Previous in Blog: Projectiles: Newsletter Challenge (04/01/08)   Next in Blog: Trisection: CR4 Challenge (04/15/08)
Page 3 of 7: « First < Prev 1 2 3 4 5 Next > Last »
Fixing The Pump: CR4 Challenge (04/08/08)
Posted April 06, 2008 5:01 PM
Tom's basement has a shallow sump pit and a pump. The pump is attached to a 25ft garden hose which empties into a drain 8 ft away. One day Tom and John were in the basement when Tom mentioned that the pump just isn't working fast enough and that he needs to buy a slightly stronger one. John says he has a cheaper solution, disappears upstairs for a minute, returns, and fixes the problem. What did John do?
And the Answer is....
John went upstairs to the kitchen for a knife came down and cut the hose in half. According to Poiseuille's Equation, this should double the flow. The pump should be fast enough now.
#134
Re: Fixing The Pump: CR4 Challenge (04/08/08)
04/11/2008 12:10 AM
He went up stairs to get a pair of scissors to cut the hose down to 9-10 ft?
WoW! Time flashes by in a blink of an eye.
Hobbies - CNC - New Member United States - Member - New Member
04/11/2008 7:10 AM
John went up and added a few more hoses to the end of the original. He then positioned it across his driveway and onto the next door Go Kart track. He challenged the kids to be able to drive the length of it and take a soaking at the other end. Then he stopped by the kitchen and grabbed 2 long necks from the fridge. He figured he was not going to get paid so he might as well get something out this. Since Tom had surgery this week to remove the skin cancer from his lip, caused by years of nibbling on pencil lead, John puts a straw in Tom's bottle. He then went back to the basement. After finishing the beers, John recycles Tom's straw. He cuts it in to 3 equal lengths. Then he pokes three holes in to the hose at 18" from the pump. He inserts a straw section into each hole being sure that they are angled so as to create a venturi effect. He places the hose back in the water. The "venturi" helps draw more water there by increasing the capacity of the pump. Since the kids on the Go Karts are acting as an auxiliary pump there is less head pressure on the pump. Now everyone is happy. The kids have a water park on the track. Tom's pump is churning away. And except for 3 small holes, no ones hose was cut.
#139
In reply to #138
04/11/2008 7:34 AM
Wow! Really entertaining.
The extent of the imaginations of the individuals responding to this are absolutely incredible.
Some of the replies, while frivolous as can be, are really amusing and have ranked up there with story book writing ability.
In reply to #139
04/11/2008 8:52 AM
And as the water level receded in sump...Mrs Tom let out a scream of horror as a withered hand was slowly revealed by foetid water....
In reply to #139
04/11/2008 9:21 AM
....Fairy Tales???
In reply to #144
04/11/2008 9:29 AM
YUP!
In reply to #138
04/14/2008 10:17 PM
And all his stories have BEER! MMMMM, BEER!
In reply to #161
04/15/2008 8:34 AM
I thought about trying whiskey this time. But, I figured you would complain about each person drinking their own pint of that. A pina collada or daiquiri would be nice if it were not raining here. Besides that I would have had a hard time working the little umbrella in to the repair. Oh, hold on. Inspiration!!!
Realizing there was partial blockage in the hose, John took the hose off of the pump. Then he took his little umbrella from his drink. Giving it a slight twist he reshaped it into a spiral point cutter. After inserting the cutter into the hose, John reconnected it and turned to pump back on. The cutter traveled through the hose and cleared the partial blockage.
Ok, so now I suppose someone will whine about a paper umbrella in a water hose.
#169
In reply to #168
04/15/2008 10:52 AM
Last time I was in your neck of the woods, the umbrellas seemed to be waterproof. I'm not sure if they were coated paper or made of plastics.
In reply to #168
04/16/2008 8:14 AM
"Ok, so now I suppose someone will whine about a paper umbrella in a water hose."
Oh, they shouldn't - it's no worse than a paper moon in a cardboard sky, now is it?
#140
04/11/2008 8:00 AM
John was able to stem the flow of water going into the sump in the basement.
United Kingdom - Member - New Member Hobbies - Musician - New Member Engineering Fields - Mechanical Engineering - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member Hobbies - Fishing - New Member
Location: South-east corner of Spain 50 48 49.24N 2 28 27.70W
04/11/2008 8:31 AM
As Tom was a known DIY disaster zone, John went upstairs to get a few beers! When he came down, he had a quick look in the junction box near the pump and noticed that Tom had very foolishly connected the pump in series with the basement lights! After looking at Tom with a look that could kill, he connected the pump to the power circuit and said 'Christ Tom, you're a walking disaster!' Tom shrugged his shoulders and said 'It was like that when I moved in here!' John knew this was a lie due to the fact that Tom was always playing with odd bits of wire that he 'found' around his house!
“It's kind of fun to do the impossible.” Walt Disney
Good Answers: 22
#146
04/11/2008 1:53 PM
After taking another look at the original post, I noticed that the sump pit is shallow. When Tom said the pump wasn't working fast enough, he meant the pit was filling up faster than the pump could empty it. That told John the pit was too shallow.
John went upstairs to retrieve both a shovel and a knife. If he went for just a knife to cut the hose, he would have been gone only half a minute. He needed the other half minute to get the shovel. When he gets back down in the basement, he hands Tom the shovel and tells him that it is his responsibility to do the dirty work of deepening the pit for not thinking of this himself. Meanwhile, John takes the easy job of trimming the hose.
Of course, if this was a frivolous answer, I would have said that John went to retrieve a stick of dynamite!
In reply to #146
04/11/2008 3:00 PM
He could use the dynamite to blast into his neighbours basement - with a bit of luck they've got a working pump. If not, it will halve the flood level (unless the neighbours are in a worse position).
Good Answers: 22
#151
04/11/2008 8:16 PM
One more frivolous answer:
While John is going up the stairs to retrieve whatever, he remembers something he read earlier, so he returns with the morning newspaper. He says, "Tom, I've got an even better solution - one that will make you money instead of costing you." He hands Tom the paper, open to the classifieds, and points to the circled ad that says:
Experienced plumber facing divorce seeks new place to stay. Would rather live in a basement than a doghouse...
Tom asks how this will make him money and solve the pump problem. John tells him to rent his basement to this guy, and being that he is a plumber, the pump problem will bother him and he will naturally be driven to fix it. "He fixes the problem for free, and you get his rent money!" John concludes.
In reply to #151
04/12/2008 1:52 AM
Bravo...
Good Answers: 97
#153
04/13/2008 4:09 PM
John went into garage then returned to basement and replaced garden hose with 1-1/2" diameter hose from shop vac.
#160
In reply to #153
04/14/2008 4:30 PM
Cut 15'11½" of the hose and be done with it....so obvious, so elementary, not at all a challenge - that's why I'll be surprised if that's the answer the challenge is looking for. Then again, when's the last time it received so many responses?
FRIENDS DON'T LET FRIENDS DRIVE HUMMERS
#163
04/15/2008 4:35 AM
John knows that the pump used to work just fine. Also, the hose is already as short as possible, as it was routed to avoid obstructions (nice little red herring - perhaps that's the cause of the blockage). The problem is that the water is silty and the hose has become clogged. John just fetches a screwdriver, spanners, and a brush. He temporarily attaches the hose to the mains water tap (there must be one in this basement, as that is where Tom does his brewing) and flushes it clean from the high pressure supply. As he enjoys tinkering (and as a precaution), he also takes the pump apart and cleans it.
To stop Tom distracting him, he sends him out to buy two bunches of flowers and fetch a clean shirt. As they are doubtless somewhere in the midwest, the bunches of flowers are for their wives (who originated in more egalitarian regions, and don't appreciate just being expected to do extra laundry).
04/15/2008 2:02 PM
Assuming that the pump was fine when it was first installed then the motor must not be running well and so the person in question went upstairs for some cooking oil from the kitchen to lubricate the bearings and some vodka to clean the commutator. After his success he drank the vodka to celebrate.
Peter Jensen
04/15/2008 3:49 PM
An alternative strategy is that John returned from the kitchen with gelatin and mixed it with the water to increase the viscosity of the water to counter the wear in the impeller as a temporary fix.
Peter Jensen
#174
04/15/2008 6:16 PM
John went upstairs, out to his Ute (pickup) and got his shotgun from the gun-rack. He went back downstairs and told Tom "Stop bloody annoying me" and promptly shot Tom.
If you don't laugh, you cry.
Good Answers: 22
#175
In reply to #174
04/15/2008 10:27 PM
I hope the shotgun was loaded with rock salt! Or else John has traded one problem for another.
Violence never solved anything, and I'll shoot anyone who disagrees with me!
04/16/2008 4:02 PM
Well I guess halving the friction would kinda double the flow. I can't be ar*** to argue over anything more here, but the 'answer' could have at least explained why the hose was only cut in half.
In reply to #189
04/16/2008 4:31 PM
The 'answer' also made no mention of Mrs Tom or the colour of her underwear...
In reply to #193
04/17/2008 4:51 AM
It's blond.
In reply to #203
04/17/2008 6:24 AM
Blonde...undies?!? Well, I didn't see THAT coming!
#205
In reply to #193
04/17/2008 4:57 AM
Underwear??
#196
In reply to #189
04/16/2008 8:36 PM
Hi Kris et Al who have studied this Challenge,
I don't believe the answer is correct either - there is simply no way that by cutting a hose in half that you can double the flow of liquid through it - it just doesn't make sense.
I think whoever set this question is misinterpreting Poiseuille's Law.
Yes there will be an increase in the flow rate as I have shown with the Darcy-Weisbach equation but it is not correct to assume it will double - I mean if we take this attitude to the limit and keep cutting the remaining length of pipe in half we will never cut all the pipe off ( Sum of 1/2 +1/4 + 1/8 etc approaches 1 but never quite gets to 1) and yet somehow we will hope to double the flow rate each and every time we make a cut - It's absurd!!!!
Come on Guys, what does everyone else think?
#197
In reply to #196
04/16/2008 11:42 PM
The more I think about the answer to this challenge the more absurd it becomes.
This type of misinterpretation of a formula clearly supports all of you who mentioned about how engineering disasters can happen. Luckily, in this case it's just a challenge question but presumably a few engineers working for CR4 other than the question setter must have viewed this answer and deemed it to be correct.
To further prove how absurd it is, I challenge anyone to procure a 25 foot or thereabouts garden house, attach it to their water main or sump-pump, if you have one, and time how long it takes to fill a bucket?
If this time halves when the hose is cut in half, I'll eat all 12 and a half feet of the cut hose and wash it down with a creamy pint of Guinness
In reply to #197
04/17/2008 4:22 AM
>>>>To further prove how absurd it is, I challenge anyone to procure a 25 foot or thereabouts garden house, attach it to their water main or sump-pump, if you have one, and time how long it takes to fill a bucket?<<<<
I can hardly wait until daylight to grab my pump and put it to the test. If it weren't 2:20 A.M., I'd go perform the test now. I'll post results... any bets?
This is it... so live it up!
In reply to #199
04/20/2008 8:49 PM
Bet is ON BABY...but I don't care about the hose, I just want the guiness
In reply to #197
04/17/2008 4:42 AM
I'll eat all 12 and a half.....
ROFLMAO !
In reply to #197
04/17/2008 7:18 AM
"...a creamy pint of Guinness..."
May I suggest instead, for your dining pleasure, a nice bottle of...
(Nothing personal, y'understand...)
The Engineer
Good Answers: 129
#222
In reply to #197
04/17/2008 10:23 AM
Maths Physics Maniac,
You raise some good points, but I think some of your concerns may be a result of not reading the answer and question carefully.
Technically the answer doesn't say that flow has been doubled. The answer says ""According to Poiseuilles's Equation , this should double the flow. The pump should be fast enough now.". I know this may seem like splitting hairs, but I think it is unfair to criticize what is in effect your interpretation of the answer rather than a careful read of the answer. I agree that the answer could have been more clearly stated, indicating in the real world idealized equations don't work exactly, but I certainly feel that the wording of the question and the answer, when read carefully, implies this.
I include the wording of the question because, as Andy German points out, the question goes out of it's way to say that Tom needs only a slightly faster pump, meaning John's solution will work even though flow isn't doubled, so I think calling the answer absurd is a bit much.
Anyway, I don't think anyone is arguing against you that the pump wouldn't double the flow in the real world, but that wasn't the question, right? The question was, what did John do to make it work. He cut the hose, it worked. I don't see a problem. Unless you are suggesting that cutting the hose wouldn't solve Tom's problem of needed a slightly faster pump. If that's the case, we can do some math together and find out.
In reply to #222
04/17/2008 10:28 AM
"...this may seem like splitting hairs..."
No objection to that, just remember to always use Occam's razor when doing so!
The Engineer
Good Answers: 129
#225
In reply to #224
04/17/2008 10:42 AM
In reply to #224
04/17/2008 10:50 AM
OCCAMOFFIT!!!
The Engineer
Good Answers: 129
#227
In reply to #226
04/17/2008 10:56 AM
I think he's just being OCCAModating.
In reply to #227
04/17/2008 11:41 AM
OCCAMon now, you're making me...
The Engineer
Good Answers: 129
#232
In reply to #229
04/17/2008 12:15 PM
I rOCCAMend we stop this. If we keep this up their gonna say "LOCCAM up".
In reply to #232
04/17/2008 12:47 PM
And rightly so, I might add! ROFLMSAO!!!
In reply to #196
04/17/2008 2:51 AM
I'm not in a position to criticise, as I needed to retract the 'Official Answer' of my own challenge .
The detail may be wrong...but shortening the hose is fair enough.
(Mind in my defence I wanted to post it as a question with no 'official answer'... after all... if I knew the answer, why whould I ..etc rambles off into the distance mumbling.)
In reply to #198
04/17/2008 9:08 AM
IS THAT IT?
What do Cats do for the rest of the day, I thought Kris was the one who posted it.....sorry Kris!!
In reply to #219
04/17/2008 3:20 PM
LOL - I'm far too lazy ! I tried getting Del to wear a tin-foil hat so I could induce him to do everything, but he just scruched it up into a ball and chased it around the room.
#204
In reply to #196
04/17/2008 4:53 AM
Sometimes a first-order approximation is unrealistic. Presumably there has always been a pump in this cellar; and, given Tom's attitude, we might consider it unlikely that he just replaced it with a smaller one.
So it seems reasonable to assume that either: an old leaking pipe has just been replaced, in which case John's solution is reasonable; or the pipe has become clogged, in which case the shorter pipe won't work for all that long, given its reduced diameter - so the screwdriver and flushing is a more sensible solution (as in my completely unregarded solution #164.
N.B. Depending on pump type, a larger pump with the original hose might very well be no quicker...
In reply to #204
04/17/2008 5:06 AM
I feel your pain - the answer ignored my previous calculations showing how all the pipe is needed.
Todays lesson children - If you reduce the lengthe of a pipe, you reduce the frictional resistance. It's a good job the sump is shallow, else we'd all drown in it as we keel over !
In reply to #206
04/17/2008 9:11 AM
The main question being, IS IT DEEP ENOUGH TO DROWN A CAT?
In reply to #220
04/17/2008 3:28 PM
He'd displace the water from the sump, then raise his head above the centimetre depth covering the basement floor. I've just had a thought - if he had a tube in his mouth, he might work as a foot pump ! Only joking Del !
In reply to #196
04/17/2008 7:02 AM
I think that if I walk halfway to the door in one minute, half of the remainimg distance in the next minute, half of the distance left in another minute, and so on...I will never leave the room! Hey! Lemme outta here!!! Pretty please???
In reply to #196
04/17/2008 9:07 AM
Mostly what you say is true, but I do feel that you are overlooking a very important sentence in the original post:-
So he does not need to "double" the thruput, only to increase it slightly. Therefore I do feel that halving the length COULD be the answer.....whether I am right or not I could not say......and I am not sure that I can be bothered to wait much longer!! Kris(?) get your finger out of wherever it is and give us the answer!!!!
May I suggest very careful reading of all infos supplied could help......not that I am good in that area myself either!!
In reply to #218
04/17/2008 3:35 PM
You gotta be kidding, it sure wasn't me - this question and it's 'answer' is driving me nuts ! No justification is given for cutting the hose in half. The answer doesn't incorporate the info on 8' to the drain. Hand up anyone who didn't know that reducing length would increse flow.
04/16/2008 5:24 PM
Surely the answer should have been posted yesterday, or did I just overlook it somewhere.
Anyone, please help, the wait is getting boring!!!
In reply to #194
04/16/2008 5:53 PM
you're not missing anything..the answer is more boring than the wait....
04/17/2008 12:24 PM
I take issue! He may have solved the problem with the pump BUT the real problem not actually stated in the question was implied that he wasn't getting the water out of the basement fast enough. Now john has gone upstairs, got a knife, CAME BACK DOWNSTAIRS and cut the hose. Now he is pumping nasty bilge water all over the carpet, the pingpong table annd generally making a big mess. Really!!!
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
The Engineer
Good Answers: 129
#237
In reply to #233
04/17/2008 12:56 PM
Reread the distance to the drain.
In reply to #237
04/17/2008 3:45 PM
If Johns guess about cutting the hose was wrong, he might have looked a bit silly. He should have observed what happened when cutting a smaller length, then proceeded to cut more off it that was seen to be helping. We were given no information about how much hose was 'spare'. If he was confident, he should have cut off all the excess, and thus had a more useful off-cut of hose. The excess hose could have been anything from 0' to 17'.
The Engineer
Good Answers: 129
#251
In reply to #249
04/17/2008 3:52 PM
I disagree. The question says a shallow sump pit. I take that to mean about 2 to three feet. Then the question says the drain is 8 feet away, so at this point we need 10 to 11 feet of hose. Figure you want to leave yourself some slack and you're around 12 feet.
The answer says he cut the 25 ft hose in half, meaning he cut it to 12.5 ft. That seems about right. Besides, that gives him two hoses he could use if one gets damaged. Basically he cut it down as much as he safely could.
Though personally I'm of the opinion that any answer that involved cutting the hose by a noticeable amount would have been correct.
In reply to #251
04/18/2008 3:51 AM
I posted this before, but say the drain is outside the house at a distance of 8' from the sump (distance measure along a 45' angle) ;the hose leads 14.5' vertically to the bathroom window, before the remaining 10.5' carries water to the drain at an angle of 32.6o
OK, that's a bit fanciful, but it's enough to show how all the hose could be needed. It's much more likely that the pump would have had a problem, and I'd contend that if shortening the hose was the answer, then the problem would always have existed.
I'd also contest that 2-3 feet is 'shallow' in a domestic context, but if it was then 8' to the drain should have been qualified as a 'short distance'. I've never looked at a domestic sump (!), but my interpretation of shallow would be < 1'. My main gripe is that the answer is too simplistic, but no matter, some interesting facts have emerged from all the discussion. It's usually the case that the discussion/debate is far more interesting than the answer
#259
In reply to #257
04/18/2008 6:50 AM
Am I dreaming? Or was that not only "on topic", but clear, succinct and .
In reply to #259
04/18/2008 1:45 PM
I have these very occasional lapses !
Tom and John have now drowned anyway - I laughed a bit too much at their failure to check for blockages etc etc. Nobody seemed brave enough to try cutting 2/3 off the pipe either.
In reply to #269
04/18/2008 2:00 PM
I will refer you back to my entry #19.
In reply to #270
04/19/2008 3:30 AM
Nah - can't say 'kudos' since it was posted as Guest ! Glad you've signed up to the madness of CR4, the place where questions are not just thrashed to death, but the very marrow of their bones is gargled.
In reply to #237
04/17/2008 3:49 PM
Right, distance to drain 8' but does that mean that the drain is in the basement? If so why is a garden hose used. I have to assume (I know, make an ass outa u n me) that this was an expediant solution and that the drain was not engineered into the sump system and probably was outside. sump shallow, ground level 6' above sump, basement window 7' gutter drain outside window turndown 1'. In all, not enough info, but I still like the idea of dumb ass pumping water all over the place. I only have experience with one basement sump that had a water jet extractor that worked well for 60 years (until hurricane Rita destroyed the whole place).
The Engineer
Good Answers: 129
#252
In reply to #250
04/17/2008 3:54 PM
I picture a drain in the floor that goes to the sewer system (which is illegal) but maybe it is outside which would explain the extra feet.
04/17/2008 6:14 PM
Just finished my real-world test of a sump pump versus two different lengths of discharge hose of the garden variety.
Pump is rated for 80 liters/min.
Start hose was 25' in length.
Bucket was 2.5 gal.
I pumped from a large container, holding many gallons of water into the bucket, which I placed about 8' away from the pump, and placed 3 coils in the hose to shorten it to the 8' distance, as was the most likely orientation in Tom's basement. I emptied the full bucket of water back into the container holding the pump before running each test, so the pump was always pumping from the same level of water.
I ran 4 tests at this condition and the times to fill the bucket were: 22.48, 22.55, 22.21,and 22.21 seconds, respectively.
Then I placed the hose into a 3" diameter PVC pipe 52" long, placing it vertically into the bucket to simulate the hose going into a washing machine drain, if that was the arrangement in Tom's basement. The time to fill the bucket in this condition was: 23.5 seconds. (I did this timed test only once, 'cause I've got ADD real bad.) I then cut the hose in half at the 12.5' length, and repeated the tests.
After cutting the hose in half the fill times were: 17.16 and 17.28 seconds. The time to fill the bucket with the hose in the 52" length of PVC was 18.12 seconds (just one timed test... ADD, again).
It was very obvious that the bucket filled faster after shortening the hose, 'cause the water came out the end of the hose with greater speed, and the times proved that shortening the hose worked to increase the efficiency of the pump.
Now... I'm off the hardware store to purchase a hose repair kit.
Reply Good Answer (Score 4)
In reply to #253
04/17/2008 7:32 PM
I have given you a GA for your excellent practical test which demonstrated an amazing difference in hose thruput, which proves beyond all doubt that the answer was real world, not just mathematical!!
Many, many thanks.
In reply to #253
04/22/2008 8:28 PM
Hello Skeeter,
I would imagine that like all sensible contributors to CR4 you would have simply abandoned this interminable thread by now and moved on to more interesting matters.
So you may not have seen my post No 290 where I had requested some more information regarding the experiment you conducted.
Actually if you had not mentioned the pump capacity as 80 lpm there would have been no cause for doubts at all.
But under the circumstances, my engineering sense tells me that you have omitted some information regarding the set-up, which you might quite justifiably have regarded as irrelevant. My guess is that the output was severely throttled, or there was a branch pipe taking a substantial part of the flow back into the large container. It must have taken some fiddling around before you got a reasonably large filling time for the bucket. Or else I am completely wrong regarding the type of pump and the arrangement you used.
I'm sure no one has any doubt at all that reducing the hose length will increase the flow rate, but unless the whole picture is both qualitatively and quantitatively consistent, I feel readers of CR4 are justified in seeking further clarifications.
Regards, =TeeSquare=
In reply to #292
04/22/2008 8:51 PM
[po]Greetings, TeeSquare,
I thought I had responded to your previous post in which you requested more information, pertaining to my test, my post seems to have disappeared. Due to freezing conditions, and work commitments, I have been forced to postpone further tests, but will resume when the weather allows.
I'm curious... do you not consider yourself to be a, "...sensible contributor to CR4...?"
In reply to #293
04/24/2008 11:07 AM
Hi Skeeter,
No, I don't expect you to resume any experiments, whether the weather be freezing or sweltering, the latter being the norm over here. I'd just appreciate a bit of data regarding your original tests -- whatever you can remember -- mainly to satisfy my curiosity.
And the short answer to your sensible question is also "No", for a variety of valid reasons. The long answer follows, though I could hardly fault you for not getting to the end of it!
I blundered into CR4 a few months ago, and have made occasional forays into a few challenge threads. But I must confess (as I've already done in some posts elsewhere) that I'm hopelessly inefficient in dealing with computers and the internet (and hence CR4). By the time I get around to reading something (offline, since I have only an erratic dial-up connection) and compose a post (usually rather long-winded!) and succeed in actually submitting it, most people on CR4 would have lost interest. So I must remain content if I get any response at all, however trivial -- the 'fault' obviously being at my end.
I'm an old-fashioned mechanical engineer, Perhaps an obsolete profession. Today it seems people only look for impressively-formatted software solutions, regardless of whether they relate to reality or not, so bewildered old fogies like me had better retire gracefully, and leave the current lot to build their own towers of Babel. Sorry about the cynical note there.
Wading through a lot of posts on CR4 takes up a lot of time, which I can ill afford. Besides, much of the off-topic banter is beyond me due to the obvious cultural divide, but I can understand that it keeps the interest alive for most of the regulars. I try to be reasonably serious and thorough with regard to technical matters, often to the exasperation of people around me, which I guess applies even more to CR4 contributors.
I would presume all that would qualify me eminently for the grand label of nonsensible contributor**! Perhaps that serves to satisfy your curiosity. If not I'm willing to lay it on still thicker.***
If you're still there, I'd be grateful for a response (on the technical points).
Thanks, =TeeSquare=
** The powers-that-be at CR4 could consider expanding their category, and I could head one of the new ones.
*** But someone who panics at the sight of never-ending blocks of teesquare text might resort to the report option, which will presumably block me off for all time! Come to think of it, that may not be such an unwelcome outcome, if it makes my overly complicated life a wee bit simpler.
In reply to #314
04/24/2008 1:04 PM
No, no, rest assured we are here to complicate your life as much as possible! Let us know, anything we can do to help...
OBTW, there is a rather high proportion, we have discovered, of "fogies" (old or otherwise) represented here. And anyone who thinks 'old school' isn't needed anymore is set to learn the error of their ways when the batteries in their calculators die in the field and the phone lines are down. (You think YOUR dial-up connex is slow?!?)
In reply to #319
04/25/2008 8:12 PM
Thanks for the assurance. It keeps happening without external help though. But when I deliberately try to mess things up, some perverse inversion of Murphy's Law comes into play!
However, since you mentioned calculators (and this thread seems never-ending anyway) let me ramble on and reminisce a bit. I graduated from my slide rule rather reluctantly when all around me were already infatuated with those little black boxes**. I still maintain that most engineering problems do not require more accuracy than provided by a slide rule (my trusty old Aristo Studio still resides in my desk drawer, though it hasn't seen the light of day for several weeks now). Most of the significant developments in technology and experimental science took place in the era of log tables and the slide rule. Practical problems (in design at least) invariably involve some fuzzy assumptions like a service factor or material property whose uncertainty may be anything from 10 to 40%, so where's the sense in calculations using eight or ten or twelve digit displays? All those long numbers simply distract us from the essence of the problem on hand. The number-crunching involved in 'modern' developments are mere peripheral refinements which I think are often quite superfluous. I've seen engineers using a finite element programme to find deflection of a simple cantilever.
There was an interesting interlude when mechanical desk calculators were used in many engineering offices for multiplying and dividing large numbers. Before the key-pad type came in, there was a model in which the numbers were set by shifting little metal projections along parallel slots on a curved plate. A senior colleague had taught me an ingenious procedure for extracting square roots. I did try to figure out the logic behind it, but failed (I think by now I've even forgotten the manual method of finding square roots). Is any of that familiar to folks on this thread? I've also heard of very compact pocket models of mechanical calculators, but never seen one. Maybe they can be found in technical museums.
In course of time I did get used to scientific pocket calculators, but now I have a new grouse. When the display on my old one started clouding up, I got me a new 'programmable' type with a two-line display, and a strange behaviour called algebraic logic. I usually waste more time trying to read the bulky manual to perform simple mathematical operations, between bouts of tearing my hair (not much left though). The "=" key is non-existent, but there's an inscrutable duo marked "Ans" and "Exe". One can no longer multiply by a constant as in the old model with single-line display. I did send a query/complaint by e-mail to the manufacturer, and after a few weeks of research they recommended a programme for multiplying numbers repetitively by say 25.4 or 2.205. There's progress for you. My reply to that one did not elicit any response. So now when I need to convert a column of numbers from inches to mm or pounds to kg, I try peering into the darkened display of my old one, or just use the slide rule.
A further shortcoming is that "algebraic logic" does not let you keep track of intermediate results, which is useful in checking for mistakes. You have to put in the whole damn expression and just trust the answer you get in one shot. With the old one, every time I closed a bracket I got a value which I could write down as a magnitude check along the way.
I guess I could go on and on and on. Just don't get me started on computers. I'm living in a maze of fatal errors and illegal operations and blue/white/pink screens.
Life is simple enough sans outside assistance, thank you.
=TeeSquare=
** Those have now given way to the ubiquitous little boxes (... green one, pink one, ... all made of ticky-tacky ...?) which nearly everyone seems to carry around these days. I get quite un-nerved by the sight of all these zombies walking around and talking to themselves, even gesticulating or shouting, quite oblivious of their surroundings. I have so far succeeded in remaining ignorant of what those contraptions are for, and hope to remain so.
In reply to #332
04/26/2008 3:21 AM
√N ≈ 1/2 (N/n + n)
You chuck in a guess at n (what you think the root might be), then keep iterating by re-inserting what comes out on the right-hand side.
In reply to #335
04/28/2008 8:04 PM
Hi Kris,
I guess your suggested iterative method is a response to my query regarding manual extraction of square roots. There used to be a (probably classical) method something like the long division procedure, in which the digits of the original number were marked off in pairs on either side of the decimal point. Then a systematic sequence of steps (requiring no iteration) involving some guess digits and bringing down successive pairs of original digits would yield the root to any desired level of accuracy. Some small multiplications in the rough work margin were needed to verify the guess digits. But I have forgotten the actual procedure!
In reply to #341
04/28/2008 9:10 PM
I have the method you refer to in a book, but it's a bit of a mouthful to explain ! Let me know if interested and I'll copy it up for you. There are similar methods for cube roots (attributed to Trenchant and Heron).
In reply to #342
04/29/2008 7:32 AM
I remember using that too, but enough years ago that I don't remember how it goes either. What's the title of that book? Might be able to save you copying if I can find it!?!
In reply to #343
04/29/2008 12:32 PM
First off, the book ; " Mathematics, From the Birth of Numbers", by Jan Gullberg (ISBN 0-393-04002-X). $50 retail. A stonking good book, very readable and with a good range of topic. There are some web sites that deal with the method, as an eg ; http://mysite.du.edu/~jcalvert/math/sqrt.htm It's a bit of a 'maths-nut' thing to want to do ! The iterative method I quoted earlier is more fun, it closes on the route very fast no matter how bad your initial guess. One of my favourite books is one I got from a junk sale for about 20 pence ! Lots of good pictures etc (it's aimed at primary school level of knowledge, but can inspire me for hours !!). Engineering Mathematics (Stroud) is often used as standard suggested math reading for UK Engineering students at degree level- good in my estimation, the emphasis being on getting answers rather than becoming a maths geek.
I have several recommendations on various topics, but I don't' recall seeing a thread about this (technical books) on CR4. Any ideas ? Books are often lots better than the internet sources.
#345
In reply to #344
04/29/2008 3:23 PM
I've found "Advanced Engineering Mathematics" by Erwin Kreyszig very useful. It not really a text book, nor is it a sequence of recipes. Essentially, it does what I need - gives just enough of the mathematical basis to develop a decent understanding, and enough of the techniques to get started. To my mind, it is also refreshingly light on errors.
In reply to #345
04/30/2008 4:58 AM
Thanks Fyz. I hear that the UK has a very high first-year drop out rate in Engineering. One of the reasons cited, is that youngsters don't arrive with enough grasp of fundamentals in mathematics. I'll keep an eye out for the book by Kreyzig.
#349
In reply to #348
04/30/2008 6:44 AM
You are right about the difficulties. To my knowledge, Cambridge first recignised this in the mid 1960s, when the practice of allowing selected students to skip the first year of the maths tripos was effectively discontinued. Since then it has continued apace - indeed, most UK establishments now find a significant chunk of the first year (in mathematically-rich subjects) is required to cover basic skills.
For the avoidance of doubt - Kreyszig would not be suitable to top-up pre-university skills - as SFIK, its "Advanced" would not have meant "final year high-school" at any time in human history. It covers most of the mathematical techniques you need for a good engineering or physics course - and a great deal that you would not expect to need until you actually see the requirement in the "real" world.
In reply to #349
04/30/2008 7:33 AM
Until the situation is redressed at school level, this nightmare will continue. To get students up to speed, the Universities have to put them through 'crash course' in maths. The subject ends up getting taught in isolation. Despondent students probably end up thinking " but I came here wanting to learn how to design bridges, etc". IMHO school level learners should find out about some of the interesting 'quirks' of mathematics, and also how it can be used to solve real-world problems. So called 'New Mathematics' was intended to address that issue, but it failed miserably. The exam system has failed students also. There are some very good 'popular science' books on the topic of mathematics, and they go some way to rekindling an interest, but in-between School and University the system fails. Engineering students need to see the value of mathematics as a tool, but by then the 'fun' has been extinguished. Even such topics as relating Fibonacci to nature, code-breaking could help. It's rare thesedays to meet a youngster who enjoys solving logic problems just for their own sake. It's quite possible to make maths 'sexy', and thereby encourage interest, but the system fails to do so. Some of the Challenge Question (and others) that have appeared on CR4 would make excellent teaching modules at School level. Learning to 'slog-it' through some things is an essential learning skill in life, but mathematics could be made more fun at an earlier age. An extraction from CR4 could provide good lessons on geometry, statistics, applied mathematics, and a whole range of topics. I hope that a few School teachers out there have used whats' on CR4 to enhance lessons they give. They're undoubtedly constrained by dictates of the curriculum, but CR4 contains some very useful material to enhance lessons. Even spending a bit of time on some of the bizarre figues who've contributed to mathematics could encourage interest. Enough ramble, I'll go find a cup of Hemlock - I had an alter cation with the oracle at Delos. < shameful use of ambiguous referrences, I know.)
#352
In reply to #350
04/30/2008 8:00 AM
Last time I went to "The Oracle" deli, they had been forced to withdraw Hemlock from the menu (under threat of immediate closure). Health and safety gone mad...
In reply to #352
04/30/2008 8:25 AM
Ask for "extra Chilli's". I always do, and it's never done me any harm ! Just don't ask for any of that buffalo milk cheese (the nice cube shaped chunks) - if they say " do you want to go large on that", you're a gonna. They follow up with " so that would be double then, would it....exactly how much would sir like ? "
#355
In reply to #353
04/30/2008 9:00 AM
Last time I asked for extra Jilly's I got rather more than anticipated
In reply to #352
04/30/2008 8:29 AM
Can't stop..... I'm in the midst of a field full of beans !
In reply to #350
04/30/2008 9:26 AM
"...but mathematics could be made more fun at an earlier age..."
Change 'could' to 'should', and I concur 100% It amazes me how dumbed-down our schools have made the coursework from Kindergarten on up. Remedial math and English are standard stuff at the university level. I've a good friend that teaches grades 4-6 (loop system, he stays with one class for all 3 years) and he does the best he can, but is appalled at the cirriculum that's forced upon him. BTW, the best he can is probably way far beyond what 90+% of the trachers available can do, much less accomplish. Don't be afraid. Be VERY afraid - these are the engineers, doctors, and other leaders of the future...
#357
In reply to #356
04/30/2008 9:53 AM
With luck there'll be enough older medics left to see me out...
In reply to #356
04/30/2008 12:14 PM
....and they're all getting raised in a culture where money is more important than a knowledge and love of the subject. Somewhere along the line, hard work became a thing of scorn. Starring in 'reality' TV, and winning a Lotto became applauded as lifetime goals. The fact that so many teachers give up in dismay, should be ringing very loud alarm bells. It's not all doom, but the signs are that a big snowball is beginning to roll down the slope.
#359
In reply to #358
04/30/2008 12:46 PM
You may remember the following from your younger days:
"The country's going to the dogs". Maybe we are all wearing ER tinted spectacles when looking at the past?
(For what it's worth, the current child-generation of my family seem to be covering much the same things I did - but of course their parents have to pay twice over for the privilege)
In reply to #359
04/30/2008 1:00 PM
Bono ? Noel Coward ? London Oratory ? I can think of many possibilities.
In reply to #359
04/30/2008 1:09 PM
Yup - "they're goin' to the dogs, you can see it more and more". When I was a kid, I heard tales from the elders about the old one-room school. The youngest students were exposed to the lessons given to those about to graduate (so they knew what was coming). Those about to graduate were constantly reminded of each lesson they'd had from the beginning (thus reinforcing their grasp). Much emphasis was perforce placed on individual study. And it was the generations that had their schooling in that manner that produced the Edisons, Bells, Wrights, Fords, Chryslers, even Lincolns; all the lesser minds and mediocre thinkers (according to what the current system uses) that created the world we live in as we know it today.
#362
In reply to #361
04/30/2008 4:10 PM
The trouble with standing on the shoulders of giants is that they just won't stand still.
In reply to #362
04/30/2008 5:40 PM
DNPMSL!!! But some of 'em will...
If Henry Ford was alive to see what they've done to his company, he'd be turning over in his grave...
#367
In reply to #363
05/01/2008 7:50 AM
I don't think it's been the same since they started using colours.
Turning over? Crank-y more like.
In reply to #367
05/01/2008 12:52 PM
Heck, they ALWAYS used colors - just most of 'em were black... But if you check a color wheel, you'll find that what we think of as "black" is made up of ALL the colors.
#373
In reply to #371
05/01/2008 4:19 PM
I don't often support guests in such matters, but:
To my way of thinking colour is light, not absorption, so an ideal black (theoretical only) is made up of precisely no colours. On that basis, the colour wheel is about absorbtive pigments, not colours.
BUT, if we accept the terminology of the colour wheel, white is made up of no colours...
Not certain what the above would mean for a glossy black
In reply to #373
05/01/2008 6:07 PM
Oh, yes, absolutely - white light IS all colors (at least all visible wavelengths). But for pigments and suchlike, white is the absence of color, and black is all of 'em muddled together. You know, the difference between art and science, right? And occasionally there's a conjunction, like wildlife illustrators, laboratory glassware blowers, and theoretical physicists.
In reply to #344
04/30/2008 7:40 AM
"I have several recommendations on various topics, but I don't' recall seeing a thread about this (technical books) on CR4. Any ideas ? Books are often lots better than the internet sources."
Oh, oh - do I detect an actually worthwhile thread topic in the making? If so, I too have some bookly recommendations to make in a highly technical vein. Plus a couple of requests for things others may have run across... Be sure to PM me when you start the thread - I'd hate to miss it!
In reply to #344
04/30/2008 8:12 PM
Hi Kris,
Thanks to you (and EnviroMan and Fyz) for the responses regarding square root extraction (and maths references and calculators). No, I don't expect you to copy out the method. I mention some of these matters in passing as I have a tendency to ramble. Thanks for the offer though.
Some of the off-topic discussions on CR4 just happen to trigger old memories, and I don't really intend to follow up on them. It's often more pleasant to muse on some vague recollections, than to be confronted with all the nitty-gritty.
I definitely find books to be more reliable than internet sources. Partly it is because I'm hopeless at dealing with computers and assimilating material from a screen. Nowadays books are too costly for me, and my access is also limited. I feel the content is generally inferior to what was available a few decades ago. Technical books now tend to have a lot of impressive-looking 3-D illustrations which provide far less information than the carefully drawn diagrams of an earlier era. I just refer to my old collection, even if the matter be out of date.
=TeeSquare=
In reply to #364
04/30/2008 8:26 PM
A lot of that sounds very familiar to my own mind ! Whilst waiting for you to get back, it suddenly dawned on me to simply check on the net about roots. I've probably already lost the plot and posted this before, but for what it's worth ; http://mysite.du.edu/~jcalvert/math/sqrt.htm. Whilst I value the stuff I read on CR4, at the end of the day I like to sit down with a good book - many of the best I have are rather cheap, tatty looking things from second hand shops. One of the things I lament in life is the demise of public book libraries and second-hand book shops. At the risk of sounding overly sentimental, someone once said to me "good books are one of life's great pleasures."
Reply to Blog Entry Page 3 of 7: « First < Prev 1 2 3 4 5 Next > Last »
3Doug (28); 95324 (1); Andy Germany (13); Anonymous Poster (51); BaldSprinter (4); Bayes (21); BC (1); Bill H. (1); BURNTCABIN23 (1); bwire (1); Charlie Greenwood (1); CSM Engineer (2); dadw5boys (1); DaS Energy (3); Dave M. (1); Deepti Sharma (1); donzi (2); EnviroMan (176); evankenmccoy (1); exemmet (1); ffej (1); FKIA (1); FSTLNE (1); Gary Karm (3); Gasman (1); geomech (3); gsuhas (3); hazman (1); JasBond (9); Keith E Bowers (1); Kris (140); MAHAPRASADRAI (1); marcot (1); Maths_Physics_Maniac (5); Maverick80 (1); MEGRL (3); moron (1); Mr. Truman Brain (16); mreinholds (2); NoSciFi (3); ozzb (1); phindrup (3); phyd man (1); Physicist? (43); Pj3ns3n (2); random ocean (1); RickLee (7); Ried (10); scotchdrnkr (1); Skeeter (6); Snaketails (13); SPIJman (4); Stan The Man (2); TeeSquare (40); The Mechanic (5); tomkaighin (12); Toomuchfun (3); user-deleted-1105 (8); Worksalot (1)
You might be interested in: Air Hose and Air Duct Hose, Hose Crimpers, Hose Reels
