Caption This! Blog
Caption This!
Previous in Blog: Caption This for 09/26/14   Next in Blog: Caption This for 10/10/14
60 comments
Caption This for 10/03/14
Posted October 02, 2014 4:45 PM by Kaplin
This week's image: (look closely)
Thanks to JE in Chicago for submitting this image.
5
Re: Caption This for 10/03/14
10/02/2014 6:57 PM
Here are my observations:
1. All of these images are too small. Can we please have larger images instead of these postage stamps?
2. The only thing that seems odd is:
a. It looks like an inside entrance because the doors have crash bars that open inward. These are not exterior doors.
b. There is some weird disguised pipe or something running the left edge and top of the entryway. I have no idea what it is because the image resolution is too small (see observation #1) to determine what it is. Why they painted it like the wall is anybody's guess.
c. The black boxes are not sitting symmetrically with respect to the floor height. I am not even sure what they are because the image size is too small.
3. We are asked to look closely because the image size is too small to be able to see what the hell is supposed to be unusual or amusing.
Reply Good Answer (Score 5)
Good Answers: 97
10/03/2014 12:40 PM
I examined each individual pixel and couldn't find anything unusual or amusing. However, if you stand back a few feet, it looks like lassie with a cigar.
CRTL-Z
11/01/2014 3:07 PM
Yep, every pixel looks fine to me too. Not a single amusing pixel to be seen.
canary
10/02/2014 7:42 PM
I see a puppy....? :/
10/02/2014 7:43 PM
Brick wall paper.
10/02/2014 8:01 PM
Camouflaged pipe?
Good Answers: 97
10/02/2014 8:28 PM
Entrance to the Soilent Green factory?
CRTL-Z
10/02/2014 9:41 PM
Look at the sign on the left. It's a mural on the wall and if you try to walk through the "doors", you go to a real hospital with a concussion!
10/02/2014 9:57 PM
That would explain the painted look over that pipe or whatever as well as the inward opening interior doors.
Would have been a lot better with a larger picture.
Only reason I did not think it was a painting was the saturated lighting at the end of the hall. It is very bright - much brighter than any other artifact in the whole picture/room, which leads me to believe that the bright area at the end of the hall too bright and white to simply be a part of a mural.
The brightest you could get is a gloss white surface and then you would need a lot of ambient light in the room to give enough reflection to yield that much dynamic range.
Good Answers: 29
10/03/2014 7:36 AM
"saturated lighting at the end of the hall." Good point.
I'll add a question about the trash cans or planters on either side of the doorway. Also, look at the hinge end of each of the doors, see the smears of dirt from air flowing through when the doors are closed. Who goes through that kind of detail when painting a mural? And if it's a lithographed mural, I have to ask why that image? Wouldn't you pose a doctor or nurse looking outward with maybe a welcoming smile?
I don't see how the camouflaged pipe fits into it either. If I was going to paint a mural, I'd try to make it fit as a pipe, not try to camouflage it.
I'm really not convinced it's a mural.
Canada - Member - New Member
10/04/2014 11:06 AM
From my perspective, (subjective to critique); the end of the hallway where it seems to open up into what may be an atrium with full natural daytime lighting from a higher glass canopy (as suggested by the foliage in the stepped garden on the far end right side). This may be a reception area, or a retreat for patients to connect back to nature, as is the case in my local hospital. As suggested by tommm in post #9.
Have a Happy! ;-)
10/03/2014 9:26 AM
Rixter was right. It is a mural. Hold down the Ctrl key + Scroll the Mouse button to see the entire photo:
10/03/2014 9:46 AM
Doesn't work on either of my browsers. I call foul! ;-)
10/03/2014 10:02 AM
The CT photo is still too low-resolution to make out the details to confirm 'mural.'
The photo cropping is also not helping, it should have included the real floor in front of the supposed mural so a close look would reveal the line of the floor/wall edge.
10/02/2014 10:42 PM
This facility was designed by Gary Larson.
10/03/2014 12:55 AM
It does seem to be an entrance to a hospital via an atrium or connecting hallway from another building that might contain doctor's offices or a clinic. The only person visible is a woman (nurse?) wearing hospital scrubs with a white smock over them. The column to the right of the entry has a wooden base that seems to be made by a cabinet maker suggesting it is indoors. The pipe on the left is interesting as it is painted to blend with the bricks. It seems the right size for a drain pipe.
After all that, I fail to see much comedy in the picture or as my late pappy would say, "Ain't funny McGee!"
10/03/2014 1:42 AM
Anyone posting such small images should learn how to make them as large as possible. Its really simple to do...
Or stop posting completely!!
10/03/2014 2:15 AM
I copied and pasted it into Microsoft word and was able to enlarge it there. The image is not sharp, but it was easier to see detail.
10/03/2014 2:36 AM
So it's a trompe loeil so good and so small we cant see it... Brilliant.
I'll go work on a bow.
On the plus side it's not morally objectionable this time (as far as we can see)
10/03/2014 7:03 AM
The brick on the arch and the left side was not done right.
10/03/2014 7:07 AM
When I was 18 years old, There was a establishment that I ventured to (often enough). They usually had a band playing there on weekends.
Anyways, I was there and I looked and saw, wow, this place is bigger then it looks from the outside, it even has a back room, I never noticed that before... I'm going to check it out, after I get my refreshment.
So, as I was waiting, I was looking across the room at it to see what's in the back room, it seems to have another bar, that was filled with people.
And at that moment I then saw someone walk into the doorway and was laid out flat on his back.
Here is was a framed full sized mirror to look like an entranceway. Needless to say, it was quite an entertainment piece that night. Especially after the crowd had a few.
10/03/2014 7:25 AM
I'll admit the "stealth" paint job on the pipe is not the greatest! I've seen better cell antennas paint jobs. But, I really don't see a directional exit sign, which should be visible.
However, I want to know who put the damn trash can on the bench! This is going to irk me all day! I know, I know guys....I Google it first!
Yep-stuck in the middle with you.
Good Answers: 97
10/03/2014 7:47 AM
Good Answers: 131
10/03/2014 8:19 AM
That wouldn't surprise me at all. If this the interface between two parts of a hospital (new wing added to old), the architectures could be very different. The wall where the two wings meet is a likely spot for water to leak in at the roof and run down through the wall, and it could be dripping out in this hallway. Some enterprising maintenance crew rigged up a pan and pipe to a bucket to catch the drips (which don't happen all the time!).
It probably worked so well that nobody pursued a real, permanent solution, so the jury-rigged fix stays in place. To make it blend in, someone painted it to match the bricks, and the janitor swaps the buckets once in a while and empties the full one. It's the old farmer's problem - When it rains, you can't get up on the roof to fix the leak, but when it's dry out you don't need to!
I've seen a similar thing in a hospital sub-basement in my area. Water was leaking through the ceiling from some drainage up above. The drips were right above the 13.8kV switchgear. So someone rigged a stainless steel kitchen sink to the ceiling right under the leak, with a drain pipe running along the ceiling and down to a floor drain, where the water could flow away without bothering anyone. No more water on the switchgear! It's been that way for years...
10/03/2014 7:50 AM
If you hold down the control key and scroll the mouse button you can increase the image size and the resolution seems to hold pretty good.
Is that the bottom of an EXIT sign at the very top of the image?
10/03/2014 8:00 AM
(On my pc, control + scroll makes the text bigger, but not the image.)
10/03/2014 7:54 AM
10/03/2014 8:01 AM
Looks like another directional EXIT sign at the hallway intersection inside.
That was funny Usbport.
10/03/2014 8:02 AM
Obviously NOT an emergency entrance - doors are for exiting - other than that....????
10/03/2014 8:03 AM
That is odd, my Control+Scroll zooms everything.
10/03/2014 8:39 AM
M C Escher LIVES ON ...and is designing hospitals!
Out in a Bowt
10/03/2014 8:52 AM
He's looked everywhere to find what's wrong with the hospital photo...
10/03/2014 8:57 AM
Wait a minute - is this like the TARDIS? This building looks about 12 feet deep from the outside, but when the doors are opened.....
10/03/2014 9:08 AM
Obama: "Folks, I am please to be the grand POO-BaH for the ribbon cutting here in the dedication of our first of many new hospital wings being built and designed by my friends from the CGI Group Inc. and by the way, did I say the first of many being built across the country that is not only 100% compliance to the Affordable Care Act, but will take care of all the people that sign up on the website.
And now because of all my important political stuff that I'm am responsible for as president, my schedule is very busy this weekend, I must bid you adieu.
Thank you."
Obama to Assistant: "What do you mean, you forgot my clubs... "
Obama's Assistance: "Sorry sir"
Obama to Assistant: "Well, at least Jay-Z and Beyonce house party is still on for tonight"
Obama's Assistance: "ahhh, sir,... by the way. Beyonce called, and said you're not invited."
Obama to Assistant: "What?,... Now, what am I'm going to do this weekend?"
10/04/2014 3:52 PM
The Obamacare outpatient shuffle.
Get to the end of the hall and you're back outside on the sidewalk. The doctor will see you now.
Red pill or blue pill?
Good Answers: 266
10/03/2014 9:14 AM
Entrance to hospital Psychiatric Ward.
10/03/2014 10:07 AM
The only good thing about this post, is I learned about the ctrl+scroll withing CR4.
Otherwise it was a waste...
10/03/2014 1:07 PM
Did you already know about ctrl + and ctrl -?
Good Answers: 97
10/03/2014 10:32 AM
"To Hospital" from where? The IRS office? Sushi bar? House of Ill Repute?
Is this a trap for Wile E. Coyote?
CRTL-Z
10/03/2014 10:45 AM
We see a chameleon pipe on the left of the bricked arch, this pipe extends into the dustbin placed there. On the right, stored in battery, is an empty spare bin. There is something flat-ish located at the top inside of the brickwork arch, also with a noble attempt at camouflage.
I would say this is a Rube Goldberg solution to a water intrusion problem.
Ceiling leaks water (we hope it's water). flat-ish element at the ceiling of the arch catches the water, directs the water to the pipe, goes down to the repurposed dustbin where it awaits building maintenance to dump. The can-in-battery is a safeguard against an unexpected torrential rain and subsequent torrential inflow.
'Owzat?
10/03/2014 12:24 PM
I see somebody finally spotted my bio-experimental cross between an anaconda, and a chameleon. I thought I would NEVER see that thing again!
10/03/2014 3:25 PM
Harry Potter: "Excuse me, Is this the way to Hogwarts School of Witchcraft and Wizardry Infirmary."
Good Answers: 114
10/03/2014 4:38 PM
Try control + and control - to bring it back. You can hit + as many times as you want.
XP with Chrome.
Good Answers: 97
10/04/2014 12:29 AM
Supervisor to nurse "I told you to fix the drip of the patient and not the drip at the entrance."
10/04/2014 6:04 AM
It's an NDE (near death experience)--there's light at the end of the tunnel.
10/04/2014 9:23 AM
The reflection on the shiny hallway floor doesn't seem to match the overhead ceiling lighting. Seems more like a reflection of rows of f96 double tube fluorescents end to end, not the (looks like to me) three pot lights. As well there are yellow spot reflections on the same floor that don't seem to match with what appears overhead???
Have a Happy! ;-)
10/04/2014 11:00 AM
That light is probably coming from a lot of windows on the right, behind what looks to be a planter of some sort.
10/04/2014 11:49 AM
Hey all you guys and gals out there: This is just like a whole bunch of us CR4s attending to an RSVP invitation to visit the Louvre in France and taking a guided tour along with all the worldly art experts, and then at one particular, undiphurable work from an anonymous and obscure, obtuse artst, they beg, asking for OUR privileged opinions, and subjective critiques on on the masterpiece(s) of the art world presented before us. I'm using too many big words today, that I don't fully understand, on this thead that I don't fully understand, and I think I'm getting a headache. I'll stop now and have another beers.;-)
Have a Happy! ;-)
Good Answers: 67
10/05/2014 6:28 AM
[deleted by user]
Good Answers: 19
10/08/2014 12:53 PM
I must say after i used the magnifying glass i still could nit see much other than the obvious. this reminds me of a Highlights "find the hidden object's" section. Still love those to this day when i bring the grand baby tot he doctors offices.
So.....
1. painted pipe
2. weird brick lay out over the door.
3. podiums on left and right not symmetrical.
4. weird soffet - bench on the right with the main column coming out of it.
5. picture too small.
Good Answers: 123
10/09/2014 10:36 PM
Am I the only one that sees an inverted face of Elvis in the floor reflection? Left of center, starting from the hallway on left.
Bob
10/10/2014 9:50 AM
Did you know that if you repeat the word 'Gullible' real fast, it sounds like you are saying 'Orange'?
Good Answers: 123
10/11/2014 1:40 AM
I hope you are not mocking me. I am, after all, a warm, sensitive human being.
Bob
10/11/2014 9:31 AM
As depicted by the flames in your avatar.
10/11/2014 6:53 PM
''Bit of a kink in the perspective lines of the floor, me-thinks...''
Good Answers: 123
10/14/2014 12:10 AM
That ain't nothing. You should see the kink in AH. :)
Bob
10/14/2014 8:15 AM
Well, I am not bent out of shape about it. ;-)
10/14/2014 11:46 PM
All this to catch a drip? Guess it works, it caught me.
10/21/2014 12:05 PM
concealed mp5 not too bad
11/01/2014 3:12 PM
That is not just a pipe painted to blend in with the brick pattern. It the feared Brick Backed Boa Constrictor. They lurk in hospital archways waiting for unwary patients to pass underneath, then they drop on them and wrap themselves around their bank accounts.
canary
Reply to Blog Entry 60 comments
adreasler (1); Andy Germany (1); Anonymous Hero (5); bob c (3); Canary (2); Doorman (2); europium mkII (1); Hendrik (2); jdsighter (1); JIMRAT (1); kramarat (1); Lo_Volt (1); Loupy (3); LuciousB (2); lyn (2); Massey (3); MR. Guest (1); ozzb (1); passingtongreen (1); PeterT (1); phoenix911 (5); Phys (2); Rixter (1); Rotag (1); SITMWY2 (1); snowboy (1); Stedou73ish (1); SWB123 (2); Tom_Consulting (2); tommm (2); Tornado (1); Unredundant (3); Usbport (2); user-deleted-1105 (1)
