With the safety and efficiency of military aircraft in mind, one researcher has taken flight with a novel idea for coating jet engine blades. The technique was originally devised to deal with sand and other particles that build up on the blades and turn into a corrosive glass. The group coated the inside of the engine with zirconium dioxide, or zirconia, the same substance used to make fake diamonds. The zirconia actually converts sand sucked into the engine into a protective coating that helps the engine run hotter without incurring any damage. The self-rejuvenating coating holds promise as a replacement for current ceramic products, and engines that can burn fuel more efficiently and cleanly.
The preceding article is a "sneak peek" from Coatings & Surface Engineering, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Coatings & Surface Engineering today.
