Previous in Forum: 01 Chevy Cavalier Starting Problems   Next in Forum: Diesel/Petrol Mix
Page 2 of 3: « First < Prev 1 2 3 Next > Last »
Good Answers: 204
Give Me a Name!
09/08/2010 11:20 PM
Two months ago today, I started this thread about motorcycle safety. As that discussion evolved, I found myself thinking "What kind of vehicle might give riders a similar sense of excitement and freedom, while giving them greater visibility and safety.
My creative juices boiled away for a while and then over the last two weeks I've poked away at creating the following. I think it is an interesting blend of styles and themes, from antique car racers, to jet fighters, to street legal quads, and animalistic power shapes.
What I'm looking for, other than your welcome comments (positive or not), are your suggestions for names, and any ideas you have for improvements or changes. (It's not perfect. I had trouble with my dashboard.. so that's missing..and keys, light switches, etc.. I was going to put on.. but they are missing for now.) Even though the fuel fill cap is on the right outboard side, I'm imagining it as piped to a tank in the lower center of the vehicle, so the tank is safest in a collision.
I've imagined the steering mechanism to be a wheel that turns 30 degrees max, and it has a combined accelerator/brake system, controlled by the forward/backward motion of the steering wheel. Internally, the whole thing could be 'fly-by-wire'... (hey, I'm not as much of a mechanic as I am a designer... but those details can be worked out if it ever got prototyped) I have put in a 'srpinger' style suspension... just for fun, and to have a bit more 'old school' feel to it.
Enjoy,
Chris
if you want larger images, pm me your email address.
Good Answers: 204
Re: Give Me a Name!
09/10/2010 5:50 PM
I received a pm from Yusef1, and I thought it was so good, I had to post it here. (he's shy...) I just wish I could give him a GA for it.
Chris,
I think it is unstable because it fights against the fundamental forces of physics. The relevant forces are a, gravity, b, centripital force, and c. gyroscopic precession.
A motorcycle steers by gyroscopic precession. Some call it, (incorrectly) counter steering. Essentially, if you want to turn left, you press forward and down on the right hand handlebar.
This is opposite to what you do on a bicycle, or what you think you do when you steer a motorcar.
What happens is that the front wheel will move in response to gyroscopic principles. The leaning has nothing to do with steering....I can steer around a circle and keep the bike completely upright (according to the horizon) by countersteering alone.
Doubling the number of wheels doubles the number of gyroscopes you have to precess, and there is a real possiblity at very high speeds that you can get a "tumble". If you spin a cheap kids's top on the table top, it will balance on a point, until the stresses get so great that it will suddenly change up to down, and will become stable on a different point. This phenomon is called "tumbling", and must be taken into account any time you have a gyroscope. The wheels on a motorcycle form gyros, and yes, they have been known to tumble. We don't talk about that much, but it is a consideration. Doubling the number of wheels will result in doubling the chance of a gyro tumble. This possibility will be limited if the swing arms keep the gyros (I mean wheels) under control. Mostly. However if you were to drive your car down the road, suddenly change lanes and then immediately change back again on the bounce, you will get a tumble. Try it, let me know what you think!
Chassis tuning is a lost art which is designed to control just this sort of squirrley behavior from a four wheeler. (google chassis tuning)
So if I can go around the curve without leaning, then why don't I? That is the second part of the physics problem. When you lean into the curve, you bring the softer sidewall rubber into contact with the pavement, and the geometry of the tire shape allows a larger surface area to contact the road. This gives you better traction when you need it, and the harder, longer wearing rubber in the centre allows long life on the tires when you are just traveling in a straight line. Also, it only "looks" unstable....in reality, if you close your eyes, you will swear you are sitting upright. (um...that would be a passenger thing...). The whole world looks like it is tilting. If I lean "way" over, then the bike will be more up-right, and the wheels will not be at such a tangent to the pavement. Since this tangent will result in a loss of traction, the greater the tangent, the more loss. So it behooves me to lean well into the curve, keeping that tangent as low as reasonable. This is the eternal fight between gravity, and centripital force, which any vehicle faces every day.
Complications would include accelerating or braking. You only get a certain amount of traction. Braking will use up some. Accelerating will use up some. Sideways moment will use up some. You only got a patch of rubber the size of the palm of your hand to play with here....so if you brake in a curve, you will use up all your traction, and you will skid out. Or if you hit the gas too soon as you come out of the curve, you will skid out. Other factors include water on the road, slippery centre lines (made my heart skip a beat once or twice before I learnt to avoid painted lines!) sand or gravel on the road, and the oily centre of the lane between the two wheel tracks.
Where it all breaks down is when somebody causes the motorcycle rider to have to do a sudden abrupt movement...a panic stop for instance, or a panic lane change. Management of the precious traction must be instantaneous and perfect, every time. Failure to do so will result in loss of traction, which can result in skids. When I was racing in Manitoba on the flat track, it was all about skidding around curves....my left boot had a steel plate a quarter of an inch thick on the sole because we always went around the curves with the foot down. This is difficult to do on the highway, though not impossible...I have done it. But then, I was a trained racer. Full of piss and vinegar and like all teen agers, immortal to boot! I now have a different philosophy....rather than try to handle everything the world throws at me on a bike, I simply stay out of trouble, try to anticipate when some bozo is going to do something stupid. NOBODY is more aware than a motorcycle rider! (ok, an OLD motorcycle rider.)
I guess that is why I am so down on other drivers who are NOT so aware. As they chat on cell phones, I have to be the one to dodge THEM! If the biker is too stupid to remain aware of road conditions (say by booting past at 150, then my sympathy runs pretty dry.
Well, enough of that. You probably already knew this whole lecture. But hopefully, I have been able to explain why I didn't think form followed function.
Regards,
Yusef1
In reply to #77
Re: Give Me a Name!
09/10/2010 6:07 PM
It sounds really technical but just creates a number of questions. Isn't centripetal force the force that moves you around a circular arc? It seems like he is describing the perception of outward force mistermed as centrifugal force. I am not sure that you lean into a corner primarily to use a larger softer surface area of the tire, since people on street bicycles moving at higher speeds do the same thing to turn. If you take a measuring wheel (or any wheel for that matter) and tilt it as you roll the wheel you will see that natural tendency to follow a curve in the direction of the lean. It seems that if you tried to turn without leaning less force is directed into the motorcycle and more is lateral across your body rather than downward through your body (that seems very uncomfortable and potentially dangerous). Also, I am not sure that motorcycles really steer that differently than bicycles, the forces and masses are jsut greater I believe.
Good Answers: 117
#94
In reply to #79
Re: Give Me a Name!
09/10/2010 11:12 PM
Quite right. My error entirely.
Good Answers: 117
#98
In reply to #79
Re: Give Me a Name!
09/11/2010 12:40 AM
Its funny, most people think they know how a bicycle turns, or an automobile turns, but the reality is that it is a lot more complicated is generally supposed.
Leaning is a red herring. Or should I say, weight transfer is a red herring. You can move all over your bike, reach down and pick up a handkerchief off the road if you like...you can still go in a straight line. The bike and rider are in equilibrium. If you countersteer, it results in a true lean of both the bike and rider, a movement around the caster, which results in centripetal force, (towards the inside of the turn) which you have to admit, has to be there if you expect to turn into a curve. If you try to stay upright in the turn (like a lot of newbie passengers and first time bike riders) your bike has to lean further in order to compensate and stay in equilibrium. If you were to lean way over, your body mass will affect the angle so that the bike's wheels will stay more upright. A bike is nothing if not stable and in equilibrium when up to speed!
The lean you see from the side of the road is not really a lean at all...the bike thinks it is upright. The lean it uses for steering is actually very little, most of what you see is just there to compensate for inertia (the mis-named centrifugal force) and you do that by keeping the bike in equilibrium....by leaning it.
This of course results in problematic traction issues.
The tire is shaped like a donut, with a rounded wheel, not a flat one like a car or a truck. So when there is a turn (for whatever reason) more rubber touches the road. As well, the centre rubber is harder for longer wear, and the side rubber is softer and stickier. That how motorcycle tires are made. So if you want more traction, you just have to lean the bike. You don't get much more though, but if you are racing, it becomes kind of useful. If you want to turn, you don't have to lean or transfer your weight at all, just countersteer. The precession will do all the leaning you need.
It is almost impossible to get enough angle on a bike to break its traction before you start hitting frame members, so the only reason I over transfer my weight in a curve is to either keep the wheels more upright on the road (hopefully improving traction a bit and avoiding scraping those frame members), or to compensate for the passenger who is leaning to the high side.
There, not so techical. And I checked it over, used the right terminology this time. I am not making this stuff up. A bike is VERY complicated machine, and it is a product of its environment as much as a fish is a product of his. If you didn't have those gyroscopes of wheels, things would be a LOT different!
Good Answers: 114
#102
In reply to #98
Re: Give Me a Name!
09/11/2010 1:42 AM
So when you ride a bicycle [or motorcycle] no handed why doesn't it continue in a straight line when you lean?
A similar effect is observed by shifting a majority of your weight to one footpeg or the other.
the larger the mass of the cycle, the less the rider can influence changes in direction my shifting his weight. Cruisers have shallower steering angles & are consequently more stable [harder to change direction]
Dual compound tires are a recent innovation, to compensate for the lack of grip, due to the lower temperature & subsequent lower grip of the side wall rubber. There are a range of profiles available ranging from triangular, to nearly flat like a car tire.
Good Answers: 117
#107
In reply to #102
Re: Give Me a Name!
09/11/2010 12:17 PM
Well, the short answer is yes, weight transfer will turn the handlebars. Or will they? But why and how? And in what direction? What do you THINK happens?
Try an experiment. Tape a piece of cardboard to the handlebars shaped like an arrow, and point it towards you. Ride your bike "no hands" and throw your weight into the turn...see what direction that arrow moves relative to the centre bar or gas tank. At low speeds, the arrow will point like you think. At higher speeds, the arrow will point opposite. There is a tricky cross over speed where you might get into trouble, so wear your helmet. So weight transfer simply does the same thing as countersteering.
Some vehicles are very sensitive to weight transfer (bicycles) and some less sensitive (motorcycles) but all two wheel vehicles are sensitive to a greater or lesser extent, and a lot depends on speed. In fact, my low rider almost doesn't care about weight transfer, yet my Yamaha 650 squirreled all over the road whenever my passenger simply blew her nose. (I did say "almost".) In fact, I have not driven a motorcycle since then that was as sensitive....and in all modern motorcycles, countersteering trumps weight transfer anytime over 30 KPH.
Another experiment would be to take a bicycle wheel, hold it by the axle, and spin up the wheel. If you attempt to tilt the wheel by raising your right hand (or standing on the left foot peg) the wheel will not allow you to do that, it will in fact turn to the left in the horizontal plane. If you push on the axle, it will tilt.
This is gyroscopic action, and you cannot neglect it when designing a vehicle with wheels. If you want to steer it that is.
So, by the diagram above, you can see that there is no difference to the gyro if it gets its input by your putting your weight on one foot peg or the other, or if you push the handlebar. Pushing the left handlebar causes the gyro to lean (tilt) to the left. The caster swings to the right, causing the steering vector to point towards the left.
A lot of people simply go with the concept that the gyroscopic action keeps you upright, and it is the leaning which will initiate the turn. Thats okay, as far as it goes, bikes have been around for a long time and people figure out by the "seats of their pants" how to make them (I prefer the term "weight transfer" to "leaning" for many reasons) but the really complex part is not the weight transfer OR the gyroscopic action, but rather, the effect these have on a castered wheel.
My wheel barrow does not have a castered wheel. It has what Chris called a "soapbox derby" wheel. You can not turn that wheel unless you swing the handles from side to side. Tilting or leaning it side to side, you still go straight along the board its riding on. My "traveling measure" is a wheel on a stick with a dial on it. It has caster to the wheel...and leaning it from side to side causes it to steer. What does this experiment prove? I believe it proves that It is caster which results in steering.
Although that statement too is an oversimplification. Here is a much better explanation. You can see this if you have ever had a car which was badly aligned to have negative caster instead of positive caster. A car which has negative caster can't follow a straight line. So we all agree that caster is essential to crisp and proper steering. Is is such a stretch to suggest that all gyroscopic effects are designed to assist the caster in its desire to properly steer the vehicle down the road?
All you do by tilting your gyro is to set up the steering geometry suitable to allow you to get around the dog which suddenly ran into the road in front of you.
Its not intuitive. Try riding your bicycle close to the edge of the sidewalk or along a railroad track.
I seem to have gotten onto a soap box. Sorry about that.
I just can't believe I can't explain something that I know so well. They say genius is the ability to state a complex concept in only a few words. These rambling posts clearly show that I am so NOT a genius! And we are like...totally off topic here, so if you wish to mark me off topic, I am, like totally okay with that.
Good Answers: 204
#109
In reply to #107
Re: Give Me a Name!
09/11/2010 1:36 PM
"I just can't believe I can't explain something that I know so well."
Your post is still shorter than the wiki you posted on the same subject. I can't imagine why this would be off topic. ga.
Good Answers: 114
#119
In reply to #107
Re: Give Me a Name!
09/11/2010 11:23 PM
Feel better? pretty pictures, nice presentation
you can use the throttle, brakes, the handlebars & your weight to change direction. The geometry & type of suspension; the size, weight & composition of the wheels; speed, available power,surface; wheelbase determine which combination of the possible inputs will be the most effective in changing direction.
yes of course most [throttle & brake excepted]changes of direction are dependent pointing the front wheel in a different direction than the rear wheel [
The bicycle wheel is nice to demonstrate gyroscopic effect, but isn't relevant in the weighting of footpegs, unless the design is now a unicycle.
Good Answers: 130
#120
In reply to #119
Re: Give Me a Name!
09/11/2010 11:41 PM
I'm waiting for "contact patch offsetting effects of lead and headstock rake" - not to mention 'backing in' ......
Good Answers: 204
#121
In reply to #120
Re: Give Me a Name!
09/12/2010 12:17 AM
I'm lost. what are lead and headstock rake...?
Good Answers: 114
#122
In reply to #121
Re: Give Me a Name!
09/12/2010 12:40 AM
Good Answers: 204
#123
In reply to #122
Re: Give Me a Name!
09/12/2010 12:47 AM
thank you.
I see head angle and rake... which must be what was meant by 'headstock rake' and I also see "trail" but that must be what "lead" meant. ??
chris
Good Answers: 130
#125
In reply to #121
Re: Give Me a Name!
09/12/2010 2:05 AM
Looking at your bike; the headstock bearing axis and the axes of forks may be parallel of at different angles. If the forks slope more forward they 'lead' the wheel axle further forward of the projected line though the head stock bearing to the road surface. This headstock projected line/point is what the bike steers about.
If the head stock and fork axes are parallel you will see the wheel axle is set in-front of the forks (axes) - this has the similar lead geometry effect. Many have both.
The net effect is, steering lifts the bike - so gravity is what makes a bike seer straight (upright). It's like caster "stability".
The more the total lead, the more centering preference (slow to turn) The less the faster to turn. So when you turn the bars - the contact patch moves 'around the tyre' as it moves to the side of the tyre.
To get the feel of it; hop on your bike - standing still - and turn the bars - note the bike moves side ways opposite to the steering movement and the front wheel rotates slightly and the contact patch has moved more toward the side of the tyre.
If you now balance the bike (still at full lock as if you were backing) you get more of both movements, a big change in height - and 'radical' turning if you now walk it.
Now if you can, without dropping it†, rock over the other way, the patch is moved to like "opposite locking" in a corner. It's way outside the headstock line of the bike - or gravity* is making the bike "fall into" the corner.
I.e. to turn right you move the contact patch to the left of the bikes center of gravity*, thus overcoming the natural tendency to align everything 'upright'.
*net down-force vector
This is also handy to know when buying a bike, as if you find yourself "sitting off" when riding straight - it's very bent. If you can't take your hands off the bars - its bent, and/or the front wheel is not true 'sideways'. Either moves the contact patch to 'unstable' relative to the head stock axis projected point. As does a cranked rear wheel due to poor chain adjustment or a bent arm, or shot arm bearings.
If you imagine a vertical plane right through the center of the bike, coincident with the center of head stock and rear wheel contact patch;
These misalignments have the effect of moving the headstock axis off that plane, so it's sloping right or left, meaning the bike thinks it is being told to turn.
Also know as 'death wobbles' - where gyroscopic precession is not your friend
† any one with a giant slug tourer might be better off checking this geometry out with a cycle.
But perhaps not this one;
(Sorry for the length)(sort of)
Good Answers: 117
#124
In reply to #119
Re: Give Me a Name!
09/12/2010 1:07 AM
okay
Good Answers: 74
#84
In reply to #77
Re: Give Me a Name!
09/10/2010 6:31 PM
Well done. Good you put it here!
The Twain Has Met
Good Answers: 117
#93
In reply to #77
Re: Give Me a Name!
09/10/2010 11:11 PM
Except that oops, I made two unforgivable mistakes...when you push forward on the LEFT handlebar, you turn left. Not the right handlebar. doooh. This happens only after you get up to speed. At low speeds, it is the opposite.
Its called counter steering, and it results in a gyroscopic precession which affects the steering geometry.
And I was incorrect in calling it centripital force...the drag or wheel geometry which turns the bike towards the inside of the circle is centripital, (thats how you steer), whereas the force which flings you outwards is centrifugal. (I know, its not really a force...its just inertia, yet the traction pad on the road doesn't care if its a vector, a force, or a virtual force! ) Mea Culpa. So everywhere I used the word "centripital", please replace it with the word "centrifugal". I am glad somebody called me on that! Shows they are reading!
So, it wasn't that I was shy Cris, but rather that I wanted to get my statement out, and fact check later. I stand behind the rest of the "lecture" (rant) though. I should have just let it sit in my out box until I was ready to post.
Good Answers: 204
#95
In reply to #93
Re: Give Me a Name!
09/10/2010 11:23 PM
I'm psychic.. I knew what you meant.
Good Answers: 74
#82
Re: Give Me a Name!
09/10/2010 6:28 PM
OK, lets play. Rough terrain, no explosives. Mad Max for poor people.
Bets any one?
The pink bit is a "Harmonica Suspension". Thought of it and made drawings of it when I was 8 years old. 50 bloody years ago, on a farm in outback Australia where cars were as rare as hens teeth.
Back then it was part of the seats, childish, I know but that's what I thought how it could work. And by now it's developed into something doable. Want to make some CAD's of it Chris? You seem to have nothing else to do but laze about all the time, so you might as well. I'll send you the drawings I have.
Open source? I don't think so, Ky.
The Twain Has Met
Good Answers: 204
#87
In reply to #82
Re: Give Me a Name!
09/10/2010 6:46 PM
What!!? I'm so busy I don't have time to even answer all the posts on this thread...
send me your pictures when you find them.
cheers,
Chris
Good Answers: 213
#111
Re: Give Me a Name!
09/11/2010 7:21 PM
Forget the steering. Lock the wheels for straight ahead only. Omit the central power plant. Mount a rocket on each outer pod. Transport to Bonneville Salt Flats, and test the Land Speed Record...
In reply to #111
Re: Give Me a Name!
09/11/2010 8:50 PM
why stop there.......the only thing missing is wings. :) .......p911
Good Answers: 204
#113
In reply to #112
Re: Give Me a Name!
09/11/2010 10:19 PM
no.. the wings are just too short for flight...and lifting down.
Good Answers: 130
#114
In reply to #113
Re: Give Me a Name!
09/11/2010 10:29 PM
Oh MaLaren!
But Oh Potential!
Good Answers: 204
#115
In reply to #114
Re: Give Me a Name!
09/11/2010 10:37 PM
this is the first render of the half-shell.. more of a rudder-able sail.
but it quickly disappeared as the streamlining increased... rev 2.0
but of course you know I have my own designs on roadable aircraft.
Good Answers: 130
#118
In reply to #115
Re: Give Me a Name!
09/11/2010 11:13 PM
"but of course you know" I can't resist a tease
Good Answers: 213
#116
In reply to #114
Re: Give Me a Name!
09/11/2010 10:45 PM
Already exists:
http://www.terrafugia.com
Good Answers: 213
#117
In reply to #113
Re: Give Me a Name!
09/11/2010 10:46 PM
Not for flying- for setting new land speed records...
Good Answers: 145
#126
Re: Give Me a Name!
09/12/2010 7:11 AM
For a name, how about Quadrollette. (Quad roll aye)
For propulsion, how is this for an idea. As you are going with fly by wire control, what about electric hub motors on each wheel, powered by a diesel driven electric generator(alternator). Perhaps "hybrid" in nature. This would give you the acceleration and throttle response without the nasty lag as experienced in drive by wire cars. The Diesel generator would be constant speed and run on demand whilst the Quadrollette would be in essence a LiFePo4 battery electric vehicle. I can't call it a bike, it is perhaps a "Cycle Car" as defined by various government transport departments.
As an electric hybrid vehicle it may be eligible for government funding or concessions. Just a thought, results may vary with individual countries "greenwash" legislation.
Hub steering is a good idea, but use it for both front and rear wheels. Proportional control in relation to the speed of the vehicle. Low speed maneuvering will want a different treatment to highway speeds.
It looks pretty funky all the same.
In reply to #126
Re: Give Me a Name!
09/12/2010 9:52 PM
Name suggest
Kniphe
Good Answers: 204
#131
In reply to #130
Re: Give Me a Name!
09/12/2010 10:14 PM
that took me a minute... lol
but interesting.
Good Answers: 204
#132
In reply to #126
Re: Give Me a Name!
09/12/2010 10:16 PM
quadrollette.... well um.. I don't want to discourage you.. but that isn't really working for me... sorry.
I do like the idea of this being electric.. but I know knothing about that technology... right now I'm busy reinventing the wheel..
In reply to #132
Re: Give Me a Name!
09/12/2010 11:59 PM
Chris-if you go electric, a whole lot of acceleration-oriented restrictions are mooted, because of the inherent weight of the batteries making high accelerations unattainable. I read somewhere that the highest density energy storage based on weight was in deforming rubber, so an hybrid electric/rubber storage system, with serious attention paid to lightening the design wherever possible could wind up giving you respectable performance: or maybe just lithium hydride cells for storage. Focus on weight reduction will allow a range of possibilities, like . . . fun. Smaller wheel diameters and non-leaning suspension geometries look lighter to me, as well.
In reply to #132
Re: Give Me a Name!
09/13/2010 6:20 PM
Hmm, if you are going to reinvent the wheel go all the way and re-invent the power source. I am leaning towards small nuclear fusion generator electric hybrid, never need to stop that way.
Good Answers: 204
#138
In reply to #137
Re: Give Me a Name!
09/13/2010 6:31 PM
that will have to be next. right now it is all about the leaning suspension system and steering system... but life is chaos.. my girlfriend/partner has just had a granddaughter born today.. (my own was 6 weeks ago) and I'm also supposed to be starting school today (distance ed)... and my brain will hardly let me sleep.. designing things in that half-awake state.... oh dear..
Good Answers: 213
#139
In reply to #138
Re: Give Me a Name!
09/13/2010 7:57 PM
Never, EVER try to design anything when you are fully awake and aware. The best ideas always sneak up on you at that odd hour in the morning when you stumble to the loo, or when you are sitting in the hospital waiting room, waiting for yet another baby to be born, and the only reading material on the table is a 15 year old copy of People Magazine (do NOT touch that magazine! History can be all consuming!!!)
Good Answers: 204
#140
In reply to #139
Re: Give Me a Name!
09/13/2010 10:25 PM
agreed!
Good Answers: 74
#141
In reply to #140
Re: Give Me a Name!
09/13/2010 11:00 PM
Ah, now I get it! When your tired and lack sleep you agree to anything
Congratulations to the new born my friend. Fertile grounds around were you are it seems and not only in the ideas department.
Enjoy Chris, all the best, Ky.
The Twain Has Met
Good Answers: 204
#142
In reply to #141
Re: Give Me a Name!
09/14/2010 12:07 AM
Thanks Ky,
I hope this one is not my fault...lol
we did a little fingerwagging today about fertility... just so they understand how this happens... the first six months is Dangerous.
cheers,
Chris
Good Answers: 123
#144
In reply to #138
Re: Give Me a Name!
09/14/2010 7:26 AM
Congratulations.
I just came back from a few days with my 3 GC at Sea World, and Nickelodeon Hotel.
Bob
Re: Give Me a Name!
09/12/2010 9:06 AM
What about "i-Car" ? People will buy it because it's stylish, and you won't have to bother with any technical detail . Don't blame me, Del pointed out people talking about 'pods'.
Sorry Chris, I'm being cheap and know that you take the engineering aspects seriously. It's a Sunday.
Good Answers: 204
#133
In reply to #127
Re: Give Me a Name!
09/12/2010 10:46 PM
i-CAR...
how bout we put fun-fur on it, and call it the squirrel mobile?
(sorry.. its sunday... I didn't get enough sleep)
In reply to #133
Re: Give Me a Name!
09/13/2010 2:00 AM
I hope you feel severely sorry over the fact that I'm now going to stick pins in my eyeballs ! 'Google-fail'....oh, the shame !
Good Answers: 204
#136
In reply to #135
Re: Give Me a Name!
09/13/2010 2:04 AM
It's worse than you can imagine... the name made me think of Bart Simpson, and Icarumba, and that was what I went searching for...
I'll reset your counter, and give you another opportunity to try again.
Chris
In reply to #136
Re: Give Me a Name!
09/14/2010 3:35 AM
Reset my counter ?!?!!!!!! I am starting to see a new side to your devilish humour, Chris. !
Good Answers: 204
#151
In reply to #143
Re: Give Me a Name!
09/14/2010 4:17 PM
I have my good days when they let me out for some sunshine...
otherwise... I'm unpredictable.
#145
Re: Give Me a Name!
09/14/2010 11:27 AM
Hey Chris how about calling it the razor? It's sleek and doesn't cause much friction.
When you get it all figured out I want one. It looks awesome.
“If you forget you have to struggle for improvement you go backward.”
Good Answers: 204
#149
In reply to #145
Re: Give Me a Name!
09/14/2010 4:11 PM
I like that!... or the Crazor... :)
#152
In reply to #149
Re: Give Me a Name!
09/14/2010 4:28 PM
You read my mind that's originally what I was going to put down.
Good Answers: 74
#153
In reply to #152
Re: Give Me a Name!
09/14/2010 4:38 PM
He does that all the time, even over long distances
The Twain Has Met
Good Answers: 123
#156
In reply to #153
Re: Give Me a Name!
09/14/2010 11:34 PM
(I have been wearing a lead shield inside my foil hat to try to prevent him from reading my mind. Another trick I have been practicing is to try to think only in pig latin. I don't think Chris can read pig latin.)
Bob
#157
In reply to #156
Re: Give Me a Name!
09/15/2010 12:11 AM
Oy vey! Oyez! oyay esyay Iay ancay! Snort
Good Answers: 74
#158
In reply to #157
Re: Give Me a Name!
09/15/2010 1:14 AM
Well, nothing surprises me any more. So you do! Did you know that leader pigs don't drink alcohol? Tests have been done to prove that. No, really! Have one on me, Ky.
The Twain Has Met
Good Answers: 204
#161
In reply to #158
Re: Give Me a Name!
09/15/2010 1:51 AM
sorry that wasn't me... I seem to have acquired an alter ego...lol
Good Answers: 74
#162
In reply to #161
Re: Give Me a Name!
09/15/2010 2:01 AM
Must have been my platinum coated titanium hat. Needs servicing I suppose.
The Twain Has Met
Good Answers: 123
#146
Re: Give Me a Name!
09/14/2010 11:58 AM
Chris, I promised more information on the rotary actuators. http://www.helac.com/actuators/
I delivered. Cheers.
Bob
Good Answers: 204
#150
In reply to #146
Re: Give Me a Name!
09/14/2010 4:12 PM
awesome...
Good Answers: 123
#155
In reply to #150
Re: Give Me a Name!
09/14/2010 11:27 PM
The design incorporates limited rotation ability along with a very rugged bearing assembly, and no protrusions like the rack and pinion style rotators.
A low hight McPherson strut with the rotator on the bottom could cover all of the front geometry except the leaning associated with 2 wheeled vehicles. And the only connection would be hydraulic hoses.
Bob
#147
Re: Give Me a Name!
09/14/2010 2:05 PM
That's a nice looking futuristic single passenger automobile AKA Car. However, it is not a motorcycle because it has 4 wheels. A motorcycle has 2 wheels and operates under the gyro principal.
Good Answers: 37
#148
In reply to #147
Re: Give Me a Name!
09/14/2010 2:20 PM
In many jurisdictions, three-wheeled vehicles, especially smaller ones, are also motorcycles, by law [licensing]. Three-wheeled roadgoing vehicles don't typically utilize the gyro effect to any significant degree. Some lean into corners, and others don't.
Having four wheels does usually disqualify vehicles from being licensed as motorcycles, granted.
" Ignorance and arrogance have more in common than their last four letters. "
In reply to #147
Re: Give Me a Name!
09/14/2010 7:29 PM
I thought motorcycle operates much like all other motorized vehicle by use of a engine and either a drive shaft of chain/belt that transfer the power to a wheel which then transfer tha power to the pavement surface. So what does the gyroscopic priciple have to do with how it operates?
Good Answers: 130
#159
In reply to #154
Re: Give Me a Name!
09/15/2010 1:30 AM
Well - it's obvious.
When you turn the steering the gyroscopic reaction tilts the bike - yes?
But "forgotten" is; this tilts the rear wheel (gyroscope) too.
And That Means; the only resolution of that gyroscopic force must be to force the frame 'forward'.
I can't believe you people don't know these things!
I mean, look; this guy stays upright purely by gyro-motor!
Good Answers: 74
#160
In reply to #159
Re: Give Me a Name!
09/15/2010 1:49 AM
He's not moving how ever hard I press that pointy finger, cursor. He is getting nowhere real fast it seems. Is it that I am missing something? Ah, you want me to read!?
I'm out of here, Ky.
The Twain Has Met
Good Answers: 119
#163
In reply to #154
Re: Give Me a Name!
09/15/2010 8:33 AM
To add to what 34.5 said:
It's called precession. To turn a motorcycle at speed, you push on the left handgrip to turn left, right to turn right. The great unwashed think that pushing on the left would make you turn right (which is true at very low speeds) but thanks to precession makes a two wheeler respond just like a gyro.
Hooker
Good Answers: 119
#164
Re: Give Me a Name!
09/15/2010 10:42 AM
Chris,
Kudos to ya for a beautiful design of a new "vehicle".
But... a motorcycle it ain't. A bike is more than the number of wheels, or the suspension or the steering controls or that it has open seating vrs something with roll up windows.
Let me extrapolate a bit if I may:
My bike (almost) never goes on high speed highways (like US interstates). Even my GPS is set to avoid major highways for trip planning. On the bike I am always on minor highways or back roads even on long distance trips. On those roads, when I have sight distance, a bike can be thought of as an wingless two wheel low level "Flyer" (to steal from the Wright Brothers) rather than an earthbound method to get somewhere. I have control of an axis (lean) that can work to my advantage that is simply a side effect in a four wheeler. I can really power through the road, taking advantage of every inch available and exploiting the advantages that only two wheelers have. I can become one with the machine: I don't have to think about the mechanics or the techniques of manipulating the machine, I just do.
So, while it would be neat to have a machine like the one you've portrayed above, it would have a very different draw and use in my life from my two wheeler.
Hooker
#165
In reply to #164
Re: Give Me a Name!
09/15/2010 11:00 AM
No matter what you call it though, the Crazor is still an awesome machine.
I would sure like to cruze around in one. I think it's a nice piece of work and hope it gets built. It's nice to see someones Idea on paper be brought to life and made a reality, so many don't. Keep the idea alive Chris and build one, or two, I'll take the extra one and do it justice.
Good Answers: 119
#166
In reply to #165
Re: Give Me a Name!
09/15/2010 11:25 AM
I agree, it does look awesome and I'd love to drive it, too.
But that wasn't my point!! It won't "replace" my motorcycle, any more than a personal watercraft would replace a towed ski. They are different experiences. And that is a good thing!!!
Hooker
Good Answers: 204
#168
In reply to #165
Re: Give Me a Name!
09/15/2010 2:41 PM
there is a tiny glimmer of hope...
I don't have your email address... it looks so much cooler as wallpaper. I can send you 2732 x 1536 pixels.. pm me.
Chris
Good Answers: 204
#167
In reply to #164
Re: Give Me a Name!
09/15/2010 2:40 PM
so poetic!
and most people don't understand the relationship between man and machine... you have just captured it...
great stuff.
so um... which is better for your soul... motorcycle or helicopter?
Good Answers: 119
#169
In reply to #167
Re: Give Me a Name!
09/15/2010 2:55 PM
Ummm.... ahhhh.... errr....
Very tough question!!!!!
Let's just say that because the cost of acquiring a helicopter ticket and the additional cost of operating a helicopter is far beyond my pocketbook, the motorcycle will have to do.
In spirit, if not in fact. Imagination can be a wonderful thing.
Hooker (oh, and the need for altitude can be met by the occasional rental of a sailplane to be flown on a sport license, if I really need to)
Good Answers: 204
#171
In reply to #169
Re: Give Me a Name!
09/15/2010 3:20 PM
heard about the Biplane?
Good Answers: 130
#175
In reply to #171
Re: Give Me a Name!
09/15/2010 10:07 PM
I like the bars on that - good for keeping sticks and thorny stuff of your hands in the bush. (the Yamaha 250 Ag bike got them too, but I guess these ones are for pedestrians, hence - pre-colored)
Good Answers: 130
#177
In reply to #175
Re: Give Me a Name!
09/15/2010 11:25 PM
Ummm - Tesseract - nice rendering - wouldn't want it to be a wet day, or a dirt road, though - or have to carry any gear. But She might have a good time (short term)
Piaggio - I wonder when I see these things; "how difficult is it really to put your feet down or flick out a stand?"
Good Answers: 119
#182
In reply to #171
Re: Give Me a Name!
09/16/2010 9:21 AM
That Biplane is pretty cool looking machine, but I'm not really into George Jetson style machines for my personal use. Here's my kind of ride, classic all the way.
It's a Honda Shadow Aero, long, low and sleek. My one concession to contemporary or futuristic features is my motorcycle gps.
Hooker
Good Answers: 266
#170
Re: Give Me a Name!
09/15/2010 3:12 PM
I was wonder why this one wasn't mentioned.
The T-Rex
http://www.youtube.com/watch?v=iluIZqOFYCA
Good Answers: 204
#172
In reply to #170
Re: Give Me a Name!
09/15/2010 3:23 PM
T-Rex is cool... but not an open cockpit design like a bike, snowmobile, or watercraft. (which was one of my criteria) I had a girlfriend a few years ago, and she told me that her "Harley was the best vibrator money can buy."
Chris
In reply to #172
Re: Give Me a Name!
09/15/2010 5:17 PM
Well, without any doubt you're an engineer. One might assume this was during your teens ? If otherwise, plaese go and beg a place on the naughty step (it's rather crowded).
Good Answers: 204
#174
In reply to #173
Re: Give Me a Name!
09/15/2010 6:16 PM
not an engineer. yes naughty at times. no not a teenager... 45 then. (girlfriend for lack of a better term) Proud to be on the naughty world step
chris
Good Answers: 123
#176
In reply to #174
Re: Give Me a Name!
09/15/2010 10:18 PM
Oh look. All my friends are on the step with me.
Bob
Good Answers: 204
#178
Re: Give Me a Name!
09/16/2010 3:46 AM
another interesting vehicle
Chris
Good Answers: 123
#180
In reply to #178
Re: Give Me a Name!
09/16/2010 9:08 AM
I am not a bike rider to begin with. But one that makes no sound seems like a magnet for slow turists in Florida looking for an accident.
Bob
Good Answers: 204
#179
Re: Give Me a Name!
09/16/2010 4:13 AM
this is pretty sick... the Hubless Monster.
Good Answers: 123
#181
In reply to #179
Re: Give Me a Name!
09/16/2010 9:16 AM
The bearing in this looks like a larger version of a bearing user in older design roof turrets. I bought one about 12 years ago. It was made by a company called Kadon (?). And then my 6 in. bearing was $600 plus.
Bob
Good Answers: 37
#184
In reply to #181
Re: Give Me a Name!
09/16/2010 10:55 AM
"... company called Kadon (?)" Close - it's Kaydon: see http://www.kaydonbearings.com/
Good Answers: 123
#187
In reply to #184
Re: Give Me a Name!
09/16/2010 11:59 AM
Thanks.
Friend-fiend, what's the difference, I was close.
Bob
Good Answers: 37
#188
In reply to #187
Re: Give Me a Name!
09/16/2010 1:46 PM
"Friend-fiend, what's the difference, I was close." Hmmmm - true. Also true that "close" and "lose" differ by just a single letter! [OK, that was rude of me . . .]
But I had in mind to note the real name just in case anyone wanted to find such bearings. Didn't check whether Google would offer the added-Y version if you searched on "Kadon." Don't think that the average person would think to try adding it on their own!
Good Answers: 123
#190
In reply to #188
Re: Give Me a Name!
09/16/2010 9:49 PM
I just want to know how long ago you dealt with Kaydon. I dealt with them many years ago, and thought I was damn sharp to remember their name. I have always sucked at spelling. Just in case I was feeling good about remembering some small detail about an event that took place so many years ago, you had to come along and announce "HEY, BOB CAN'T SPELL WORTH A CRAP!
Thanks for sharing that. Have a sunsational day.
Bob
Good Answers: 130
#191
In reply to #190
Re: Give Me a Name!
09/16/2010 10:25 PM
Just wait 'till Ron types form instead of from, again.
Good Answers: 74
#195
In reply to #191
Re: Give Me a Name!
09/17/2010 2:27 PM
For you, there should be a sin tax introduced.
I see nussing, vich akcent?
The Twain Has Met
Good Answers: 37
#196
In reply to #191
Re: Give Me a Name!
09/17/2010 2:37 PM
My typing stinks - always has. Pretty much in keeping with my lack of dexterity in general. The only place where I seriously beat the average - and in most sports, etc. I can't even approach the average - is working with very tiny things, such as building stuff under the microscope. So you can pretty well count on seeing from/form and similar in my posts.
Good Answers: 204
#193
In reply to #190
Re: Give Me a Name!
09/17/2010 12:23 AM
I just got home.. been on the run all day... long day.. thank you for the splarf on my keyboard...
Good Answers: 123
#213
In reply to #193
Re: Give Me a Name!
09/18/2010 11:52 PM
Think nothing of it.
Your comfort means everything to me.
Bob
Good Answers: 37
#194
In reply to #190
Re: Give Me a Name!
09/17/2010 11:51 AM
Actually, I have never dealt with Kaydon, nor any competitors of theirs. I recognized the name, and just double-checked that they had a website before replying. I've never built anything that called for such bearings, with a single exception.* I've certainly had ideas for large rotating items, but either there was no follow-through, or there were conflicting requirements, such as that the bearing had to be non-metallic or non-conductive (*see http://cr4.globalspec.com/thread/59758/Manually-Operated-Rotating-Platform, which will explain that "single exception" and what I did).
As far as my announcing anything with regard to your spelling prowess: didn't you self-declare by putting that question mark in parentheses following "Kadon" in your earlier post? I've bin lukky in alwais finding speling verry easee . . .
Good Answers: 114
#185
In reply to #179
Re: Give Me a Name!
09/16/2010 11:13 AM
I pondered turning the wheel/rim into the armature of an electric motor
Since it's a flight of fancy, might as well use room temperature super conducting wire & what ever unobtainum sounds like fun :D Which brings up questions of:
How to attach the tire?
How efficient can it be with the less the ideal field shape?
Good Answers: 74
#189
In reply to #185
Re: Give Me a Name!
09/16/2010 2:54 PM
Like this one?
http://www.youtube.com/watch?v=zPSoNfmuBXc
I had thought of it, in principle, years and years ago. Somethings in the air tonight, Ky.
The Twain Has Met
Good Answers: 114
#192
In reply to #189
Re: Give Me a Name!
09/17/2010 12:03 AM
yaeh I trot that one out from time to time, mostly I would get Puzzled dog look [tilts head quizzically]
trick would be how not to increase the unsprung weight
I imagine rim or spokes as winding
lots of cool things that could be done with freq drives, regenerative braking.
on a different note, you won't see any hubless rims on any thing but foo foo choppers, too heavy & a real amount of side play...
Good Answers: 76
#183
Re: Give Me a Name!
09/16/2010 10:34 AM
Good Answers: 123
#186
In reply to #183
Re: Give Me a Name!
09/16/2010 11:56 AM
In case anyone failed to read the article, the winning vehicle got 102 miles per gallon from a modified IC engine running on E-85. No electric motor. 4 passenger car with air conditioning.
So why are we waisting time and money trying to improve an obsolete IC design? The Edison2 above is why.
Bob
Good Answers: 117
#197
Re: Give Me a Name!
09/18/2010 1:38 AM
The Tron Legacy Bike at Fan Expo in Toronto 2009. Must steer like a Dyson Vacuum Cleaner.
Good Answers: 204
#198
In reply to #197
Re: Give Me a Name!
09/18/2010 2:13 AM
I'm looking forward to it.
Good Answers: 130
#199
In reply to #197
Re: Give Me a Name!
09/18/2010 2:28 AM
No - Dyson's can steer.
What would guess the maximum lean at ? 200
Now ask "why does a flat belt center on a domed pulley?"
Good grief - just as well it's "massless"
(now where is that
Register to Reply Page 2 of 3: « First < Prev 1 2 3 Next > Last »
34point5 (24); Anonymous Poster (2); bob c (21); bwire (1); chrisg288 (85); cwarner7_11 (12); Drew K (7); Ed Weldon (4); garagedetailer (1); Garthh (26); guds777 (2); Hooker (5); JavaHead (2); Jim C (2); kramarat (3); Kris (11); ky (25); mrclean (3); msm98lw (1); naturalextraction (1); ozzb (1); phoenix911 (10); RCE (8); Robert Laurin (1); Ron (11); Tobugrynbak (1); Tornado (1); U V (2); Usbport (1); woodpower (4); Yusef1 (10)
You might be interested in: Diamond Tools and Wheel Dressers, Contact Wheels
