Previous in Blog: Playing the Didgeridoo: Newsletter Challenge (09/25/07)   Next in Blog: San Juan and Ponce: Newsletter Challenge (10/09/07)
The Film on the Windows: Newsletter Challenge (10/02/07)
Posted September 30, 2007 5:01 PM
The question as it appears in the 10/02 edition of Specs & Techs from GlobalSpec:
During the summer I covered the glass windows in my living room with a metal oxide transparent film to keep the room cool. (I wanted to block light coming into the room but keep the brightness.) Now, at the beginning of October, with a harsh Northeast winter looming, I want to remove the film to allow more light in to help warm the room. However, my wife insists we should keep the film on. Who is right?
(Update: Oct 9, 8:55 AM EST) And the Answer is...
My wife is right. The metal oxide film helps to keep the room warm because it prevents infrared radiation from escaping from the room to the outside. The energy of the infrared radiation stays inside the room.
Re: The Film on the Windows: Newsletter Challenge (10/02/07)
09/30/2007 5:45 PM
The wife's always right?
09/30/2007 6:30 PM
Mine has always been, it just took me awhile to find it out.
Reply Off Topic (Score 4)
10/02/2007 8:53 AM
Please say 100% right
10/02/2007 11:29 AM
Agreed. Especially if you want to keep the peace.
09/30/2007 7:31 PM
The film will also assist in keeping in the heat during the winter. leaveing it on will save your fuel bills and keep you wife happy. stubbing your toes on the furniture occasionally is a small price to pay for a happy wife. But then again if she's threatning to banish you to the workshop if you remove the film. Check that the heater is working and the fridge is full of beer and tear it off
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
10/01/2007 7:48 AM
That is probably true. It is a bi-directional shield, I think, and I also think that it is the infrared radiation that you want to block. UV will not be a thermal issue, but it does cause sun fading of material.
Another consideration, winter days are shorter and the Northeast typically does not have a lot of days that are sunny; compounding the problem of insufficient solar radiation. Over the course of an average winter day the percentage of sunshine will probably be outweighed by the heat dissipation from inside to outside the glass, even with the film off.
I'll bet Coconutpete has the correct answer.
10/02/2007 12:36 PM
Standard plate glass does not allow for the transmission of UV light. Howmany times have you gotten a sunburn by sitting in a sunny living room, or driving down the highway?
10/02/2007 2:27 PM
This is not quite true. The addition of iron oxides to plate glass-this is what gives it the slight greenish cast does inhibit some uv but not all or even most. When using uv cure adhesives on plate glass there is no problem at all of placing the uv lamp or sun on one side and gluing glass or other objects to the subsurface. On the other hand, laminated glass completely blocks uv. The plastic inner layer has uv inhibitors that prevent uv rays from passing through it. Thus no sunburn through the car windshield.
10/02/2007 5:24 PM
I know that your comment represents the norm, BUT I GOT SLIGHTLY SUNBURNED ON A TRAIN FROM PORTSMOUTH TO LONDON, I HAVE A VERY SENSITIVE SKIN!! IT IS POSSIBLE!! I EVEN HAD WHITE BITS AROUND MY EYES FROM MY GOOD SHADES.....
Good Answers: 88
In reply to #77
10/02/2007 5:28 PM
Are you shouting? Yikes!
At any rate, UV does not cause dandruff.
In reply to #79
10/02/2007 5:39 PM
YES, IT HURT!!!
10/01/2007 8:07 AM
Being in the Fiji Islands, you probibly do not have to worry too much about the cold. What is the weather like there?
Reply Off Topic (Score 6)
10/01/2007 11:37 AM
I am in Florida. What winter? :)
I have a similar film on my windows, but it not so much of a band-pass filter for sunlight (suppression of the longer and shorter wavelengths), but as a protection from hurricanes.
The film works a lot like the plastic film in auto glass and keeps the glass from turning into thousands of flying knives in the event of a glass strike.
It is slightly darker optically and I suspect that it does act as a band-pass filter for visible light.
As far as the challenge goes, it would be interesting to run some numbers thermally and see what the ratio of infrared radiation from sunlight at latitudes of about 44 degrees versus the amount infrared radiation transmitted from the inside of a glass window to the outside of the window. You would have to make an estimate (from historical data) of the percentage of sunlight falling on an area (say 1 meter square) of glass per day. A lot would depend on the orientation of the glass to the Sun and the transmissivity of the glass, blah, blah, blah.
However, I think you could take a best case example where the Sun is directly shinning on the glass at noon and determine how much energy is imparted versus leaked back out over a day. I don't think that you would need to use actual numbers for the filtering of the sunlight for glass, just determine how much solar energy is radiated per square meter over a 24-hour period. Keep in mind, the Sun is only shining on the glass of a fraction of a day and the angle of incidence changes, so you need to calculate the area under the curve. That number represents the maximum amount of energy that could be transmitted into the window.
Next, calculate the thermal loss for a 1 meter square of glass over 24 hours. Here you do need to get some numbers (R factor?) for the glass and what the inside and outside temperatures are on average over a 24-hour period. You could then assume a constant rate of heat loss through transmission out of a window.
Assuming that the film blocks thermal energy the same amount regardless of direction, if the net energy loss during a 24-hour period is greater than the net energy absorbed from sunlight, it doesn't matter how efficient the film is, you are better off leaving it on. On the other hand, if the net energy absorbed from sunlight exceeds the energy loss through the glass, pull it off. However, I doubt the film should come off.
Good Answers: 22
10/01/2007 2:21 PM
Huh, isn't the sun directly overhead at noon? Unless your windows are on your roof and you have a flat roof, you're not going to get much sunlight coming in at solar noon. I say solar noon, because solar noon and noon on the clock don't often coincide. Houses must be built strange in Florida. And everyone thinks California is full of wierdos....
10/02/2007 12:22 AM
Hi Rick
Well its not cold bit cool the last week as its still winter about 28 C. But its been raining for the last 4 days so I will be swimming to work soon
Cheers
10/02/2007 7:47 AM
I need to repost this!
You say winter at 28C, that is warm for most of the year up here except for maybe July & August. Typically our winters average around -10C and fall & spring run around 16C. Enjoy the winter while it lasts.
10/02/2007 8:15 AM
LOL - I stop functioning at about 25°C, by 28°C I'm hiding in the coolest part of the house...
I don't think the UK got to 28°C this summer!
10/01/2007 7:58 AM
The film acts to reflect the longer wavelengths of energy which includes heat. It should work to reflect heat back into the house but it will also inhibit the sun from contributing to the heating of the house. As the sunlight is seriously diminished during the winter, the amount of heat contribution from the sun might be negligible anyway.
In the end it might be better to have deciduous trees around the house so it is shaded in the summer and has full sun in the winter.
10/01/2007 2:23 PM
Without more info this could get confusing for the simpler minded Brits like me. Cooling houses is not generally a problem here. However you can buy 'cling-film' type stuff that adheres to a window frame - a quick blast with a hair-dryer tensions it up, and you have instant secondary glazing. The resultant air gap send insulation values skyward.
I don't knock the question, but perhaps more explanation and detail for those outside the USA would have been helpful. Adding ' metal oxide' gives a fair clue as to the set up and nature of the question, but a bit more detail wouldn't have gone amiss. This reads like another USA only question. < gone off sulking, but probably back later>
10/01/2007 3:50 PM
Kris,
Don't feel bad. I am in the US and am not familiar with the term "metal oxide" as applied to window films. However it is apparent (if not transparent ) that he is referring to a film which blocks infrared (heat) radiation from the sun, yet allows visible light to pass through relatively unimpeded. Your "cling-film" which provides an air gap to reduce convective and conductive heat loss in the winter time is a different matter altogether. I suppose there may even be some blockage of radiation by the film, but generally it would be negligible unless your film also had an IR reducing tint.
Actually, the answer to the question is quite simple, "It depends". If the "metal oxide" film act strictly as an IR blocker, which reduces A/C load from the summer sun's infrared heating, then it would be desirable to leave it up in the winter time as well to retain heat that might be lost by radiation through the windows, since the transfer of IR through a window or "black hole" (in the non-astronomical sense) is always from an area of higher temperature (inside surfaces) to one of lower temperature (objects and air molecules outside and surrounding the house, with the reduced solar radiation being an exception (outside to inside). As noted earlier, the nights are longer in winter and the days are shorter, so there is more potential for loss than for gain without the film.
Ideally, an easily removable film which could be switched day and night would work better in both winter and summer. Perhaps a return to the roll-up window shades of old, instead of the now ubiquitous "mini-blinds", or in addition to them if possible, would work in this case. However, the roll-up shades would be made of material similar to or coated with the "metal oxide" film. That way you could "have your cake and eat it, too!", i.e. let the sun help warm the house during milder and sunny winter days, when net IR transfer is inward, by rolling up the shade and removing the IR blocker, but roll it back down and put the IR blocker in place at night and during cold overcast days when the net IR transfer would otherwise be a loss for the interior.
I know the last paragraph does not answer the question, which seeks a simple yes or no answer, but as is often the case, the answer is "depends". That is, the answer depends on which direction is the average IR transfer through the windows, which usually would be out on average during the winter when you actually want to keep the house warmer, and so "leave it alone" is the better answer, I believe.
10/02/2007 1:41 AM
Thanks STL, You've added clarity to the Question. I understood what the questioner was referring to with the use of film ( and the distinction between that and a secondary glazing gap), but felt like a mild snipe because of the lack of further detail.
I agree with your comments about the length of day and IR heat transfer being factors. The question leaves us to assume the building is in America, but even that's not very informative as to the overall question. Taking the question 'as is', it seems to be querying the manner of heat transfer across the window. The oxide film will function to block radiant heat, but what of it's effect on conductive heat ? Glass with film will have a different u value to glass on it's own, albeit not much for a few microns of Oxide. At present I'm thinking 'leave the film in place during Winter' because less radiant heat will escape the building than could be gained by having lower conductance of heat via an oxide film. < Also I'm lazy and wouldn't want to go around filming the windows every year.>
10/02/2007 7:57 AM
You got to realize a couple of things here.
In the higher latitudes the sun is hitting the earth at a lower angle than summer, so there will be more light entering the window.
Secondly the light entering the window is at shorter wavelengths and will not get converted to the longer wavelengths until it strikes the interior. In the summer the angle is high and less light enters the window but the shorter wavelengths created by the light striking the ground outside can not enter through the film. So there can be a little bit of an advantage. In the summer though, the light coming through the window is still going to heat the room but there will be less of it since it is at a higher angle.
10/02/2007 8:07 AM
Please explain how shorter wavelengths are converted to longer, I am fascinated to learn how this happens!
10/02/2007 8:26 AM
Sorry Andy, I was in the middle of posting a comment and you beat me to it. The answer will be intriguing.
10/02/2007 9:05 AM
Electromagnetic waves are emited by all objects unless their temperature is at absolute zero. The radiation is broadband, but peaks at shorter wavelengths for hotter objects and at longer wavelengths for cooler objects. The temperature of the surface of the sun is about 6000 degrees C so its peak radiation is at shorter wavelengths than the objects in your living room which will radiate at longer wavelengths because the temperature of the living room is lower than the temperature of the sun. To learn more about this topic look at Planck's law in Wikipedia http://en.wikipedia.org/wiki/Black_body_radiation or search on greenhouse effect http://en.wikipedia.org/wiki/Greenhouse_effect.
MZE
#115
10/03/2007 9:57 AM
Andy,
This is what the greenhouse effect is all about. It isn't the infrared energy from the sun that heats things up, so much as the UV and visible light. Objects (such as people and bricks and asphalt) that neither transmit UV and visible (UV-VIS) light, nor reflect UV-VIS (like mirrors), will absorb that UV-VIS energy.
Once absorbed, the energy of the UV-VIS light causes the object to heat up. Everything that has temperature emits light. Even you! You just can't see it, because it's infrared. The warmer an object is, the closer the infrared output gets to the visible realm... which is why very hot object start to glow red, and then orange, and then yellow, and then white.
The UV-VIS passes through glass easily, and is absorbed by objects in the room. Those objects heat up, and radiate infrared. Glass is opaque to infrared! Therefore the infrared gets trapped in the room, and the whole place gets warmed up. Just like a greenhouse!
If the glass is laminated, only the VIS light can enter the room. The UV is blocked by the vinyl layer. Therefore there's less energy to heat up the room, so the room stays cooler.
I hope that helps!
Shawn
In reply to #115
10/03/2007 10:06 AM
It was a kind thought, but it did not really help.
I understood that UV also does not get through glass either or is severely attenuated at best.......!!!
In reply to #115
10/03/2007 10:20 AM
Shawn,
I agree with most of what you said, and I think that this goes along with my example of the fluorescent light tube, where the coating absorbs UV and re-radiates visible light, which is lower in frequency and has a longer wavelength.
However, and not to quibble, because you make excellent points, but I have to disagree with:
If this was the case, when I drove by the box company warehouse fire many years back in my car, I would not have felt the intense heat hitting my face through the window glass. The fire did not emit UV and very little visible light, mostly from a few flames that were visible intermittently and the red glow of the burning embers. It was night time, so my pupils were dilated by the dark and therefore my eyes were already more sensitive, yet this light was not even intense enough to cause me to need to shade my eyes. Granted, rolling my window down increase the intensity of the IR I felt, but I still received considerable IR with the window rolled UP!
Let's say that Glass is "Semi-opaque" to infrared, OK? Certainly IR encompasses a wide band of frequencies and some may pass through more easily than others, depending on the composition of the glass. Others contributors here have noted how some glass windows are more IR reflective than others.
Otherwise, good job.
10/02/2007 8:22 AM
Hang on, you got me playing with razor blades and oranges Rick. In Winter, the incident angle will be lower and so less light hits the window. Isn't that what makes Winter 'Winter' ? Maybe I'm missing something in the phrasing here.
On the second bit, how does the short wavelength get converted to long wavelength (and also loose heating power) ? I'm probably being obtuse, bu can you explain a bit more.
In Winter, the Oxide is going to enable the window to conduct more heat ( my guess). My interpretation is that it would increase convection around the room by increasing emissivity of the window. This question was no doubt phrase to ignite debate about terms etc, but I'm interested to hear more. In city's over here, 'tinted' ( I use that to include glass with added thermal properties) glass is not unusual - I'm guessing not just for the privacy effect, but also for energy efficiency. I observe no majority opinion when looking at buildings in London. My assumption is that the jury is out, ie there is no cover-all rule of thumb. Do a high percent of building in NYC or elsewhere in the USA use coated glass ? Accepting that some buildings do it for aesthetic/security reasons, it doesn't seem that many use it for thermal reason.
10/02/2007 2:02 PM
Thanks MZE for elaborating on the wavelengths. I just thought everybody knew that little tidbit.
If the sun is at a high angle the light comes straight down on the building and not into the windows. With a low angle the sun will hit more of the windows, especially those with a southern exposure (Northern exposure for those folks in the southern hemisphere.)
As for coatings, those are more popular in the south and on commercial buildings. I used to work for PPG and they made coated glass. The machine sprayed the glass before it went into the Lehr where it got baked on. Very toughy machine which broke down often, but when it was running, it made a ton of money.
10/02/2007 2:37 PM
Hmmm...wouldn't a toughy machine by tough and NOT brake down often? I guess you meant touchy, right?
10/03/2007 7:33 AM
Yes, spelling is not my strong suit.
Good Answers: 247
#114
10/03/2007 9:48 AM
As always, I am in complete agreement with STL!
This site provides two paragraphs ("Reflex glass reduces solar gain" and "Reflex glass retains heat") that support STL's contention.
Clearly, STL must own stock in a titanium company.
In reply to #114
10/03/2007 10:04 AM
No, but my brother-in-law is sitting on about 300 acres in Tennessee (old family farm) with rich deposits of titanium oxide, however the oxide is in a form that is not yet cost effective to mine and process with the current technology. However, energy, metals, and mining companies are still willing to pay him and his family large amounts of money just for a LEASE on the mineral rights, should technology change quickly or the value of the metal increases substantially. The lease expires soon and he is trying to determine whether processing technology has advanced to the point where it would make the lease more valuable, before he just automatically signs an extension of the old lease. He is a chemist by training and education, so that should help him in his decision-making.
#133
10/03/2007 4:49 PM
I definitely agree. More information would have been helpful.
#134
10/03/2007 5:24 PM
That's a bit hard. Even in Northern England it's not uncommon for 60's and 70s office buildings to have suffered from excessive sunlight in summer** (too much glass means insolation can easily overpower the available air-conditioning). The first amelioration is commonly application of heat-reflective film, often followed by white strip-blinds to be drwn under worst-case conditions. My experience of this is only having been roasted and then having to my desk moved temporarily so that the facilities people could apply the film (and, before you ask, yes, we were too mean to pay overtime so it could be done at weekends; and yes, the film did help, but you could tell it also reflected about half the visible light - both by looking at the outside of the building, and from the inside because there was a small border of uncovered window all the way around the film).
Fyz
**Blame un-thought-out architectural fashions if you like...
Good Answers: 15
10/01/2007 3:40 PM
This is off topic but after installing some on our trapezoidal windows in our 3 season, I would not want to go through the effort to take them off and properly store them. These windows are 7 feet above the floor.
Undoubtedly the film would get relocated during the winter and I wouldn't be able to find the film the next spring!
downhill slide to 112 (damn memor.)
10/02/2007 2:19 AM
I believe the coating is an oxide of Titanium, but don't quote me please....
I think it should be left on if you want to stop textiles and photos from fading, it probably stops IR from leaving the house too, but as to it helping or hindering the house getting cooler I can't say exactly, "swings and roundabouts"?
10/02/2007 12:43 PM
Ti Coating is a UV inhibitor. But again, window glass does not transmit UV radiation. The color changes you refer to are based on Photo sensitivity of the material not the UV sensitivity.
The Ti will not limit IR transmission if the amount allows the glass to be completely transparent. Occlusion of the glass (darkening, or other form of translucency) will limit the IR transmission.
You can effect the transmission in about the 2400nm range by messing with the OH content, but with soft glass you are already at virtual 0% transmission anyway.
Good Answers: 88
10/02/2007 4:29 PM
Not so. Windows specifically treated to block UV are available to help keep curtains, draperies, and other window treatments from fading. Untreated glass transmits UV in varying degrees which are dependent on specific wavelength. I have tested various kinds of glass myself to see whether it blocked long- and short-wave UV. Some do, some don't. I might also point out that fluorescent lamps emit some UV which can cause certain pigments to fade which do not otherwise fade under regular incandescent lamps.
10/02/2007 4:23 AM
The question is not easy, as there are several parameters to be considered.
First, although solar radiation is minimal in winter, the presence of sunlight may be important in the maintenance of a comfortable temperature inside a room. Keep in mind that solar radiation in winter may be in the order of a few hundreds of watts per square meter. The convenience of shielding the sunlight depends naturally on actual exposure of the window to sunlight. For south-oriented windows it may be worth removing the film. For other directions, the difference in having the film or not may be hardly appreciable. Other parameters to be considered are the actual daily period of solar exposure and the area of the windows.
Additionally, by a theoretical point of view, there is a basic difference in having the film applied in the internal or external side of the glass. If the layer is placed internally, its effect shall be to reduce the emissivity of the glass on the surface facing the house room. The radiative dissipation from hot room to cold glass will be minimised, and the thermal dispersion will be reduced. On the contrary, if the layer is placed outside, being the natural emissivity of the glass high (in the IR region), the cold glass will absorb a higher thermal radiation from the environment, cooling the room further.
We could also consider that the layer on the internal side makes the glass hotter during daylight and colder at night (vive versa the layer on outside), but at this point the problem becomes very complex, also because convective effects cannot be neglected in all the reasoning.
The best solution, after having performed all necessary trade-offs and calculations, by assuming a wide set of environmental parameters, is: make your wife happy , and you both will be bursting with health. The advice of your wife have priority over the principles of thermodynamics.
Fatti non foste a viver come bruti / Ma per seguir virtute e canoscenza (Ye were not made to live like unto brutes / But for pursuit of virtue and of knowledge) (Dante Alighieri)
Good Answers: 266
10/02/2007 7:18 AM
Titanium Oxide is used in glass to produce Low-E Glass. It will reflect light in the spectrum associated with heat back in or out of the room. It will do nothing for the heat you wife is going to give you if you don't abide by her wish to keep it on. Just think of it as one less chore you will have to do for her spring and fall.
10/02/2007 7:33 AM
I'm with you Brother!!
10/02/2007 8:02 AM
Yea, and try cleaning all the adhesive off the glass and you will roo the day you started the job.
10/02/2007 8:08 AM
...now where has Kanga gone to?
10/02/2007 7:46 AM
Having just given up and read this, the solution is obvious. Just take out the windows each year and turn them around. Maybe there is a market here for windows that pivot 180o about a mid-axis.
10/02/2007 8:13 AM
Store products in a dry place, protected from exposure to direct sunlight and rainwater
A quote from Kris's link - is it me? Looks like we need STL's blinds after all.
10/02/2007 8:38 AM
Now hold on ER, I thought I had assumed the job of diverting these discussion ! Vertical, horizontal, linen, Hessian, transparent, reflective.....Confound it, I've only just got started trying to answer it serious and you two start taking it to the extreme. I now demand that you lobby Brussels to mandate reflectoty blinds according to any spec determined within this thread. In the meantime can I find Tom Cruises shade on e-bay ? They don't quite go with the bowler hat, but ' better safe than sorry' ! I wouldn't mind if they tried using copper to get a nice ' British racing Green' effect.
10/02/2007 8:53 AM
Consider yourself usurped!!
Did you actualy read the text on that site you posted? It was advising that the glass treated with its coating were kept out of direct sunlight. Not much Bl00dy use as windows then, are they? Where's John Stalker and his dog when you need 'em. I'm sure he'd have a solution.
10/02/2007 12:37 PM
Are you completely mad ? Read the stuff I link to ? LOL. Forget Stalker, he just floggs garden patio awnings these-days. Gets my vote, (after all he was an ex-cop !). Castle Stalker is very nice - I often go there, but have not seen him recently. They have their act together and now do nice soup. On the subject of experts, I have yet to be persuade by Ms Vorderman. Darn it, I'm sure there's a contradiction there. Others can assuredly give beter advice than me on 'im indoors. Oh, the irony, Im sure I hear a drip-drip.
10/02/2007 1:29 PM
Total Non-sequitor for us non-Brits.
Must be some UK pop-culture or politico reference.
10/02/2007 3:52 PM
Actually, it said "block light coming into the room, but keep the brightness" which still doesn't make much sense
10/02/2007 4:48 PM
Obviously the main object is humour - but it's just close enough to being believable to be worth elaborating. Unless the temperature of the glass and film varies across the thickness of the pane, the principle of reciprocity can be applied - equal absorption of transmitted light in either direction, and similarly equal emissions. If it's a film on a double glazed unit it would indeed be better on the inside of the outside pane in winter and probably vice versa in summer (but then two would be better than one, and you wouldn't be considering stripping it anyway - right?).
10/02/2007 9:41 AM
On further reflection (pun intended), I wish to add a corollary to my posting in #11. The answer still is "it depends", but in addition to the notion of net or average IR transmission being to the outside in wintertime without the film, let me say that IF there are suitable curtains, drapes or blinds on the windows, and they are used at night, they would effectively prevent the thermal loss by radiant IR at night, possibly tipping the average towards a heat gain, if there are many sunny days, and so it might make removing the film worthwhile, if only for the pleasant effect of sitting in the warmth of the IR from sunlight on a cold winter's day!
Someone also asked how is it that IR can be absorbed at a shorter wavelength and re-transmitted at a longer wavelength. This is true in general for any electromagnetic energy that is actually absorbed and not just reflected. It is the principle behind the functioning of fluorescent lighting, as the lamp actually creates Ultra-violet radiation, which strikes the coating inside the glass. This coating absorbs the UV, which excites the electrons in the material of the coating. The coating then "fluoresces" and emits visible (white) light as the excited electrons drop back into lower energy states and give up their excess energy. This also how "the Greenhouse effect works" as the interior of a Greenhouse (and the Earth as well) absorbs IR from sunlight, heating solid surfaces, which excites their electrons, but then re-emits IR at a slightly lower frequency or longer wavelength, more of which will be reflected by the glass back into the room. This is because longer wavelengths have a higher critical angle (the angle of incidence at which energy would pass through rather than be reflected).
Similarly, radio waves of lower frequency and longer wavelength (HF) reflect off the ionosphere and come back to Earth (skip), while higher frequencies with shorter wavelengths (VHF/UHF and higher) pass through even at the lowest angles, making them good only for local (ground wave) or satellite communications.
10/02/2007 10:00 AM
This question is impossible to answer without knowing the temperature stats. Ever get the feeling a question is asked just to wind folk up and get them rowing. Yow... I'd love it if this had been posed for an un-named building then the real ID revealed. One solution will work in Colorado and another in Florida. Somebody has an evil sense of humour. If you live in Murmansk, forget it.
10/02/2007 5:19 PM
Please explain in more exact detail as it reads at this moment like hype, sorry....
10/03/2007 8:05 AM
Your explanation with regards to a fluorescent light is great, but what has this to do with furnishings in a room converting energy from one level to another???
Please explain with a better example that actually relates to the problem you are trying to tell us about, I am fascinated.
If by chance you accidentally "over extended" yourself in this area, just submit a retraction, nobody will hound you for that.....we just want to know one way or the other.....
Thanks in advance.
#99
In reply to #97
10/03/2007 8:25 AM
Andy,
1) Doug3 has posted somewhere on this thread another explanation of this phenomenom - it's all to do with how heat energy is transmitted - low energy, long wavelengths, think red hot vs blue hot. I'm sure you can work out why each time energy is re-emitted its wavelength is increased.
2) the fluorescent example STL gave is a good one as it is relevant to the question since we are looking at heat energy passing through windows. If you can't make the leap from glass to furnishings...
3) Watch your tone. That "If by chance" paragraph is very insulting. You have been around CR4 long enough to know that STL is a) rather knowledgeable about a wide subject range and b) isn't above admitting either gaps in his knowledge or his mistakes (not that there are many of either on evidence so far!)
So - if you didn't understand what STL was talking about, ask for clarification in a way that doesn't insult. Ironically, people will then think more of you.
In reply to #99
10/03/2007 8:32 AM
Thanks for your thoughts, but I still do not understand how furnishings can convert energy in a manner similar to a Fluorescent light!!!
I am willing to listen and understand if a plausible method is demonstrated in some manner, up to now I feel that has not been achieved.....
I am genuinely interested in improving my knowledge!
#113
In reply to #101
10/03/2007 9:37 AM
Some furnishings are fluorescent, but that's not really relevant here. The conversion is that the incoming light is at the wavelength emitted by the sun, but the important radiation being affected here is what is re-emitted thermally by the materials. Materials at room temperatures emit entirely in the infra-red - which is why you can't see the thermally re-emitted radiation - you only see reflected or fluoresced light - and this is only a small proportion of the incoming light.
10/02/2007 10:12 AM
The wife is always right.
DN
(18 yrs happily married)
Good Answers: 123
10/02/2007 10:32 AM
How's this for a solution?
  1. Insist to your wife that she is wrong. But, you will take scientific measurments just to prove her wrong.
  2. Take out something that looks like a sextant. (It does not have to work.) Aim it out the window every hour for six consecutive hours. Write a series of numbers on a large piece of paper.
  3. Put a thermometer on a stand about one foot from the window. Again it does not have to actually work.
  4. Drag this out for a week.
  5. Then announce that she was right, apologize to her, and have a long and happy marriage.
Bob
10/02/2007 4:07 PM
That might work as long as your wife is not an engineer or a scientist. Your approach would have my hubbie in the doghouse in no time flat!
Good Answers: 88
10/02/2007 4:12 PM
That might for him be a Good Thing, given the comfort level of the doghouse and provided it has metal-oxide window treatments. Not to mention his familiarity with said doghouse, given the number of his prior experiences dwelling therein. Heck, mine has a fully-stocked kitchen, wet bar, Jacuzzi, and my own personal Armani wardrobe. And I don't even own a dog!
10/02/2007 4:40 PM
I own a dog, and the dog lives in our house, but I wish I had a doghouse like you describe!
Only mine would include a top-flight Ham Radio station and a Samsung 46 in (117 cm.) diagonal LCD HDTV with mating HD-DVD player and Home Theater Surround Sound system. Add the fastest cable Internet connection and a high-end HP PC with Wi-Fi to connect a Panasonic Toughbook Tablet PC (with touch screen of course and software to control it all) and a Motorola Bluetooth stereo headset.
Oh yeah, one last little detail.... Cabretta leather covered rocker-recliner with built-in massager from Flexsteel!
Can you say, "AAAAAAAAHHHHH!!!!" ?
Good Answers: 88
10/02/2007 4:43 PM
Very nice! I just fired my interior decorator for omitting all that stuff you just mentioned. I'm hiring you instead. Want the job?
Good Answers: 88
10/02/2007 4:45 PM
Btw, I'll take the doghouse any day given a choice between it and doing time in the main house with Ms Right. You know, Ms Right as in "Always?"
10/02/2007 5:28 PM
CLEVER !!!!
10/02/2007 5:20 PM
......LOVE IT!!!!
Good Answers: 19
10/02/2007 10:35 AM
There are so many complications to this issue (and too many other "fish to fry"), that I will take the easy way out and say my wife is right!
10/02/2007 10:43 AM
Well, the answer seems to be in how the question is worded!
Hmmm...
Change "living room" to "office" and "wife" to "co-worker" and I bet we get a whole lot of different answers!
ROFLMAO at people who said "wife is always right". This may be true, but not really an answer to the challenge.
Good Answers: 123
10/02/2007 10:47 AM
There isn't enough heat to be derived from window films to make up for a cold wife.
Pick a fight you can win.
Bob
10/02/2007 10:52 AM
I did! That is why I said, "Change 'wife' to 'co-worker'."
ROFL
Good Answers: 88
10/02/2007 4:15 PM
No aliases. You never wanna forget the nature of your opponent.
By the way, if a man speaks when his wife can't him, is he still wrong?
In reply to #59
10/02/2007 4:48 PM
Eu,
Speaking of pedanticism (ROfloorL), is that hum, like possibly a hymn? I don't know the verb him!
And, yes, he is wrong no matter what, if he knows what is good for him (or is it hum?)
I've got your back ER!
#90
In reply to #65
10/03/2007 4:07 AM
<bows and applauds>
In reply to #90
10/03/2007 2:09 PM
There's one of my kudos! (I am collecting them now you know.)
In reply to #132
10/04/2007 1:03 AM
I must check my hearing, it'll never work. A Gold Star might be worth trying.
Good Answers: 247
#128
In reply to #65
10/03/2007 1:57 PM
And Ken adds, pedantically:
How does a wife "him". I'm unfamiliar with that word as a verb.
Perhaps eu meant to write "If a man sings and his wife can't hymn, is he still wrong?" Of course even then, the use of hymn as a verb is a bit unusual.
In reply to #128
10/03/2007 2:01 PM
Maybe "Humms"?
Good Answers: 247
#131
In reply to #128
10/03/2007 2:05 PM
Ken adds:
Ken, try to keep up. STL already wrote words to this effect quite a while back.
Good Answers: 19
#87
10/02/2007 11:20 PM
I still got to many other priorities, and the actual difference probably is not worth the effort and energy to make the change.
10/03/2007 3:12 AM
Respect Our Forum, Loyal Management, And Others? Yes I do.
#127
10/03/2007 1:40 PM
I married "Miss Right". I didn't realize until after the ceremony that her first name was "Always".
In reply to #127
10/03/2007 2:00 PM
Why should yours be any different from the rest? EH???
10/02/2007 1:29 PM
I'd leave it on. The same reflective properties that kept the heat out in the summertime will act to keep the heat in in the wintertime, making your furnace run less to keep the house warm.
10/02/2007 2:34 PM
The READER'S DIGEST condensed version!
Good Answers: 88
10/02/2007 4:33 PM
You're obviously not married.
Good Answers: 88
10/02/2007 3:30 PM
The brightness of what? If the brightness refers to light coming into the room through the window, then you're hosed, Bud, because you just "blocked the light coming into the room" with your film.
If the brightness comes from some other source, then the clause "block light coming into the room" has nothing all to do with the clause "keep the brightness." These two clauses are diametrically at odds in this sentence. Or quite possibly unrelated even though they are joined with the conjunction "but." You might as well say "The Moon is smaller than the Earth but it is farther away."
Brightness might also be interpreted here as an aesthetic quality of the room having nothing at all to do with light per se.
What, exactly, do you mean here? How is this to be interpreted?
I don't mean to be pedantic but, generally speaking, if you ask an ambiguously-phrased question, then expect to get an ambiguously-phrased answer. Or more than one, most likely.
10/02/2007 3:45 PM
Eu, I agree. The questioner seems to be technically-challenged. Don't know how this one ever got past the CR4 editor.
I understood/guessed/surmised/assumed him to mean he wanted to block the heat of the sun (light), but allow in the visible light (brightness).
I think most people interpreted it this way as well.
Too bad we have to interpret the technical meaning in a "Challenge Question". This was just a poor choice of words in my opinion.
Good Answers: 88
10/02/2007 3:59 PM
Somehow the question (as posed) calls to mind this cartoon:
10/02/2007 4:03 PM
ROLMAO
Good Answers: 88
10/02/2007 4:06 PM
ROLMAO.
So what, exactly, are you rolling on, Rosebud? I don't mean to be pedantic, but you didn't say.
#89
10/03/2007 4:00 AM
A ferry, it should have read ROROLMAO
In reply to #89
10/03/2007 4:25 AM
#93
In reply to #91
10/03/2007 4:40 AM
YTTDSFATCCSH
In reply to #93
10/04/2007 12:47 AM
LOL !
Jack
In reply to #93
10/04/2007 1:18 AM
Is there a tune to that? And what has RoRoRoYrBot done to engender this vow of fealty from you?
Mark
#141
In reply to #138
10/04/2007 8:27 AM
The way to a man's heart may be through his stomach (well, it is easier than the direct route through his sternum), but the way to a Rose's heart is through water related sports.
As to the tune, this is quite close
In reply to #141
10/04/2007 9:04 AM
...but the way to a Rose's heart is through water related sports.
You mean like this? (ROFLMAO at ER's much too generic statement)
3Doug (1); agua_doc (2); Andy Germany (22); Anonymous Poster (23); ballsinc (1); Blink (3); bob c (3); carterinms (1); charsley99 (1); Cipo (1); coconutpete (2); cuznmonkey (2); dbdwoods (1); ddk (1); Dnorman (1); English Rose (14); jdretired (2); Kris (18); MarkTheHandyman (4); mze (1); ozzb (1); pg2004 (1); Physicist? (11); Rick@cae (4); RickLee (9); Ried (2); semi-retired designer (1); SP (2); stinkbug1974 (1); STL Engineer (22); user-deleted-13 (16); vikas (1)
You might be interested in: Thin Film Materials, Room Partitions
