Previous in Forum: Smallest storage device to store analog data   Next in Forum: Reason for Losing Brightness of the LED Over Time
Popular Science - Cosmology - New Member United States - Member - New Member
Is There a Solution for Loud TV Commercials?
02/10/2008 7:58 PM
Hi all,
As many of you know, the television volume level increases dramatically when certain commercials come on. It is downright aggravating and infuriating!
I don't know is this is strictly a U.S. problem or not, but I would like to know if you folks in other countries have the same problem with advertisers. Surely there must be a way to keep the volume constant. I know "Magnavox" has what they call "Smart Sound" which supposedly does just this; keep the volume constant. I assume they use some sort of op amp feedback loop or something like that to maintain volume constancy.
I have checked with the FCC website here and as you will see if you read the link, they do not regulate the volume of programs or commercials. They just suggest contacting the station that broadcasts obnoxiously loud commercials. Not a good solution IMHO.
Is anyone else as frustrated as I am about this? Does anyone know of an existing device that can be incorporated/attached to one's television to maintain a constant volume?
Thanks to all,
-John
All worthwhile programmers know that constants always vary.
Pathfinder Tags: Loud commercials
#101
Re: Is There a Solution for Loud TV Commercials?
08/02/2010 1:54 PM
Buy a reasonable quality "compressor" this will be a music & recording device.
I use this : http://www.alesis.com/3630
you set the device to start to limit just above the acceptable level and it will limit or compress the sounds dynamic range.
I use it to set up PA systems when some DJ's and Bands just want to keep turning up the volume...then they can do so and as they turn up the volume you get more distortion and they are happy as it sounds louder to them and they see the volume at 10.
I am a deeply religious nonbeliever - this is a somewhat new kind of religion. Albert Einstein
10/19/2010 10:40 AM
Charlie don't surf.
afabbricante (1); agua_doc (1); Andy Germany (6); Anonymous Poster (12); AppsGuy (1); bmorrow492 (3); ca1ic0cat (1); case491 (1); chtank (1); cnpower (1); CSM Engineer (1); dragon_slayer79 (2); DVader1000 (1); Electroman (2); EnviroMan (13); es59 (1); garth (2); Georgee (1); gniMan (1); gsuhas (4); Hendrik (2); horace40 (1); IanR (2); indel (3); Johnjohn (8); Just an Engineer (1); Lleros MaHarg (1); Moto (1); Munky (1); ndt-tom (1); Nigh (4); portugalphilip (1); Pure Boer (1); PWSlack (1); RHABE (1); Rorschach (2); Scapolie (1); Sparkstation (3); stevem (1); Switchman (1); techno (1); user-deleted-1105 (2); Vulcan (4); welderman (1); Zackextreme2001 (1)
