Coatings & Surface Engineering Blog
The Coatings & Surface Engineering is the place for conversation and discussion about coatings; substrate modifications; cleaning and surface preparation; and friction, lubrication and wear. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Reducing Solvent Emissions   Next in Blog: Chemical Safety and Security
2 comments
Diatoms Promise Next Generation Paints
Posted October 28, 2007 2:18 PM
My first view through a microscope was at a diatom - a tiny, beautiful, crystalline creature that seemed to come in infinite shapes and configurations. Naturally iridescent, these microscopic plants with their silica shells may be the source of the next generation of paints, cosmetics, fabrics, and even the holograms on your credit cards. Scientists in the UK are growing diatoms in the laboratory, and believe they can scale up the process enough to make the industrial manufacture of paints and other products more environmentally friendly and cost effective.
The preceding article is a "sneak peek" from Coatings & Surface Engineering, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Coatings & Surface Engineering today.
Engineering Fields - Environmental Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
Good Answers: 101
Re: Diatoms Promise Next Generation Paints
10/29/2007 10:25 PM
Considering that diatoms are just algae, this would be a good way to reuse treated effluent and remove dissolved minerals to purify it at the same time. Innoculate the treated wastewater with the desired species, cover it to prevent contamination by undesired species, and expose the water to direct sunlight for several hours a day. The diatoms will feed on the dissolved minerals, purifying the water, and they in turn can be harvested for use periodically. Just remember that diatoms require dissolved silica in the water.
If only you knew the power of the Dark Side of the Force
10/03/2009 10:11 AM
This could be used to remove dissolved silica from wastewater from coal-burning power plants.
