hang on a minute.... I was gradually trying to get STL onto Haggis ( figuratively speaking) - you know, the wee beasties that run around the hills. 3 legs, 1 shorter than the other so that they don't fall over. Where is your national pride man ?
I have to go, Sasquatch needs feeding in the back garden, the drop-bears have pinched all it's food ! When the Yeti gets home there's gonna be hell to pay. " No dear,I didn't mean tha.. < thwunk> .. but honey it was a jo..<splat> .. I didn.. < crunch|>....they made me say it... < splonk>......aaaaaggggghhhhhhhhh
#126
In reply to #125
10/04/2007 11:01 AM
And if MS et al had segmented the software suitably, the relevant parts of an OS might just have left space for the applications....
In reply to #125
10/04/2007 11:45 AM
Kris, you must have quite the menagerie! Sasquatch is native to North America, I believe, Yeti from the Himalayas of Nepal and Tibet, and drop-bears from Oz. (Frank Oz? <grin>) I am surprised Nessie is not in your backyard pool or aqua-culture pond!
Yes, I posted a reference to Haggis (and my Scottish cousins) in another spot.
And we have several other North American examples of cryptozoology, including the Jersey Devil and the Chupacabra (which has also been reported in other parts of the Americas), but my favorite remains the jackalope!
Interestingly, a few years ago, the late August Busch II, then CEO of Anheuser-Busch Breweries (St. Louis, MO), bred several interesting creatures on his country estate, Grant's Farm, now open to the public. Some of these include; a striped mule, by breeding a zebra with a donkey; and a miniature mule, by breeding a Shetland Pony with a donkey, along with more conventional wild animals.
By the way, the favorite attraction at Grant's Farm is really the FREE BEER in the biergarten of the Baurenhof. Maybe after a few of these you will start to see all sorts of strange animals!
In reply to #127
10/04/2007 12:01 PM
STL, I could hug and kiss you (in a 'manly' sort of way) : few other people could I tweak and get such an elegant and detailed discourse on any subject ! If I ever get to the great place that is St Louus, I will shout the bar for the night, cuddle you, thrash you at pool. and tweek you by saying something provovative. Book a night off with you good lady wife and send me a ticket - I'm on my way ! Promise not to cheat by felling me with that great sense of humour of yours. I would be collapsed on the floor with your brilliant repartee. We'll send Ken a postcard.
In reply to #128
10/04/2007 12:08 PM
Hey! They ain't pillows! Arrrgh.....you see the ball game last night?
In reply to #130
10/04/2007 12:22 PM
Ah....a reference to one of my favorite "buddy flicks", Trains, Planes, and Automobiles" starring two of my favorite all-time comic actors, Steve Martin and John Candy, with a very funny cameo by, of all people, Kevin Bacon.
I was just going to tell Kris, yes, we could hug , you know, that mutual back-patting (no, butt-patting, this ain't Baseball!) with NO abdominal proximity, but then we would have to immediately deepen our voices and talk about sports or something else manly, like hunting, fishing, hot chicks, engines, etc! Grunting a few times wouldn't hurt either.
In reply to #131
10/04/2007 1:03 PM
I'm laughing so bad it seriously hurts ! I don't know where Ken's been, but I'm going to need major surgory when he gets back . Hey, he can have a manly hug as well ! Oh my good grief ... thi is so ba... d I 'm go nnn a . ... aghhhhhhh.
C'mon guys , this is one of those separated at birth things, yeah ? A.w...ww..... no i..'m alllin ove r..stooo p i t gu t s ye r ki llio me..............
In reply to #132
10/04/2007 1:22 PM
You mean, like Schwarzenegger and DeVito in Twins?
ROFL
#129
In reply to #127
10/04/2007 12:08 PM
The only way to keep these critters in captivity is for them to lose all hope of getting home under their own steam. That makes Nessie problematic.
In reply to #125
10/04/2007 1:10 PM
"I was gradually trying to get STL onto Haggis"
Just head Due South!
In reply to #133
10/04/2007 1:45 PM
OMG! I LLLLLoved that show! I especially like the episode where Fraser had to turn in his traditional red Mountie uniform in favor of the new uniform with more modern looks and subdued colors. I think he fretted more over that than catching the bad guy!
Mr. Haggis must have seen one too many Dudley Do-Right cartoons when he was a kid!
<grin>
Good Answers: 15
#136
In reply to #118
10/04/2007 7:20 PM
Oops, my apologies, damn work, its lunch time, and looks like I have successfully hijacked the thread :P
Nah, we don't always get to see the QANTAS adverts that are shown in other parts of the world..
Your right, I guess I didn't get the joke, wrong part of the world, but I did love the tangent that this thread took after your post above :D
now back to loading spring loaded needles in a pin grid ;o( where are the band-aids
Good Answers: 22
#137
In reply to #136
10/05/2007 12:28 AM
Sounds like you have a stick-y job!
In reply to #136
10/05/2007 9:47 AM
OK, Snakey. Sorry if I came down a little hard on you yesterday. My morning caffeine fix had not yet taken effect.
G'day, mate!
#105
In reply to #101
10/03/2007 12:27 PM
I suspect you are correct - that the leaf is initially attracted into the curved region of the (acoustically-driven alternating) flow around the end of the pipe. Thereafter, the closeness of the leaf to the pipe generates a region between the leaf and the edge of the pipe where the air naturally flows faster, and we see a combination of Coanda and Bernoulli.
Fyz
#106
10/03/2007 12:28 PM
Hey Kids this is my first ever Blog entry but your discussion has been so interesting I just had to get involved.
I think that the leaf gets caught in a low pressure area between two high pressure 'nodes' and if the leaf moves into the tube it would be due to a change in frequency.
#140
11/06/2007 4:03 PM
Swirls by air keeps it attracted towards did.. even sound is created inside this instrument when membranes vibrate ...emm already answered
i would like to design something around this theory what............
#141
05/27/2008 9:15 AM
HI i am a seasoned didgeridoo player and as a gig leaving / party trick, i walk round a room playing the didge whilst it holds onto a £5 note at the end, when i stop playing the note falls away.
I am not a scientific person but when i play the didgeridoo it creates a vaccuum, the wood ressonates and you can feel air on the way out at the end of the instrument, but as above it creates a vaccuum also.
Why this happens i have no idea, i just know the trick works well everytime.
You do need usually an E key didgeridoo with an approx 90mm opening though!!!
Enjoy
Didgeridoo Pete
www.idoo.info
Good Answers: 15
#142
In reply to #141
05/28/2008 12:01 AM
Read above, its not a vacuum as such, its standing waves.
If it was a vacuum, it would suck the note in, not allow it to pulsate on the end.
3Doug (3); Anonymous Poster (21); bonesrus (3); charsley99 (2); Dr Didge Maverick (1); English Rose (1); frankd20 (1); GM1964 (2); jdretired (5); jfbenam (2); Jorrie (2); Kris (12); LG_Dave (1); Maths_Physics_Maniac (9); Mr. Truman Brain (5); ndt-tom (1); Physicist (1); Physicist? (25); PhysicsGuy (1); RickLee (8); Snaketails (6); SoftwareEngineer (1); STL Engineer (28); vikas (1)
You might be interested in: Leaf Chain, Leaf Wetness Sensors, Flat Springs
