Previous in Forum: VFD for Single Phase Motors   Next in Forum: Can I use stun gun technology to build a hydrogen home furnace
Good Answers: 39
Cooling Solar Panels
08/12/2008 3:51 PM
I have not seen any water cooled solar panels. Given that a cooler panel produces more output, this would seem like a good thing. Appears to me there is a potential application for adding water cooling jackets to the back side of PV panels. What is the downside apart from the need to make liquid proof connections? The PV panels are already rain proof so I can't see it being a big issue.
Elnav
Good Answers: 150
#100
In reply to #99
Find in discussion
Re: Cooling Solar Panels
08/09/2010 8:37 AM
Minus 400W of power to run the pump.....
Who is John Galt?
#101
08/16/2010 12:32 AM
With a 5kW system, and using the 400w pumps full 400w useage,( I think it is more like 300w once running) that means the net gain is about 8-10%, well worth the effort I think.
#102
08/23/2010 10:15 AM
I ran experiments in Tucson, AZ comparing the output of cooled and non-cooled solar panels in side to side tests. The cooled panels provided hot water in addition to producing mo less the 20% more power.
Solar Panel and Solar Heater at the same time
11/04/2010 11:23 AM
Ideally, you would pass tap water through a copper/aluminum radiator beneath the solar panels on your roof, and thus hit 2 birds with one stone!
Get electricity from the solar panels as well as hot water from the radiator.
03/07/2012 3:42 PM
First, I am not a solar engineer. I had an idea a couple years ago to use water to cool my panels, a closed system tied to my water heater and forced air cooling/heating system. It would have a small pump and automatic diversion valves to reroute the water according to outside temp.
Water would run at all times, summer and winter. In the summer it would cool and in winter it would warm to keep snow from sticking to the panels.
12/28/2015 5:50 PM
I'm pretty new to solar panels.
I am currently building my own down here in Houston,tex.
My thought was to sandwich a water flow through 2 glass panels
with the solar cells underneath. facing upward. Using a strong 12 volt water pump
running off my array and using water from my hvac drip pipe I could possibly cool all my panels . Have'nt figured out how to cool the water coming back out yet though.
Also wouldn't the water also magnify sunlight to some extent? And if you dropped it down into a shallow light box, say with mirror tape around the inside edges,
could that solve some problems? I,m working on one now. Any input is appreciated.
Andy Germany (1); Anonymous Poster (11); Duckinthepond (21); elnav (27); EnviroMan (12); EV1guy2004 (1); gsuhas (1); Jack Jersawitz (3); marcot (1); Mark684 (2); mrbill (1); North of 60 (2); Pineapple (2); PWSlack (1); ron martin (1); Rorschach (11); Sapper (1); starfleetsystems (1); The_curious_one (1); Transcendian (2); user-deleted-1105 (1); vicini (1); Wafi (1)
