Previous in Blog: Projectiles: Newsletter Challenge (04/01/08)   Next in Blog: Trisection: CR4 Challenge (04/15/08)
Page 5 of 7: « First < Prev 3 4 5 6 7 Next > Last »
Fixing The Pump: CR4 Challenge (04/08/08)
Posted April 06, 2008 5:01 PM
Tom's basement has a shallow sump pit and a pump. The pump is attached to a 25ft garden hose which empties into a drain 8 ft away. One day Tom and John were in the basement when Tom mentioned that the pump just isn't working fast enough and that he needs to buy a slightly stronger one. John says he has a cheaper solution, disappears upstairs for a minute, returns, and fixes the problem. What did John do?
And the Answer is....
John went upstairs to the kitchen for a knife came down and cut the hose in half. According to Poiseuille's Equation, this should double the flow. The pump should be fast enough now.
In reply to #280
Find in discussion
Re: Fixing The Pump: CR4 Challenge (04/08/08)
04/19/2008 4:01 AM
You'll be back !
With the uncut pipe, adding a 52" stand-pipe reduced flow by 0.0054132 g/s. If I ignore the extra friction loss, I'm thinking a 90' stand-pipe would stop the flow totally. I'm having to prime my hose for some unknown reason.... Got to go because my neighbour is asking why his kitchen tap just blew.
#283
In reply to #280
Find in discussion
04/19/2008 11:56 AM
Am I the only one here who would be worried if the flow-rate into my basement exceeded 5-gallons/minute?
In reply to #283
04/19/2008 2:07 PM
I'd be pleased - my kitchen tap is only dribbling 9l/min. The steel supply pipe is more furred-up than my arteries.
In reply to #284
04/20/2008 6:52 AM
What would happen if you devised an ultrasonic transducer that would screw onto the tap and knock the fuzz out of the pipes? How far would sound waves travel down a small encrusted channel?
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
In reply to #285
04/20/2008 7:36 AM
It's an interesting thought, but I suspect I'd end up flooded. My use of the word 'furred' was a bit misleading; Although the water where I live is 'hard' (out of chalk aquifers I think), the pipe is rusted up real nasty. A length of about 8m is reducing flow from about 27l/min down to 9 ! It's awkward to fit a new one, so I keep putting off the inevitable. It has to be 2 1/2 feet u/g for the distance outside the house and 2 1/2 inside. The annoying bit is going to be waiting for the water company to give an OK to how well the work is done before I can reconnect to their mains (assuming I tell them what I'm doing ). When the weather has warmed up in a few months I'll probably do it, that way I can enjoy a beer in the sun whilst I wait for the water company to turn up.
#287
In reply to #286
04/20/2008 10:00 AM
A beer? If true, I'm prepared to relocate.
But maybe you better fill every sound vessel in the house before starting, and then sit in the shade.
In reply to #287
04/20/2008 11:01 AM
Hee hee....a keg of beer ! I haven't been reading all this stuff about pumping cellars dry to save some silly sod's house from flood ! My triangular calculations on the 25' pipe length had it's purpose.
#278
04/18/2008 10:42 PM
Cannot you just publish whatever the answer is supposed to be, and kill this thread?
Repetitive as hell on a problem that lacks the detail needed to be meaningful --- everybody is making assumptions---
04/20/2008 8:09 PM
Curioser and curioser, said Alice (or whoever).
I've run into a problem with the numerical values reported by Skeeter in post 254.
The experiment shows that the flow rate increases from about 25 lpm to 33 lpm when the discharge hose is shortened from 25 ft to 12.5 ft. (I'm ignoring the additional data on drain simulation which I didn't quite understand.)
Since the pump rated capacity is given as 80 lpm, it seems to me that rather than Tom, it is Skeeter who has a pump which is challenged, and quite severely too!
Obviously we need more data to figure out this one, which is a more tangible challenge than the original, and we can hopefully rely on Skeeter to fill in the gaps.
I am presuming that the 'sump pump' being referred to is an ordinary centrifugal pump with radial flow impeller. Possibly it is also one of the self-priming types, in which case the efficiency may be rather low, but a foot valve can be avoided. If the pump is of some other kind I'll probably have to eat my words, though I'm not volunteering to eat any of the hose.
The 80 lpm is probably a maximum, which goes with a head of say 6m or 8m, and the capacity would drop to say 40 lpm at a head of say 15 or 20m. I am used to seeing pump specifications given in this manner (usually a number of head vs. discharge values in pairs -- the characteristic curve). Sometimes the data may be just one pair of values at the best efficiency point. The motor rating and speed are always specified, and for an engineer, all these are important in order to make a proper pump selection.
So if everyone hasn't yet abandoned this thread in sheer disgust, I would request Skeeter to furnish whatever additional information he has on the pump that was used, and also the relative heights at which the large container, the pump, and the bucket were placed. Was an inlet strainer used? What about a check valve at the discharge?
With the known flow rates, the pressure drop at each element external to the pump can be estimated.
It would appear to me that the pump was working against little or no static head (possibly even negative), and unless the pump output was severely throttled, it would be so large as to trip the motor (or even burn it out if not adequately protected against overload). The mystery can be cleared once the data is in.
With regard to the original challenge, I appreciate the logic behind Roger Pink's defence of the official solution. But not entirely. I simply cannot support the use of Poiseuille's law the way it was quoted, as it is likely to send the wrong signals to those who may just read the CR4 challenge question and answer (and have no time to wade through the interminable 'discussion').
Encouraging the use of physical or engineering laws in such an approximate way is surely irresponsible. Engineers should certainly know where accuracy or precision are called for, but I consider the official answer to be a misplaced approximation. I always thought of Poiseuille's Law as something in physics which has applications in capillary flow, whereas engineers are more likely to use Bernoulli's principle, and the charts for flow losses in pipes, for dealing with pump flow problems.
The last word in pump fixing has not yet been written despite nearly 300 posts.
=TeeSquare=
04/20/2008 8:52 PM
The number of posts on a question any plumber could have fixed by now is the reason we don't hire engineers to deal with plumbing issues. At the current 'rate' of fixes, we'd have gone through about 4 kegs of guiness and 500 man-hours (50 man-hours sober).
Now do we understand why engineer's are only called in to design things, not fix them?
#294
In reply to #291
04/22/2008 10:44 PM
I'm fascinated by the 'who-evers law, principal,' or whatever. I wonder though how many of those replying have ever installed a pump driven system such as we use in rural areas?
I have setup more than a few. You look at the water source, — sometimes a creek, sometimes an off the roof collection tank, sometime a combination system — look for an appropriate spot for your header tank that will provide sufficient pressure — here in Australia that means enough pressure to do the preliminary defence against bush fire, without the use of a fire pump, and set it up.
The most common mistake that people make is to 'save money' on the pipe diameter selection. Without question to extract maximum lift capacity from a pump — or minimise the load on the pump motor — requires a two inch (50mm) pipe on the commonly used impeller type 'fire pumps', which is the size of the outlet on some, ½ inch larger than others, and 1 ½ inch on positive displacement pumps with 1 inch outlets.
Agricultural 'Poly pipe', a black flexible 'plastic' is the most commonly used piping.
In reply to #291
04/23/2008 3:31 AM
A Mechanic is called upon to solve the problem and, after a moment scratching his ****, hit the pump with a hammer so as to free the impeller. In the same situation, an Engineer will draw upon his many years of University study, calculate the necessary flow parameters and, using his reference book of material properties, produce a fully flow-charted solution strategy. Then he'll hit the pump with a hammer so as to free the impeller.
#296
In reply to #295
04/23/2008 4:33 AM
You omitted a caveat: the mechanic will have done this before, and know where and how to hit. The engineer, being more of a generalist, will not have these skills; so he will almost certainly end up breaking the casing. (I'm speaking for myself here, of course).
That is why I do not go along with Lord Finchley in areas where I lack experience...
In reply to #296
04/23/2008 5:43 AM
LOL - I never heard that before !
In reply to #296
04/23/2008 1:22 PM
O-M-G! A physicist wot reads poertry? And they said this thread 'ad gone on too long! Wotta "they" know? If it'd stopped a moment sooner, we'd nivver 'a knowed this little fact, eh?!?
#303
In reply to #299
04/23/2008 3:23 PM
Poetry - no problem - but reading - now that is going too far.
In any event, I'm a very querylous physicist.
Fyz
In reply to #303
04/23/2008 3:54 PM
Regarding reading, then...
"LO! in thine honest eyes I read
The auspicious beacon that shall lead,
After long sailing in deep seas,
To quiet havens in June ease."
- R.L. Stevenson (yes, Robert Louis...)
Good Answers: 22
#302
In reply to #296
04/23/2008 2:00 PM
If the engineer is cautious enough to create a flow-charted action plan, he will be cautious when he starts to act.
He will lightly tap on the pump at various places with no results. He becomes frustrated and starts banging away recklessly. Because he is unaccustomed to vigorous exercise, he doesn't have the strength to break the casing. He does put a few scars in it.
He eventually disassembles the pump. He loses several critical parts and manages to shred all the gaskets and seals in his frustration. He sets out to find the parts needed to repair the pump. He returns empty-handed to eat lunch and re-evaluate things.
He leaves again, but soon returns with a new pump that doesn't work any better than the old one.
He turns to his most valuable engineering resource, CR4. He finds this thread, reads the official answer, and then his wife calls the men in white coats as he repeatedly bangs his head against the computer monitor.
In reply to #302
04/23/2008 4:21 PM
LOL ! My science teacher once gave us a homework assignment to describe how a toilet cistern worked. Upon collecting the homework he said, "mine's busted, and I wanted to see how they work before I risked taking it to bits !" . Obviously he knew, but it was a good teaching strategy - he got us to learn. Trouble is, or maybe not, we all got a liking for doing such things.
In reply to #305
04/23/2008 4:33 PM
So I take it you now have a compulsion for dismantling toilet cisterns. Well, they say everybody's got to have a hobby...
In reply to #306
04/23/2008 4:40 PM
I diverted to the bat soemthing else once ! NO, No....no....whimper....I won't go there again....
#308
In reply to #307
04/23/2008 4:47 PM
Is that the one that was demolished, or was that someone else? Whichever, surely the area is safe again by now?
(I for one shall refuse to speak to you until you've had that bath or equivalent)
In reply to #308
04/24/2008 5:40 AM
I have a brisk rub-down with a wire brush each day !
In reply to #313
04/24/2008 12:44 PM
I know one of your kin, then...
In reply to #315
04/24/2008 1:10 PM
He's got my hat !
In reply to #321
04/24/2008 3:12 PM
'Twas only borrowed, here 'tis back...
In reply to #307
04/23/2008 5:01 PM
No, no! Dismantling bats is right out! They're all protected species, y'know...well, with maybe this one exception...
Good Answers: 22
#311
In reply to #309
04/24/2008 12:36 AM
I wish aluminum bats were an endangered species! That, and the DH.
#312
In reply to #311
04/24/2008 4:41 AM
Stop this, you're driving me... around the twist
In reply to #312
04/24/2008 12:53 PM
You must be nearly home by now then. Isn't your address still 3Σ3 Möbius Strip?
#323
In reply to #317
04/24/2008 4:07 PM
No, that's the address of my club. I thought it was confidential.
United Kingdom - Member - New Member Hobbies - Musician - New Member Engineering Fields - Mechanical Engineering - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member Hobbies - Fishing - New Member
Location: South-east corner of Spain 50 48 49.24N 2 28 27.70W
In reply to #323
04/24/2008 4:25 PM
The shits going to hit the fan Gentlemen! May I suggest we raise the umbrellas?
“It's kind of fun to do the impossible.” Walt Disney
#326
In reply to #324
04/24/2008 4:47 PM
So that's what the pump was really for - no wonder the hose got clogged.
In reply to #326
04/24/2008 5:20 PM
Just wait for the back pressure to build up a bit and............whoooosh!
There's the answer! John went upstairs to get a fan and some umbrellas! He knew that the bulge in the hose pipe was a sure sign of trouble! Only the week before had he installed a booster pump to pump out the larger debris! Something had to give and he wanted a ringside seat!!
In reply to #323
04/24/2008 5:57 PM
Now, now, don't get all physical just because I got a little psychical... So it's a strip club, no problem - we're all entitled to a little fun!
In reply to #311
04/24/2008 12:47 PM
Ahhh-hh, another purist! I root for the Royals; you?
Good Answers: 22
#325
In reply to #316
04/24/2008 4:37 PM
The Cardinals! Red Auerbach, Enos Slaughter, Stan "The Man" Musial, Bob Gibson, Whitey Herzog, Ozzie Smith, Willie McGee, and one of the greatest voices in baseball: Jack Buck, need I say more?
How can you call yourself a purist if you root for a team with a DH? I'm not being mean or picky, I just want an explanation.
In reply to #325
04/24/2008 6:06 PM
I always rooted for the St. Louis Cardinals, but where I grew up (Iowa), when KC got a team it was closer, so naturally we got to see a game once in a while, so I became a Royals fan. Now the Cardinals are in Arid-zona, and it just ain't the same anymore. I also like the Detroit Tigers, but I guess I'll have to become a fan of some Florida team now that I live here...we have tickets to a pre-season Tampa Rays game, so maybe that will soak in, who knows?
Good Answers: 22
#330
In reply to #329
04/24/2008 8:29 PM
I can understand the regional loyalty. Many baseball fans here in the Tulsa area are St. Louis Cardinals fans because the original local Texas League team was a St. Louis affiliate for a while. And the baseball Cardinals are still in St. Louis! You must have gotten the baseball Cardinals confused with the football Cardinals.
Maybe you shouldn't spend so much time in bars, strip or otherwise.
In reply to #330
04/25/2008 7:35 AM
Just chalk one up to a late-in-the-day mental irregularity...
BTW, EnviroMrs. is a Tulsa native, that's where we met, and up until about 2 years ago, we lived on the far east side - on Lynn Lane just south of the Skelly Exp'way.
#310
In reply to #305
04/23/2008 8:22 PM
Long ago I was explaining to a young woman that the reason that a tradesman had an apprentice was so that if a builder/carpenter, for instance, got called to a problem with a floor where you couldn't get a look underneath it, you gave it to the apprentice. Once he had opened it up, so you could see the problem, you said: ' yes, not too bad, but if you had used your head you could simply have done this and this', and if the problem was not yet apparent, simply: 'Mmm, yes ', and left it until you could see the problem.
She used the most unladylike of language in describing me and didn't speak to me for weeks!
(I was an apprentice mechanic, and they learned not to do such things to me. My response was anything up to the total dismantling of the vehicle, with utterly unjustified certainty that I could reassemble it!)
In reply to #310
04/24/2008 12:55 PM
"...the most unladylike of language..."
Perhaps she was thinking of her own apprentice?
In reply to #291
04/23/2008 1:50 PM
4 kegs of the big G, and we'd stay sober for 50 hours? You have GOT to be joking!
Aye, lads, 4 kegs - we've a night's work ahead of us, we'd best get started!
#338
04/27/2008 8:03 PM
Tom sported a hose much too long,
And his pumping rate just wasn't strong
Enough. So his friend
Just chopped off the end,
And our Hero burst forth into song.
(Much too tame an ending, wot?)
But it didn't set matters at rest
In spite of the great Skeeter test.
The Poiseuille Law link
Stoutly championed by Pink
Elicited howls of protest.
Then Skeeter in turn found his work
Being closely examined for murk.
It's all inconsistent,
Claimed Tee Square persistent,
With more than the hint of a smirk.
We have not reached the end of this quest.
That we got thus far, who would have guessed?
While Skeeter engages
Tee square's wordy rages,
I'll sign off.
Yours faithfully,
There's still a long way to the 400 mark. Where are the CR4 laureates (ba/el, EnviroMan, from dumbbells)? Surely they can improve on that. Physicist also deserves mention in verse, but he's currently preoccupied with the trisection of angles rather than hoses. Can limericks be at least as challenging as Tom's pump!
04/29/2008 8:11 PM
Following my analysis of the data on Skeeter's experiment (posts 254 & 335), my verdict in short is that the pump and experimental rig cannot be faulted for any inconsistent behaviour, based on the fairly exhaustive information provided. So I must now take back my earlier accusations!
It should of course be understood that such situations do not permit any precise analysis. Some 20 to 30% variation between theory and practice can be considered acceptable, because a large number of sometimes questionable assumptions may have to be made, apart from measurement errors and doubts regarding the validity of equipment specifications.
Nevertheless let me try to present my findings in a manner which I hope will be of interest to at least a few CR4 readers who haven't yet given up on this thread.
Assumptions regarding the experimental set-up
The pump is a self-priming centrifugal type with radial flow impeller. Connection size is not indicated, but I have assumed that 'garden hose' of 5/8" nominal size having 16 mm ID has been used for inlet and discharge.
About 1 m of hose has been considered at the inlet, without any foot valve or strainer. In the discharge line, a Y-hose coupling connects to a pressure gauge. What the pressure reading represents is a bit uncertain, as a part of the velocity head may also get measured. A 'side' tapping or tee branch would have been preferable, but this is a minor issue.
Since the main container, pump and bucket are at about the same level, it is assumed that the pump does not have to overcome any static head (level increase from suction pool to discharge point).
One bit of information I have ignored is the discharge hose going over the edge of the large container. I presume this is a physical layout constraint -- maybe the pump was near a wall and the container had to be placed in front of it, which is anyway convenient for the 'open discharge' test. (Any possibility of the pump being placed inside has not been considered.)
Assumption relating to the calculations
Data about the pump itself is rather meagre. Rated flow is mentioned as 80 lpm, which probably refers to a state of free discharge from the outlet. Maximum head is given as 7 m water column (abbreviated as mWC hereafter), but the corresponding flow rate is not indicated.
Motor data is missing, but my guess is that it would be a two-pole cage motor which at 60 Hz supply (in the US) would run at about 3400 rpm. Power rating may be 1/4 or 1/3 HP as a rough guess, considering that a self-priming pump typically incorporates a vortex chamber and will have a low hydraulic efficiency because of the complex flow pattern within the pump casing.
Calculation of flow losses in pipes requires a whole set of assumptions. Kinematic viscosity of water is 0.8 cSt (or mm2/s) at 30°C. The hose has an internal roughness of 0.3 mm, for which the Colebrook chart yields a friction coefficient of about 0.05 for turbulent flow in rough pipes at Reynolds numbers over 45000 or so. Some of these values could be questioned. By the way, the French apparently have a name for the SI unit of dynamic viscosity -- what else but Poiseuille!
Results
I am skipping all the tedious working and presenting just a summary (do I hear sighs of relief?). If perchance somebody checks it all out and arrives convincingly at substantially different conclusions, I'll agree to any reasonable form of penance. (My difficulty lies in finding someone who is willing to cross-check my work -- it is a tricky business, as pointed out in the Projectiles thread, posts 60 to 62.)
In the absence of adequate pump data it is not possible to calculate what the flow rates 'should' be. What is presented below is a selection of parameters which I feel are relevant, corresponding to the measured flow rates of 30 and 40 lpm, plus 80 lpm assumed for free discharge. The working is in the metric system, with a few fps equivalents.
For brevity in presentation, the three numerical values for each parameter are just separated by a slash.
1.) Length of discharge hose (m) 7.6 / 3.8 / (negligible)
2.) Total length of inlet+discharge line (m) 8.6 / 4.8 / 1.0
3.) Flow rate (lpm) 30 / 40 / 80
4.) Mean flow velocity in pipe (m/s) 2.5 / 3.3 / 6.6
5.) Head loss due to pipe friction (mWC) 8.5 / 8.4 / 7.0
6.) Velocity head (free discharge loss) (mWC) 0.3 / 0.6 / 2.2
7.) Total pump head reqd. (mWC) 8.8 / 9.0 / 9.2
8.) Theor. power [flow × pressure] (Watt) ~45 / ~60 / ~105
8a.) " " (HP) ~0.06 / ~0.080 / ~0.14
9.) Estimated pressure at discharge port (mWC) 7.8 / 7.2 / 2.2
9a.) " " " " " (psig) 11.1 / 10.3 / 3.2
10.) Measured pressure at Y-branch (psig) 8.8 / 7.2 / 2.1
The correlation between the last two lines can be taken as reasonable, considering all the uncertainties and assumptions involved.
Concluding Remarks
Reducing the flow losses in the discharge line from a radial impeller pump (or blower) for increasing the flow rate should not be resorted to blindly. If the unit is already delivering its maximum rated flow (usually difficult to measure in practice) any further increase could lead to motor overload (tripping or burn-out). In the case of Tom's pump, he presumably had reason enough to expect a higher discharge based on past experience. But it's not a fit case for simplistic generalisation.
On the same general topic of flow and head, the problem of emptying an overhead tank is probably too well known to be posed as a CR4 challenge. Will it empty faster if the water is discharged directly from the outlet, or when it flows through a pipe leading down to ground level?
To digress a bit (more), as is my wont, I make no claim of being a specialist or expert in turbomachines, but I've picked up some essentials of relating catalogue data to real situations, by having had to deal with a variety of pump/fan/blower installations.
I studied the subject long ago under a German professor whose knowledge and experience were indeed fantastic. Indeed I acquired much of my general design knowledge in between the lines of his lectures and by studying the diagrams of impeller profiles or pump components he drew on the blackboard, so effortlessly it seemed. Not many of my classmates took him seriously though, and some made fun of his accent. But I realised then itself that my mathematical limitations (coping with 3-D flow equations, vortex theory, boundary layers, ...) would prevent me from choosing that line as a career. I just stuck to simple general purpose mechanical engineering using conventional machine elements, and no regrets about that. If people today think my knowledge is outdated, that's their problem. I've immensely enjoyed my professional life, even though no one can accuse me of being a 'success', and I'm not too worried about my inability to communicate in computerese with the present generation.
=TeeSquare=
Reply Good Answer (Score 4)
Good Answers: 22
#376
05/01/2008 11:13 PM
I think this thread has gone on long enough that it is about time for Tom to install a whole new sump pump and drainage system so his house will be in salable condition. He needs to sell it so he can move into a retirement center.
#377
In reply to #376
05/02/2008 6:15 AM
Tom Tom the Piper's son
Pumped a pump - let the water run
The pipe got cut
(Let the water suck)
Do you really think we give a damn?
05/03/2008 8:08 PM
I've noticed that my post 348 has acquired a GA rating. Since that indicates it was of some interest to a few readers at least, let me add a few remarks.
The whole business of selecting a pump (or fan or blower -- a turbomachine in general) to perform a specific duty, or predicting the performance of a given pump, cannot in general be accomplished by a clear once-through procedure. In practice the level of uncertainty in the final result would be of the same order as for Skeeter's pump, even if data regarding the pump characteristics (head vs. flow curve) were available. The losses in the system can rarely be predicted with any precision. The hose example we considered was in fact an extremely simple case. More often there will be a number of valves and fittings and occasional special elements, for which only rough estimates can be made regarding pressure drop. If there are branches in the discharge line the situation is almost hopeless from the theoretical viewpoint, and calls for some inspired guesswork to estimate the flow distribution.
The operating parameters of the pump is found at the point of intersection between the system resistance curve and the pump performance curve on the head-flow graph. The practical way to find it is through an iterative sequence. I have found that if one starts with an assumed flow rate near the middle of the pump capacity range, one can work out the corresponding pressure (head) on both curves, and decide in which direction the flow should be corrected to achieve convergence. Generally one gets there in three or four steps, or decides that another pump or different pipe diameter is advisable.
There could probably be computer programmes to speed up this process, but in my opinion a step-by-step procedure provides much insight into the magnitudes of various parameters which an engineer should value.
Whatever results are obtained theoretically must be taken with a large pinch of salt. Behaviour of a flow system can be very sensitive to many factors, such as the actual internal diameter and roughness of the pipe (often just assumed for calculation) or the speed of rotation. As an example, here in India we are likely to get a supply frequency closer to 48.5 Hz instead of the nominally assumed 50Hz. So the speed of the motor may be upto 3% lower than expected, and the pump will have a noticeably smaller head and flow rate. Some manufacturers provide performance curves for a range of speeds.
A layman probably has few options if he needs a pump for some garden or domestic purpose. He is unlikely to find anyone who is knowledgeable enough to advise him properly. So he goes to a dealer and states his requirement in whatever language he can. The prevalent commercial practice is to talk mainly in terms of pump HP with little or no reference to the head or flow capacity. The dealer's engineering knowledge is also limited so he may go largely by thumb rules from the manufacturer, together with any customer feedback and past experience. Occasionally one has bad luck and finds the pump to be seriously under-rated or too powerful.
One useful 'trick' to gain experience is to check measured performance against theoretical prediction whenever possible. This holds good for all engineering problems, not just pump applications. Quite often we just don't take the trouble. Skeeter has provided a good set of actual data which gave us a chance to see how it all fits together. That is what I have tried to do, and I hope something useful to readers comes out of this exercise, which has 'fortunately' gone beyond the mere question regarding Tom's pump.
=TeeSquare=
#396
05/05/2008 8:03 PM
A rhymer who ventured to dwell
On pump fixing soon bid farewell.
But as you might have guessed
The mysterious guest
Was too shy to emerge from his shell.
# 378 hardly deserves a GA rating, because of the poor quality of rhyming and scanning. The above verse refers to #339 which was decidedly better.
In reply to #396
05/06/2008 8:58 AM
Evacu-line a Tale of Flooding
with regrets to Henry Wadsworth Longfellow
This is the sump pump electric. The murmuring brine and the rotor,
Bearded with moss, and in algal growth green, indistinct in the cellar light,
Lurk like Kobold of eld, with hoses long and defective,
Pump like dragons roar, with discharges that go down the floor drain.
Loud from its concrete caverns, the deep-voiced neighboring sewer
Speaks, and in burbles of methane answers the wail of the sump pump.
This is the sump pump electric; but where are the dregs that beneath it
Swirled like the flow, when engaged in the rotor vanes, the heart of the sump pump?
In reply to #400
05/08/2008 8:08 PM
While Tommy watched his basement flood
A few feet 'neath the ground,
The nearest drain that could be used
Was eight feet off he found.
Tom rigged his pump with garden hose
Full score and five in length.
But when he switched the motor on
The pump seemed short of strength.
Fear not, quoth John, who happened by
And knew just what to do.
He nipped upstairs and fetched some shears
To chop the hose in two.
=TeeSquare=
In reply to #422
05/09/2008 8:33 AM
Huzzah, Sirrah! I can but vote it one lonely Good Answer, but if there's justice, others shall make up the lack! And here's a...
Good Answers: 22
#397
05/06/2008 1:12 AM
This thread
Should be dead,
But it's not.
Oh, rot!
Not a thing
I can do.
So I'll wait
'Til it's through.
The answer's been given, but some are not satisfied.
That's why this thread hasn't died!
You might think these people are dense,
But they just want an explanation that makes sense.
You can't fault their dissatisfaction.
But this constant posting is driving me to distraction!
I guess this whole matter I could ignore,
But I can't help but read when people post more.
In reply to #397
05/06/2008 8:25 AM
So did you press the button to just read this then 3Doug?
#399
In reply to #398
05/06/2008 8:46 AM
400
05/12/2008 7:39 PM
A faulty pump and more
Could John with ease restore.
With his usual aplomb
He dazzled poor Tom
And Lady Mondeflore.
Hope there's no chance of her illustrious kinswoman getting wind of this. She might get envious!
=TeeSquare=
In reply to #449
06/23/2008 4:40 PM
Outstanding!
07/02/2008 8:06 AM
I came back to this thread out of nostalgia since it had fetched me a couple of GAs, and was pleasantly surprised to find that after a gap of over five weeks the tally has gone beyond 450 posts! Some sort of record? Of course I'm delighted that at least EnviroMan has seen through the little riddle I posed! I had thought this thread was dead and buried. I would have been happier though with some discussion related to my pump analysis rather than any GA votes. Much too late for that now as everyone has moved on I guess.
Seems like I always enter the threads too late because of my irregular internet access. I had posted a graphical solution of the bouncing ball problem which was probably not seen by anyone. My contribution to Crossing the River was acknowledged by Blink.
I also had an alternative approach to the sliding block problem, but could not post it because my IP address got blocked! Now that has been sorted out, thanks to Kris who could contact CR4Admin on my behalf
=TeeSquare=
In reply to #454
07/02/2008 8:22 AM
Actually, I think the record is >1,200 for a post by Kris (no, I refuse to comment on which one, the 'breaking the bath' thread is better dead!). But never give up - you may as well hand your pelt to the trapper!
In reply to #455
07/02/2008 8:45 AM
If I hear the word 'Bath' again I shall scream. We have TeeSquare back, so lets rejoice. Think I'll have a nice shower, baths just scare me now.
In reply to #456
07/02/2008 3:49 PM
Best stay away from this place, then...
In reply to #457
07/02/2008 8:11 PM
Dang right ;
No contest really !
Good Answers: 15
#459
In reply to #458
07/03/2008 4:00 AM
Isn't the one on the left, the Nursie on the right?
In reply to #459
07/03/2008 4:10 AM
It was her day off. Trouble is, I got left in the bath.
In reply to #460
07/03/2008 6:10 AM
No wonder yer skeered of a bath now...
Good Answers: 15
#462
07/03/2008 7:44 PM
Ahhh, so the 5 squirrels in the picture are looking for nuts?
In reply to #462
07/03/2008 10:17 PM
Trust me,we already have them in plenty.
07/04/2008 8:12 PM
It puzzles me why this thread should have got a strange new lease of life at this late fifth century stage! Nothing of any significance seems to have happened to justify the revival of interest. Other threads have been simply abandoned by the regulars, and even the official answer to the car front end problem has not evoked the slightest comment.
Thanks to Tom's deficient pump (or lengthy hose), and even more to Skeeter's experimental inputs, I played some role in extending the life of this thread, besides acquiring some GAs for whatever they are worth. By way of celebration I had introduced Lady Mondeflore in verse, but hardly expected anyone would notice her presence (though someone did).
With so much recent emphasis on the past adventures of Kris, it occurred to me that the infamous pump arrangement could be suitably adapted for either filling or emptying his celebrated bath, if it can be conveniently relocated in Tom's basement. Then we could go through a whole set of calculations with revised parameters for pump capacity, hose length, and whatever else may (or not) be relevant. And Skeeter could perhaps be persuaded (for a nominal fee of course) to conduct another experiment.
Now, did I hear someone scream? Maybe it came from post 457.
All that was by way of expressing my utter ingratitude to Kris for resurrecting me in CR4!!
=TeeSquare=
In reply to #464
07/04/2008 9:22 PM
A good thread never dies. Tell your grandchildren about the excellent post made by Fyz on 'trisection' , it will run forever. Classic CR4, it has all the elements required. My progeny won't get much in money terms, except one instruction '"visit CR4". It will educate them in life more than I or life ever could.
#466
In reply to #465
07/05/2008 4:53 AM
In reply to #465
07/06/2008 8:09 PM
Hi Kris,
There's a slight difficulty about telling my grandchildren anything. As a sixty-plus bachelor ("... and likely to remain so ..." if I may quote 'enry 'iggings), it's unlikely that I'll be able to find anyone who is remotely interested in the merits of CR4 or my adventures and misadventures in attempting to grapple with it. I've given up on my contemporaries, who are mostly preoccupied with their own thing -- stock market or grandchildren or whatever. My surfacing here from time to time is partly a means of escape from a society with which I cannot keep pace!
=TeeSquare=
In reply to #467
07/07/2008 5:42 AM
Engrave the directions on the inside wall of your house. They will figure it out. I can't even make the DVD player work, but they can. A brief note with directions will get the kids here. They can keep up the good work. As a bachelor, find a deserving kid to leave your inheritance to. It's too good to pass up. Let someone share the joy.I'll cry when I see "TeeSquare2", but the good stuff will continue. "Kris2" will be hell, if he's learned anything from me. Maybe we should start a Prozac collection for the people in 'Admin'. I suspect you are good for a few years yet. If you ain't, I will get vermin round to do 'mouth -to-mouth'. Oh no ! Keep breathing mate, I didn't mean to shock you like that !
In reply to #468
07/07/2008 7:18 AM
Long haul from Silly Valley to Madras, we'd best keep vermin on advance notice, y'think? Of course, by the time he'll likely be needed, that laser should be perfected to the point he can use it to transmogrify hisself and be there at only slightly sub-C. Better than what he's probably used to...
#470
In reply to #469
07/07/2008 7:34 AM
Vermin generally have to keep at least one step ahead of the predators, so I imagine he (?) has probably pre-arranged quantum entanglement. (No need to wait for light, then - just access the local instantiation)
In reply to #470
07/07/2008 7:43 AM
Quantum entanglement? No, no! It's a trap! But instantiation comes easy here...
#472
In reply to #471
07/07/2008 8:39 AM
Not all that easy, as it seems to require almost continuous skilled maintenance. And surely it should be blue - a police telephone box. (Already of limited use for camouflage even when the good Doctor first appeared)
In reply to #470
07/07/2008 9:25 AM
Vermin be generally very quick. RUN.
In reply to #469
07/07/2008 9:21 AM
In reply to #473
07/07/2008 11:20 AM
Hey, that kid's pretty good! I predict a long, successful career for him...
In reply to #473
07/07/2008 11:31 AM
Yer ears heard 'long tall Sally' outta "long haul from Silly Valley'? Sorry, old chap, free Miracle Ear hearing exams next Saturday at the local Pharmacy for you!
In reply to #476
07/07/2008 5:20 PM
It's no problem ; vermin is in silly valley I think. Kinda explains a lot.You should be safe in Florida, just don't go bathing in Okefenokee or Disney-world. Unless talking clothing, Gaiters can be bad news.Still, it's worth being free ( if you can wait 'till it gets good !). Skyn's is Jacksonville I think.
In reply to #477
07/08/2008 8:02 AM
Not so many gators in de swomp - Lake Okeechobee either 'cause of the drought (may parts of hte lake are so dry the breush and weeds grew there, then died and dried, and there was a helluva wildfire on the lakebed last summer!), but do check out this... (It's the "B" side to Larry Verne's "Please Mr. Custer [I don't want to go!]")
In reply to #478
07/08/2008 11:27 AM
I'm not sure I should share this, but what the hey. Loss of water is bad, but loss of Gators is terrible. My mother-in law has a fairly big pond. Just a thaught.......I'd pay the air-freight, and well, accidents happen. Slowly, at 1 KG/day it would be safe for a year or so (the gator that is. If I can't gaffer tape the things mouth, it's a dead reptile).
#480
In reply to #479
07/08/2008 12:34 PM
1) "at 1 KG/day it would be safe for a year "
That sounds an impressive growth rate even for a gator - what's your secret feed?
2) I assume that's the mother-in-law's mouth you need to tape? (known as curing two birds in the hand with one stone?)
In reply to #480
07/08/2008 1:16 PM
1- Gators have slow metabolism - it would live. Finding next years feed would be hard, but hellish fun. "Hi honey, can we date for a while. BTW, how big is your mom ? If things don't work out, I have a nice pool out back".
2- You got it !
In reply to #479
07/08/2008 12:38 PM
"...If I can't gaffer tape the things mouth..."
Crikey, Mate, don't be tryin' this at home! These are trained perfessionals...
In reply to #481
07/08/2008 1:25 PM
I dunno if we have folk like 'best boy' in this country. It wouldn't surprise me though. We make better movies - mainly 'cos we borrow your money, and the writers don't go on strike. Don't rush folk's, I've slapped myself already.
In reply to #483
07/08/2008 1:42 PM
"...I've slapped myself already."
See, there y'go, having fun during business hours again! When will you start to stop taking this stuff seriously, eh?
In reply to #484
07/08/2008 4:33 PM
What does that word 'serious' mean ? You need the in-tel as well.My language mistakes are infamous - have a spare 'l' You need it, by the look of things.
In reply to #485
07/08/2008 5:18 PM
Per Wiki:
Sirius is the brightest star in the night sky with a visual apparent magnitude of −1.47, almost twice as bright as Canopus, the next brightest star.
How's THAT for in-tel, then? When have YOU made language misteaks? That's GOTTA be brighter than any four candles...
In reply to #486
07/08/2008 6:33 PM
I'm gonna tell Masu about you. Be scared.Very scared
07/08/2008 8:25 PM
Absolutely mystified and bewildered by the sudden flurry of activity in this little corner of the cyber-world. Seems like some kind of landslide has been triggered, and I've just about managed to skip out of the way. I must confess that much of the idiom in the CR4 off-topic banter passes me by completely. I'm rather content to remain on the periphery during my sporadic appearances. At best I take some wild guesses at what the interactive crowd might be saying to each other (the reference to vermin, for instance -- I think it pertains to some exchanges in some other thread)! As a rule I don't risk clicking on the links (to youtube, etc. which might contain image/video files or other monsters that could screw up my precarious pc with dial-up internet access).
Since there is a likelihood of this post being seen (unlike some of my belated on-topic contributions to other threads), let me ramble on a bit. The technical content of some of the challenge questions is enough to keep my interest in CR4 alive, because of my infrequent visits. But it's clear that all the diversionary antics are essential for those who are hooked up on a regular basis. I do make occasional attempts to get involved in the wider discussions or sneak in a limerick or so. But any reactions (or actions) from me are likely to be delayed and will often be too late to be meaningful, mainly because I do all my reading and composing off-line. I suspect that the archaic nature of my inputs may be a matter of amusement to some! I've had a fascination for things mechanical, having grown up in the age of steam locomotives. I still have a mental picture of say the Bombay Calcutta mail thundering past, hauled by what we called a 'bullet' engine. Among my mostest favouritest childhood poems was R L Stevenson's 'From a Railway Carriage'. Much of the magic vanished though when diesel and electric locos took over. Technology today is tending to be a dull array of keypads, blinking lights and monitor screens, which do not excite me in any way.
As regards the advice from Kris about my 'inheritance', I think today's kids would properly be well advised to be wary of any overtures from elderly bachelors! In fact I have very little interaction with young people. They are in general a lot smarter than me, especially in matters relating to computers and all the gadgetry of 'modern' life which confuses me no end. I find myself a little more at ease in the company of 70 to 90 year old folk, even if they harp on the so-called good old days. I can at least relate to their sentiments, whether or not I agree.
I really don't know where this random off-off-topic path is leading, so best I sign off. If anyone is put off by my verbiage, the accusing finger should point primarily at Kris who was instrumental in getting me to register here in the first place about a year back (along with Fyz), and further resuscitating me more recently after CR4 Admin decided in its wisdom to cut me off!.
=TeeSquare=
Good Answers: 15
#489
In reply to #488
07/08/2008 8:45 PM
As a test of intelligence for those young "Whipper-snappers"
Get a piece of Mylar film, wrap it around the Active electrode of the powerplug (assuming its one of those bladed ones, not the round ones, and insert the plug into the wall, turn on power and make sure the lights don't come on the computer.
Alternatevely, do this modification to the IEC power socket on the back of the computer, and remove the video lead from the monitor, sit back and see how long it takes them to find the problem, they may get suspicious from the chuckling from the Audiance.
Alternatives, if the mouse has a ball, remove the ball, place a piece of tape across 1 of the rollers, reinsert ball, if Laser mouse (light under mouse) place a piece of clear tape over the lense area, but place black ink on the tape so the light is not reflected back to the lense as easily, in the computer menu's change the mouse from Right handed to Left, in one of their games, go into the "Options-Control" and set (or reset) the "Invert Mouse" checkbox.
Have a wonderful weekend.
#491
In reply to #489
07/09/2008 5:35 AM
Reminds me of sending new graduates to stores to get a "long weight".
As an avid punster (and one who had been warned to anticipate something of the sort - oh, blessed mentor...) I picked up a book and went as requested.
Then there was the time I asked where the grease was kept (to aid in tapping a thread); rewarded (!) with "try elbow grease", I handed the offending item across for the smart-**** to break the tap himself.
Surprisingly, that turned out to be the last of the "initiation" attempts.
In reply to #491
07/09/2008 6:26 AM
Ah, the days of sending whipper-snappers for a quart of relative bearing grease!!!
In reply to #489
07/09/2008 6:25 AM
You've a mean streak in you a meter wide, ain'tcha?!?
In reply to #488
07/08/2008 10:02 PM
Teasng /taunting vermin is one of lifes great pleasures. We have you hooked to CR4 now man. Ha ! No escape is possible, and no cure exists.
In reply to #490
07/09/2008 6:28 AM
Resistance is futile. Assimilation is assured. Gaze into the eyes of my current avatar...
In reply to #495
07/09/2008 6:35 AM
You may have a place on our committee. One conditiion - wear some shades !
In reply to #496
07/09/2008 8:48 AM
Would something like this be sufficient?
Reply to Blog Entry Page 5 of 7: « First < Prev 3 4 5 6 7 Next > Last »
3Doug (28); 95324 (1); Andy Germany (13); Anonymous Poster (51); BaldSprinter (4); Bayes (21); BC (1); Bill H. (1); BURNTCABIN23 (1); bwire (1); Charlie Greenwood (1); CSM Engineer (2); dadw5boys (1); DaS Energy (3); Dave M. (1); Deepti Sharma (1); donzi (2); EnviroMan (176); evankenmccoy (1); exemmet (1); ffej (1); FKIA (1); FSTLNE (1); Gary Karm (3); Gasman (1); geomech (3); gsuhas (3); hazman (1); JasBond (9); Keith E Bowers (1); Kris (140); MAHAPRASADRAI (1); marcot (1); Maths_Physics_Maniac (5); Maverick80 (1); MEGRL (3); moron (1); Mr. Truman Brain (16); mreinholds (2); NoSciFi (3); ozzb (1); phindrup (3); phyd man (1); Physicist? (43); Pj3ns3n (2); random ocean (1); RickLee (7); Ried (10); scotchdrnkr (1); Skeeter (6); Snaketails (13); SPIJman (4); Stan The Man (2); TeeSquare (40); The Mechanic (5); tomkaighin (12); Toomuchfun (3); user-deleted-1105 (8); Worksalot (1)
You might be interested in: Air Hose and Air Duct Hose, Hose Crimpers, Hose Reels
