Previous in Forum: 1998 Chevy S10 Blazer - Brake Replacement   Next in Forum: 1995 Dodge Caravan - Engine Stalls
Personal Transportation - Out of the Box Thinking
02/27/2010 8:09 AM
After reading a number of past posts regarding alternate energy personal vehicles I decided to pose the question to my students. They came up with a number of unique and interesting ideas and so I thought that I would propose the same question to the great, international minds within this community.
When we discuss personal transportation, we seem to always be limited by the idea that a vehicle should meet all of our transportation needs. That is to say that if we commute say 40 miles per day and take a family vacation one week per year, the vehicle should meet both of those needs. I like many weekend warriors do not expect my vehicle to haul a couple hundred pounds of building materials and so I hook up my trusty trailer to my Blazer and proceed. At times, the trailer is not sufficient and so I drive to the nearest rental store and grab a bigger truck.
My point, and therefore my question, is that this discussion in America always seems to be black and white. As an example, a number of contributors to this forum will routinely respond that electric vehicles are not viable because they will not go the distance, but as one of my students pointed out, their family owns a small IC car for daily use, but when they go on vacation they rent a van with a topper for more storage. If you take the time as our class did, the cost analysis is quite interesting.
I will pass on one more of my students ideas and then turn it over the minds on this forum. One student suggested that we take the Volt idea and rather than include the IC motor in the vehicle, to rather make available a small trailer that would include storage and the IC motor for electric power that could be owned or rented when one wants to make a longer trip.
Thank you in advance for any thoughts you might share and have a great day all.
Good Answers: 213
#93
In reply to #89
Find in discussion
Re: Personal Transportation - Out of the Box Thinking
03/02/2010 3:45 PM
There used to be something around called a "gyrocopter", if I remember rightly. Single passenger, powered by Briggs & Straton, no license required to fly it if you build it yourself...Open air (sorry, no convertible models).
03/04/2010 1:02 PM
Greetings All,
lots of good comments, Wish Id seen this sooner. Many of the problems with thiking out of the box is that politicians and govt has put so many restrictions on it. If you have ever build a car from scratch in CA and tried to get it licenced you know what Im talking about.
If I were let loose, without restrictions, with the goal of better transportation, without any considerations for peoples asthetic opinions, then I would have only a few basic requirments. 1) Fuel economy (gas or elec), aerodynamics and lightness. 2) enough performance to be safe (0-60 in 6sec., 100mph top speed). 3) Comfort
These requirements can be filled with a tandem seated vehicle for 2 or 3 people, because of CA's restrictions I've had to go with a two wheel in front and one in rear configuration.
This could actually be built for under $5k, using off the shelf parts.
The person who wrote the above is not resposible for spelling, grammar or puncuation, ......
Good Answers: 213
#100
In reply to #99
03/04/2010 1:17 PM
spacecannon-
Any details of your concept that can be shared without violating any IP concerns? Sounds quite interesting, although your top end speed scares me a bit...
California won't let you you with one wheel in front and two in the rear? What about a side-car style, two wheels on one side and one on the other?
In reply to #100
03/04/2010 3:12 PM
Two wheels in front and one in rear is more stable, compared to one in front and two in rear. I did the drawings in the 70s on paper, frame was tubular, like a sand rail, covering was of panels with a floor pan like an old VW bug, back then I was going to use bug front end and a motorcycle engine and rear end, but today I would go down to a junk yard and get a front wheel drive engine so the steering an suspension are all in one that way it has a reverse and AC/heating and all the electric in one place. Maybe a subaru (low profile) or a small diesel. Elec. would work too with the batteries lined up down the center like putting your legs around a motorcycle, this center line of batteries in a "tube" also acts a frame stiffener. The lightness and tandem aerodynamics would double the gas milage. A 3 wheeled vehicle in CA if under 1500 lbs is considered a motorcycle and so all the crash test, safety regs and smog regs can be avoided, the Regs inhibit and restrict out of the box thinking.
Good Answers: 196
#101
In reply to #99
03/04/2010 2:01 PM
Spacecannon -- 0-60mph in 6 seconds and 100 mph may be your design reqirements and that's fine. But please don't try to pass off this level of performance as having anything to do with safety except insofar as it may create a hazard in the hands of an irresponsible or incompetent driver. The highest performance level of any of my everyday drivers for the last 40 years was a 64 Plymouth Valiant station wagon with a 225 slant 6 that would pull the east side of Tioga Pass to 10,000 feet in top gear carrying a load of kids and camping gear. (if that gives any hint to it's power to weight ratio) In that period (450,000 miles)the only accident I had that was any way my fault was a scratched bumper caused by my own inattention in a yield lane.
All that aside, since it's been quite a few years since I built the hot rod sitting in my garage I'd really like to hear you elaborate on the problems associated with getting a homebuilt 4 wheel vehicle its first time California registration. It's been some 30 years since I went through a similar exercise and since then there has been a crackdown on bogus registrations of professionally built street rods as well as a lot tighter emmission regs.
This registration issue will vary among the states; but it can be a serious hurdle, especially for the first time car builder looking to experiment with green technology. I realize such folks often don't have a good grasp of exactly what is required for safety and emmission compliance and need some specific guidance best before their first presentation to a DMV referree. What can you tell us about your experience so far?
Ed Weldon
In reply to #101
03/04/2010 4:50 PM
I thought 0-60 in 6 sec. was slow with a 100mph top end. We could make it slower but merging on the CA freeway becomes hazardous.
My experience with the DMV in CA starts with "happy lawful compliance" as a youth and ends with "subterfuge and tecnically fraud", which i wont go into, but CA is not friendly so I gave up on it a long time ago.
Good Answers: 196
#107
In reply to #105
03/04/2010 5:09 PM
Hmmm........ 0-60 in 6 seconds. I have to respect your Southern California experience. We have one place up here like that, the 880 corridor between San Jose and Oakland. I have to admit in that stretch my little 4 cyl Tacoma is pedal to the metal merging out there. It's probably good for 40 to 60 in maybe 6 seconds but has too much factory cam to get off the line fast even with the automatic tranny. I did once in a moment of slightly reckless experimentation get the Tacoma up to an indicated 95 or so on I5. Took a while though.
Ed Weldon
Good Answers: 196
#108
In reply to #107
03/04/2010 5:11 PM
Oops!! Got a little of topic there. Gonna have to go hide my head after jumping all over Roger Pink for going OT...... EW
Popular Science - Weaponology - Ancient Weapon Enthusiast United States - US - Statue of Liberty - Viva la Revolucion!
Good Answers: 15
#106
In reply to #101
03/04/2010 5:04 PM
Irresponsible and/or incompetent drivers should be banned from the roadways as a first step in reducing our emissions.
If we required people to actually demonstrate more skill than being able to navigate a parking lot most of the drivers on the road today would cease driving and our emissions would drop dramatically.
I won't go into too much of this rant here, since we've already been down that road in another thread. I will simply say that driving is a privilege not a right and until we start treating it that way we can expect our roadways to be overflowing with 'statistic makers'.
Education is not preparation for life; life itself is education.
In reply to #99
03/04/2010 3:40 PM
In Wisconsin we're able to get around that by licensing it as a hobbyist
Good Answers: 196
#104
In reply to #103
03/04/2010 4:41 PM
Phoenix --- Here's the link to the Wisconsin Hobbyist Registration Application.
http://www.dot.wisconsin.gov/drivers/forms/mv2388.pdf
Looks like there has to be a connection to a 20 year old vehicle, either in the basic chassis or the outward form. I can see some possible loopholes; but the unsophisticated experimenter trying to get road registration for his creation with an all new aerodynamic body and minimum vehicle weight would be pretty much left out in the cold unless he followed motorcycle design practice.
An example of such a loser would be the following: The UC Davis and 2nd place winner in the 1993 Ford Motor company sponsored hybrid vehicle national competition for the class of complete newly constructed designs. (this is a project my son, David, worked on as an engineering student at Davis). The vehicle was a aluminum framed two seater with a fully enclosed low drag coefficient composite body that weighed 1600 pounds street ready with batteries. It had prototype 25 hp Briggs and Stratton high efficiency 4 stroke gasoline engine and a parallel drive train setup (and controls) for the electric motor/generator. I don't have the performance data on it; but David described the low speed performance on a driving course as pretty exciting.
The hybrid I described is the kind of vehicle that might be most attractive to the experienced mechanic or engineer to build. These are the very folks who are capable of producing significant prototypes but lack the resources to do their development work and testing anywhere but the public highways.
Ed Weldon
In reply to #104
03/04/2010 7:44 PM
My brother and nephew were building hobby vehicles as a project or hobby......one of which was a low rider tow truck that had a compulation of a GMC 1 ton truck Cab and motor and partial drive train, Chevorlet Chassis?., Ford (4WD)I think, Gleaner Combine (gas tank and running lights), John Deere Combine I think more working/running lights)?. Rear axle is up in the air, I can't remember.
can't remember I think thats the approx. origins..........real work of art. saying sarcasticly...they take it in parades and family outtings.
Its interesting about the vehicle prototype, It seems to me as I remember it, Its easier to build a prototype or home built airplane.
p911
Good Answers: 204
#111
03/12/2010 2:57 PM
Hi Velisj,
I think your students might be interested in discussing this subject.
Chris
70AARCuda (1); Anonymous Poster (3); Blink (11); charsley99 (1); chrisg288 (10); cwarner7_11 (8); Ed Weldon (11); gaiatechnician (2); hairlesssimian (2); hotwater (1); Jaen (2); JBTardis (4); jt (1); mike k (4); ozzb (1); phoenix911 (23); spacecannon (3); StandardsGuy (1); Tad (1); tcmtech (2); Tom_Consulting (2); Tornado (2); Transcendian (1); velisj (16)
