Previous in Forum: Wanted: Panel Voltage Meter   Next in Forum: Data Acquisition Board for a Flight Data Recorder
What Is It?
01/27/2009 9:47 AM
Sorry about the duplicate picture, don't know how to erase it.
LL
Re: What Is It?
01/31/2009 12:37 PM
Ok, now I'll (try to) be serious. Is it used to test the tension on a cable of some sort? Maybe like on fencing material?
CARPE CRUSTULORUM!
Re: What Is It?
01/31/2009 12:42 PM
Where to begin?
"probably proprietary, for one specific machine".....Not at all!
"stuppor boil"............football
"lifting device?"............Nope
"strings or cables"........Nope
"I'm tellin"..................Go ahead!
Good Answers: 103
#82
Re: What Is It?
01/31/2009 12:53 PM
setting tension on strings eg violin or guitar ?
In reply to #82
Re: What Is It?
01/31/2009 1:36 PM
This instrument is not used to tune another instrument. In any musical sense.
In reply to #83
Re: What Is It?
01/31/2009 2:04 PM
You're enjoying this entirely too much. Frankly, so am I.
Ok, so you "clamp" some type of material between the jaws,and measure...what? The elasticity of the material? It's "sponginess"? It's density?Or maybe it's speed or ability to return to form?
Is this the entire device? Is it normally mounted on something else?
This is really cool.
CARPE CRUSTULORUM!
In reply to #84
Re: What Is It?
01/31/2009 2:16 PM
"clamp".........no clamping in any mechanical sense. The term "capture" could be associated with the device's use.
"jaws"..........none
"sponginess"?..is a term you could loosely apply to the quality of the item which is the subject of the test.
Time's running out!
Good Answers: 68
#86
Re: What Is It?
01/31/2009 2:21 PM
Hello lynlynch:
It is to set the tension of the threads on a spinning loom.
This it really good LL, you have got most by the short & curlews. I think that word is acceptable....?
Take care.............
Re: What Is It?
01/31/2009 2:27 PM
Let's try another perspective.
The device has two graduations, one is in LBS from 100-320 in 40 # increments, the other is N. 400-1500 in 100 N. increments.
Go Cards!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
In reply to #88
Re: What Is It?
01/31/2009 2:58 PM
Okay a long shot....
Is it for measuring the bendability of cardboard / paper???
Maybe for measuring the paper thickness / weight in lbs/foot^2???
In reply to #91
Re: What Is It?
01/31/2009 7:43 PM
No
Good Answers: 68
#116
In reply to #102
Re: What Is It?
02/01/2009 2:35 AM
Hello LL,
GA to you for one of the best! As I said to ky I thought it would run and run.
I ahd probs with my computer and was not able to get on for over three days I think, and didn't thank you when I had about 40 answers as I logged back in!
Do you have one? Cos I still am not certain what you do? Is it hook the bent finger thing over the belt? Or is that the spring?
Well done LL. GA well earned!
In reply to #116
Re: What Is It?
02/01/2009 8:42 AM
OK. In case you haven't quite got it.
Slip your index finger through the rubber retainer. The device should be in contact with the front of your finger, between the first and second joint.
Now find yourself a v-belt and simply push the device into the middle of the longest span of the belt. The curved plastic piece contacting your finger is actually a spring loaded release which is preset to trip at some load. As you press the tool into the belt the green "pointy thing" is deflected outward by the belt. It's designed so that when the tool is removed from the belt the pointer remains at it's last position. So, remove the tool from the belt when it clicks and the resulting reading gives belt tension in either #'s or Newton's.
For reference, the pictures at the beginning of my post shows the tool with a reading of appx 700 N/ 140#.
Believe it or not, once you get over the odd configuration and the fact that you wear the thing, it works very well.
Used to use it to check drive belt tension on 10 HP blowers used to blow dry PCB's during processing.
Go Cards............................
Good Answers: 68
#125
In reply to #124
Re: What Is It?
02/01/2009 9:40 AM
Hello LL,
Thanks for the reply post. They are all interesting........But this takes the biscuit! Thanks.
I thought of a little wood plane at first after you sent the comparison pic with a rule by the side. Several posts mentioned testing and tension and I could not see how 'top' and 'bottom' could be used at the same time! The only answer I recall that would fit is a door stop.
Oh well, Got any more? Did your 'side' win the Football match?
Just to get it right in my mind. The angled bit is not a hook?
Take care...................
Location: 1,000,000 miles from somewhere else, 846' above sea level in N.A.
Re: What Is It?
01/31/2009 10:28 PM
its a whatchama-fundoody-thingimajiggy thing for testing the clamp pressure of a closepin! great challenge, i like all the answers and i hope you reveal the answer soon!!
I started with nothing, and I still have some left
Re: What Is It?
02/01/2009 12:07 AM
It's been loads of fun...................................
Thanks
LL
Good Answers: 58
#112
Re: What Is It?
02/01/2009 2:03 AM
Measure Belt Tension?
Good Answers: 74
#113
In reply to #112
Re: What Is It?
02/01/2009 2:11 AM
What else?
The Twain Has Met
Good Answers: 58
#121
In reply to #113
Re: What Is It?
02/01/2009 3:09 AM
Deflection?
Good Answers: 74
#122
In reply to #121
Re: What Is It?
02/01/2009 3:24 AM
You are right. It could have been but the device shown would not be suitable for such a measurement. If you would want to measure deflection you would have other tools at hand, not hand held and not in contact with the belt. Or am I not getting something here?
BTW you have entered the 121st reply and the solution was ratified at post 111. 11x11= 121. It will all make sense in the end as it has here. What comes around goes around. Lots of # ones adding up to a lot of fun being had. Never mind my maths, its to do with some aspects of Kabala.
Its Sunday evening and I'm waiting for the power to come off any minute now. See Ya's, Ky.
The Twain Has Met
Good Answers: 58
#128
In reply to #122
Re: What Is It?
02/02/2009 1:31 AM
Suitably chastened and embarrassed . This will teach me to read at least 111 posts after trying to drain China of "White Spirit" during New Year holidays before responding.
Will post a picture of my very old and simple belt tension device later.
Good Answers: 74
#129
In reply to #128
Re: What Is It?
02/02/2009 4:12 AM
No reason too at all. To be honest I thought I had stuffed up big time my self. Never mind the numbers game. Good as gold! Ky.
The Twain Has Met
#132
In reply to #122
Re: What Is It?
02/03/2009 9:13 PM
The measurement is taken when the machine is turned off - static tension.
Good Answers: 74
#133
In reply to #132
Re: What Is It?
02/03/2009 10:14 PM
Thanks, I had the feeling that the water was getting a bit deep. Its soooo me.
The Twain Has Met
In reply to #132
Re: What Is It?
02/03/2009 11:53 PM
Sorry.
It would have needed batteries to be used with the power on.
There's no room for batteries.
Good Answers: 68
#117
In reply to #112
Re: What Is It?
02/01/2009 2:41 AM
Sorry to all in the exitement I replied to my own post!
Good Answers: 68
#118
In reply to #112
Re: What Is It?
02/01/2009 2:45 AM
Hello Prof,
you should have got that as you are a prof' an all!
I wanted to get another one in before the end of the game and the passing line so as to speak. Pot luck really.
Take care...........................
Good Answers: 68
#119
In reply to #112
Re: What Is It?
02/01/2009 2:50 AM
Hello Prof,
Good Answers: 74
#120
In reply to #119
Re: What Is It?
02/01/2009 3:00 AM
Need one more. Kabala thing, I'll explain later.
The Twain Has Met
Good Answers: 68
#123
In reply to #120
Re: What Is It?
02/01/2009 4:21 AM
Hello ky,
no probs. I am off to the land of nod myself...........see you later.
Good Answers: 97
#115
Re: What Is It?
02/01/2009 2:34 AM
It is for measuring / setting the tension in piano wire for tuning a piano.
At long last they are getting away from (mis)using blind people for tuning pianos.
Re: What Is It?
02/01/2009 12:37 PM
Poor quality photos of tester. Left photo is zero deflection of the indicator. This would yield the highest force reading.
Right is max deflection/minimum force reading. Notice that the instrument rests on the flat under your finger. At this point, the indicator is not in contact with the belt.
As you apply pressure the belt deflects, and indicator contacts belt, and moves according to resistance/deflection of subject belt. When the test begins, the indicator is at the highest reading. The more the belt deflects, the more the indicator is deflected downward on the scale, till the little clicker thing clicks.
Good Answers: 15
#135
In reply to #126
Re: What Is It?
03/11/2009 11:37 PM
can you make a video of it in operation?
Curious to see it in operation ;o)
Whats to stop you from adding too much force onto the belt with your hand, thus a incorrect reading?
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Good Answers: 38
#127
Re: What Is It?
02/01/2009 8:46 PM
For setting the tension in the wire of a wire making or a weaving machine?
Otherwise to set the correct tension in a Victoria Secrets Panty and Bra?
Re: What Is It?
02/03/2009 11:15 AM
I'm lurking in the bushes waiting for the answer to scurry by so I can ponce on it and bite it's bloody head off
In reply to #130
Re: What Is It?
02/03/2009 11:24 AM
See post # 103.
Anonymous Poster (7); artsmith (1); babybear (17); BlueAussieBoy (2); Bricktop (9); edignan (1); Electroman (7); EnviroMan (2); Epke (3); genx (1); hairlesssimian (3); Hendrik (2); ky (12); lyn (36); Mr. Guy (1); murphyc1 (2); not so smart (10); PlbMak (2); PWSlack (1); Randall (1); RVZ717 (1); sb (2); Snaketails (3); The Prof (3); tomfranpat (4); U V (1); user-deleted-1105 (1)
